[ GiDlist ] Read mesh
Ramon Ribó
Post by Ramon Ribó »
There are several possibilities:
- The simplest one is go to postprocess and read the file.
Maybe it is necessary to use a recent beta for this.
- In the preprocess:
Open the right button toolbar (Utilities-Graphical-Toolbar)
and use: Data Materials DrawMaterials DrawAll
- Also in the right buttons, use: View Layers Material
Commands accessed with the right buttons toolbar can also be
written in the command line.
Compass Ing. y Sistemas Dr. Ramon Ribó
De: owner-gid at gatxan.cimne.upc.es
[mailto:owner-gid at gatxan.cimne.upc.es]En nombre de Mark Smith
Enviado el: viernes, 19 de octubre de 2001 13:46
Para: Gidlist (E-mail)
Asunto: [ GiDlist ] Read mesh
I am reading in a triangular mesh (using mesh read) which has a material
number associated with each element. i.e. in the elements part of the mesh
file I have:
element number node1 node2 node3 material
The mesh imports OK but I cannot find a way of viewing the material ID of
each element. The reference manual suggests there is a way of forcing each
material number onto a unique layer but I cannot find a way of doing it.
Any help will be most appreciated.
Mark
Mark Smith (E-mail).vcf
This e-mail may contain privileged/confidential information and may be
read, copied and used only by the intended recipient. If you have received
it in error, please contact the sender by return e-mail or by
telephoning +44 (0)1480 302100.
Please then delete the e-mail and do not disclose its contents to any
person.
Any information in this message that does not relate to the official
business of Linx shall be understood as neither given nor endorsed by Linx.
We reserve the right to monitor all e-mail communications through our
internal and external networks.
