[GiDlist] Separate Node Numbering.
sujith gowda
Post by sujith gowda »
I would like to have Node and Element numbering for 2 separate surfaces
starting from Initial number (1).
i.e. Separate numbering for both surfaces not the continued numbering as
shown in attached picture (obtained.jpg).
I need as attached picture (required.jpg),
Is it possible to obtain it from Gid ?
How can I do that ?
Thank you,
*Sujith Gowda H S*
Universität Stuttgart,
Germany
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140929/d24239e2/attachment-0001.htm
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140929/d24239e2/attachment-0001.jpg
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140929/d24239e2/attachment-0001.jpeg
This is not possible, each kind of entity, e.g. each node must have inside GiD a unique number that identify it
The only that you could is to export the GiD internal information in the format you want
e.g. for your solver you can create an input file where the nodes are renamed to fit your requirements
De: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de sujith gowda
Enviado el: lunes, 29 de septiembre de 2014 16:39
Asunto: [GiDlist] Separate Node Numbering.
I would like to have Node and Element numbering for 2 separate surfaces starting from Initial number (1).
i.e. Separate numbering for both surfaces not the continued numbering as shown in attached picture (obtained.jpg).
How can I do that ?
Thank you,
Sujith Gowda H S
Germany
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140929/025a45b6/attachment.htm
sujith gowda
Thank you. .
I will try that.
format you want
*De:* gidlist-bounces at listas.cimne.upc.edu [mailto:
gidlist-bounces at listas.cimne.upc.edu] *En nombre de *sujith gowda
*Enviado el:* lunes, 29 de septiembre de 2014 16:39
*Para:* gidlist at listas.cimne.upc.edu
*Asunto:* [GiDlist] Separate Node Numbering.
How can I do that ?
Thank you,
*Sujith Gowda H S*
Germany
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20140929/38d15628/attachment.htm
