[ GiDlist ] contact elements with tetra10
Actually only is available the element contact prisma of 6 nodes (from
linear triangles 3 nodes) or the prisma of 8 nodes (from linear
quadrilaterals of 4 nodes).
We will study the possibility of including the quadratic case next.
The GiD Team
Sent: Wednesday, October 24, 2001 3:50 PM
Subject: [ GiDlist ] contact elements with tetra10
is it possible to create contact between tetra 10 nodes elements?
The GiD manual about contact volumes says that only Prisma elements with 6
nodes (contact between tetra 4 nodes) are possible.
In GiD6.1.5b every test ends in error.
Thank you in advance and regards.
ALDO GHISI
Department of Structural Engineering
Politecnico di Milano
Piazza Leonardo da Vinci 32, 20133 Milano, Italy
Tel.: +39 02 2399 4218
Fax.: +39 02 2399 4220
E_mail: aldo.ghisi at polimi.it
For GiD, a contact is only a node-to-node link. It is interpreted as a mesh
specification to create two identical meshes, and connect the nodes with
prism element (named contact elements).
Another type of contact is unkown for GiD. Usually a problem type define
conditions, for example, named "Source" and "Target" and is applied in GiD
to two families of surfaces (transferred automatically to elements or nodes
of the mesh). The condition stores the contact properties (friction, etc.)
and a ID common to Source and Target (for more than 1 contact).
I' not know if this form to treat a contact by means of a condition adapts
to your case. It would need to know that it exactly expects of the file
input the analysis program.
Sent: Thursday, October 25, 2001 2:54 AM
Hello;
Imagine, i want to study a contact between two bodies, so one body slide
over
another body, like when i push a book over table. This kind of contact, i
known
like node-surface, source contact and target contact. It is possible to
create
in GID?
thanks again
The GiD Team
with 6
ALDO GHISI
You can see a ProblemType tutorial to learn "How to configure GiD for a particular type of analysis" in
http://gid.cimne.upc.es/support
See also Customization on the GiD Manual (yoy can see the online version located in support)
In GiD Plus (Gid+) you can download some analysis codes, and you can see the problemtype files as samples.
Here is a small problemtype for example:
Create a directory "name".gid in the directory gid/problemtypes an
create inside these files: *.cnd, *.bas and *.prb
Sample file "name".cnd
NUMBER: 1 CONDITION: Source
CONDTYPE: over surfaces
CONDMESHTYPE: over elems
QUESTION: ID:#CB#(1,2,3,4,5,6,7,8,9,10)
VALUE: 1
QUESTION: Friction_coeff
VALUE: 0.0
END CONDITION
NUMBER: 2 CONDITION: Target
VALUE: 1
END CONDITION
Sample file "name".bas
*Set Cond Source *elems *CanRepeat
*Loop elems *OnlyInCond
ELEM=*elemsnum ID=*Cond(ID,int) COEF=*Cond(Friction_coeff,real)
*end elems
*Set Cond Target *elems *CanRepeat
*end elems
Sample file "name".prb (required for any problem type)
PROBLEM DATA
QUESTION:Title
VALUE:untitled
END PROBLEM DATA
Sent: Thursday, October 25, 2001 4:29 AM
Subject: Re: [ GiDlist ] contact elements
I think that is a good solution, but can i add that condition to problem type
exits?, do you known if exist similar problem type?, so i can modify it.
Thanks again.
Hello;
over
known
create
in GID?
thanks again
The GiD Team
with 6
ALDO GHISI
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011024/f79b2c9f/attachment.htm
Post by Pablo Perez del Castillo »
Hello;
Imagine, i want to study a contact between two bodies, so one body slide over
another body, like when i push a book over table. This kind of contact, i known
like node-surface, source contact and target contact. It is possible to create
in GID?
thanks again
The GiD Team
ALDO GHISI
Thanks again.
Hello;
over
known
create
in GID?
thanks again
The GiD Team
with 6
ALDO GHISI
THANKS
a particular type of analysis" a href="inhttp://gid.cimne.upc.es/supportSee"inhttp://gid.cimne.upc.es/supportSee/a
located in support) In GiD Plus (Gid+) you can download some analysis
codes, and you can see the problemtype files as samples. Here is a
small problemtype for example:Create a directory "name".gid in the
directory gid/problemtypes ancreate inside these files: *.cnd, *.bas
and *.prb Sample file "name".cndNUMBER: 1 CONDITION: SourceCONDTYPE:
over surfaces
VALUE: 1
VALUE: 0.0
END CONDITIONNUMBER: 2 CONDITION: TargetCONDTYPE: over surfaces
VALUE: 1
END CONDITION Sample file "name".bas*Set Cond Source *elems
*CanRepeat*Loop elems *OnlyInCondELEM=*elemsnum ID=*Cond(ID,int)
COEF=*Cond(Friction_coeff,real)*end elems *Set Cond Target *elems
*CanRepeat*Loop elems *OnlyInCondELEM=*elemsnum ID=*Cond(ID,int)*end
elems Sample file "name".prb (required for any problem type)PROBLEM
DATAQUESTION:TitleVALUE:untitledEND PROBLEM DATA ----- Original
Message -----From: "Pablo Perez del Castillo" pablopdc at terra.esTo:
gidlist at gatxan.cimne.upc.esSent: Thursday, October 25, 2001 4:29
AMSubject: Re: [ GiDlist ] contact elements I think that is a good
it.
Thanks again.
as a mesh
nodes with
define
applied in GiD
or nodes
(friction, etc.)
condition adapts
file
Hello;
body slide
over
contact, i
known
possible to
create
in GID?
thanks again
nodes (from
linear
next.
The GiD Team
elements?
elements
with 6
ALDO GHISI
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011024/ab47216a/attachment.htm
