[GiDlist] How to get tetrahedral mesh for a 3d model from su
Xiang Lan
Post by Xiang Lan »
Hello All,
I'm a beginner using GiD.
I try to generate tetrahedral volume mesh from
existing 3d models in surface meshes, such as triangle
meshes.
It seems I couldn't generate tetrahedral volume mesh.
Here I send a example to you. (A cat model in DXF
format)
Can anyone give me some help?
Thanks in advance.
Xiang
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
An embedded and charset-unspecified text was scrubbed...
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021215/dcc2ed45/attachment.txt
You must first create the missing bottom surfaces to close a volume,
and then create this volume and generate the mesh.
I attach the model with this modifications, the aditional surfaces are in
the layer 'Layer0'.
(The mesh is not included, you must re-generate for example with the default
size=27)
Sent: Sunday, December 15, 2002 9:13 PM
Subject: [GiDlist] How to get tetrahedral mesh for a 3d model from surface
mesh?
Hello All,
meshes.
format)
Thanks in advance.
Xiang
Do you Yahoo!?
0
SECTION
2
ENTITIES
0
3DFACE
8
0
10
-0.188568
20
-11.321
30
1.88669
11
0
21
0
31
0
12
-8.30194
22
-6.41525
32
-1.88667
13
-8.30194
23
-6.41525
33
-1.88667
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
-13.208
21
-13.3965
31
-6.22638
12
-8.30194
22
-6.41525
32
-1.88667
13
-8.30194
23
-6.41525
33
-1.88667
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
-8.30194
21
-6.41525
31
-1.88667
12
0
22
0
32
0
13
0
23
0
33
0
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
0
21
0
31
0
12
-6.60382
22
4.52829
32
-1.69809
13
-6.60382
23
4.52829
33
-1.69809
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
-6.60382
21
4.52829
31
-1.69809
12
-13.774
22
10.3775
32
-6.7924
13
-13.774
23
10.3775
33
-6.7924
0
3DFACE
8
0
10
-13.774
20
10.3775
30
-6.7924
11
0.754623
21
9.81148
31
0
12
-6.60382
22
4.52829
32
-1.69809
13
-6.60382
23
4.52829
33
-1.69809
0
3DFACE
8
0
10
-6.60382
20
4.52829
30
-1.69809
11
0.754623
21
9.81148
31
0
12
0
22
0
32
0
13
0
23
0
33
0
0
3DFACE
8
0
10
-0.188568
20
-11.321
30
1.88669
11
14.34
21
0
31
-1.50922
12
0
22
0
32
0
13
0
23
0
33
0
0
3DFACE
8
0
10
-10.7549
20
-17.9251
30
0
11
-0.188568
21
-11.321
31
1.88669
12
-13.208
22
-13.3965
32
-6.22638
13
-13.208
23
-13.3965
33
-6.22638
0
3DFACE
8
0
10
-10.7549
20
-17.9251
30
0
11
-0.188568
21
-11.321
31
1.88669
12
-8.86797
22
-21.6988
32
5.47177
13
-8.86797
23
-21.6988
33
5.47177
0
3DFACE
8
0
10
-8.86797
20
-21.6988
30
5.47177
11
-0.188568
21
-11.321
31
1.88669
12
-1.32063
22
-21.1327
32
8.6794
13
-1.32063
23
-21.1327
33
8.6794
0
3DFACE
8
0
10
-8.86797
20
-21.6988
30
5.47177
11
-1.32063
21
-21.1327
31
8.6794
12
-1.88667
22
-26.4159
32
10.9435
13
-1.88667
23
-26.4159
33
10.9435
0
3DFACE
8
0
10
-6.0378
20
-27.548
30
9.24544
11
-1.88667
21
-26.4159
31
10.9435
12
-8.86797
22
-21.6988
32
5.47177
13
-8.86797
23
-21.6988
33
5.47177
0
3DFACE
8
0
10
-1.32063
20
-21.1327
30
8.6794
11
-0.188568
21
-11.321
31
1.88669
12
9.62289
22
-17.5477
32
-0.566025
13
9.62289
23
-17.5477
33
-0.566025
0
3DFACE
8
0
10
4.33971
20
-24.7178
30
6.41527
11
9.62289
21
-17.5477
31
-0.566025
12
-1.32063
22
-21.1327
32
8.6794
13
-1.32063
23
-21.1327
33
8.6794
0
3DFACE
8
0
10
-1.32063
20
-21.1327
30
8.6794
11
4.33971
21
-24.7178
31
6.41527
12
-1.88667
22
-26.4159
32
10.9435
13
-1.88667
23
-26.4159
33
10.9435
0
3DFACE
8
0
10
-1.88667
20
-26.4159
30
10.9435
11
4.33971
21
-24.7178
31
6.41527
12
-2.07526
22
-33.2086
32
8.86798
13
-2.07526
23
-33.2086
33
8.86798
0
3DFACE
8
0
10
-6.0378
20
-27.548
30
9.24544
11
-2.07526
21
-33.2086
31
8.86798
12
-1.88667
22
-26.4159
32
10.9435
13
-1.88667
23
-26.4159
33
10.9435
0
3DFACE
8
0
10
4.33971
20
-24.7178
30
6.41527
11
9.62289
21
-17.5477
31
-0.566025
12
6.22639
22
-29.2461
32
0.377167
13
6.22639
23
-29.2461
33
0.377167
0
3DFACE
8
0
10
2.6416
20
-32.0766
30
5.28319
11
6.22639
21
-29.2461
31
0.377167
12
4.33971
22
-24.7178
32
6.41527
13
4.33971
23
-24.7178
33
6.41527
0
3DFACE
8
0
10
2.6416
20
-32.0766
30
5.28319
11
4.33971
21
-24.7178
31
6.41527
12
-2.07526
22
-33.2086
32
8.86798
13
-2.07526
23
-33.2086
33
8.86798
0
3DFACE
8
0
10
-2.07526
20
-33.2086
30
8.86798
11
2.6416
21
-32.0766
31
5.28319
12
-1.88667
22
-34.7182
32
1.6981
13
-1.88667
23
-34.7182
33
1.6981
0
3DFACE
8
0
10
-1.88667
20
-34.7182
30
1.6981
11
2.6416
21
-32.0766
31
5.28319
12
0.377167
22
-34.1521
32
-5.28317
13
0.377167
23
-34.1521
33
-5.28317
0
3DFACE
8
0
10
0.377167
20
-34.1521
30
-5.28317
11
2.6416
21
-32.0766
31
5.28319
12
6.22639
22
-29.2461
32
0.377167
13
6.22639
23
-29.2461
33
0.377167
0
3DFACE
8
0
10
6.22639
20
-29.2461
30
0.377167
11
10.1889
21
-25.4724
31
-6.98128
12
0.377167
22
-34.1521
32
-5.28317
13
0.377167
23
-34.1521
33
-5.28317
0
3DFACE
8
0
10
0.377167
20
-34.1521
30
-5.28317
11
10.1889
21
-25.4724
31
-6.98128
12
3.58479
22
-30.1896
32
-15.0947
13
3.58479
23
-30.1896
33
-15.0947
0
3DFACE
8
0
10
0.377167
20
-34.1521
30
-5.28317
11
3.58479
21
-30.1896
31
-15.0947
12
-3.39619
22
-33.2086
32
-5.66034
13
-3.39619
23
-33.2086
33
-5.66034
0
3DFACE
8
0
10
-3.39619
20
-33.2086
30
-5.66034
11
-1.88667
21
-34.7182
31
1.6981
12
0.377167
22
-34.1521
32
-5.28317
13
0.377167
23
-34.1521
33
-5.28317
0
3DFACE
8
0
10
-3.39619
20
-33.2086
30
-5.66034
11
3.58479
21
-30.1896
31
-15.0947
12
-5.47176
22
-29.0575
32
-13.774
13
-5.47176
23
-29.0575
33
-13.774
0
3DFACE
8
0
10
-5.47176
20
-29.0575
30
-13.774
11
-5.47176
21
-21.3213
31
-5.66034
12
-3.39619
22
-33.2086
32
-5.66034
13
-3.39619
23
-33.2086
33
-5.66034
0
3DFACE
8
0
10
-5.47176
20
-21.3213
30
-5.66034
11
-3.39619
21
-33.2086
31
-5.66034
12
-1.88667
22
-34.7182
32
1.6981
13
-1.88667
23
-34.7182
33
1.6981
0
3DFACE
8
0
10
-5.47176
20
-21.3213
30
-5.66034
11
-1.88667
21
-34.7182
31
1.6981
12
-2.07526
22
-33.2086
32
8.86798
13
-2.07526
23
-33.2086
33
8.86798
0
3DFACE
8
0
10
-5.47176
20
-21.3213
30
-5.66034
11
-2.07526
21
-33.2086
31
8.86798
12
-6.0378
22
-27.548
32
9.24544
13
-6.0378
23
-27.548
33
9.24544
0
3DFACE
8
0
10
-6.0378
20
-27.548
30
9.24544
11
-5.47176
21
-21.3213
31
-5.66034
12
-8.86797
22
-21.6988
32
5.47177
13
-8.86797
23
-21.6988
33
5.47177
0
3DFACE
8
0
10
-8.86797
20
-21.6988
30
5.47177
11
-5.47176
21
-21.3213
31
-5.66034
12
-10.7549
22
-17.9251
32
0
13
-10.7549
23
-17.9251
33
0
0
3DFACE
8
0
10
-10.7549
20
-17.9251
30
0
11
-5.47176
21
-21.3213
31
-5.66034
12
-13.208
22
-13.3965
32
-6.22638
13
-13.208
23
-13.3965
33
-6.22638
0
3DFACE
8
0
10
-0.188568
20
-11.321
30
1.88669
11
14.34
21
0
31
-1.50922
12
9.62289
22
-17.5477
32
-0.566025
13
9.62289
23
-17.5477
33
-0.566025
0
3DFACE
8
0
10
9.62289
20
-17.5477
30
-0.566025
11
18.3023
21
-10.0003
31
-3.77365
12
19.0572
22
-19.0572
32
-10.0003
13
19.0572
23
-19.0572
33
-10.0003
0
3DFACE
8
0
10
-5.84921
20
-30.1896
30
-27.548
11
3.58479
21
-30.1896
31
-15.0947
12
-5.47176
22
-29.0575
32
-13.774
13
-5.47176
23
-29.0575
33
-13.774
0
3DFACE
8
0
10
-19.0572
20
-24.9064
30
-27.548
11
-5.47176
21
-29.0575
31
-13.774
12
-21.6988
22
-21.8874
32
-20.5667
13
-21.6988
23
-21.8874
33
-20.5667
0
3DFACE
8
0
10
-22.0762
20
-16.9816
30
-16.2267
11
-21.6988
21
-21.8874
31
-20.5667
12
-5.47176
22
-29.0575
32
-13.774
13
-5.47176
23
-29.0575
33
-13.774
0
3DFACE
8
0
10
-22.0762
20
-16.9816
30
-16.2267
11
-5.47176
21
-29.0575
31
-13.774
12
-5.47176
22
-21.3213
32
-5.66034
13
-5.47176
23
-21.3213
33
-5.66034
0
3DFACE
8
0
10
-22.0762
20
-16.9816
30
-16.2267
11
-13.208
21
-13.3965
31
-6.22638
12
-21.3213
22
-9.4343
32
-13.3965
13
-21.3213
23
-9.4343
33
-13.3965
0
3DFACE
8
0
10
6.22639
20
-29.2461
30
0.377167
11
9.62289
21
-17.5477
31
-0.566025
12
10.1889
22
-25.4724
32
-6.98128
13
10.1889
23
-25.4724
33
-6.98128
0
3DFACE
8
0
10
9.62289
20
-17.5477
30
-0.566025
11
10.1889
21
-25.4724
31
-6.98128
12
19.0572
22
-19.0572
32
-10.0003
13
19.0572
23
-19.0572
33
-10.0003
0
3DFACE
8
0
10
-21.3213
20
-9.4343
30
-13.3965
11
-15.6607
21
-1.69809
31
-6.0378
12
-23.3969
22
-2.83017
32
-13.3965
13
-23.3969
23
-2.83017
33
-13.3965
0
3DFACE
8
0
10
-23.3969
20
-2.83017
30
-13.3965
11
-23.3969
21
3.96225
31
-15.2835
12
-15.6607
22
-1.69809
32
-6.0378
13
-15.6607
23
-1.69809
33
-6.0378
0
3DFACE
8
0
10
-23.3969
20
3.96225
30
-15.2835
11
-15.6607
21
-1.69809
31
-6.0378
12
-13.774
22
10.3775
32
-6.7924
13
-13.774
23
10.3775
33
-6.7924
0
3DFACE
8
0
10
-23.3969
20
3.96225
30
-15.2835
11
-13.774
21
10.3775
31
-6.7924
12
-24.1518
22
9.43431
32
-18.1137
13
-24.1518
23
9.43431
33
-18.1137
0
3DFACE
8
0
10
-24.1518
20
9.43431
30
-18.1137
11
-23.3969
21
16.7931
31
-23.0194
12
-13.774
22
10.3775
32
-6.7924
13
-13.774
23
10.3775
33
-6.7924
0
3DFACE
8
0
10
-23.3969
20
16.7931
30
-23.0194
11
-13.774
21
10.3775
31
-6.7924
12
-5.66034
22
20.0007
32
-7.7359
13
-5.66034
23
20.0007
33
-7.7359
0
3DFACE
8
0
10
-23.3969
20
16.7931
30
-23.0194
11
-5.66034
21
20.0007
31
-7.7359
12
-11.5096
22
24.7178
32
-20.7553
13
-11.5096
23
24.7178
33
-20.7553
0
3DFACE
8
0
10
-11.5096
20
24.7178
30
-20.7553
11
-2.83017
21
29.435
31
-20.0007
12
-5.66034
22
20.0007
32
-7.7359
13
-5.66034
23
20.0007
33
-7.7359
0
3DFACE
8
0
10
-5.66034
20
20.0007
30
-7.7359
11
-2.83017
21
29.435
31
-20.0007
12
-3.77365
22
31.3217
32
-11.5096
13
-3.77365
23
31.3217
33
-11.5096
0
3DFACE
8
0
10
-4.33969
20
31.5106
30
-4.71686
11
-3.77365
21
31.3217
31
-11.5096
12
-5.66034
22
20.0007
32
-7.7359
13
-5.66034
23
20.0007
33
-7.7359
0
3DFACE
8
0
10
-5.66034
20
20.0007
30
-7.7359
11
-4.33969
21
31.5106
31
-4.71686
12
-5.0943
22
30.5671
32
1.6981
13
-5.0943
23
30.5671
33
1.6981
0
3DFACE
8
0
10
-6.41525
20
27.7366
30
7.16988
11
-5.0943
21
30.5671
31
1.6981
12
-5.66034
22
20.0007
32
-7.7359
13
-5.66034
23
20.0007
33
-7.7359
0
3DFACE
8
0
10
-6.41525
20
27.7366
30
7.16988
11
-5.66034
21
20.0007
31
-7.7359
12
-8.67938
22
22.6423
32
6.41527
13
-8.67938
23
22.6423
33
6.41527
0
3DFACE
8
0
10
-10.1889
20
18.6797
30
2.83018
11
-8.67938
21
22.6423
31
6.41527
12
-5.66034
22
20.0007
32
-7.7359
13
-5.66034
23
20.0007
33
-7.7359
0
3DFACE
8
0
10
-11.6984
20
14.7175
30
-1.32063
11
-10.1889
21
18.6797
31
2.83018
12
-5.66034
22
20.0007
32
-7.7359
13
-5.66034
23
20.0007
33
-7.7359
0
3DFACE
8
0
10
-11.6984
20
14.7175
30
-1.32063
11
-5.66034
21
20.0007
31
-7.7359
12
-13.774
22
10.3775
32
-6.7924
13
-13.774
23
10.3775
33
-6.7924
0
3DFACE
8
0
10
-13.774
20
10.3775
30
-6.7924
11
-11.6984
21
14.7175
31
-1.32063
12
0.754623
22
9.81148
32
0
13
0.754623
23
9.81148
33
0
0
3DFACE
8
0
10
-11.6984
20
14.7175
30
-1.32063
11
0.754623
21
9.81148
31
0
12
-10.1889
22
18.6797
32
2.83018
13
-10.1889
23
18.6797
33
2.83018
0
3DFACE
8
0
10
-10.1889
20
18.6797
30
2.83018
11
-3.39619
21
18.8686
31
5.28319
12
0.754623
22
9.81148
32
0
13
0.754623
23
9.81148
33
0
0
3DFACE
8
0
10
-3.39619
20
18.8686
30
5.28319
11
0.754623
21
9.81148
31
0
12
0.943207
22
23.0194
32
3.77367
13
0.943207
23
23.0194
33
3.77367
0
3DFACE
8
0
10
-3.39619
20
18.8686
30
5.28319
11
0.943207
21
23.0194
31
3.77367
12
-6.41525
22
27.7366
32
7.16988
13
-6.41525
23
27.7366
33
7.16988
0
3DFACE
8
0
10
-6.41525
20
27.7366
30
7.16988
11
-3.39619
21
18.8686
31
5.28319
12
-8.67938
22
22.6423
32
6.41527
13
-8.67938
23
22.6423
33
6.41527
0
3DFACE
8
0
10
0.943207
20
23.0194
30
3.77367
11
7.54733
21
19.2458
31
-2.83017
12
0.754623
22
9.81148
32
0
13
0.754623
23
9.81148
33
0
0
3DFACE
8
0
10
-6.41525
20
27.7366
30
7.16988
11
0.943207
21
23.0194
31
3.77367
12
0.377167
22
28.1141
32
1.32065
13
0.377167
23
28.1141
33
1.32065
0
3DFACE
8
0
10
-6.41525
20
27.7366
30
7.16988
11
0.377167
21
28.1141
31
1.32065
12
-5.0943
22
30.5671
32
1.6981
13
-5.0943
23
30.5671
33
1.6981
0
3DFACE
8
0
10
-5.0943
20
30.5671
30
1.6981
11
-4.33969
21
31.5106
31
-4.71686
12
0.377167
22
28.1141
32
1.32065
13
0.377167
23
28.1141
33
1.32065
0
3DFACE
8
0
10
-4.33969
20
31.5106
30
-4.71686
11
0.377167
21
28.1141
31
1.32065
12
3.58479
22
29.0575
32
-11.5096
13
3.58479
23
29.0575
33
-11.5096
0
3DFACE
8
0
10
-4.33969
20
31.5106
30
-4.71686
11
3.58479
21
29.0575
31
-11.5096
12
-3.77365
22
31.3217
32
-11.5096
13
-3.77365
23
31.3217
33
-11.5096
0
3DFACE
8
0
10
-3.77365
20
31.3217
30
-11.5096
11
-2.83017
21
29.435
31
-20.0007
12
3.58479
22
29.0575
32
-11.5096
13
3.58479
23
29.0575
33
-11.5096
0
3DFACE
8
0
10
7.54733
20
19.2458
30
-2.83017
11
17.1702
21
17.5477
31
-8.11336
12
7.16988
22
26.0385
32
-8.30194
13
7.16988
23
26.0385
33
-8.30194
0
3DFACE
8
0
10
0.377167
20
28.1141
30
1.32065
11
0.943207
21
23.0194
31
3.77367
12
7.16988
22
26.0385
32
-8.30194
13
7.16988
23
26.0385
33
-8.30194
0
3DFACE
8
0
10
7.16988
20
26.0385
30
-8.30194
11
7.54733
21
19.2458
31
-2.83017
12
0.943207
22
23.0194
32
3.77367
13
0.943207
23
23.0194
33
3.77367
0
3DFACE
8
0
10
0.377167
20
28.1141
30
1.32065
11
3.58479
21
29.0575
31
-11.5096
12
7.16988
22
26.0385
32
-8.30194
13
7.16988
23
26.0385
33
-8.30194
0
3DFACE
8
0
10
7.54733
20
19.2458
30
-2.83017
11
17.1702
21
17.5477
31
-8.11336
12
14.34
22
0
32
-1.50922
13
14.34
23
0
33
-1.50922
0
3DFACE
8
0
10
0.754623
20
9.81148
30
0
11
14.34
21
0
31
-1.50922
12
7.54733
22
19.2458
32
-2.83017
13
7.54733
23
19.2458
33
-2.83017
0
3DFACE
8
0
10
-27.548
20
-4.90572
30
-25.8499
11
-23.3969
21
-2.83017
31
-13.3965
12
-21.3213
22
-9.4343
32
-13.3965
13
-21.3213
23
-9.4343
33
-13.3965
0
3DFACE
8
0
10
-22.0762
20
-16.9816
30
-16.2267
11
-21.3213
21
-9.4343
31
-13.3965
12
-27.548
22
-4.90572
32
-25.8499
13
-27.548
23
-4.90572
33
-25.8499
0
3DFACE
8
0
10
-27.548
20
-4.90572
30
-25.8499
11
-22.0762
21
-16.9816
31
-16.2267
12
-24.1518
22
-17.5477
32
-22.0762
13
-24.1518
23
-17.5477
33
-22.0762
0
3DFACE
8
0
10
-26.4159
20
-9.81146
30
-31.3217
11
-24.1518
21
-17.5477
31
-22.0762
12
-27.548
22
-4.90572
32
-25.8499
13
-27.548
23
-4.90572
33
-25.8499
0
3DFACE
8
0
10
-27.548
20
-4.90572
30
-25.8499
11
-26.4159
21
-9.81146
31
-31.3217
12
-28.8689
22
-5.47176
32
-31.6991
13
-28.8689
23
-5.47176
33
-31.6991
0
3DFACE
8
0
10
-28.8689
20
-5.47176
30
-31.6991
11
-26.4159
21
1.50923
31
-32.4537
12
-27.548
22
-4.90572
32
-25.8499
13
-27.548
23
-4.90572
33
-25.8499
0
3DFACE
8
0
10
-27.548
20
-4.90572
30
-25.8499
11
-26.4159
21
1.50923
31
-32.4537
12
-26.4159
22
7.92479
32
-23.7743
13
-26.4159
23
7.92479
33
-23.7743
0
3DFACE
8
0
10
-26.4159
20
7.92479
30
-23.7743
11
-23.3969
21
3.96225
31
-15.2835
12
-27.548
22
-4.90572
32
-25.8499
13
-27.548
23
-4.90572
33
-25.8499
0
3DFACE
8
0
10
-27.548
20
-4.90572
30
-25.8499
11
-23.3969
21
3.96225
31
-15.2835
12
-23.3969
22
-2.83017
32
-13.3965
13
-23.3969
23
-2.83017
33
-13.3965
0
3DFACE
8
0
10
-24.1518
20
9.43431
30
-18.1137
11
-23.3969
21
3.96225
31
-15.2835
12
-26.4159
22
7.92479
32
-23.7743
13
-26.4159
23
7.92479
33
-23.7743
0
3DFACE
8
0
10
-26.4159
20
7.92479
30
-23.7743
11
-23.3969
21
16.7931
31
-23.0194
12
-24.1518
22
9.43431
32
-18.1137
13
-24.1518
23
9.43431
33
-18.1137
0
3DFACE
8
0
10
-26.4159
20
7.92479
30
-23.7743
11
-23.3969
21
16.7931
31
-23.0194
12
-25.4724
22
13.5851
32
-26.4159
13
-25.4724
23
13.5851
33
-26.4159
0
3DFACE
8
0
10
-25.4724
20
13.5851
30
-26.4159
11
-24.1518
21
15.8496
31
-30.1896
12
-23.3969
22
16.7931
32
-23.0194
13
-23.3969
23
16.7931
33
-23.0194
0
3DFACE
8
0
10
-24.1518
20
15.8496
30
-30.1896
11
-23.3969
21
16.7931
31
-23.0194
12
-18.8686
22
20.0007
32
-39.6239
13
-18.8686
23
20.0007
33
-39.6239
0
3DFACE
8
0
10
-18.8686
20
20.0007
30
-39.6239
11
-13.3965
21
24.3404
31
-32.8312
12
-23.3969
22
16.7931
32
-23.0194
13
-23.3969
23
16.7931
33
-23.0194
0
3DFACE
8
0
10
-23.3969
20
16.7931
30
-23.0194
11
-13.3965
21
24.3404
31
-32.8312
12
-11.5096
22
24.7178
32
-20.7553
13
-11.5096
23
24.7178
33
-20.7553
0
3DFACE
8
0
10
-13.3965
20
24.3404
30
-32.8312
11
-11.5096
21
24.7178
31
-20.7553
12
-2.83017
22
29.435
32
-20.0007
13
-2.83017
23
29.435
33
-20.0007
0
3DFACE
8
0
10
-25.4724
20
13.5851
30
-26.4159
11
-24.1518
21
15.8496
31
-30.1896
12
-28.114
22
8.30196
32
-30.001
13
-28.114
23
8.30196
33
-30.001
0
3DFACE
8
0
10
-28.114
20
8.30196
30
-30.001
11
-26.4159
21
8.11337
31
-36.2277
12
-24.1518
22
15.8496
32
-30.1896
13
-24.1518
23
15.8496
33
-30.1896
0
3DFACE
8
0
10
-26.4159
20
8.11337
30
-36.2277
11
-24.1518
21
15.8496
31
-30.1896
12
-27.7366
22
7.16988
32
-41.6995
13
-27.7366
23
7.16988
33
-41.6995
0
3DFACE
8
0
10
-27.7366
20
7.16988
30
-41.6995
11
-26.7934
21
8.30196
31
-44.3411
12
-24.1518
22
15.8496
32
-30.1896
13
-24.1518
23
15.8496
33
-30.1896
0
3DFACE
8
0
10
-26.7934
20
8.30196
30
-44.3411
11
-24.1518
21
15.8496
31
-30.1896
12
-18.8686
22
20.0007
32
-39.6239
13
-18.8686
23
20.0007
33
-39.6239
0
3DFACE
8
0
10
-28.114
20
8.30196
30
-30.001
11
-26.4159
21
7.92479
31
-23.7743
12
-26.4159
22
1.50923
32
-32.4537
13
-26.4159
23
1.50923
33
-32.4537
0
3DFACE
8
0
10
-28.8689
20
-5.47176
30
-31.6991
11
-26.4159
21
1.50923
31
-32.4537
12
-30.567
22
-6.22638
32
-35.2842
13
-30.567
23
-6.22638
33
-35.2842
0
3DFACE
8
0
10
-32.0766
20
-2.64159
30
-37.7372
11
-30.567
21
-6.22638
31
-35.2842
12
-26.4159
22
1.50923
32
-32.4537
13
-26.4159
23
1.50923
33
-32.4537
0
3DFACE
8
0
10
-32.0766
20
-2.64159
30
-37.7372
11
-26.4159
21
1.50923
31
-32.4537
12
-31.6991
22
0
32
-40.5674
13
-31.6991
23
0
33
-40.5674
0
3DFACE
8
0
10
-31.6991
20
0
30
-40.5674
11
-27.7366
21
7.16988
31
-41.6995
12
-26.4159
22
1.50923
32
-32.4537
13
-26.4159
23
1.50923
33
-32.4537
0
3DFACE
8
0
10
-27.7366
20
7.16988
30
-41.6995
11
-26.4159
21
1.50923
31
-32.4537
12
-26.4159
22
8.11337
32
-36.2277
13
-26.4159
23
8.11337
33
-36.2277
0
3DFACE
8
0
10
-26.4159
20
1.50923
30
-32.4537
11
-26.4159
21
8.11337
31
-36.2277
12
-28.114
22
8.30196
32
-30.001
13
-28.114
23
8.30196
33
-30.001
0
3DFACE
8
0
10
-24.1518
20
-17.5477
30
-22.0762
11
-22.0762
21
-16.9816
31
-16.2267
12
-21.6988
22
-21.8874
32
-20.5667
13
-21.6988
23
-21.8874
33
-20.5667
0
3DFACE
8
0
10
-21.6988
20
-21.8874
30
-20.5667
11
-19.0572
21
-24.9064
31
-27.548
12
-24.1518
22
-17.5477
32
-22.0762
13
-24.1518
23
-17.5477
33
-22.0762
0
3DFACE
8
0
10
-24.1518
20
-17.5477
30
-22.0762
11
-19.0572
21
-24.9064
31
-27.548
12
-25.661
22
-18.1137
32
-28.3029
13
-25.661
23
-18.1137
33
-28.3029
0
3DFACE
8
0
10
-26.4159
20
-9.81146
30
-31.3217
11
-25.661
21
-18.1137
31
-28.3029
12
-24.1518
22
-17.5477
32
-22.0762
13
-24.1518
23
-17.5477
33
-22.0762
0
3DFACE
8
0
10
-28.114
20
8.30196
30
-30.001
11
-26.4159
21
7.92479
31
-23.7743
12
-25.4724
22
13.5851
32
-26.4159
13
-25.4724
23
13.5851
33
-26.4159
0
3DFACE
8
0
10
-10.1889
20
18.6797
30
2.83018
11
-8.67938
21
22.6423
31
6.41527
12
-3.39619
22
18.8686
32
5.28319
13
-3.39619
23
18.8686
33
5.28319
0
3DFACE
8
0
10
-19.0572
20
-24.9064
30
-27.548
11
-5.47176
21
-29.0575
31
-13.774
12
-5.84921
22
-30.1896
32
-27.548
13
-5.84921
23
-30.1896
33
-27.548
0
3DFACE
8
0
10
-17.9251
20
-25.2839
30
-37.9258
11
-5.84921
21
-30.1896
31
-27.548
12
-19.0572
22
-24.9064
32
-27.548
13
-19.0572
23
-24.9064
33
-27.548
0
3DFACE
8
0
10
-19.0572
20
-24.9064
30
-27.548
11
-17.9251
21
-25.2839
31
-37.9258
12
-24.1518
22
-15.6607
32
-34.1521
13
-24.1518
23
-15.6607
33
-34.1521
0
3DFACE
8
0
10
-25.661
20
-18.1137
30
-28.3029
11
-24.1518
21
-15.6607
31
-34.1521
12
-19.0572
22
-24.9064
32
-27.548
13
-19.0572
23
-24.9064
33
-27.548
0
3DFACE
8
0
10
-26.4159
20
-9.81146
30
-31.3217
11
-25.661
21
-18.1137
31
-28.3029
12
-24.1518
22
-15.6607
32
-34.1521
13
-24.1518
23
-15.6607
33
-34.1521
0
3DFACE
8
0
10
-25.661
20
-15.8495
30
-38.8693
11
-24.1518
21
-15.6607
31
-34.1521
12
-26.4159
22
-9.81146
32
-31.3217
13
-26.4159
23
-9.81146
33
-31.3217
0
3DFACE
8
0
10
-26.4159
20
-9.81146
30
-31.3217
11
-25.661
21
-15.8495
31
-38.8693
12
-30.3782
22
-10.7549
32
-38.3033
13
-30.3782
23
-10.7549
33
-38.3033
0
3DFACE
8
0
10
-30.567
20
-6.22638
30
-35.2842
11
-26.4159
21
-9.81146
31
-31.3217
12
-28.8689
22
-5.47176
32
-31.6991
13
-28.8689
23
-5.47176
33
-31.6991
0
3DFACE
8
0
10
-34.3407
20
-6.22638
30
-41.322
11
-30.3782
21
-10.7549
31
-38.3033
12
-32.8312
22
-9.62288
32
-43.5864
13
-32.8312
23
-9.62288
33
-43.5864
0
3DFACE
8
0
10
-32.8312
20
-9.62288
30
-43.5864
11
-32.4537
21
-5.84921
31
-47.3601
12
-34.3407
22
-6.22638
32
-41.322
13
-34.3407
23
-6.22638
33
-41.322
0
3DFACE
8
0
10
-34.3407
20
-6.22638
30
-41.322
11
-32.4537
21
-5.84921
31
-47.3601
12
-33.3972
22
-2.26413
32
-44.5296
13
-33.3972
23
-2.26413
33
-44.5296
0
3DFACE
8
0
10
-33.3972
20
-2.26413
30
-44.5296
11
-31.6991
21
0
31
-40.5674
12
-34.3407
22
-6.22638
32
-41.322
13
-34.3407
23
-6.22638
33
-41.322
0
3DFACE
8
0
10
-34.3407
20
-6.22638
30
-41.322
11
-31.6991
21
0
31
-40.5674
12
-32.0766
22
-2.64159
32
-37.7372
13
-32.0766
23
-2.64159
33
-37.7372
0
3DFACE
8
0
10
-32.0766
20
-2.64159
30
-37.7372
11
-30.567
21
-6.22638
31
-35.2842
12
-34.3407
22
-6.22638
32
-41.322
13
-34.3407
23
-6.22638
33
-41.322
0
3DFACE
8
0
10
-25.661
20
-15.8495
30
-38.8693
11
-24.1518
21
-15.6607
31
-34.1521
12
-17.9251
22
-25.2839
32
-37.9258
13
-17.9251
23
-25.2839
33
-37.9258
0
3DFACE
8
0
10
-22.6423
20
-18.6797
30
-45.2845
11
-17.9251
21
-25.2839
31
-37.9258
12
-25.661
22
-15.8495
32
-38.8693
13
-25.661
23
-15.8495
33
-38.8693
0
3DFACE
8
0
10
-25.661
20
-15.8495
30
-38.8693
11
-22.6423
21
-18.6797
31
-45.2845
12
-30.9445
22
-13.208
32
-47.1715
13
-30.9445
23
-13.208
33
-47.1715
0
3DFACE
8
0
10
-30.9445
20
-13.208
30
-47.1715
11
-30.3782
21
-10.7549
31
-38.3033
12
-25.661
22
-15.8495
32
-38.8693
13
-25.661
23
-15.8495
33
-38.8693
0
3DFACE
8
0
10
-30.9445
20
-13.208
30
-47.1715
11
-22.6423
21
-18.6797
31
-45.2845
12
-26.6045
22
-12.8305
32
-52.2658
13
-26.6045
23
-12.8305
33
-52.2658
0
3DFACE
8
0
10
-30.3782
20
-10.3775
30
-50.5677
11
-26.6045
21
-12.8305
31
-52.2658
12
-30.9445
22
-13.208
32
-47.1715
13
-30.9445
23
-13.208
33
-47.1715
0
3DFACE
8
0
10
-30.9445
20
-13.208
30
-47.1715
11
-30.3782
21
-10.3775
31
-50.5677
12
-32.4537
22
-5.84921
32
-47.3601
13
-32.4537
23
-5.84921
33
-47.3601
0
3DFACE
8
0
10
-32.8312
20
-9.62288
30
-43.5864
11
-32.4537
21
-5.84921
31
-47.3601
12
-30.9445
22
-13.208
32
-47.1715
13
-30.9445
23
-13.208
33
-47.1715
0
3DFACE
8
0
10
-32.8312
20
-9.62288
30
-43.5864
11
-30.9445
21
-13.208
31
-47.1715
12
-30.3782
22
-10.7549
32
-38.3033
13
-30.3782
23
-10.7549
33
-38.3033
0
3DFACE
8
0
10
-17.9251
20
-25.2839
30
-37.9258
11
-5.84921
21
-30.1896
31
-27.548
12
-5.84921
22
-27.3594
32
-40.1899
13
-5.84921
23
-27.3594
33
-40.1899
0
3DFACE
8
0
10
-7.54732
20
-16.2267
30
-55.0963
11
-5.84921
21
-27.3594
31
-40.1899
12
-17.9251
22
-25.2839
32
-37.9258
13
-17.9251
23
-25.2839
33
-37.9258
0
3DFACE
8
0
10
-17.9251
20
-25.2839
30
-37.9258
11
-7.54732
21
-16.2267
31
-55.0963
12
-22.6423
22
-18.6797
32
-45.2845
13
-22.6423
23
-18.6797
33
-45.2845
0
3DFACE
8
0
10
-5.84921
20
-30.1896
30
-27.548
11
-5.84921
21
-27.3594
31
-40.1899
12
1.6981
22
-27.3594
32
-45.2845
13
1.6981
23
-27.3594
33
-45.2845
0
3DFACE
8
0
10
-7.54732
20
-16.2267
30
-55.0963
11
1.6981
21
-27.3594
31
-45.2845
12
-5.84921
22
-27.3594
32
-40.1899
13
-5.84921
23
-27.3594
33
-40.1899
0
3DFACE
8
0
10
-22.6423
20
-18.6797
30
-45.2845
11
-16.9816
21
-14.1512
31
-53.5868
12
-7.54732
22
-16.2267
32
-55.0963
13
-7.54732
23
-16.2267
33
-55.0963
0
3DFACE
8
0
10
-9.24542
20
-6.22638
30
-58.1151
11
-7.54732
21
-16.2267
31
-55.0963
12
-16.9816
22
-14.1512
32
-53.5868
13
-16.9816
23
-14.1512
33
-53.5868
0
3DFACE
8
0
10
-16.9816
20
-14.1512
30
-53.5868
11
-9.24542
21
-6.22638
31
-58.1151
12
-26.6045
22
-12.8305
32
-52.2658
13
-26.6045
23
-12.8305
33
-52.2658
0
3DFACE
8
0
10
-26.6045
20
-12.8305
30
-52.2658
11
-22.6423
21
-18.6797
31
-45.2845
12
-16.9816
22
-14.1512
32
-53.5868
13
-16.9816
23
-14.1512
33
-53.5868
0
3DFACE
8
0
10
-7.54732
20
-16.2267
30
-55.0963
11
1.6981
21
-27.3594
31
-45.2845
12
2.6416
22
-29.6236
32
-50.9452
13
2.6416
23
-29.6236
33
-50.9452
0
3DFACE
8
0
10
-5.0943
20
-19.6232
30
-60.1906
11
2.6416
21
-29.6236
31
-50.9452
12
-7.54732
22
-16.2267
32
-55.0963
13
-7.54732
23
-16.2267
33
-55.0963
0
3DFACE
8
0
10
-7.54732
20
-16.2267
30
-55.0963
11
-5.0943
21
-19.6232
31
-60.1906
12
-7.35873
22
-6.98128
32
-69.8138
13
-7.35873
23
-6.98128
33
-69.8138
0
3DFACE
8
0
10
-33.3972
20
-2.26413
30
-44.5296
11
-31.6991
21
0
31
-40.5674
12
-32.0766
22
0.754623
32
-46.228
13
-32.0766
23
0.754623
33
-46.228
0
3DFACE
8
0
10
-32.0766
20
0.754623
30
-46.228
11
-29.6236
21
4.52829
31
-45.4731
12
-31.6991
22
0
32
-40.5674
13
-31.6991
23
0
33
-40.5674
0
3DFACE
8
0
10
-31.6991
20
0
30
-40.5674
11
-29.6236
21
4.52829
31
-45.4731
12
-27.7366
22
7.16988
32
-41.6995
13
-27.7366
23
7.16988
33
-41.6995
0
3DFACE
8
0
10
-29.6236
20
4.52829
30
-45.4731
11
-27.7366
21
7.16988
31
-41.6995
12
-26.7934
22
8.30196
32
-44.3411
13
-26.7934
23
8.30196
33
-44.3411
0
3DFACE
8
0
10
-32.4537
20
-5.84921
30
-47.3601
11
-30.3782
21
-10.3775
31
-50.5677
12
-28.6801
22
-6.22638
32
-54.1528
13
-28.6801
23
-6.22638
33
-54.1528
0
3DFACE
8
0
10
-31.5105
20
-1.69809
30
-50.7563
11
-28.6801
21
-6.22638
31
-54.1528
12
-32.4537
22
-5.84921
32
-47.3601
13
-32.4537
23
-5.84921
33
-47.3601
0
3DFACE
8
0
10
-32.4537
20
-5.84921
30
-47.3601
11
-31.5105
21
-1.69809
31
-50.7563
12
-32.0766
22
0.754623
32
-46.228
13
-32.0766
23
0.754623
33
-46.228
0
3DFACE
8
0
10
-33.3972
20
-2.26413
30
-44.5296
11
-32.0766
21
0.754623
31
-46.228
12
-32.4537
22
-5.84921
32
-47.3601
13
-32.4537
23
-5.84921
33
-47.3601
0
3DFACE
8
0
10
-32.0766
20
0.754623
30
-46.228
11
-29.6236
21
4.52829
31
-45.4731
12
-27.7366
22
3.58479
32
-51.6998
13
-27.7366
23
3.58479
33
-51.6998
0
3DFACE
8
0
10
-29.6236
20
4.52829
30
-45.4731
11
-27.7366
21
3.58479
31
-51.6998
12
-26.7934
22
8.30196
32
-44.3411
13
-26.7934
23
8.30196
33
-44.3411
0
3DFACE
8
0
10
-32.0766
20
0.754623
30
-46.228
11
-31.5105
21
-1.69809
31
-50.7563
12
-27.7366
22
3.58479
32
-51.6998
13
-27.7366
23
3.58479
33
-51.6998
0
3DFACE
8
0
10
-31.5105
20
-1.69809
30
-50.7563
11
-27.7366
21
3.58479
31
-51.6998
12
-28.6801
22
-6.22638
32
-54.1528
13
-28.6801
23
-6.22638
33
-54.1528
0
3DFACE
8
0
10
-28.6801
20
-6.22638
30
-54.1528
11
-17.9251
21
6.98129
31
-53.964
12
-27.7366
22
3.58479
32
-51.6998
13
-27.7366
23
3.58479
33
-51.6998
0
3DFACE
8
0
10
-27.7366
20
3.58479
30
-51.6998
11
-17.9251
21
6.98129
31
-53.964
12
-26.7934
22
8.30196
32
-44.3411
13
-26.7934
23
8.30196
33
-44.3411
0
3DFACE
8
0
10
-30.3782
20
-10.3775
30
-50.5677
11
-28.6801
21
-6.22638
31
-54.1528
12
-26.6045
22
-12.8305
32
-52.2658
13
-26.6045
23
-12.8305
33
-52.2658
0
3DFACE
8
0
10
-26.6045
20
-12.8305
30
-52.2658
11
-9.24542
21
-6.22638
31
-58.1151
12
-28.6801
22
-6.22638
32
-54.1528
13
-28.6801
23
-6.22638
33
-54.1528
0
3DFACE
8
0
10
-28.6801
20
-6.22638
30
-54.1528
11
-9.24542
21
-6.22638
31
-58.1151
12
-15.2835
22
3.01875
32
-55.8509
13
-15.2835
23
3.01875
33
-55.8509
0
3DFACE
8
0
10
-17.9251
20
6.98129
30
-53.964
11
-15.2835
21
3.01875
31
-55.8509
12
-28.6801
22
-6.22638
32
-54.1528
13
-28.6801
23
-6.22638
33
-54.1528
0
3DFACE
8
0
10
-9.24542
20
-6.22638
30
-58.1151
11
-7.35873
21
-6.98128
31
-69.8138
12
-3.77365
22
2.26414
32
-61.7001
13
-3.77365
23
2.26414
33
-61.7001
0
3DFACE
8
0
10
-4.71686
20
8.86798
30
-56.2284
11
-3.77365
21
2.26414
31
-61.7001
12
-9.24542
22
-6.22638
32
-58.1151
13
-9.24542
23
-6.22638
33
-58.1151
0
3DFACE
8
0
10
-9.24542
20
-6.22638
30
-58.1151
11
-4.71686
21
8.86798
31
-56.2284
12
-15.2835
22
3.01875
32
-55.8509
13
-15.2835
23
3.01875
33
-55.8509
0
3DFACE
8
0
10
-4.71686
20
8.86798
30
-56.2284
11
-3.77365
21
2.26414
31
-61.7001
12
6.98129
22
13.9626
32
-67.1722
13
6.98129
23
13.9626
33
-67.1722
0
3DFACE
8
0
10
6.98129
20
13.9626
30
-67.1722
11
8.11337
21
15.8496
31
-57.549
12
-4.71686
22
8.86798
32
-56.2284
13
-4.71686
23
8.86798
33
-56.2284
0
3DFACE
8
0
10
-4.71686
20
8.86798
30
-56.2284
11
8.11337
21
15.8496
31
-57.549
12
-0.188568
22
16.9816
32
-51.1338
13
-0.188568
23
16.9816
33
-51.1338
0
3DFACE
8
0
10
-7.54732
20
18.6797
30
-48.6808
11
-0.188568
21
16.9816
31
-51.1338
12
-4.71686
22
8.86798
32
-56.2284
13
-4.71686
23
8.86798
33
-56.2284
0
3DFACE
8
0
10
-7.54732
20
18.6797
30
-48.6808
11
-4.71686
21
8.86798
31
-56.2284
12
-17.9251
22
6.98129
32
-53.964
13
-17.9251
23
6.98129
33
-53.964
0
3DFACE
8
0
10
-17.9251
20
6.98129
30
-53.964
11
-4.71686
21
8.86798
31
-56.2284
12
-15.2835
22
3.01875
32
-55.8509
13
-15.2835
23
3.01875
33
-55.8509
0
3DFACE
8
0
10
-19.0572
20
13.0191
30
-49.6243
11
-18.8686
21
20.0007
31
-39.6239
12
-26.7934
22
[i] 8.30196
[/i][i] 32
[/i][i] -44.3411
[/i][i] 13
[/i][i] -26.7934
[/i][i] 23
[/i][i] 8.30196
[/i][i] 33
[/i][i] -44.3411
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -26.7934
[/i][i] 20
[/i][i] 8.30196
[/i][i] 30
[/i][i] -44.3411
[/i][i] 11
[/i][i] -17.9251
[/i][i] 21
[/i][i] 6.98129
[/i][i] 31
[/i][i] -53.964
[/i][i] 12
[/i][i] -19.0572
[/i][i] 22
[/i][i] 13.0191
[/i][i] 32
[/i][i] -49.6243
[/i][i] 13
[/i][i] -19.0572
[/i][i] 23
[/i][i] 13.0191
[/i][i] 33
[/i][i] -49.6243
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -19.0572
[/i][i] 20
[/i][i] 13.0191
[/i][i] 30
[/i][i] -49.6243
[/i][i] 11
[/i][i] -17.9251
[/i][i] 21
[/i][i] 6.98129
[/i][i] 31
[/i][i] -53.964
[/i][i] 12
[/i][i] -7.54732
[/i][i] 22
[/i][i] 18.6797
[/i][i] 32
[/i][i] -48.6808
[/i][i] 13
[/i][i] -7.54732
[/i][i] 23
[/i][i] 18.6797
[/i][i] 33
[/i][i] -48.6808
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.8686
[/i][i] 20
[/i][i] 20.0007
[/i][i] 30
[/i][i] -39.6239
[/i][i] 11
[/i][i] -7.54732
[/i][i] 21
[/i][i] 18.6797
[/i][i] 31
[/i][i] -48.6808
[/i][i] 12
[/i][i] -19.0572
[/i][i] 22
[/i][i] 13.0191
[/i][i] 32
[/i][i] -49.6243
[/i][i] 13
[/i][i] -19.0572
[/i][i] 23
[/i][i] 13.0191
[/i][i] 33
[/i][i] -49.6243
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.8686
[/i][i] 20
[/i][i] 20.0007
[/i][i] 30
[/i][i] -39.6239
[/i][i] 11
[/i][i] -13.3965
[/i][i] 21
[/i][i] 24.3404
[/i][i] 31
[/i][i] -32.8312
[/i][i] 12
[/i][i] -6.41525
[/i][i] 22
[/i][i] 25.095
[/i][i] 32
[/i][i] -38.4918
[/i][i] 13
[/i][i] -6.41525
[/i][i] 23
[/i][i] 25.095
[/i][i] 33
[/i][i] -38.4918
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.41525
[/i][i] 20
[/i][i] 25.095
[/i][i] 30
[/i][i] -38.4918
[/i][i] 11
[/i][i] -2.83017
[/i][i] 21
[/i][i] 29.435
[/i][i] 31
[/i][i] -20.0007
[/i][i] 12
[/i][i] -13.3965
[/i][i] 22
[/i][i] 24.3404
[/i][i] 32
[/i][i] -32.8312
[/i][i] 13
[/i][i] -13.3965
[/i][i] 23
[/i][i] 24.3404
[/i][i] 33
[/i][i] -32.8312
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.8686
[/i][i] 20
[/i][i] 20.0007
[/i][i] 30
[/i][i] -39.6239
[/i][i] 11
[/i][i] -6.41525
[/i][i] 21
[/i][i] 25.095
[/i][i] 31
[/i][i] -38.4918
[/i][i] 12
[/i][i] -7.54732
[/i][i] 22
[/i][i] 18.6797
[/i][i] 32
[/i][i] -48.6808
[/i][i] 13
[/i][i] -7.54732
[/i][i] 23
[/i][i] 18.6797
[/i][i] 33
[/i][i] -48.6808
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -7.54732
[/i][i] 20
[/i][i] 18.6797
[/i][i] 30
[/i][i] -48.6808
[/i][i] 11
[/i][i] -0.188568
[/i][i] 21
[/i][i] 16.9816
[/i][i] 31
[/i][i] -51.1338
[/i][i] 12
[/i][i] 8.49081
[/i][i] 22
[/i][i] 24.7178
[/i][i] 32
[/i][i] -37.1709
[/i][i] 13
[/i][i] 8.49081
[/i][i] 23
[/i][i] 24.7178
[/i][i] 33
[/i][i] -37.1709
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.41525
[/i][i] 20
[/i][i] 25.095
[/i][i] 30
[/i][i] -38.4918
[/i][i] 11
[/i][i] 8.49081
[/i][i] 21
[/i][i] 24.7178
[/i][i] 31
[/i][i] -37.1709
[/i][i] 12
[/i][i] -7.54732
[/i][i] 22
[/i][i] 18.6797
[/i][i] 32
[/i][i] -48.6808
[/i][i] 13
[/i][i] -7.54732
[/i][i] 23
[/i][i] 18.6797
[/i][i] 33
[/i][i] -48.6808
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.41525
[/i][i] 20
[/i][i] 25.095
[/i][i] 30
[/i][i] -38.4918
[/i][i] 11
[/i][i] -2.83017
[/i][i] 21
[/i][i] 29.435
[/i][i] 31
[/i][i] -20.0007
[/i][i] 12
[/i][i] 8.49081
[/i][i] 22
[/i][i] 24.7178
[/i][i] 32
[/i][i] -37.1709
[/i][i] 13
[/i][i] 8.49081
[/i][i] 23
[/i][i] 24.7178
[/i][i] 33
[/i][i] -37.1709
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -2.83017
[/i][i] 20
[/i][i] 29.435
[/i][i] 30
[/i][i] -20.0007
[/i][i] 11
[/i][i] 8.49081
[/i][i] 21
[/i][i] 24.7178
[/i][i] 31
[/i][i] -37.1709
[/i][i] 12
[/i][i] 3.58479
[/i][i] 22
[/i][i] 29.0575
[/i][i] 32
[/i][i] -11.5096
[/i][i] 13
[/i][i] 3.58479
[/i][i] 23
[/i][i] 29.0575
[/i][i] 33
[/i][i] -11.5096
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 3.58479
[/i][i] 20
[/i][i] 29.0575
[/i][i] 30
[/i][i] -11.5096
[/i][i] 11
[/i][i] 8.49081
[/i][i] 21
[/i][i] 24.7178
[/i][i] 31
[/i][i] -37.1709
[/i][i] 12
[/i][i] 16.0381
[/i][i] 22
[/i][i] 24.529
[/i][i] 32
[/i][i] -19.0572
[/i][i] 13
[/i][i] 16.0381
[/i][i] 23
[/i][i] 24.529
[/i][i] 33
[/i][i] -19.0572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 14.34
[/i][i] 20
[/i][i] 0
[/i][i] 30
[/i][i] -1.50922
[/i][i] 11
[/i][i] 17.1702
[/i][i] 21
[/i][i] 17.5477
[/i][i] 31
[/i][i] -8.11336
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -0.188568
[/i][i] 32
[/i][i] -9.62288
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -0.188568
[/i][i] 33
[/i][i] -9.62288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 18.3023
[/i][i] 20
[/i][i] -10.0003
[/i][i] 30
[/i][i] -3.77365
[/i][i] 11
[/i][i] 27.7366
[/i][i] 21
[/i][i] -0.188568
[/i][i] 31
[/i][i] -9.62288
[/i][i] 12
[/i][i] 14.34
[/i][i] 22
[/i][i] 0
[/i][i] 32
[/i][i] -1.50922
[/i][i] 13
[/i][i] 14.34
[/i][i] 23
[/i][i] 0
[/i][i] 33
[/i][i] -1.50922
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.7366
[/i][i] 20
[/i][i] -0.188568
[/i][i] 30
[/i][i] -9.62288
[/i][i] 11
[/i][i] 31.3217
[/i][i] 21
[/i][i] -16.9816
[/i][i] 31
[/i][i] -21.6988
[/i][i] 12
[/i][i] 19.0572
[/i][i] 22
[/i][i] -19.0572
[/i][i] 32
[/i][i] -10.0003
[/i][i] 13
[/i][i] 19.0572
[/i][i] 23
[/i][i] -19.0572
[/i][i] 33
[/i][i] -10.0003
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 18.3023
[/i][i] 20
[/i][i] -10.0003
[/i][i] 30
[/i][i] -3.77365
[/i][i] 11
[/i][i] 19.0572
[/i][i] 21
[/i][i] -19.0572
[/i][i] 31
[/i][i] -10.0003
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -0.188568
[/i][i] 32
[/i][i] -9.62288
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -0.188568
[/i][i] 33
[/i][i] -9.62288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.0572
[/i][i] 20
[/i][i] -19.0572
[/i][i] 30
[/i][i] -10.0003
[/i][i] 11
[/i][i] 31.3217
[/i][i] 21
[/i][i] -16.9816
[/i][i] 31
[/i][i] -21.6988
[/i][i] 12
[/i][i] 24.529
[/i][i] 22
[/i][i] -24.529
[/i][i] 32
[/i][i] -26.4159
[/i][i] 13
[/i][i] 24.529
[/i][i] 23
[/i][i] -24.529
[/i][i] 33
[/i][i] -26.4159
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.1889
[/i][i] 20
[/i][i] -25.4724
[/i][i] 30
[/i][i] -6.98128
[/i][i] 11
[/i][i] 24.529
[/i][i] 21
[/i][i] -24.529
[/i][i] 31
[/i][i] -26.4159
[/i][i] 12
[/i][i] 19.0572
[/i][i] 22
[/i][i] -19.0572
[/i][i] 32
[/i][i] -10.0003
[/i][i] 13
[/i][i] 19.0572
[/i][i] 23
[/i][i] -19.0572
[/i][i] 33
[/i][i] -10.0003
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.1889
[/i][i] 20
[/i][i] -25.4724
[/i][i] 30
[/i][i] -6.98128
[/i][i] 11
[/i][i] 24.529
[/i][i] 21
[/i][i] -24.529
[/i][i] 31
[/i][i] -26.4159
[/i][i] 12
[/i][i] 16.9816
[/i][i] 22
[/i][i] -26.4159
[/i][i] 32
[/i][i] -22.2648
[/i][i] 13
[/i][i] 16.9816
[/i][i] 23
[/i][i] -26.4159
[/i][i] 33
[/i][i] -22.2648
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 3.58479
[/i][i] 20
[/i][i] -30.1896
[/i][i] 30
[/i][i] -15.0947
[/i][i] 11
[/i][i] 16.9816
[/i][i] 21
[/i][i] -26.4159
[/i][i] 31
[/i][i] -22.2648
[/i][i] 12
[/i][i] 10.1889
[/i][i] 22
[/i][i] -25.4724
[/i][i] 32
[/i][i] -6.98128
[/i][i] 13
[/i][i] 10.1889
[/i][i] 23
[/i][i] -25.4724
[/i][i] 33
[/i][i] -6.98128
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.9816
[/i][i] 20
[/i][i] -26.4159
[/i][i] 30
[/i][i] -22.2648
[/i][i] 11
[/i][i] 24.529
[/i][i] 21
[/i][i] -24.529
[/i][i] 31
[/i][i] -26.4159
[/i][i] 12
[/i][i] 11.6985
[/i][i] 22
[/i][i] -30.001
[/i][i] 32
[/i][i] -37.1709
[/i][i] 13
[/i][i] 11.6985
[/i][i] 23
[/i][i] -30.001
[/i][i] 33
[/i][i] -37.1709
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 3.58479
[/i][i] 20
[/i][i] -30.1896
[/i][i] 30
[/i][i] -15.0947
[/i][i] 11
[/i][i] 11.6985
[/i][i] 21
[/i][i] -30.001
[/i][i] 31
[/i][i] -37.1709
[/i][i] 12
[/i][i] 16.9816
[/i][i] 22
[/i][i] -26.4159
[/i][i] 32
[/i][i] -22.2648
[/i][i] 13
[/i][i] 16.9816
[/i][i] 23
[/i][i] -26.4159
[/i][i] 33
[/i][i] -22.2648
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 3.58479
[/i][i] 20
[/i][i] -30.1896
[/i][i] 30
[/i][i] -15.0947
[/i][i] 11
[/i][i] 11.6985
[/i][i] 21
[/i][i] -30.001
[/i][i] 31
[/i][i] -37.1709
[/i][i] 12
[/i][i] -5.84921
[/i][i] 22
[/i][i] -30.1896
[/i][i] 32
[/i][i] -27.548
[/i][i] 13
[/i][i] -5.84921
[/i][i] 23
[/i][i] -30.1896
[/i][i] 33
[/i][i] -27.548
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 11.6985
[/i][i] 20
[/i][i] -30.001
[/i][i] 30
[/i][i] -37.1709
[/i][i] 11
[/i][i] 24.529
[/i][i] 21
[/i][i] -24.529
[/i][i] 31
[/i][i] -26.4159
[/i][i] 12
[/i][i] 23.2083
[/i][i] 22
[/i][i] -30.001
[/i][i] 32
[/i][i] -36.4163
[/i][i] 13
[/i][i] 23.2083
[/i][i] 23
[/i][i] -30.001
[/i][i] 33
[/i][i] -36.4163
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 13.3966
[/i][i] 20
[/i][i] -32.8312
[/i][i] 30
[/i][i] -42.2655
[/i][i] 11
[/i][i] 23.2083
[/i][i] 21
[/i][i] -30.001
[/i][i] 31
[/i][i] -36.4163
[/i][i] 12
[/i][i] 11.6985
[/i][i] 22
[/i][i] -30.001
[/i][i] 32
[/i][i] -37.1709
[/i][i] 13
[/i][i] 11.6985
[/i][i] 23
[/i][i] -30.001
[/i][i] 33
[/i][i] -37.1709
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 11.6985
[/i][i] 20
[/i][i] -30.001
[/i][i] 30
[/i][i] -37.1709
[/i][i] 11
[/i][i] 13.3966
[/i][i] 21
[/i][i] -32.8312
[/i][i] 31
[/i][i] -42.2655
[/i][i] 12
[/i][i] 2.6416
[/i][i] 22
[/i][i] -29.6236
[/i][i] 32
[/i][i] -50.9452
[/i][i] 13
[/i][i] 2.6416
[/i][i] 23
[/i][i] -29.6236
[/i][i] 33
[/i][i] -50.9452
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 1.6981
[/i][i] 20
[/i][i] -27.3594
[/i][i] 30
[/i][i] -45.2845
[/i][i] 11
[/i][i] 2.6416
[/i][i] 21
[/i][i] -29.6236
[/i][i] 31
[/i][i] -50.9452
[/i][i] 12
[/i][i] 11.6985
[/i][i] 22
[/i][i] -30.001
[/i][i] 32
[/i][i] -37.1709
[/i][i] 13
[/i][i] 11.6985
[/i][i] 23
[/i][i] -30.001
[/i][i] 33
[/i][i] -37.1709
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 1.6981
[/i][i] 20
[/i][i] -27.3594
[/i][i] 30
[/i][i] -45.2845
[/i][i] 11
[/i][i] 11.6985
[/i][i] 21
[/i][i] -30.001
[/i][i] 31
[/i][i] -37.1709
[/i][i] 12
[/i][i] -5.84921
[/i][i] 22
[/i][i] -30.1896
[/i][i] 32
[/i][i] -27.548
[/i][i] 13
[/i][i] -5.84921
[/i][i] 23
[/i][i] -30.1896
[/i][i] 33
[/i][i] -27.548
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.529
[/i][i] 20
[/i][i] -24.529
[/i][i] 30
[/i][i] -26.4159
[/i][i] 11
[/i][i] 35.4728
[/i][i] 21
[/i][i] -20.3778
[/i][i] 31
[/i][i] -30.7556
[/i][i] 12
[/i][i] 23.2083
[/i][i] 22
[/i][i] -30.001
[/i][i] 32
[/i][i] -36.4163
[/i][i] 13
[/i][i] 23.2083
[/i][i] 23
[/i][i] -30.001
[/i][i] 33
[/i][i] -36.4163
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.529
[/i][i] 20
[/i][i] -24.529
[/i][i] 30
[/i][i] -26.4159
[/i][i] 11
[/i][i] 31.3217
[/i][i] 21
[/i][i] -16.9816
[/i][i] 31
[/i][i] -21.6988
[/i][i] 12
[/i][i] 35.4728
[/i][i] 22
[/i][i] -20.3778
[/i][i] 32
[/i][i] -30.7556
[/i][i] 13
[/i][i] 35.4728
[/i][i] 23
[/i][i] -20.3778
[/i][i] 33
[/i][i] -30.7556
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.0378
[/i][i] 20
[/i][i] -25.2839
[/i][i] 30
[/i][i] -66.4173
[/i][i] 11
[/i][i] -5.0943
[/i][i] 21
[/i][i] -19.6232
[/i][i] 31
[/i][i] -60.1906
[/i][i] 12
[/i][i] 2.6416
[/i][i] 22
[/i][i] -29.6236
[/i][i] 32
[/i][i] -50.9452
[/i][i] 13
[/i][i] 2.6416
[/i][i] 23
[/i][i] -29.6236
[/i][i] 33
[/i][i] -50.9452
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 1.13206
[/i][i] 20
[/i][i] -33.5861
[/i][i] 30
[/i][i] -56.983
[/i][i] 11
[/i][i] 2.6416
[/i][i] 21
[/i][i] -29.6236
[/i][i] 31
[/i][i] -50.9452
[/i][i] 12
[/i][i] -6.0378
[/i][i] 22
[/i][i] -25.2839
[/i][i] 32
[/i][i] -66.4173
[/i][i] 13
[/i][i] -6.0378
[/i][i] 23
[/i][i] -25.2839
[/i][i] 33
[/i][i] -66.4173
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.0378
[/i][i] 20
[/i][i] -25.2839
[/i][i] 30
[/i][i] -66.4173
[/i][i] 11
[/i][i] 1.13206
[/i][i] 21
[/i][i] -33.5861
[/i][i] 31
[/i][i] -56.983
[/i][i] 12
[/i][i] -3.96223
[/i][i] 22
[/i][i] -45.096
[/i][i] 32
[/i][i] -72.4554
[/i][i] 13
[/i][i] -3.96223
[/i][i] 23
[/i][i] -45.096
[/i][i] 33
[/i][i] -72.4554
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.1324
[/i][i] 20
[/i][i] -36.2277
[/i][i] 30
[/i][i] -91.7012
[/i][i] 11
[/i][i] -8.86797
[/i][i] 21
[/i][i] -46.228
[/i][i] 31
[/i][i] -83.0218
[/i][i] 12
[/i][i] -6.0378
[/i][i] 22
[/i][i] -25.2839
[/i][i] 32
[/i][i] -66.4173
[/i][i] 13
[/i][i] -6.0378
[/i][i] 23
[/i][i] -25.2839
[/i][i] 33
[/i][i] -66.4173
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -7.35873
[/i][i] 20
[/i][i] -6.98128
[/i][i] 30
[/i][i] -69.8138
[/i][i] 11
[/i][i] -6.0378
[/i][i] 21
[/i][i] -25.2839
[/i][i] 31
[/i][i] -66.4173
[/i][i] 12
[/i][i] -5.0943
[/i][i] 22
[/i][i] -19.6232
[/i][i] 32
[/i][i] -60.1906
[/i][i] 13
[/i][i] -5.0943
[/i][i] 23
[/i][i] -19.6232
[/i][i] 33
[/i][i] -60.1906
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.4156
[/i][i] 20
[/i][i] -13.5851
[/i][i] 30
[/i][i] -99.6263
[/i][i] 11
[/i][i] -6.0378
[/i][i] 21
[/i][i] -25.2839
[/i][i] 31
[/i][i] -66.4173
[/i][i] 12
[/i][i] -7.35873
[/i][i] 22
[/i][i] -6.98128
[/i][i] 32
[/i][i] -69.8138
[/i][i] 13
[/i][i] -7.35873
[/i][i] 23
[/i][i] -6.98128
[/i][i] 33
[/i][i] -69.8138
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.4156
[/i][i] 20
[/i][i] -13.5851
[/i][i] 30
[/i][i] -99.6263
[/i][i] 11
[/i][i] -7.35873
[/i][i] 21
[/i][i] -6.98128
[/i][i] 31
[/i][i] -69.8138
[/i][i] 12
[/i][i] -8.86797
[/i][i] 22
[/i][i] 0.56604
[/i][i] 32
[/i][i] -85.2859
[/i][i] 13
[/i][i] -8.86797
[/i][i] 23
[/i][i] 0.56604
[/i][i] 33
[/i][i] -85.2859
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -8.86797
[/i][i] 20
[/i][i] 0.56604
[/i][i] 30
[/i][i] -85.2859
[/i][i] 11
[/i][i] 6.98129
[/i][i] 21
[/i][i] 13.9626
[/i][i] 31
[/i][i] -67.1722
[/i][i] 12
[/i][i] -7.35873
[/i][i] 22
[/i][i] -6.98128
[/i][i] 32
[/i][i] -69.8138
[/i][i] 13
[/i][i] -7.35873
[/i][i] 23
[/i][i] -6.98128
[/i][i] 33
[/i][i] -69.8138
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -12.6419
[/i][i] 20
[/i][i] -25.661
[/i][i] 30
[/i][i] -98.8714
[/i][i] 11
[/i][i] -6.0378
[/i][i] 21
[/i][i] -25.2839
[/i][i] 31
[/i][i] -66.4173
[/i][i] 12
[/i][i] -16.4156
[/i][i] 22
[/i][i] -13.5851
[/i][i] 32
[/i][i] -99.6263
[/i][i] 13
[/i][i] -16.4156
[/i][i] 23
[/i][i] -13.5851
[/i][i] 33
[/i][i] -99.6263
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.1324
[/i][i] 20
[/i][i] -28.6801
[/i][i] 30
[/i][i] -103.966
[/i][i] 11
[/i][i] -6.0378
[/i][i] 21
[/i][i] -25.2839
[/i][i] 31
[/i][i] -66.4173
[/i][i] 12
[/i][i] -12.6419
[/i][i] 22
[/i][i] -25.661
[/i][i] 32
[/i][i] -98.8714
[/i][i] 13
[/i][i] -12.6419
[/i][i] 23
[/i][i] -25.661
[/i][i] 33
[/i][i] -98.8714
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -12.6419
[/i][i] 20
[/i][i] -25.661
[/i][i] 30
[/i][i] -98.8714
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -28.6801
[/i][i] 31
[/i][i] -103.966
[/i][i] 12
[/i][i] -13.0191
[/i][i] 22
[/i][i] -26.0385
[/i][i] 32
[/i][i] -110.947
[/i][i] 13
[/i][i] -13.0191
[/i][i] 23
[/i][i] -26.0385
[/i][i] 33
[/i][i] -110.947
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.4156
[/i][i] 20
[/i][i] -13.5851
[/i][i] 30
[/i][i] -99.6263
[/i][i] 11
[/i][i] -13.0191
[/i][i] 21
[/i][i] -26.0385
[/i][i] 31
[/i][i] -110.947
[/i][i] 12
[/i][i] -12.6419
[/i][i] 22
[/i][i] -25.661
[/i][i] 32
[/i][i] -98.8714
[/i][i] 13
[/i][i] -12.6419
[/i][i] 23
[/i][i] -25.661
[/i][i] 33
[/i][i] -98.8714
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.1324
[/i][i] 20
[/i][i] -31.3217
[/i][i] 30
[/i][i] -97.7393
[/i][i] 11
[/i][i] -6.0378
[/i][i] 21
[/i][i] -25.2839
[/i][i] 31
[/i][i] -66.4173
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -103.966
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -103.966
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.1324
[/i][i] 20
[/i][i] -36.2277
[/i][i] 30
[/i][i] -91.7012
[/i][i] 11
[/i][i] -6.0378
[/i][i] 21
[/i][i] -25.2839
[/i][i] 31
[/i][i] -66.4173
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -31.3217
[/i][i] 32
[/i][i] -97.7393
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -31.3217
[/i][i] 33
[/i][i] -97.7393
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.0378
[/i][i] 20
[/i][i] -25.2839
[/i][i] 30
[/i][i] -66.4173
[/i][i] 11
[/i][i] -3.96223
[/i][i] 21
[/i][i] -45.096
[/i][i] 31
[/i][i] -72.4554
[/i][i] 12
[/i][i] -8.86797
[/i][i] 22
[/i][i] -46.228
[/i][i] 32
[/i][i] -83.0218
[/i][i] 13
[/i][i] -8.86797
[/i][i] 23
[/i][i] -46.228
[/i][i] 33
[/i][i] -83.0218
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.77365
[/i][i] 20
[/i][i] 2.26414
[/i][i] 30
[/i][i] -61.7001
[/i][i] 11
[/i][i] 6.98129
[/i][i] 21
[/i][i] 13.9626
[/i][i] 31
[/i][i] -67.1722
[/i][i] 12
[/i][i] -7.35873
[/i][i] 22
[/i][i] -6.98128
[/i][i] 32
[/i][i] -69.8138
[/i][i] 13
[/i][i] -7.35873
[/i][i] 23
[/i][i] -6.98128
[/i][i] 33
[/i][i] -69.8138
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.4156
[/i][i] 20
[/i][i] -13.5851
[/i][i] 30
[/i][i] -99.6263
[/i][i] 11
[/i][i] -7.16986
[/i][i] 21
[/i][i] 3.01875
[/i][i] 31
[/i][i] -102.268
[/i][i] 12
[/i][i] -8.86797
[/i][i] 22
[/i][i] 0.56604
[/i][i] 32
[/i][i] -85.2859
[/i][i] 13
[/i][i] -8.86797
[/i][i] 23
[/i][i] 0.56604
[/i][i] 33
[/i][i] -85.2859
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.39619
[/i][i] 20
[/i][i] 7.92479
[/i][i] 30
[/i][i] -89.0596
[/i][i] 11
[/i][i] 6.98129
[/i][i] 21
[/i][i] 13.9626
[/i][i] 31
[/i][i] -67.1722
[/i][i] 12
[/i][i] -8.86797
[/i][i] 22
[/i][i] 0.56604
[/i][i] 32
[/i][i] -85.2859
[/i][i] 13
[/i][i] -8.86797
[/i][i] 23
[/i][i] 0.56604
[/i][i] 33
[/i][i] -85.2859
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 6.98129
[/i][i] 20
[/i][i] 13.9626
[/i][i] 30
[/i][i] -67.1722
[/i][i] 11
[/i][i] 29.8122
[/i][i] 21
[/i][i] 20.0007
[/i][i] 31
[/i][i] -68.6817
[/i][i] 12
[/i][i] 22.2648
[/i][i] 22
[/i][i] 19.4346
[/i][i] 32
[/i][i] -57.3605
[/i][i] 13
[/i][i] 22.2648
[/i][i] 23
[/i][i] 19.4346
[/i][i] 33
[/i][i] -57.3605
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.0381
[/i][i] 20
[/i][i] 20.5667
[/i][i] 30
[/i][i] -47.9261
[/i][i] 11
[/i][i] 22.2648
[/i][i] 21
[/i][i] 19.4346
[/i][i] 31
[/i][i] -57.3605
[/i][i] 12
[/i][i] 8.11337
[/i][i] 22
[/i][i] 15.8496
[/i][i] 32
[/i][i] -57.549
[/i][i] 13
[/i][i] 8.11337
[/i][i] 23
[/i][i] 15.8496
[/i][i] 33
[/i][i] -57.549
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 6.98129
[/i][i] 20
[/i][i] 13.9626
[/i][i] 30
[/i][i] -67.1722
[/i][i] 11
[/i][i] 8.11337
[/i][i] 21
[/i][i] 15.8496
[/i][i] 31
[/i][i] -57.549
[/i][i] 12
[/i][i] 22.2648
[/i][i] 22
[/i][i] 19.4346
[/i][i] 32
[/i][i] -57.3605
[/i][i] 13
[/i][i] 22.2648
[/i][i] 23
[/i][i] 19.4346
[/i][i] 33
[/i][i] -57.3605
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 7.16988
[/i][i] 20
[/i][i] 12.6419
[/i][i] 30
[/i][i] -100.381
[/i][i] 11
[/i][i] 16.6042
[/i][i] 21
[/i][i] 18.8686
[/i][i] 31
[/i][i] -80.3802
[/i][i] 12
[/i][i] 6.98129
[/i][i] 22
[/i][i] 13.9626
[/i][i] 32
[/i][i] -67.1722
[/i][i] 13
[/i][i] 6.98129
[/i][i] 23
[/i][i] 13.9626
[/i][i] 33
[/i][i] -67.1722
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 6.98129
[/i][i] 20
[/i][i] 13.9626
[/i][i] 30
[/i][i] -67.1722
[/i][i] 11
[/i][i] 16.6042
[/i][i] 21
[/i][i] 18.8686
[/i][i] 31
[/i][i] -80.3802
[/i][i] 12
[/i][i] 29.8122
[/i][i] 22
[/i][i] 20.0007
[/i][i] 32
[/i][i] -68.6817
[/i][i] 13
[/i][i] 29.8122
[/i][i] 23
[/i][i] 20.0007
[/i][i] 33
[/i][i] -68.6817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.6042
[/i][i] 20
[/i][i] 18.8686
[/i][i] 30
[/i][i] -80.3802
[/i][i] 11
[/i][i] 29.8122
[/i][i] 21
[/i][i] 20.0007
[/i][i] 31
[/i][i] -68.6817
[/i][i] 12
[/i][i] 26.0385
[/i][i] 22
[/i][i] 18.6797
[/i][i] 32
[/i][i] -99.0599
[/i][i] 13
[/i][i] 26.0385
[/i][i] 23
[/i][i] 18.6797
[/i][i] 33
[/i][i] -99.0599
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.0385
[/i][i] 20
[/i][i] 18.6797
[/i][i] 30
[/i][i] -99.0599
[/i][i] 11
[/i][i] 38.4919
[/i][i] 21
[/i][i] 19.4346
[/i][i] 31
[/i][i] -84.1539
[/i][i] 12
[/i][i] 29.8122
[/i][i] 22
[/i][i] 20.0007
[/i][i] 32
[/i][i] -68.6817
[/i][i] 13
[/i][i] 29.8122
[/i][i] 23
[/i][i] 20.0007
[/i][i] 33
[/i][i] -68.6817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 7.16988
[/i][i] 20
[/i][i] 12.6419
[/i][i] 30
[/i][i] -100.381
[/i][i] 11
[/i][i] 16.6042
[/i][i] 21
[/i][i] 18.8686
[/i][i] 31
[/i][i] -80.3802
[/i][i] 12
[/i][i] 26.0385
[/i][i] 22
[/i][i] 18.6797
[/i][i] 32
[/i][i] -99.0599
[/i][i] 13
[/i][i] 26.0385
[/i][i] 23
[/i][i] 18.6797
[/i][i] 33
[/i][i] -99.0599
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 7.16988
[/i][i] 20
[/i][i] 12.6419
[/i][i] 30
[/i][i] -100.381
[/i][i] 11
[/i][i] 26.0385
[/i][i] 21
[/i][i] 18.6797
[/i][i] 31
[/i][i] -99.0599
[/i][i] 12
[/i][i] 10.755
[/i][i] 22
[/i][i] 1.32065
[/i][i] 32
[/i][i] -120.382
[/i][i] 13
[/i][i] 10.755
[/i][i] 23
[/i][i] 1.32065
[/i][i] 33
[/i][i] -120.382
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.11337
[/i][i] 20
[/i][i] 15.8496
[/i][i] 30
[/i][i] -57.549
[/i][i] 11
[/i][i] 16.0381
[/i][i] 21
[/i][i] 20.5667
[/i][i] 31
[/i][i] -47.9261
[/i][i] 12
[/i][i] 8.49081
[/i][i] 22
[/i][i] 24.7178
[/i][i] 32
[/i][i] -37.1709
[/i][i] 13
[/i][i] 8.49081
[/i][i] 23
[/i][i] 24.7178
[/i][i] 33
[/i][i] -37.1709
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -13.0191
[/i][i] 20
[/i][i] -26.0385
[/i][i] 30
[/i][i] -110.947
[/i][i] 11
[/i][i] -8.30194
[/i][i] 21
[/i][i] -13.774
[/i][i] 31
[/i][i] -164.723
[/i][i] 12
[/i][i] -14.34
[/i][i] 22
[/i][i] -11.1324
[/i][i] 32
[/i][i] -118.872
[/i][i] 13
[/i][i] -14.34
[/i][i] 23
[/i][i] -11.1324
[/i][i] 33
[/i][i] -118.872
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -14.34
[/i][i] 20
[/i][i] -11.1324
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] -13.0191
[/i][i] 21
[/i][i] -26.0385
[/i][i] 31
[/i][i] -110.947
[/i][i] 12
[/i][i] -16.4156
[/i][i] 22
[/i][i] -13.5851
[/i][i] 32
[/i][i] -99.6263
[/i][i] 13
[/i][i] -16.4156
[/i][i] 23
[/i][i] -13.5851
[/i][i] 33
[/i][i] -99.6263
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.4156
[/i][i] 20
[/i][i] -13.5851
[/i][i] 30
[/i][i] -99.6263
[/i][i] 11
[/i][i] -14.34
[/i][i] 21
[/i][i] -11.1324
[/i][i] 31
[/i][i] -118.872
[/i][i] 12
[/i][i] -7.16986
[/i][i] 22
[/i][i] 3.01875
[/i][i] 32
[/i][i] -102.268
[/i][i] 13
[/i][i] -7.16986
[/i][i] 23
[/i][i] 3.01875
[/i][i] 33
[/i][i] -102.268
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -14.34
[/i][i] 20
[/i][i] -11.1324
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] -7.16986
[/i][i] 21
[/i][i] 3.01875
[/i][i] 31
[/i][i] -102.268
[/i][i] 12
[/i][i] -3.77365
[/i][i] 22
[/i][i] 0.56604
[/i][i] 32
[/i][i] -120.759
[/i][i] 13
[/i][i] -3.77365
[/i][i] 23
[/i][i] 0.56604
[/i][i] 33
[/i][i] -120.759
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -7.16986
[/i][i] 20
[/i][i] 3.01875
[/i][i] 30
[/i][i] -102.268
[/i][i] 11
[/i][i] 10.755
[/i][i] 21
[/i][i] 1.32065
[/i][i] 31
[/i][i] -120.382
[/i][i] 12
[/i][i] 7.16988
[/i][i] 22
[/i][i] 12.6419
[/i][i] 32
[/i][i] -100.381
[/i][i] 13
[/i][i] 7.16988
[/i][i] 23
[/i][i] 12.6419
[/i][i] 33
[/i][i] -100.381
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.755
[/i][i] 20
[/i][i] 1.32065
[/i][i] 30
[/i][i] -120.382
[/i][i] 11
[/i][i] 26.0385
[/i][i] 21
[/i][i] 18.6797
[/i][i] 31
[/i][i] -99.0599
[/i][i] 12
[/i][i] 26.0385
[/i][i] 22
[/i][i] 14.34
[/i][i] 32
[/i][i] -116.419
[/i][i] 13
[/i][i] 26.0385
[/i][i] 23
[/i][i] 14.34
[/i][i] 33
[/i][i] -116.419
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.755
[/i][i] 20
[/i][i] 1.32065
[/i][i] 30
[/i][i] -120.382
[/i][i] 11
[/i][i] 26.0385
[/i][i] 21
[/i][i] 14.34
[/i][i] 31
[/i][i] -116.419
[/i][i] 12
[/i][i] 24.7178
[/i][i] 22
[/i][i] 9.43431
[/i][i] 32
[/i][i] -132.835
[/i][i] 13
[/i][i] 24.7178
[/i][i] 23
[/i][i] 9.43431
[/i][i] 33
[/i][i] -132.835
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.755
[/i][i] 20
[/i][i] 1.32065
[/i][i] 30
[/i][i] -120.382
[/i][i] 11
[/i][i] 24.7178
[/i][i] 21
[/i][i] 9.43431
[/i][i] 31
[/i][i] -132.835
[/i][i] 12
[/i][i] 12.6419
[/i][i] 22
[/i][i] -0.377151
[/i][i] 32
[/i][i] -136.42
[/i][i] 13
[/i][i] 12.6419
[/i][i] 23
[/i][i] -0.377151
[/i][i] 33
[/i][i] -136.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.755
[/i][i] 20
[/i][i] 1.32065
[/i][i] 30
[/i][i] -120.382
[/i][i] 11
[/i][i] 12.6419
[/i][i] 21
[/i][i] -0.377151
[/i][i] 31
[/i][i] -136.42
[/i][i] 12
[/i][i] -2.45271
[/i][i] 22
[/i][i] -0.566025
[/i][i] 32
[/i][i] -135.288
[/i][i] 13
[/i][i] -2.45271
[/i][i] 23
[/i][i] -0.566025
[/i][i] 33
[/i][i] -135.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -2.45271
[/i][i] 20
[/i][i] -0.566025
[/i][i] 30
[/i][i] -135.288
[/i][i] 11
[/i][i] 10.1889
[/i][i] 21
[/i][i] 2.26414
[/i][i] 31
[/i][i] -170.572
[/i][i] 12
[/i][i] 12.6419
[/i][i] 22
[/i][i] -0.377151
[/i][i] 32
[/i][i] -136.42
[/i][i] 13
[/i][i] 12.6419
[/i][i] 23
[/i][i] -0.377151
[/i][i] 33
[/i][i] -136.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.1889
[/i][i] 20
[/i][i] 2.26414
[/i][i] 30
[/i][i] -170.572
[/i][i] 11
[/i][i] 12.6419
[/i][i] 21
[/i][i] -0.377151
[/i][i] 31
[/i][i] -136.42
[/i][i] 12
[/i][i] 24.7178
[/i][i] 22
[/i][i] 9.43431
[/i][i] 32
[/i][i] -132.835
[/i][i] 13
[/i][i] 24.7178
[/i][i] 23
[/i][i] 9.43431
[/i][i] 33
[/i][i] -132.835
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -7.16986
[/i][i] 20
[/i][i] 3.01875
[/i][i] 30
[/i][i] -102.268
[/i][i] 11
[/i][i] -3.77365
[/i][i] 21
[/i][i] 0.56604
[/i][i] 31
[/i][i] -120.759
[/i][i] 12
[/i][i] 10.755
[/i][i] 22
[/i][i] 1.32065
[/i][i] 32
[/i][i] -120.382
[/i][i] 13
[/i][i] 10.755
[/i][i] 23
[/i][i] 1.32065
[/i][i] 33
[/i][i] -120.382
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.77365
[/i][i] 20
[/i][i] 0.56604
[/i][i] 30
[/i][i] -120.759
[/i][i] 11
[/i][i] 10.755
[/i][i] 21
[/i][i] 1.32065
[/i][i] 31
[/i][i] -120.382
[/i][i] 12
[/i][i] -2.45271
[/i][i] 22
[/i][i] -0.566025
[/i][i] 32
[/i][i] -135.288
[/i][i] 13
[/i][i] -2.45271
[/i][i] 23
[/i][i] -0.566025
[/i][i] 33
[/i][i] -135.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -14.34
[/i][i] 20
[/i][i] -11.1324
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] -3.77365
[/i][i] 21
[/i][i] 0.56604
[/i][i] 31
[/i][i] -120.759
[/i][i] 12
[/i][i] -2.45271
[/i][i] 22
[/i][i] -0.566025
[/i][i] 32
[/i][i] -135.288
[/i][i] 13
[/i][i] -2.45271
[/i][i] 23
[/i][i] -0.566025
[/i][i] 33
[/i][i] -135.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -14.34
[/i][i] 20
[/i][i] -11.1324
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] -2.45271
[/i][i] 21
[/i][i] -0.566025
[/i][i] 31
[/i][i] -135.288
[/i][i] 12
[/i][i] -6.7924
[/i][i] 22
[/i][i] 0
[/i][i] 32
[/i][i] -171.516
[/i][i] 13
[/i][i] -6.7924
[/i][i] 23
[/i][i] 0
[/i][i] 33
[/i][i] -171.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.7924
[/i][i] 20
[/i][i] 0
[/i][i] 30
[/i][i] -171.516
[/i][i] 11
[/i][i] -1.88667
[/i][i] 21
[/i][i] 3.58479
[/i][i] 31
[/i][i] -169.818
[/i][i] 12
[/i][i] -2.45271
[/i][i] 22
[/i][i] -0.566025
[/i][i] 32
[/i][i] -135.288
[/i][i] 13
[/i][i] -2.45271
[/i][i] 23
[/i][i] -0.566025
[/i][i] 33
[/i][i] -135.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -2.45271
[/i][i] 20
[/i][i] -0.566025
[/i][i] 30
[/i][i] -135.288
[/i][i] 11
[/i][i] -1.88667
[/i][i] 21
[/i][i] 3.58479
[/i][i] 31
[/i][i] -169.818
[/i][i] 12
[/i][i] 10.1889
[/i][i] 22
[/i][i] 2.26414
[/i][i] 32
[/i][i] -170.572
[/i][i] 13
[/i][i] 10.1889
[/i][i] 23
[/i][i] 2.26414
[/i][i] 33
[/i][i] -170.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -10.7549
[/i][i] 20
[/i][i] 7.73592
[/i][i] 30
[/i][i] -179.629
[/i][i] 11
[/i][i] -3.20761
[/i][i] 21
[/i][i] 12.4531
[/i][i] 31
[/i][i] -179.063
[/i][i] 12
[/i][i] -6.7924
[/i][i] 22
[/i][i] 0
[/i][i] 32
[/i][i] -171.516
[/i][i] 13
[/i][i] -6.7924
[/i][i] 23
[/i][i] 0
[/i][i] 33
[/i][i] -171.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.7924
[/i][i] 20
[/i][i] 0
[/i][i] 30
[/i][i] -171.516
[/i][i] 11
[/i][i] -3.20761
[/i][i] 21
[/i][i] 12.4531
[/i][i] 31
[/i][i] -179.063
[/i][i] 12
[/i][i] -1.88667
[/i][i] 22
[/i][i] 3.58479
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] -1.88667
[/i][i] 23
[/i][i] 3.58479
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 10.1889
[/i][i] 20
[/i][i] 2.26414
[/i][i] 30
[/i][i] -170.572
[/i][i] 11
[/i][i] 21.3213
[/i][i] 21
[/i][i] 7.16988
[/i][i] 31
[/i][i] -170.006
[/i][i] 12
[/i][i] 24.7178
[/i][i] 22
[/i][i] 9.43431
[/i][i] 32
[/i][i] -132.835
[/i][i] 13
[/i][i] 24.7178
[/i][i] 23
[/i][i] 9.43431
[/i][i] 33
[/i][i] -132.835
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 21.3213
[/i][i] 20
[/i][i] 7.16988
[/i][i] 30
[/i][i] -170.006
[/i][i] 11
[/i][i] 24.7178
[/i][i] 21
[/i][i] 9.43431
[/i][i] 31
[/i][i] -132.835
[/i][i] 12
[/i][i] 26.7934
[/i][i] 22
[/i][i] 6.41527
[/i][i] 32
[/i][i] -170.572
[/i][i] 13
[/i][i] 26.7934
[/i][i] 23
[/i][i] 6.41527
[/i][i] 33
[/i][i] -170.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.7934
[/i][i] 20
[/i][i] 6.41527
[/i][i] 30
[/i][i] -170.572
[/i][i] 11
[/i][i] 31.8877
[/i][i] 21
[/i][i] 2.83018
[/i][i] 31
[/i][i] -171.327
[/i][i] 12
[/i][i] 24.7178
[/i][i] 22
[/i][i] 9.43431
[/i][i] 32
[/i][i] -132.835
[/i][i] 13
[/i][i] 24.7178
[/i][i] 23
[/i][i] 9.43431
[/i][i] 33
[/i][i] -132.835
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.7178
[/i][i] 20
[/i][i] 9.43431
[/i][i] 30
[/i][i] -132.835
[/i][i] 11
[/i][i] 31.8877
[/i][i] 21
[/i][i] 2.83018
[/i][i] 31
[/i][i] -171.327
[/i][i] 12
[/i][i] 38.1144
[/i][i] 22
[/i][i] 2.26414
[/i][i] 32
[/i][i] -146.986
[/i][i] 13
[/i][i] 38.1144
[/i][i] 23
[/i][i] 2.26414
[/i][i] 33
[/i][i] -146.986
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.8877
[/i][i] 20
[/i][i] 2.83018
[/i][i] 30
[/i][i] -171.327
[/i][i] 11
[/i][i] 38.1144
[/i][i] 21
[/i][i] 2.26414
[/i][i] 31
[/i][i] -146.986
[/i][i] 12
[/i][i] 36.0388
[/i][i] 22
[/i][i] -6.22638
[/i][i] 32
[/i][i] -171.704
[/i][i] 13
[/i][i] 36.0388
[/i][i] 23
[/i][i] -6.22638
[/i][i] 33
[/i][i] -171.704
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.8877
[/i][i] 20
[/i][i] 2.83018
[/i][i] 30
[/i][i] -171.327
[/i][i] 11
[/i][i] 32.8312
[/i][i] 21
[/i][i] 6.79242
[/i][i] 31
[/i][i] -180.761
[/i][i] 12
[/i][i] 26.7934
[/i][i] 22
[/i][i] 6.41527
[/i][i] 32
[/i][i] -170.572
[/i][i] 13
[/i][i] 26.7934
[/i][i] 23
[/i][i] 6.41527
[/i][i] 33
[/i][i] -170.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.1144
[/i][i] 20
[/i][i] 2.26414
[/i][i] 30
[/i][i] -146.986
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -130.005
[/i][i] 12
[/i][i] 41.6995
[/i][i] 22
[/i][i] 6.22639
[/i][i] 32
[/i][i] -130.759
[/i][i] 13
[/i][i] 41.6995
[/i][i] 23
[/i][i] 6.22639
[/i][i] 33
[/i][i] -130.759
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.7178
[/i][i] 20
[/i][i] 9.43431
[/i][i] 30
[/i][i] -132.835
[/i][i] 11
[/i][i] 41.6995
[/i][i] 21
[/i][i] 6.22639
[/i][i] 31
[/i][i] -130.759
[/i][i] 12
[/i][i] 38.1144
[/i][i] 22
[/i][i] 2.26414
[/i][i] 32
[/i][i] -146.986
[/i][i] 13
[/i][i] 38.1144
[/i][i] 23
[/i][i] 2.26414
[/i][i] 33
[/i][i] -146.986
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 41.6995
[/i][i] 20
[/i][i] 6.22639
[/i][i] 30
[/i][i] -130.759
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -130.005
[/i][i] 12
[/i][i] 45.2846
[/i][i] 22
[/i][i] 9.62289
[/i][i] 32
[/i][i] -116.608
[/i][i] 13
[/i][i] 45.2846
[/i][i] 23
[/i][i] 9.62289
[/i][i] 33
[/i][i] -116.608
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.7178
[/i][i] 20
[/i][i] 9.43431
[/i][i] 30
[/i][i] -132.835
[/i][i] 11
[/i][i] 45.2846
[/i][i] 21
[/i][i] 9.62289
[/i][i] 31
[/i][i] -116.608
[/i][i] 12
[/i][i] 41.6995
[/i][i] 22
[/i][i] 6.22639
[/i][i] 32
[/i][i] -130.759
[/i][i] 13
[/i][i] 41.6995
[/i][i] 23
[/i][i] 6.22639
[/i][i] 33
[/i][i] -130.759
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.7178
[/i][i] 20
[/i][i] 9.43431
[/i][i] 30
[/i][i] -132.835
[/i][i] 11
[/i][i] 45.2846
[/i][i] 21
[/i][i] 9.62289
[/i][i] 31
[/i][i] -116.608
[/i][i] 12
[/i][i] 26.0385
[/i][i] 22
[/i][i] 14.34
[/i][i] 32
[/i][i] -116.419
[/i][i] 13
[/i][i] 26.0385
[/i][i] 23
[/i][i] 14.34
[/i][i] 33
[/i][i] -116.419
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.0385
[/i][i] 20
[/i][i] 14.34
[/i][i] 30
[/i][i] -116.419
[/i][i] 11
[/i][i] 45.2846
[/i][i] 21
[/i][i] 9.62289
[/i][i] 31
[/i][i] -116.608
[/i][i] 12
[/i][i] 44.5297
[/i][i] 22
[/i][i] 15.6607
[/i][i] 32
[/i][i] -97.7393
[/i][i] 13
[/i][i] 44.5297
[/i][i] 23
[/i][i] 15.6607
[/i][i] 33
[/i][i] -97.7393
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 44.5297
[/i][i] 20
[/i][i] 15.6607
[/i][i] 30
[/i][i] -97.7393
[/i][i] 11
[/i][i] 45.2846
[/i][i] 21
[/i][i] 9.62289
[/i][i] 31
[/i][i] -116.608
[/i][i] 12
[/i][i] 54.7189
[/i][i] 22
[/i][i] 3.01875
[/i][i] 32
[/i][i] -97.5507
[/i][i] 13
[/i][i] 54.7189
[/i][i] 23
[/i][i] 3.01875
[/i][i] 33
[/i][i] -97.5507
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 45.2846
[/i][i] 20
[/i][i] 9.62289
[/i][i] 30
[/i][i] -116.608
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] 3.01875
[/i][i] 31
[/i][i] -97.5507
[/i][i] 12
[/i][i] 53.0208
[/i][i] 22
[/i][i] -4.71686
[/i][i] 32
[/i][i] -117.174
[/i][i] 13
[/i][i] 53.0208
[/i][i] 23
[/i][i] -4.71686
[/i][i] 33
[/i][i] -117.174
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.4547
[/i][i] 20
[/i][i] -17.5477
[/i][i] 30
[/i][i] -106.796
[/i][i] 11
[/i][i] 53.0208
[/i][i] 21
[/i][i] -4.71686
[/i][i] 31
[/i][i] -117.174
[/i][i] 12
[/i][i] 54.7189
[/i][i] 22
[/i][i] 3.01875
[/i][i] 32
[/i][i] -97.5507
[/i][i] 13
[/i][i] 54.7189
[/i][i] 23
[/i][i] 3.01875
[/i][i] 33
[/i][i] -97.5507
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 45.2846
[/i][i] 20
[/i][i] 9.62289
[/i][i] 30
[/i][i] -116.608
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -130.005
[/i][i] 12
[/i][i] 53.0208
[/i][i] 22
[/i][i] -4.71686
[/i][i] 32
[/i][i] -117.174
[/i][i] 13
[/i][i] 53.0208
[/i][i] 23
[/i][i] -4.71686
[/i][i] 33
[/i][i] -117.174
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.0385
[/i][i] 20
[/i][i] 14.34
[/i][i] 30
[/i][i] -116.419
[/i][i] 11
[/i][i] 44.5297
[/i][i] 21
[/i][i] 15.6607
[/i][i] 31
[/i][i] -97.7393
[/i][i] 12
[/i][i] 26.0385
[/i][i] 22
[/i][i] 18.6797
[/i][i] 32
[/i][i] -99.0599
[/i][i] 13
[/i][i] 26.0385
[/i][i] 23
[/i][i] 18.6797
[/i][i] 33
[/i][i] -99.0599
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.0385
[/i][i] 20
[/i][i] 18.6797
[/i][i] 30
[/i][i] -99.0599
[/i][i] 11
[/i][i] 44.5297
[/i][i] 21
[/i][i] 15.6607
[/i][i] 31
[/i][i] -97.7393
[/i][i] 12
[/i][i] 38.4919
[/i][i] 22
[/i][i] 19.4346
[/i][i] 32
[/i][i] -84.1539
[/i][i] 13
[/i][i] 38.4919
[/i][i] 23
[/i][i] 19.4346
[/i][i] 33
[/i][i] -84.1539
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -14.34
[/i][i] 20
[/i][i] -11.1324
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] -6.7924
[/i][i] 21
[/i][i] 0
[/i][i] 31
[/i][i] -171.516
[/i][i] 12
[/i][i] -8.30194
[/i][i] 22
[/i][i] -13.774
[/i][i] 32
[/i][i] -164.723
[/i][i] 13
[/i][i] -8.30194
[/i][i] 23
[/i][i] -13.774
[/i][i] 33
[/i][i] -164.723
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.20761
[/i][i] 20
[/i][i] 12.4531
[/i][i] 30
[/i][i] -179.063
[/i][i] 11
[/i][i] 8.6794
[/i][i] 21
[/i][i] 10.755
[/i][i] 31
[/i][i] -180.572
[/i][i] 12
[/i][i] 8.6794
[/i][i] 22
[/i][i] 11.6985
[/i][i] 32
[/i][i] -184.346
[/i][i] 13
[/i][i] 8.6794
[/i][i] 23
[/i][i] 11.6985
[/i][i] 33
[/i][i] -184.346
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.321
[/i][i] 20
[/i][i] 8.6794
[/i][i] 30
[/i][i] -184.158
[/i][i] 11
[/i][i] -3.20761
[/i][i] 21
[/i][i] 12.4531
[/i][i] 31
[/i][i] -179.063
[/i][i] 12
[/i][i] -3.39619
[/i][i] 22
[/i][i] 13.208
[/i][i] 32
[/i][i] -184.912
[/i][i] 13
[/i][i] -3.39619
[/i][i] 23
[/i][i] 13.208
[/i][i] 33
[/i][i] -184.912
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.39619
[/i][i] 20
[/i][i] 13.208
[/i][i] 30
[/i][i] -184.912
[/i][i] 11
[/i][i] -3.20761
[/i][i] 21
[/i][i] 12.4531
[/i][i] 31
[/i][i] -179.063
[/i][i] 12
[/i][i] 8.6794
[/i][i] 22
[/i][i] 11.6985
[/i][i] 32
[/i][i] -184.346
[/i][i] 13
[/i][i] 8.6794
[/i][i] 23
[/i][i] 11.6985
[/i][i] 33
[/i][i] -184.346
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.49081
[/i][i] 20
[/i][i] 24.7178
[/i][i] 30
[/i][i] -37.1709
[/i][i] 11
[/i][i] 16.0381
[/i][i] 21
[/i][i] 20.5667
[/i][i] 31
[/i][i] -47.9261
[/i][i] 12
[/i][i] 16.0381
[/i][i] 22
[/i][i] 24.529
[/i][i] 32
[/i][i] -19.0572
[/i][i] 13
[/i][i] 16.0381
[/i][i] 23
[/i][i] 24.529
[/i][i] 33
[/i][i] -19.0572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.0381
[/i][i] 20
[/i][i] 20.5667
[/i][i] 30
[/i][i] -47.9261
[/i][i] 11
[/i][i] 29.2461
[/i][i] 21
[/i][i] 14.1512
[/i][i] 31
[/i][i] -23.2083
[/i][i] 12
[/i][i] 34.9068
[/i][i] 22
[/i][i] 13.0191
[/i][i] 32
[/i][i] -34.9068
[/i][i] 13
[/i][i] 34.9068
[/i][i] 23
[/i][i] 13.0191
[/i][i] 33
[/i][i] -34.9068
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.0381
[/i][i] 20
[/i][i] 20.5667
[/i][i] 30
[/i][i] -47.9261
[/i][i] 11
[/i][i] 34.9068
[/i][i] 21
[/i][i] 13.0191
[/i][i] 31
[/i][i] -34.9068
[/i][i] 12
[/i][i] 40.19
[/i][i] 22
[/i][i] 12.2645
[/i][i] 32
[/i][i] -45.4731
[/i][i] 13
[/i][i] 40.19
[/i][i] 23
[/i][i] 12.2645
[/i][i] 33
[/i][i] -45.4731
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.0381
[/i][i] 20
[/i][i] 20.5667
[/i][i] 30
[/i][i] -47.9261
[/i][i] 11
[/i][i] 22.2648
[/i][i] 21
[/i][i] 19.4346
[/i][i] 31
[/i][i] -57.3605
[/i][i] 12
[/i][i] 40.19
[/i][i] 22
[/i][i] 12.2645
[/i][i] 32
[/i][i] -45.4731
[/i][i] 13
[/i][i] 40.19
[/i][i] 23
[/i][i] 12.2645
[/i][i] 33
[/i][i] -45.4731
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 22.2648
[/i][i] 20
[/i][i] 19.4346
[/i][i] 30
[/i][i] -57.3605
[/i][i] 11
[/i][i] 40.19
[/i][i] 21
[/i][i] 12.2645
[/i][i] 31
[/i][i] -45.4731
[/i][i] 12
[/i][i] 45.4731
[/i][i] 22
[/i][i] 10.9435
[/i][i] 32
[/i][i] -54.7189
[/i][i] 13
[/i][i] 45.4731
[/i][i] 23
[/i][i] 10.9435
[/i][i] 33
[/i][i] -54.7189
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 22.2648
[/i][i] 20
[/i][i] 19.4346
[/i][i] 30
[/i][i] -57.3605
[/i][i] 11
[/i][i] 45.4731
[/i][i] 21
[/i][i] 10.9435
[/i][i] 31
[/i][i] -54.7189
[/i][i] 12
[/i][i] 29.8122
[/i][i] 22
[/i][i] 20.0007
[/i][i] 32
[/i][i] -68.6817
[/i][i] 13
[/i][i] 29.8122
[/i][i] 23
[/i][i] 20.0007
[/i][i] 33
[/i][i] -68.6817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.8122
[/i][i] 20
[/i][i] 20.0007
[/i][i] 30
[/i][i] -68.6817
[/i][i] 11
[/i][i] 51.6998
[/i][i] 21
[/i][i] 9.05685
[/i][i] 31
[/i][i] -69.4364
[/i][i] 12
[/i][i] 45.4731
[/i][i] 22
[/i][i] 10.9435
[/i][i] 32
[/i][i] -54.7189
[/i][i] 13
[/i][i] 45.4731
[/i][i] 23
[/i][i] 10.9435
[/i][i] 33
[/i][i] -54.7189
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.8122
[/i][i] 20
[/i][i] 20.0007
[/i][i] 30
[/i][i] -68.6817
[/i][i] 11
[/i][i] 38.4919
[/i][i] 21
[/i][i] 19.4346
[/i][i] 31
[/i][i] -84.1539
[/i][i] 12
[/i][i] 51.6998
[/i][i] 22
[/i][i] 9.05685
[/i][i] 32
[/i][i] -69.4364
[/i][i] 13
[/i][i] 51.6998
[/i][i] 23
[/i][i] 9.05685
[/i][i] 33
[/i][i] -69.4364
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.4919
[/i][i] 20
[/i][i] 19.4346
[/i][i] 30
[/i][i] -84.1539
[/i][i] 11
[/i][i] 51.6998
[/i][i] 21
[/i][i] 9.05685
[/i][i] 31
[/i][i] -69.4364
[/i][i] 12
[/i][i] 53.3979
[/i][i] 22
[/i][i] 6.79242
[/i][i] 32
[/i][i] -80.1913
[/i][i] 13
[/i][i] 53.3979
[/i][i] 23
[/i][i] 6.79242
[/i][i] 33
[/i][i] -80.1913
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.4919
[/i][i] 20
[/i][i] 19.4346
[/i][i] 30
[/i][i] -84.1539
[/i][i] 11
[/i][i] 53.3979
[/i][i] 21
[/i][i] 6.79242
[/i][i] 31
[/i][i] -80.1913
[/i][i] 12
[/i][i] 44.5297
[/i][i] 22
[/i][i] 15.6607
[/i][i] 32
[/i][i] -97.7393
[/i][i] 13
[/i][i] 44.5297
[/i][i] 23
[/i][i] 15.6607
[/i][i] 33
[/i][i] -97.7393
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 44.5297
[/i][i] 20
[/i][i] 15.6607
[/i][i] 30
[/i][i] -97.7393
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] 3.01875
[/i][i] 31
[/i][i] -97.5507
[/i][i] 12
[/i][i] 53.3979
[/i][i] 22
[/i][i] 6.79242
[/i][i] 32
[/i][i] -80.1913
[/i][i] 13
[/i][i] 53.3979
[/i][i] 23
[/i][i] 6.79242
[/i][i] 33
[/i][i] -80.1913
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 47.9262
[/i][i] 20
[/i][i] -20.9439
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] 52.4547
[/i][i] 21
[/i][i] -17.5477
[/i][i] 31
[/i][i] -106.796
[/i][i] 12
[/i][i] 53.0208
[/i][i] 22
[/i][i] -4.71686
[/i][i] 32
[/i][i] -117.174
[/i][i] 13
[/i][i] 53.0208
[/i][i] 23
[/i][i] -4.71686
[/i][i] 33
[/i][i] -117.174
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 49.6243
[/i][i] 20
[/i][i] -7.7359
[/i][i] 30
[/i][i] -130.005
[/i][i] 11
[/i][i] 53.0208
[/i][i] 21
[/i][i] -4.71686
[/i][i] 31
[/i][i] -117.174
[/i][i] 12
[/i][i] 47.9262
[/i][i] 22
[/i][i] -20.9439
[/i][i] 32
[/i][i] -118.872
[/i][i] 13
[/i][i] 47.9262
[/i][i] 23
[/i][i] -20.9439
[/i][i] 33
[/i][i] -118.872
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 47.9262
[/i][i] 20
[/i][i] -20.9439
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -130.005
[/i][i] 12
[/i][i] 38.6804
[/i][i] 22
[/i][i] -17.7362
[/i][i] 32
[/i][i] -140.382
[/i][i] 13
[/i][i] 38.6804
[/i][i] 23
[/i][i] -17.7362
[/i][i] 33
[/i][i] -140.382
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 1.13206
[/i][i] 20
[/i][i] -33.5861
[/i][i] 30
[/i][i] -56.983
[/i][i] 11
[/i][i] 2.6416
[/i][i] 21
[/i][i] -29.6236
[/i][i] 31
[/i][i] -50.9452
[/i][i] 12
[/i][i] 14.34
[/i][i] 22
[/i][i] -37.9258
[/i][i] 32
[/i][i] -47.9261
[/i][i] 13
[/i][i] 14.34
[/i][i] 23
[/i][i] -37.9258
[/i][i] 33
[/i][i] -47.9261
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 2.6416
[/i][i] 20
[/i][i] -29.6236
[/i][i] 30
[/i][i] -50.9452
[/i][i] 11
[/i][i] 14.34
[/i][i] 21
[/i][i] -37.9258
[/i][i] 31
[/i][i] -47.9261
[/i][i] 12
[/i][i] 13.3966
[/i][i] 22
[/i][i] -32.8312
[/i][i] 32
[/i][i] -42.2655
[/i][i] 13
[/i][i] 13.3966
[/i][i] 23
[/i][i] -32.8312
[/i][i] 33
[/i][i] -42.2655
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 13.3966
[/i][i] 20
[/i][i] -32.8312
[/i][i] 30
[/i][i] -42.2655
[/i][i] 11
[/i][i] 23.2083
[/i][i] 21
[/i][i] -30.001
[/i][i] 31
[/i][i] -36.4163
[/i][i] 12
[/i][i] 14.34
[/i][i] 22
[/i][i] -37.9258
[/i][i] 32
[/i][i] -47.9261
[/i][i] 13
[/i][i] 14.34
[/i][i] 23
[/i][i] -37.9258
[/i][i] 33
[/i][i] -47.9261
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 14.34
[/i][i] 20
[/i][i] -37.9258
[/i][i] 30
[/i][i] -47.9261
[/i][i] 11
[/i][i] 23.2083
[/i][i] 21
[/i][i] -30.001
[/i][i] 31
[/i][i] -36.4163
[/i][i] 12
[/i][i] 24.529
[/i][i] 22
[/i][i] -35.6617
[/i][i] 32
[/i][i] -43.0204
[/i][i] 13
[/i][i] 24.529
[/i][i] 23
[/i][i] -35.6617
[/i][i] 33
[/i][i] -43.0204
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 1.13206
[/i][i] 20
[/i][i] -33.5861
[/i][i] 30
[/i][i] -56.983
[/i][i] 11
[/i][i] 14.34
[/i][i] 21
[/i][i] -37.9258
[/i][i] 31
[/i][i] -47.9261
[/i][i] 12
[/i][i] -3.96223
[/i][i] 22
[/i][i] -45.096
[/i][i] 32
[/i][i] -72.4554
[/i][i] 13
[/i][i] -3.96223
[/i][i] 23
[/i][i] -45.096
[/i][i] 33
[/i][i] -72.4554
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.96223
[/i][i] 20
[/i][i] -45.096
[/i][i] 30
[/i][i] -72.4554
[/i][i] 11
[/i][i] 14.34
[/i][i] 21
[/i][i] -37.9258
[/i][i] 31
[/i][i] -47.9261
[/i][i] 12
[/i][i] 13.208
[/i][i] 22
[/i][i] -50.5677
[/i][i] 32
[/i][i] -56.417
[/i][i] 13
[/i][i] 13.208
[/i][i] 23
[/i][i] -50.5677
[/i][i] 33
[/i][i] -56.417
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 13.208
[/i][i] 20
[/i][i] -50.5677
[/i][i] 30
[/i][i] -56.417
[/i][i] 11
[/i][i] 14.34
[/i][i] 21
[/i][i] -37.9258
[/i][i] 31
[/i][i] -47.9261
[/i][i] 12
[/i][i] 24.529
[/i][i] 22
[/i][i] -35.6617
[/i][i] 32
[/i][i] -43.0204
[/i][i] 13
[/i][i] 24.529
[/i][i] 23
[/i][i] -35.6617
[/i][i] 33
[/i][i] -43.0204
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.529
[/i][i] 20
[/i][i] -35.6617
[/i][i] 30
[/i][i] -43.0204
[/i][i] 11
[/i][i] 24.9064
[/i][i] 21
[/i][i] -51.3224
[/i][i] 31
[/i][i] -53.3979
[/i][i] 12
[/i][i] 13.208
[/i][i] 22
[/i][i] -50.5677
[/i][i] 32
[/i][i] -56.417
[/i][i] 13
[/i][i] 13.208
[/i][i] 23
[/i][i] -50.5677
[/i][i] 33
[/i][i] -56.417
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 11.1324
[/i][i] 20
[/i][i] -64.1532
[/i][i] 30
[/i][i] -66.0401
[/i][i] 11
[/i][i] 13.208
[/i][i] 21
[/i][i] -50.5677
[/i][i] 31
[/i][i] -56.417
[/i][i] 12
[/i][i] -8.67938
[/i][i] 22
[/i][i] -55.8509
[/i][i] 32
[/i][i] -89.8145
[/i][i] 13
[/i][i] -8.67938
[/i][i] 23
[/i][i] -55.8509
[/i][i] 33
[/i][i] -89.8145
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -8.67938
[/i][i] 20
[/i][i] -55.8509
[/i][i] 30
[/i][i] -89.8145
[/i][i] 11
[/i][i] -3.96223
[/i][i] 21
[/i][i] -45.096
[/i][i] 31
[/i][i] -72.4554
[/i][i] 12
[/i][i] 13.208
[/i][i] 22
[/i][i] -50.5677
[/i][i] 32
[/i][i] -56.417
[/i][i] 13
[/i][i] 13.208
[/i][i] 23
[/i][i] -50.5677
[/i][i] 33
[/i][i] -56.417
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -8.86797
[/i][i] 20
[/i][i] -46.228
[/i][i] 30
[/i][i] -83.0218
[/i][i] 11
[/i][i] -8.67938
[/i][i] 21
[/i][i] -55.8509
[/i][i] 31
[/i][i] -89.8145
[/i][i] 12
[/i][i] -3.96223
[/i][i] 22
[/i][i] -45.096
[/i][i] 32
[/i][i] -72.4554
[/i][i] 13
[/i][i] -3.96223
[/i][i] 23
[/i][i] -45.096
[/i][i] 33
[/i][i] -72.4554
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.0381
[/i][i] 20
[/i][i] -52.6433
[/i][i] 30
[/i][i] -109.061
[/i][i] 11
[/i][i] -14.5286
[/i][i] 21
[/i][i] -60.002
[/i][i] 31
[/i][i] -108.872
[/i][i] 12
[/i][i] -8.67938
[/i][i] 22
[/i][i] -55.8509
[/i][i] 32
[/i][i] -89.8145
[/i][i] 13
[/i][i] -8.67938
[/i][i] 23
[/i][i] -55.8509
[/i][i] 33
[/i][i] -89.8145
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.0381
[/i][i] 20
[/i][i] -52.6433
[/i][i] 30
[/i][i] -109.061
[/i][i] 11
[/i][i] -8.67938
[/i][i] 21
[/i][i] -55.8509
[/i][i] 31
[/i][i] -89.8145
[/i][i] 12
[/i][i] -16.0381
[/i][i] 22
[/i][i] -46.228
[/i][i] 32
[/i][i] -111.136
[/i][i] 13
[/i][i] -16.0381
[/i][i] 23
[/i][i] -46.228
[/i][i] 33
[/i][i] -111.136
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.0381
[/i][i] 20
[/i][i] -46.228
[/i][i] 30
[/i][i] -111.136
[/i][i] 11
[/i][i] -8.86797
[/i][i] 21
[/i][i] -46.228
[/i][i] 31
[/i][i] -83.0218
[/i][i] 12
[/i][i] -8.67938
[/i][i] 22
[/i][i] -55.8509
[/i][i] 32
[/i][i] -89.8145
[/i][i] 13
[/i][i] -8.67938
[/i][i] 23
[/i][i] -55.8509
[/i][i] 33
[/i][i] -89.8145
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.0381
[/i][i] 20
[/i][i] -46.228
[/i][i] 30
[/i][i] -111.136
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -36.2277
[/i][i] 31
[/i][i] -91.7012
[/i][i] 12
[/i][i] -8.86797
[/i][i] 22
[/i][i] -46.228
[/i][i] 32
[/i][i] -83.0218
[/i][i] 13
[/i][i] -8.86797
[/i][i] 23
[/i][i] -46.228
[/i][i] 33
[/i][i] -83.0218
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.0381
[/i][i] 20
[/i][i] -46.228
[/i][i] 30
[/i][i] -111.136
[/i][i] 11
[/i][i] -15.2835
[/i][i] 21
[/i][i] -40.9449
[/i][i] 31
[/i][i] -116.419
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -36.2277
[/i][i] 32
[/i][i] -91.7012
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -36.2277
[/i][i] 33
[/i][i] -91.7012
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -13.5851
[/i][i] 20
[/i][i] -37.3598
[/i][i] 30
[/i][i] -123.023
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -36.2277
[/i][i] 31
[/i][i] -91.7012
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -31.3217
[/i][i] 32
[/i][i] -97.7393
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -31.3217
[/i][i] 33
[/i][i] -97.7393
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -13.5851
[/i][i] 20
[/i][i] -37.3598
[/i][i] 30
[/i][i] -123.023
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -31.3217
[/i][i] 31
[/i][i] -97.7393
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -103.966
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -103.966
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.2835
[/i][i] 20
[/i][i] -40.9449
[/i][i] 30
[/i][i] -116.419
[/i][i] 11
[/i][i] -13.5851
[/i][i] 21
[/i][i] -37.3598
[/i][i] 31
[/i][i] -123.023
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -36.2277
[/i][i] 32
[/i][i] -91.7012
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -36.2277
[/i][i] 33
[/i][i] -91.7012
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -13.5851
[/i][i] 20
[/i][i] -37.3598
[/i][i] 30
[/i][i] -123.023
[/i][i] 11
[/i][i] -2.26413
[/i][i] 21
[/i][i] -22.8309
[/i][i] 31
[/i][i] -159.817
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -103.966
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -103.966
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -9.05684
[/i][i] 20
[/i][i] -9.4343
[/i][i] 30
[/i][i] -172.836
[/i][i] 11
[/i][i] -6.22638
[/i][i] 21
[/i][i] -11.6984
[/i][i] 31
[/i][i] -184.535
[/i][i] 12
[/i][i] -15.8495
[/i][i] 22
[/i][i] -13.3965
[/i][i] 32
[/i][i] -171.893
[/i][i] 13
[/i][i] -15.8495
[/i][i] 23
[/i][i] -13.3965
[/i][i] 33
[/i][i] -171.893
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.3023
[/i][i] 20
[/i][i] -15.0947
[/i][i] 30
[/i][i] -178.686
[/i][i] 11
[/i][i] -12.8305
[/i][i] 21
[/i][i] -17.7362
[/i][i] 31
[/i][i] -186.422
[/i][i] 12
[/i][i] -6.22638
[/i][i] 22
[/i][i] -11.6984
[/i][i] 32
[/i][i] -184.535
[/i][i] 13
[/i][i] -6.22638
[/i][i] 23
[/i][i] -11.6984
[/i][i] 33
[/i][i] -184.535
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.3023
[/i][i] 20
[/i][i] -15.0947
[/i][i] 30
[/i][i] -178.686
[/i][i] 11
[/i][i] -17.3591
[/i][i] 21
[/i][i] -25.095
[/i][i] 31
[/i][i] -185.29
[/i][i] 12
[/i][i] -12.8305
[/i][i] 22
[/i][i] -17.7362
[/i][i] 32
[/i][i] -186.422
[/i][i] 13
[/i][i] -12.8305
[/i][i] 23
[/i][i] -17.7362
[/i][i] 33
[/i][i] -186.422
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.3023
[/i][i] 20
[/i][i] -15.0947
[/i][i] 30
[/i][i] -178.686
[/i][i] 11
[/i][i] -15.8495
[/i][i] 21
[/i][i] -13.3965
[/i][i] 31
[/i][i] -171.893
[/i][i] 12
[/i][i] -20.5667
[/i][i] 22
[/i][i] -25.095
[/i][i] 32
[/i][i] -176.987
[/i][i] 13
[/i][i] -20.5667
[/i][i] 23
[/i][i] -25.095
[/i][i] 33
[/i][i] -176.987
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.321
[/i][i] 20
[/i][i] 8.6794
[/i][i] 30
[/i][i] -184.158
[/i][i] 11
[/i][i] -9.05684
[/i][i] 21
[/i][i] -9.4343
[/i][i] 31
[/i][i] -172.836
[/i][i] 12
[/i][i] -10.7549
[/i][i] 22
[/i][i] 7.73592
[/i][i] 32
[/i][i] -179.629
[/i][i] 13
[/i][i] -10.7549
[/i][i] 23
[/i][i] 7.73592
[/i][i] 33
[/i][i] -179.629
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.8495
[/i][i] 20
[/i][i] -13.3965
[/i][i] 30
[/i][i] -171.893
[/i][i] 11
[/i][i] -8.30194
[/i][i] 21
[/i][i] -13.774
[/i][i] 31
[/i][i] -164.723
[/i][i] 12
[/i][i] -2.26413
[/i][i] 22
[/i][i] -22.8309
[/i][i] 32
[/i][i] -159.817
[/i][i] 13
[/i][i] -2.26413
[/i][i] 23
[/i][i] -22.8309
[/i][i] 33
[/i][i] -159.817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.3023
[/i][i] 20
[/i][i] -15.0947
[/i][i] 30
[/i][i] -178.686
[/i][i] 11
[/i][i] -6.22638
[/i][i] 21
[/i][i] -11.6984
[/i][i] 31
[/i][i] -184.535
[/i][i] 12
[/i][i] -15.8495
[/i][i] 22
[/i][i] -13.3965
[/i][i] 32
[/i][i] -171.893
[/i][i] 13
[/i][i] -15.8495
[/i][i] 23
[/i][i] -13.3965
[/i][i] 33
[/i][i] -171.893
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -24.3404
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -115.098
[/i][i] 11
[/i][i] -14.5286
[/i][i] 21
[/i][i] -60.002
[/i][i] 31
[/i][i] -108.872
[/i][i] 12
[/i][i] -16.0381
[/i][i] 22
[/i][i] -52.6433
[/i][i] 32
[/i][i] -109.061
[/i][i] 13
[/i][i] -16.0381
[/i][i] 23
[/i][i] -52.6433
[/i][i] 33
[/i][i] -109.061
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -24.3404
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -115.098
[/i][i] 11
[/i][i] -16.0381
[/i][i] 21
[/i][i] -52.6433
[/i][i] 31
[/i][i] -109.061
[/i][i] 12
[/i][i] -16.0381
[/i][i] 22
[/i][i] -46.228
[/i][i] 32
[/i][i] -111.136
[/i][i] 13
[/i][i] -16.0381
[/i][i] 23
[/i][i] -46.228
[/i][i] 33
[/i][i] -111.136
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -24.3404
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -115.098
[/i][i] 11
[/i][i] -16.0381
[/i][i] 21
[/i][i] -46.228
[/i][i] 31
[/i][i] -111.136
[/i][i] 12
[/i][i] -23.0194
[/i][i] 22
[/i][i] -41.322
[/i][i] 32
[/i][i] -125.288
[/i][i] 13
[/i][i] -23.0194
[/i][i] 23
[/i][i] -41.322
[/i][i] 33
[/i][i] -125.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -23.0194
[/i][i] 20
[/i][i] -41.322
[/i][i] 30
[/i][i] -125.288
[/i][i] 11
[/i][i] -15.2835
[/i][i] 21
[/i][i] -40.9449
[/i][i] 31
[/i][i] -116.419
[/i][i] 12
[/i][i] -16.0381
[/i][i] 22
[/i][i] -46.228
[/i][i] 32
[/i][i] -111.136
[/i][i] 13
[/i][i] -16.0381
[/i][i] 23
[/i][i] -46.228
[/i][i] 33
[/i][i] -111.136
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -23.0194
[/i][i] 20
[/i][i] -41.322
[/i][i] 30
[/i][i] -125.288
[/i][i] 11
[/i][i] -13.5851
[/i][i] 21
[/i][i] -37.3598
[/i][i] 31
[/i][i] -123.023
[/i][i] 12
[/i][i] -15.2835
[/i][i] 22
[/i][i] -40.9449
[/i][i] 32
[/i][i] -116.419
[/i][i] 13
[/i][i] -15.2835
[/i][i] 23
[/i][i] -40.9449
[/i][i] 33
[/i][i] -116.419
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -23.0194
[/i][i] 20
[/i][i] -41.322
[/i][i] 30
[/i][i] -125.288
[/i][i] 11
[/i][i] -13.5851
[/i][i] 21
[/i][i] -37.3598
[/i][i] 31
[/i][i] -123.023
[/i][i] 12
[/i][i] -19.2458
[/i][i] 22
[/i][i] -38.8693
[/i][i] 32
[/i][i] -143.213
[/i][i] 13
[/i][i] -19.2458
[/i][i] 23
[/i][i] -38.8693
[/i][i] 33
[/i][i] -143.213
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -19.2458
[/i][i] 20
[/i][i] -38.8693
[/i][i] 30
[/i][i] -143.213
[/i][i] 11
[/i][i] -10.1889
[/i][i] 21
[/i][i] -35.4728
[/i][i] 31
[/i][i] -145.099
[/i][i] 12
[/i][i] -13.5851
[/i][i] 22
[/i][i] -37.3598
[/i][i] 32
[/i][i] -123.023
[/i][i] 13
[/i][i] -13.5851
[/i][i] 23
[/i][i] -37.3598
[/i][i] 33
[/i][i] -123.023
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -13.5851
[/i][i] 20
[/i][i] -37.3598
[/i][i] 30
[/i][i] -123.023
[/i][i] 11
[/i][i] -10.1889
[/i][i] 21
[/i][i] -35.4728
[/i][i] 31
[/i][i] -145.099
[/i][i] 12
[/i][i] -2.26413
[/i][i] 22
[/i][i] -22.8309
[/i][i] 32
[/i][i] -159.817
[/i][i] 13
[/i][i] -2.26413
[/i][i] 23
[/i][i] -22.8309
[/i][i] 33
[/i][i] -159.817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -10.1889
[/i][i] 20
[/i][i] -35.4728
[/i][i] 30
[/i][i] -145.099
[/i][i] 11
[/i][i] -2.26413
[/i][i] 21
[/i][i] -22.8309
[/i][i] 31
[/i][i] -159.817
[/i][i] 12
[/i][i] -8.67938
[/i][i] 22
[/i][i] -36.6049
[/i][i] 32
[/i][i] -162.836
[/i][i] 13
[/i][i] -8.67938
[/i][i] 23
[/i][i] -36.6049
[/i][i] 33
[/i][i] -162.836
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -10.1889
[/i][i] 20
[/i][i] -35.4728
[/i][i] 30
[/i][i] -145.099
[/i][i] 11
[/i][i] -8.67938
[/i][i] 21
[/i][i] -36.6049
[/i][i] 31
[/i][i] -162.836
[/i][i] 12
[/i][i] -19.2458
[/i][i] 22
[/i][i] -38.8693
[/i][i] 32
[/i][i] -143.213
[/i][i] 13
[/i][i] -19.2458
[/i][i] 23
[/i][i] -38.8693
[/i][i] 33
[/i][i] -143.213
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -19.2458
[/i][i] 20
[/i][i] -38.8693
[/i][i] 30
[/i][i] -143.213
[/i][i] 11
[/i][i] -18.6797
[/i][i] 21
[/i][i] -42.8315
[/i][i] 31
[/i][i] -164.345
[/i][i] 12
[/i][i] -8.67938
[/i][i] 22
[/i][i] -36.6049
[/i][i] 32
[/i][i] -162.836
[/i][i] 13
[/i][i] -8.67938
[/i][i] 23
[/i][i] -36.6049
[/i][i] 33
[/i][i] -162.836
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.9439
[/i][i] 20
[/i][i] -29.435
[/i][i] 30
[/i][i] -170.006
[/i][i] 11
[/i][i] -8.67938
[/i][i] 21
[/i][i] -36.6049
[/i][i] 31
[/i][i] -162.836
[/i][i] 12
[/i][i] -16.793
[/i][i] 22
[/i][i] -22.4534
[/i][i] 32
[/i][i] -170.006
[/i][i] 13
[/i][i] -16.793
[/i][i] 23
[/i][i] -22.4534
[/i][i] 33
[/i][i] -170.006
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -16.793
[/i][i] 20
[/i][i] -22.4534
[/i][i] 30
[/i][i] -170.006
[/i][i] 11
[/i][i] -15.8495
[/i][i] 21
[/i][i] -13.3965
[/i][i] 31
[/i][i] -171.893
[/i][i] 12
[/i][i] -8.67938
[/i][i] 22
[/i][i] -36.6049
[/i][i] 32
[/i][i] -162.836
[/i][i] 13
[/i][i] -8.67938
[/i][i] 23
[/i][i] -36.6049
[/i][i] 33
[/i][i] -162.836
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.8495
[/i][i] 20
[/i][i] -13.3965
[/i][i] 30
[/i][i] -171.893
[/i][i] 11
[/i][i] -8.67938
[/i][i] 21
[/i][i] -36.6049
[/i][i] 31
[/i][i] -162.836
[/i][i] 12
[/i][i] -2.26413
[/i][i] 22
[/i][i] -22.8309
[/i][i] 32
[/i][i] -159.817
[/i][i] 13
[/i][i] -2.26413
[/i][i] 23
[/i][i] -22.8309
[/i][i] 33
[/i][i] -159.817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.5667
[/i][i] 20
[/i][i] -25.095
[/i][i] 30
[/i][i] -176.987
[/i][i] 11
[/i][i] -16.793
[/i][i] 21
[/i][i] -22.4534
[/i][i] 31
[/i][i] -170.006
[/i][i] 12
[/i][i] -15.8495
[/i][i] 22
[/i][i] -13.3965
[/i][i] 32
[/i][i] -171.893
[/i][i] 13
[/i][i] -15.8495
[/i][i] 23
[/i][i] -13.3965
[/i][i] 33
[/i][i] -171.893
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.9439
[/i][i] 20
[/i][i] -29.435
[/i][i] 30
[/i][i] -170.006
[/i][i] 11
[/i][i] -16.793
[/i][i] 21
[/i][i] -22.4534
[/i][i] 31
[/i][i] -170.006
[/i][i] 12
[/i][i] -20.5667
[/i][i] 22
[/i][i] -25.095
[/i][i] 32
[/i][i] -176.987
[/i][i] 13
[/i][i] -20.5667
[/i][i] 23
[/i][i] -25.095
[/i][i] 33
[/i][i] -176.987
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.9439
[/i][i] 20
[/i][i] -29.435
[/i][i] 30
[/i][i] -170.006
[/i][i] 11
[/i][i] -20.5667
[/i][i] 21
[/i][i] -25.095
[/i][i] 31
[/i][i] -176.987
[/i][i] 12
[/i][i] -28.4915
[/i][i] 22
[/i][i] -34.1521
[/i][i] 32
[/i][i] -178.308
[/i][i] 13
[/i][i] -28.4915
[/i][i] 23
[/i][i] -34.1521
[/i][i] 33
[/i][i] -178.308
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -28.4915
[/i][i] 20
[/i][i] -34.1521
[/i][i] 30
[/i][i] -178.308
[/i][i] 11
[/i][i] -20.9439
[/i][i] 21
[/i][i] -29.435
[/i][i] 31
[/i][i] -170.006
[/i][i] 12
[/i][i] -27.3594
[/i][i] 22
[/i][i] -35.4728
[/i][i] 32
[/i][i] -171.327
[/i][i] 13
[/i][i] -27.3594
[/i][i] 23
[/i][i] -35.4728
[/i][i] 33
[/i][i] -171.327
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -35.2842
[/i][i] 20
[/i][i] -45.2845
[/i][i] 30
[/i][i] -172.459
[/i][i] 11
[/i][i] -27.3594
[/i][i] 21
[/i][i] -35.4728
[/i][i] 31
[/i][i] -171.327
[/i][i] 12
[/i][i] -28.4915
[/i][i] 22
[/i][i] -34.1521
[/i][i] 32
[/i][i] -178.308
[/i][i] 13
[/i][i] -28.4915
[/i][i] 23
[/i][i] -34.1521
[/i][i] 33
[/i][i] -178.308
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -35.2842
[/i][i] 20
[/i][i] -45.2845
[/i][i] 30
[/i][i] -172.459
[/i][i] 11
[/i][i] -28.4915
[/i][i] 21
[/i][i] -34.1521
[/i][i] 31
[/i][i] -178.308
[/i][i] 12
[/i][i] -35.8502
[/i][i] 22
[/i][i] -42.643
[/i][i] 32
[/i][i] -179.44
[/i][i] 13
[/i][i] -35.8502
[/i][i] 23
[/i][i] -42.643
[/i][i] 33
[/i][i] -179.44
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -35.8502
[/i][i] 20
[/i][i] -42.643
[/i][i] 30
[/i][i] -179.44
[/i][i] 11
[/i][i] -31.5105
[/i][i] 21
[/i][i] -42.4541
[/i][i] 31
[/i][i] -185.667
[/i][i] 12
[/i][i] -28.4915
[/i][i] 22
[/i][i] -34.1521
[/i][i] 32
[/i][i] -178.308
[/i][i] 13
[/i][i] -28.4915
[/i][i] 23
[/i][i] -34.1521
[/i][i] 33
[/i][i] -178.308
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -31.5105
[/i][i] 20
[/i][i] -42.4541
[/i][i] 30
[/i][i] -185.667
[/i][i] 11
[/i][i] -28.4915
[/i][i] 21
[/i][i] -34.1521
[/i][i] 31
[/i][i] -178.308
[/i][i] 12
[/i][i] -23.2083
[/i][i] 22
[/i][i] -33.2086
[/i][i] 32
[/i][i] -185.29
[/i][i] 13
[/i][i] -23.2083
[/i][i] 23
[/i][i] -33.2086
[/i][i] 33
[/i][i] -185.29
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -23.2083
[/i][i] 20
[/i][i] -33.2086
[/i][i] 30
[/i][i] -185.29
[/i][i] 11
[/i][i] -20.5667
[/i][i] 21
[/i][i] -25.095
[/i][i] 31
[/i][i] -176.987
[/i][i] 12
[/i][i] -28.4915
[/i][i] 22
[/i][i] -34.1521
[/i][i] 32
[/i][i] -178.308
[/i][i] 13
[/i][i] -28.4915
[/i][i] 23
[/i][i] -34.1521
[/i][i] 33
[/i][i] -178.308
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.5667
[/i][i] 20
[/i][i] -25.095
[/i][i] 30
[/i][i] -176.987
[/i][i] 11
[/i][i] -17.3591
[/i][i] 21
[/i][i] -25.095
[/i][i] 31
[/i][i] -185.29
[/i][i] 12
[/i][i] -18.3023
[/i][i] 22
[/i][i] -15.0947
[/i][i] 32
[/i][i] -178.686
[/i][i] 13
[/i][i] -18.3023
[/i][i] 23
[/i][i] -15.0947
[/i][i] 33
[/i][i] -178.686
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -23.2083
[/i][i] 20
[/i][i] -33.2086
[/i][i] 30
[/i][i] -185.29
[/i][i] 11
[/i][i] -20.5667
[/i][i] 21
[/i][i] -25.095
[/i][i] 31
[/i][i] -176.987
[/i][i] 12
[/i][i] -17.3591
[/i][i] 22
[/i][i] -25.095
[/i][i] 32
[/i][i] -185.29
[/i][i] 13
[/i][i] -17.3591
[/i][i] 23
[/i][i] -25.095
[/i][i] 33
[/i][i] -185.29
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -18.6797
[/i][i] 20
[/i][i] -42.8315
[/i][i] 30
[/i][i] -164.345
[/i][i] 11
[/i][i] -8.67938
[/i][i] 21
[/i][i] -36.6049
[/i][i] 31
[/i][i] -162.836
[/i][i] 12
[/i][i] -20.9439
[/i][i] 22
[/i][i] -29.435
[/i][i] 32
[/i][i] -170.006
[/i][i] 13
[/i][i] -20.9439
[/i][i] 23
[/i][i] -29.435
[/i][i] 33
[/i][i] -170.006
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.9439
[/i][i] 20
[/i][i] -29.435
[/i][i] 30
[/i][i] -170.006
[/i][i] 11
[/i][i] -18.6797
[/i][i] 21
[/i][i] -42.8315
[/i][i] 31
[/i][i] -164.345
[/i][i] 12
[/i][i] -27.3594
[/i][i] 22
[/i][i] -35.4728
[/i][i] 32
[/i][i] -171.327
[/i][i] 13
[/i][i] -27.3594
[/i][i] 23
[/i][i] -35.4728
[/i][i] 33
[/i][i] -171.327
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -27.3594
[/i][i] 20
[/i][i] -35.4728
[/i][i] 30
[/i][i] -171.327
[/i][i] 11
[/i][i] -18.6797
[/i][i] 21
[/i][i] -42.8315
[/i][i] 31
[/i][i] -164.345
[/i][i] 12
[/i][i] -35.2842
[/i][i] 22
[/i][i] -45.2845
[/i][i] 32
[/i][i] -172.459
[/i][i] 13
[/i][i] -35.2842
[/i][i] 23
[/i][i] -45.2845
[/i][i] 33
[/i][i] -172.459
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -35.2842
[/i][i] 20
[/i][i] -45.2845
[/i][i] 30
[/i][i] -172.459
[/i][i] 11
[/i][i] -18.6797
[/i][i] 21
[/i][i] -42.8315
[/i][i] 31
[/i][i] -164.345
[/i][i] 12
[/i][i] -29.8121
[/i][i] 22
[/i][i] -56.983
[/i][i] 32
[/i][i] -167.176
[/i][i] 13
[/i][i] -29.8121
[/i][i] 23
[/i][i] -56.983
[/i][i] 33
[/i][i] -167.176
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -39.0579
[/i][i] 20
[/i][i] -53.7754
[/i][i] 30
[/i][i] -173.968
[/i][i] 11
[/i][i] -29.8121
[/i][i] 21
[/i][i] -56.983
[/i][i] 31
[/i][i] -167.176
[/i][i] 12
[/i][i] -35.2842
[/i][i] 22
[/i][i] -45.2845
[/i][i] 32
[/i][i] -172.459
[/i][i] 13
[/i][i] -35.2842
[/i][i] 23
[/i][i] -45.2845
[/i][i] 33
[/i][i] -172.459
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -19.2458
[/i][i] 20
[/i][i] -38.8693
[/i][i] 30
[/i][i] -143.213
[/i][i] 11
[/i][i] -18.6797
[/i][i] 21
[/i][i] -42.8315
[/i][i] 31
[/i][i] -164.345
[/i][i] 12
[/i][i] -29.0575
[/i][i] 22
[/i][i] -50.7563
[/i][i] 32
[/i][i] -151.515
[/i][i] 13
[/i][i] -29.0575
[/i][i] 23
[/i][i] -50.7563
[/i][i] 33
[/i][i] -151.515
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -29.0575
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -151.515
[/i][i] 11
[/i][i] -19.2458
[/i][i] 21
[/i][i] -38.8693
[/i][i] 31
[/i][i] -143.213
[/i][i] 12
[/i][i] -29.0575
[/i][i] 22
[/i][i] -46.0392
[/i][i] 32
[/i][i] -133.212
[/i][i] 13
[/i][i] -29.0575
[/i][i] 23
[/i][i] -46.0392
[/i][i] 33
[/i][i] -133.212
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -29.0575
[/i][i] 20
[/i][i] -46.0392
[/i][i] 30
[/i][i] -133.212
[/i][i] 11
[/i][i] -19.2458
[/i][i] 21
[/i][i] -38.8693
[/i][i] 31
[/i][i] -143.213
[/i][i] 12
[/i][i] -23.0194
[/i][i] 22
[/i][i] -41.322
[/i][i] 32
[/i][i] -125.288
[/i][i] 13
[/i][i] -23.0194
[/i][i] 23
[/i][i] -41.322
[/i][i] 33
[/i][i] -125.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -24.3404
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -115.098
[/i][i] 11
[/i][i] -23.0194
[/i][i] 21
[/i][i] -41.322
[/i][i] 31
[/i][i] -125.288
[/i][i] 12
[/i][i] -29.0575
[/i][i] 22
[/i][i] -46.0392
[/i][i] 32
[/i][i] -133.212
[/i][i] 13
[/i][i] -29.0575
[/i][i] 23
[/i][i] -46.0392
[/i][i] 33
[/i][i] -133.212
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -32.4537
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -130.193
[/i][i] 11
[/i][i] -29.0575
[/i][i] 21
[/i][i] -46.0392
[/i][i] 31
[/i][i] -133.212
[/i][i] 12
[/i][i] -32.0766
[/i][i] 22
[/i][i] -71.1345
[/i][i] 32
[/i][i] -154.723
[/i][i] 13
[/i][i] -32.0766
[/i][i] 23
[/i][i] -71.1345
[/i][i] 33
[/i][i] -154.723
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -32.0766
[/i][i] 20
[/i][i] -71.1345
[/i][i] 30
[/i][i] -154.723
[/i][i] 11
[/i][i] -29.0575
[/i][i] 21
[/i][i] -50.7563
[/i][i] 31
[/i][i] -151.515
[/i][i] 12
[/i][i] -29.0575
[/i][i] 22
[/i][i] -46.0392
[/i][i] 32
[/i][i] -133.212
[/i][i] 13
[/i][i] -29.0575
[/i][i] 23
[/i][i] -46.0392
[/i][i] 33
[/i][i] -133.212
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -29.0575
[/i][i] 20
[/i][i] -46.0392
[/i][i] 30
[/i][i] -133.212
[/i][i] 11
[/i][i] -24.3404
[/i][i] 21
[/i][i] -50.7563
[/i][i] 31
[/i][i] -115.098
[/i][i] 12
[/i][i] -32.4537
[/i][i] 22
[/i][i] -56.983
[/i][i] 32
[/i][i] -130.193
[/i][i] 13
[/i][i] -32.4537
[/i][i] 23
[/i][i] -56.983
[/i][i] 33
[/i][i] -130.193
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -32.4537
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -130.193
[/i][i] 11
[/i][i] -24.3404
[/i][i] 21
[/i][i] -50.7563
[/i][i] 31
[/i][i] -115.098
[/i][i] 12
[/i][i] -30.9445
[/i][i] 22
[/i][i] -67.9268
[/i][i] 32
[/i][i] -125.288
[/i][i] 13
[/i][i] -30.9445
[/i][i] 23
[/i][i] -67.9268
[/i][i] 33
[/i][i] -125.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -33.2086
[/i][i] 20
[/i][i] -68.6817
[/i][i] 30
[/i][i] -136.797
[/i][i] 11
[/i][i] -30.9445
[/i][i] 21
[/i][i] -67.9268
[/i][i] 31
[/i][i] -125.288
[/i][i] 12
[/i][i] -32.4537
[/i][i] 22
[/i][i] -56.983
[/i][i] 32
[/i][i] -130.193
[/i][i] 13
[/i][i] -32.4537
[/i][i] 23
[/i][i] -56.983
[/i][i] 33
[/i][i] -130.193
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -29.0575
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -151.515
[/i][i] 11
[/i][i] -18.6797
[/i][i] 21
[/i][i] -42.8315
[/i][i] 31
[/i][i] -164.345
[/i][i] 12
[/i][i] -29.8121
[/i][i] 22
[/i][i] -56.983
[/i][i] 32
[/i][i] -167.176
[/i][i] 13
[/i][i] -29.8121
[/i][i] 23
[/i][i] -56.983
[/i][i] 33
[/i][i] -167.176
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -29.8121
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -167.176
[/i][i] 11
[/i][i] -29.0575
[/i][i] 21
[/i][i] -50.7563
[/i][i] 31
[/i][i] -151.515
[/i][i] 12
[/i][i] -32.0766
[/i][i] 22
[/i][i] -71.1345
[/i][i] 32
[/i][i] -154.723
[/i][i] 13
[/i][i] -32.0766
[/i][i] 23
[/i][i] -71.1345
[/i][i] 33
[/i][i] -154.723
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -32.2652
[/i][i] 20
[/i][i] -66.4173
[/i][i] 30
[/i][i] -167.931
[/i][i] 11
[/i][i] -32.0766
[/i][i] 21
[/i][i] -71.1345
[/i][i] 31
[/i][i] -154.723
[/i][i] 12
[/i][i] -29.8121
[/i][i] 22
[/i][i] -56.983
[/i][i] 32
[/i][i] -167.176
[/i][i] 13
[/i][i] -29.8121
[/i][i] 23
[/i][i] -56.983
[/i][i] 33
[/i][i] -167.176
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -33.2086
[/i][i] 20
[/i][i] -68.6817
[/i][i] 30
[/i][i] -136.797
[/i][i] 11
[/i][i] -32.4537
[/i][i] 21
[/i][i] -56.983
[/i][i] 31
[/i][i] -130.193
[/i][i] 12
[/i][i] -32.0766
[/i][i] 22
[/i][i] -71.1345
[/i][i] 32
[/i][i] -154.723
[/i][i] 13
[/i][i] -32.0766
[/i][i] 23
[/i][i] -71.1345
[/i][i] 33
[/i][i] -154.723
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -33.2086
[/i][i] 20
[/i][i] -68.6817
[/i][i] 30
[/i][i] -136.797
[/i][i] 11
[/i][i] -32.0766
[/i][i] 21
[/i][i] -71.1345
[/i][i] 31
[/i][i] -154.723
[/i][i] 12
[/i][i] -26.982
[/i][i] 22
[/i][i] -90.9466
[/i][i] 32
[/i][i] -142.458
[/i][i] 13
[/i][i] -26.982
[/i][i] 23
[/i][i] -90.9466
[/i][i] 33
[/i][i] -142.458
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -26.982
[/i][i] 20
[/i][i] -90.9466
[/i][i] 30
[/i][i] -142.458
[/i][i] 11
[/i][i] -26.2274
[/i][i] 21
[/i][i] -92.6447
[/i][i] 31
[/i][i] -157.553
[/i][i] 12
[/i][i] -32.0766
[/i][i] 22
[/i][i] -71.1345
[/i][i] 32
[/i][i] -154.723
[/i][i] 13
[/i][i] -32.0766
[/i][i] 23
[/i][i] -71.1345
[/i][i] 33
[/i][i] -154.723
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -32.0766
[/i][i] 20
[/i][i] -71.1345
[/i][i] 30
[/i][i] -154.723
[/i][i] 11
[/i][i] -26.2274
[/i][i] 21
[/i][i] -92.6447
[/i][i] 31
[/i][i] -157.553
[/i][i] 12
[/i][i] -27.3594
[/i][i] 22
[/i][i] -91.5126
[/i][i] 32
[/i][i] -167.742
[/i][i] 13
[/i][i] -27.3594
[/i][i] 23
[/i][i] -91.5126
[/i][i] 33
[/i][i] -167.742
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -31.8877
[/i][i] 20
[/i][i] -75.4745
[/i][i] 30
[/i][i] -168.308
[/i][i] 11
[/i][i] -27.3594
[/i][i] 21
[/i][i] -91.5126
[/i][i] 31
[/i][i] -167.742
[/i][i] 12
[/i][i] -32.0766
[/i][i] 22
[/i][i] -71.1345
[/i][i] 32
[/i][i] -154.723
[/i][i] 13
[/i][i] -32.0766
[/i][i] 23
[/i][i] -71.1345
[/i][i] 33
[/i][i] -154.723
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -32.0766
[/i][i] 20
[/i][i] -71.1345
[/i][i] 30
[/i][i] -154.723
[/i][i] 11
[/i][i] -31.8877
[/i][i] 21
[/i][i] -75.4745
[/i][i] 31
[/i][i] -168.308
[/i][i] 12
[/i][i] -32.2652
[/i][i] 22
[/i][i] -66.4173
[/i][i] 32
[/i][i] -167.931
[/i][i] 13
[/i][i] -32.2652
[/i][i] 23
[/i][i] -66.4173
[/i][i] 33
[/i][i] -167.931
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -66.2287
[/i][i] 30
[/i][i] -175.101
[/i][i] 11
[/i][i] -32.2652
[/i][i] 21
[/i][i] -66.4173
[/i][i] 31
[/i][i] -167.931
[/i][i] 12
[/i][i] -29.8121
[/i][i] 22
[/i][i] -56.983
[/i][i] 32
[/i][i] -167.176
[/i][i] 13
[/i][i] -29.8121
[/i][i] 23
[/i][i] -56.983
[/i][i] 33
[/i][i] -167.176
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -66.2287
[/i][i] 30
[/i][i] -175.101
[/i][i] 11
[/i][i] -29.8121
[/i][i] 21
[/i][i] -56.983
[/i][i] 31
[/i][i] -167.176
[/i][i] 12
[/i][i] -39.0579
[/i][i] 22
[/i][i] -53.7754
[/i][i] 32
[/i][i] -173.968
[/i][i] 13
[/i][i] -39.0579
[/i][i] 23
[/i][i] -53.7754
[/i][i] 33
[/i][i] -173.968
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -32.2652
[/i][i] 20
[/i][i] -66.4173
[/i][i] 30
[/i][i] -167.931
[/i][i] 11
[/i][i] -31.8877
[/i][i] 21
[/i][i] -75.4745
[/i][i] 31
[/i][i] -168.308
[/i][i] 12
[/i][i] -42.2655
[/i][i] 22
[/i][i] -66.2287
[/i][i] 32
[/i][i] -175.101
[/i][i] 13
[/i][i] -42.2655
[/i][i] 23
[/i][i] -66.2287
[/i][i] 33
[/i][i] -175.101
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -66.2287
[/i][i] 30
[/i][i] -175.101
[/i][i] 11
[/i][i] -31.8877
[/i][i] 21
[/i][i] -75.4745
[/i][i] 31
[/i][i] -168.308
[/i][i] 12
[/i][i] -41.888
[/i][i] 22
[/i][i] -77.5497
[/i][i] 32
[/i][i] -176.233
[/i][i] 13
[/i][i] -41.888
[/i][i] 23
[/i][i] -77.5497
[/i][i] 33
[/i][i] -176.233
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -41.888
[/i][i] 20
[/i][i] -77.5497
[/i][i] 30
[/i][i] -176.233
[/i][i] 11
[/i][i] -31.8877
[/i][i] 21
[/i][i] -75.4745
[/i][i] 31
[/i][i] -168.308
[/i][i] 12
[/i][i] -37.7372
[/i][i] 22
[/i][i] -89.437
[/i][i] 32
[/i][i] -175.855
[/i][i] 13
[/i][i] -37.7372
[/i][i] 23
[/i][i] -89.437
[/i][i] 33
[/i][i] -175.855
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -37.7372
[/i][i] 20
[/i][i] -89.437
[/i][i] 30
[/i][i] -175.855
[/i][i] 11
[/i][i] -31.8877
[/i][i] 21
[/i][i] -75.4745
[/i][i] 31
[/i][i] -168.308
[/i][i] 12
[/i][i] -27.3594
[/i][i] 22
[/i][i] -91.5126
[/i][i] 32
[/i][i] -167.742
[/i][i] 13
[/i][i] -27.3594
[/i][i] 23
[/i][i] -91.5126
[/i][i] 33
[/i][i] -167.742
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -27.7366
[/i][i] 20
[/i][i] -105.853
[/i][i] 30
[/i][i] -176.044
[/i][i] 11
[/i][i] -27.3594
[/i][i] 21
[/i][i] -91.5126
[/i][i] 31
[/i][i] -167.742
[/i][i] 12
[/i][i] -37.7372
[/i][i] 22
[/i][i] -89.437
[/i][i] 32
[/i][i] -175.855
[/i][i] 13
[/i][i] -37.7372
[/i][i] 23
[/i][i] -89.437
[/i][i] 33
[/i][i] -175.855
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -24.3404
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -115.098
[/i][i] 11
[/i][i] -23.0194
[/i][i] 21
[/i][i] -71.5119
[/i][i] 31
[/i][i] -115.853
[/i][i] 12
[/i][i] -30.9445
[/i][i] 22
[/i][i] -67.9268
[/i][i] 32
[/i][i] -125.288
[/i][i] 13
[/i][i] -30.9445
[/i][i] 23
[/i][i] -67.9268
[/i][i] 33
[/i][i] -125.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -30.9445
[/i][i] 20
[/i][i] -67.9268
[/i][i] 30
[/i][i] -125.288
[/i][i] 11
[/i][i] -23.0194
[/i][i] 21
[/i][i] -71.5119
[/i][i] 31
[/i][i] -115.853
[/i][i] 12
[/i][i] -20.7553
[/i][i] 22
[/i][i] -86.7954
[/i][i] 32
[/i][i] -123.967
[/i][i] 13
[/i][i] -20.7553
[/i][i] 23
[/i][i] -86.7954
[/i][i] 33
[/i][i] -123.967
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -30.9445
[/i][i] 20
[/i][i] -67.9268
[/i][i] 30
[/i][i] -125.288
[/i][i] 11
[/i][i] -20.7553
[/i][i] 21
[/i][i] -86.7954
[/i][i] 31
[/i][i] -123.967
[/i][i] 12
[/i][i] -26.982
[/i][i] 22
[/i][i] -90.9466
[/i][i] 32
[/i][i] -142.458
[/i][i] 13
[/i][i] -26.982
[/i][i] 23
[/i][i] -90.9466
[/i][i] 33
[/i][i] -142.458
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -33.2086
[/i][i] 20
[/i][i] -68.6817
[/i][i] 30
[/i][i] -136.797
[/i][i] 11
[/i][i] -26.982
[/i][i] 21
[/i][i] -90.9466
[/i][i] 31
[/i][i] -142.458
[/i][i] 12
[/i][i] -30.9445
[/i][i] 22
[/i][i] -67.9268
[/i][i] 32
[/i][i] -125.288
[/i][i] 13
[/i][i] -30.9445
[/i][i] 23
[/i][i] -67.9268
[/i][i] 33
[/i][i] -125.288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -24.3404
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -115.098
[/i][i] 11
[/i][i] -14.5286
[/i][i] 21
[/i][i] -60.002
[/i][i] 31
[/i][i] -108.872
[/i][i] 12
[/i][i] -23.0194
[/i][i] 22
[/i][i] -71.5119
[/i][i] 32
[/i][i] -115.853
[/i][i] 13
[/i][i] -23.0194
[/i][i] 23
[/i][i] -71.5119
[/i][i] 33
[/i][i] -115.853
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -23.0194
[/i][i] 20
[/i][i] -71.5119
[/i][i] 30
[/i][i] -115.853
[/i][i] 11
[/i][i] -14.5286
[/i][i] 21
[/i][i] -60.002
[/i][i] 31
[/i][i] -108.872
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -79.0592
[/i][i] 32
[/i][i] -114.721
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -79.0592
[/i][i] 33
[/i][i] -114.721
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.7553
[/i][i] 20
[/i][i] -86.7954
[/i][i] 30
[/i][i] -123.967
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -79.0592
[/i][i] 31
[/i][i] -114.721
[/i][i] 12
[/i][i] -23.0194
[/i][i] 22
[/i][i] -71.5119
[/i][i] 32
[/i][i] -115.853
[/i][i] 13
[/i][i] -23.0194
[/i][i] 23
[/i][i] -71.5119
[/i][i] 33
[/i][i] -115.853
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -8.67938
[/i][i] 20
[/i][i] -55.8509
[/i][i] 30
[/i][i] -89.8145
[/i][i] 11
[/i][i] 11.1324
[/i][i] 21
[/i][i] -64.1532
[/i][i] 31
[/i][i] -66.0401
[/i][i] 12
[/i][i] -3.96223
[/i][i] 22
[/i][i] -71.3233
[/i][i] 32
[/i][i] -93.5882
[/i][i] 13
[/i][i] -3.96223
[/i][i] 23
[/i][i] -71.3233
[/i][i] 33
[/i][i] -93.5882
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -14.5286
[/i][i] 20
[/i][i] -60.002
[/i][i] 30
[/i][i] -108.872
[/i][i] 11
[/i][i] -3.96223
[/i][i] 21
[/i][i] -71.3233
[/i][i] 31
[/i][i] -93.5882
[/i][i] 12
[/i][i] -8.67938
[/i][i] 22
[/i][i] -55.8509
[/i][i] 32
[/i][i] -89.8145
[/i][i] 13
[/i][i] -8.67938
[/i][i] 23
[/i][i] -55.8509
[/i][i] 33
[/i][i] -89.8145
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -14.5286
[/i][i] 20
[/i][i] -60.002
[/i][i] 30
[/i][i] -108.872
[/i][i] 11
[/i][i] -3.96223
[/i][i] 21
[/i][i] -71.3233
[/i][i] 31
[/i][i] -93.5882
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -79.0592
[/i][i] 32
[/i][i] -114.721
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -79.0592
[/i][i] 33
[/i][i] -114.721
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.1324
[/i][i] 20
[/i][i] -79.0592
[/i][i] 30
[/i][i] -114.721
[/i][i] 11
[/i][i] -3.96223
[/i][i] 21
[/i][i] -71.3233
[/i][i] 31
[/i][i] -93.5882
[/i][i] 12
[/i][i] 4.90573
[/i][i] 22
[/i][i] -97.7393
[/i][i] 32
[/i][i] -105.475
[/i][i] 13
[/i][i] 4.90573
[/i][i] 23
[/i][i] -97.7393
[/i][i] 33
[/i][i] -105.475
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -9.24542
[/i][i] 20
[/i][i] -89.437
[/i][i] 30
[/i][i] -119.438
[/i][i] 11
[/i][i] 4.90573
[/i][i] 21
[/i][i] -97.7393
[/i][i] 31
[/i][i] -105.475
[/i][i] 12
[/i][i] -11.1324
[/i][i] 22
[/i][i] -79.0592
[/i][i] 32
[/i][i] -114.721
[/i][i] 13
[/i][i] -11.1324
[/i][i] 23
[/i][i] -79.0592
[/i][i] 33
[/i][i] -114.721
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.96223
[/i][i] 20
[/i][i] -71.3233
[/i][i] 30
[/i][i] -93.5882
[/i][i] 11
[/i][i] 11.1324
[/i][i] 21
[/i][i] -64.1532
[/i][i] 31
[/i][i] -66.0401
[/i][i] 12
[/i][i] 8.49081
[/i][i] 22
[/i][i] -78.3046
[/i][i] 32
[/i][i] -79.6253
[/i][i] 13
[/i][i] 8.49081
[/i][i] 23
[/i][i] -78.3046
[/i][i] 33
[/i][i] -79.6253
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 4.90573
[/i][i] 20
[/i][i] -97.7393
[/i][i] 30
[/i][i] -105.475
[/i][i] 11
[/i][i] 8.49081
[/i][i] 21
[/i][i] -78.3046
[/i][i] 31
[/i][i] -79.6253
[/i][i] 12
[/i][i] -3.96223
[/i][i] 22
[/i][i] -71.3233
[/i][i] 32
[/i][i] -93.5882
[/i][i] 13
[/i][i] -3.96223
[/i][i] 23
[/i][i] -71.3233
[/i][i] 33
[/i][i] -93.5882
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.7553
[/i][i] 20
[/i][i] -86.7954
[/i][i] 30
[/i][i] -123.967
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -79.0592
[/i][i] 31
[/i][i] -114.721
[/i][i] 12
[/i][i] -9.24542
[/i][i] 22
[/i][i] -89.437
[/i][i] 32
[/i][i] -119.438
[/i][i] 13
[/i][i] -9.24542
[/i][i] 23
[/i][i] -89.437
[/i][i] 33
[/i][i] -119.438
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -12.6419
[/i][i] 20
[/i][i] -99.6263
[/i][i] 30
[/i][i] -128.495
[/i][i] 11
[/i][i] -9.24542
[/i][i] 21
[/i][i] -89.437
[/i][i] 31
[/i][i] -119.438
[/i][i] 12
[/i][i] -20.7553
[/i][i] 22
[/i][i] -86.7954
[/i][i] 32
[/i][i] -123.967
[/i][i] 13
[/i][i] -20.7553
[/i][i] 23
[/i][i] -86.7954
[/i][i] 33
[/i][i] -123.967
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -20.7553
[/i][i] 20
[/i][i] -86.7954
[/i][i] 30
[/i][i] -123.967
[/i][i] 11
[/i][i] -12.6419
[/i][i] 21
[/i][i] -99.6263
[/i][i] 31
[/i][i] -128.495
[/i][i] 12
[/i][i] -26.982
[/i][i] 22
[/i][i] -90.9466
[/i][i] 32
[/i][i] -142.458
[/i][i] 13
[/i][i] -26.982
[/i][i] 23
[/i][i] -90.9466
[/i][i] 33
[/i][i] -142.458
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -9.24542
[/i][i] 20
[/i][i] -89.437
[/i][i] 30
[/i][i] -119.438
[/i][i] 11
[/i][i] 4.90573
[/i][i] 21
[/i][i] -97.7393
[/i][i] 31
[/i][i] -105.475
[/i][i] 12
[/i][i] -1.32063
[/i][i] 22
[/i][i] -103.589
[/i][i] 32
[/i][i] -120.193
[/i][i] 13
[/i][i] -1.32063
[/i][i] 23
[/i][i] -103.589
[/i][i] 33
[/i][i] -120.193
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -12.6419
[/i][i] 20
[/i][i] -99.6263
[/i][i] 30
[/i][i] -128.495
[/i][i] 11
[/i][i] -1.32063
[/i][i] 21
[/i][i] -103.589
[/i][i] 31
[/i][i] -120.193
[/i][i] 12
[/i][i] -9.24542
[/i][i] 22
[/i][i] -89.437
[/i][i] 32
[/i][i] -119.438
[/i][i] 13
[/i][i] -9.24542
[/i][i] 23
[/i][i] -89.437
[/i][i] 33
[/i][i] -119.438
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -12.6419
[/i][i] 20
[/i][i] -99.6263
[/i][i] 30
[/i][i] -128.495
[/i][i] 11
[/i][i] -11.6984
[/i][i] 21
[/i][i] -108.306
[/i][i] 31
[/i][i] -143.967
[/i][i] 12
[/i][i] -26.982
[/i][i] 22
[/i][i] -90.9466
[/i][i] 32
[/i][i] -142.458
[/i][i] 13
[/i][i] -26.982
[/i][i] 23
[/i][i] -90.9466
[/i][i] 33
[/i][i] -142.458
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -12.6419
[/i][i] 20
[/i][i] -99.6263
[/i][i] 30
[/i][i] -128.495
[/i][i] 11
[/i][i] 11.6985
[/i][i] 21
[/i][i] -112.268
[/i][i] 31
[/i][i] -126.042
[/i][i] 12
[/i][i] -11.6984
[/i][i] 22
[/i][i] -108.306
[/i][i] 32
[/i][i] -143.967
[/i][i] 13
[/i][i] -11.6984
[/i][i] 23
[/i][i] -108.306
[/i][i] 33
[/i][i] -143.967
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -12.6419
[/i][i] 20
[/i][i] -99.6263
[/i][i] 30
[/i][i] -128.495
[/i][i] 11
[/i][i] -1.32063
[/i][i] 21
[/i][i] -103.589
[/i][i] 31
[/i][i] -120.193
[/i][i] 12
[/i][i] 11.6985
[/i][i] 22
[/i][i] -112.268
[/i][i] 32
[/i][i] -126.042
[/i][i] 13
[/i][i] 11.6985
[/i][i] 23
[/i][i] -112.268
[/i][i] 33
[/i][i] -126.042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 4.90573
[/i][i] 20
[/i][i] -97.7393
[/i][i] 30
[/i][i] -105.475
[/i][i] 11
[/i][i] 11.6985
[/i][i] 21
[/i][i] -112.268
[/i][i] 31
[/i][i] -126.042
[/i][i] 12
[/i][i] 14.5286
[/i][i] 22
[/i][i] -102.268
[/i][i] 32
[/i][i] -105.475
[/i][i] 13
[/i][i] 14.5286
[/i][i] 23
[/i][i] -102.268
[/i][i] 33
[/i][i] -105.475
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 4.90573
[/i][i] 20
[/i][i] -97.7393
[/i][i] 30
[/i][i] -105.475
[/i][i] 11
[/i][i] 14.5286
[/i][i] 21
[/i][i] -102.268
[/i][i] 31
[/i][i] -105.475
[/i][i] 12
[/i][i] 17.3591
[/i][i] 22
[/i][i] -92.8335
[/i][i] 32
[/i][i] -91.324
[/i][i] 13
[/i][i] 17.3591
[/i][i] 23
[/i][i] -92.8335
[/i][i] 33
[/i][i] -91.324
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 4.90573
[/i][i] 20
[/i][i] -97.7393
[/i][i] 30
[/i][i] -105.475
[/i][i] 11
[/i][i] 17.3591
[/i][i] 21
[/i][i] -92.8335
[/i][i] 31
[/i][i] -91.324
[/i][i] 12
[/i][i] 8.49081
[/i][i] 22
[/i][i] -78.3046
[/i][i] 32
[/i][i] -79.6253
[/i][i] 13
[/i][i] 8.49081
[/i][i] 23
[/i][i] -78.3046
[/i][i] 33
[/i][i] -79.6253
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.49081
[/i][i] 20
[/i][i] -78.3046
[/i][i] 30
[/i][i] -79.6253
[/i][i] 11
[/i][i] 20.3779
[/i][i] 21
[/i][i] -80.7576
[/i][i] 31
[/i][i] -76.9837
[/i][i] 12
[/i][i] 17.3591
[/i][i] 22
[/i][i] -92.8335
[/i][i] 32
[/i][i] -91.324
[/i][i] 13
[/i][i] 17.3591
[/i][i] 23
[/i][i] -92.8335
[/i][i] 33
[/i][i] -91.324
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.49081
[/i][i] 20
[/i][i] -78.3046
[/i][i] 30
[/i][i] -79.6253
[/i][i] 11
[/i][i] 20.3779
[/i][i] 21
[/i][i] -80.7576
[/i][i] 31
[/i][i] -76.9837
[/i][i] 12
[/i][i] 22.8309
[/i][i] 22
[/i][i] -66.4173
[/i][i] 32
[/i][i] -64.1532
[/i][i] 13
[/i][i] 22.8309
[/i][i] 23
[/i][i] -66.4173
[/i][i] 33
[/i][i] -64.1532
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.49081
[/i][i] 20
[/i][i] -78.3046
[/i][i] 30
[/i][i] -79.6253
[/i][i] 11
[/i][i] 22.8309
[/i][i] 21
[/i][i] -66.4173
[/i][i] 31
[/i][i] -64.1532
[/i][i] 12
[/i][i] 11.1324
[/i][i] 22
[/i][i] -64.1532
[/i][i] 32
[/i][i] -66.0401
[/i][i] 13
[/i][i] 11.1324
[/i][i] 23
[/i][i] -64.1532
[/i][i] 33
[/i][i] -66.0401
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 11.1324
[/i][i] 20
[/i][i] -64.1532
[/i][i] 30
[/i][i] -66.0401
[/i][i] 11
[/i][i] 13.208
[/i][i] 21
[/i][i] -50.5677
[/i][i] 31
[/i][i] -56.417
[/i][i] 12
[/i][i] 24.9064
[/i][i] 22
[/i][i] -51.3224
[/i][i] 32
[/i][i] -53.3979
[/i][i] 13
[/i][i] 24.9064
[/i][i] 23
[/i][i] -51.3224
[/i][i] 33
[/i][i] -53.3979
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 22.8309
[/i][i] 20
[/i][i] -66.4173
[/i][i] 30
[/i][i] -64.1532
[/i][i] 11
[/i][i] 24.9064
[/i][i] 21
[/i][i] -51.3224
[/i][i] 31
[/i][i] -53.3979
[/i][i] 12
[/i][i] 11.1324
[/i][i] 22
[/i][i] -64.1532
[/i][i] 32
[/i][i] -66.0401
[/i][i] 13
[/i][i] 11.1324
[/i][i] 23
[/i][i] -64.1532
[/i][i] 33
[/i][i] -66.0401
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -40.3788
[/i][i] 20
[/i][i] -52.0773
[/i][i] 30
[/i][i] -179.629
[/i][i] 11
[/i][i] -35.8502
[/i][i] 21
[/i][i] -42.643
[/i][i] 31
[/i][i] -179.44
[/i][i] 12
[/i][i] -31.5105
[/i][i] 22
[/i][i] -42.4541
[/i][i] 32
[/i][i] -185.667
[/i][i] 13
[/i][i] -31.5105
[/i][i] 23
[/i][i] -42.4541
[/i][i] 33
[/i][i] -185.667
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -40.3788
[/i][i] 20
[/i][i] -52.0773
[/i][i] 30
[/i][i] -179.629
[/i][i] 11
[/i][i] -31.5105
[/i][i] 21
[/i][i] -42.4541
[/i][i] 31
[/i][i] -185.667
[/i][i] 12
[/i][i] -37.9258
[/i][i] 22
[/i][i] -52.6433
[/i][i] 32
[/i][i] -185.667
[/i][i] 13
[/i][i] -37.9258
[/i][i] 23
[/i][i] -52.6433
[/i][i] 33
[/i][i] -185.667
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -40.3788
[/i][i] 20
[/i][i] -52.0773
[/i][i] 30
[/i][i] -179.629
[/i][i] 11
[/i][i] -37.9258
[/i][i] 21
[/i][i] -52.6433
[/i][i] 31
[/i][i] -185.667
[/i][i] 12
[/i][i] -40.756
[/i][i] 22
[/i][i] -65.6627
[/i][i] 32
[/i][i] -185.29
[/i][i] 13
[/i][i] -40.756
[/i][i] 23
[/i][i] -65.6627
[/i][i] 33
[/i][i] -185.29
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -40.756
[/i][i] 20
[/i][i] -65.6627
[/i][i] 30
[/i][i] -185.29
[/i][i] 11
[/i][i] -40.3788
[/i][i] 21
[/i][i] -52.0773
[/i][i] 31
[/i][i] -179.629
[/i][i] 12
[/i][i] -42.8315
[/i][i] 22
[/i][i] -66.2287
[/i][i] 32
[/i][i] -181.139
[/i][i] 13
[/i][i] -42.8315
[/i][i] 23
[/i][i] -66.2287
[/i][i] 33
[/i][i] -181.139
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.8315
[/i][i] 20
[/i][i] -66.2287
[/i][i] 30
[/i][i] -181.139
[/i][i] 11
[/i][i] -42.2655
[/i][i] 21
[/i][i] -77.5497
[/i][i] 31
[/i][i] -181.516
[/i][i] 12
[/i][i] -40.756
[/i][i] 22
[/i][i] -65.6627
[/i][i] 32
[/i][i] -185.29
[/i][i] 13
[/i][i] -40.756
[/i][i] 23
[/i][i] -65.6627
[/i][i] 33
[/i][i] -185.29
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -77.5497
[/i][i] 30
[/i][i] -181.516
[/i][i] 11
[/i][i] -40.756
[/i][i] 21
[/i][i] -65.6627
[/i][i] 31
[/i][i] -185.29
[/i][i] 12
[/i][i] -38.8693
[/i][i] 22
[/i][i] -77.3611
[/i][i] 32
[/i][i] -186.044
[/i][i] 13
[/i][i] -38.8693
[/i][i] 23
[/i][i] -77.3611
[/i][i] 33
[/i][i] -186.044
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -77.5497
[/i][i] 30
[/i][i] -181.516
[/i][i] 11
[/i][i] -38.6804
[/i][i] 21
[/i][i] -89.437
[/i][i] 31
[/i][i] -181.327
[/i][i] 12
[/i][i] -34.5293
[/i][i] 22
[/i][i] -88.4936
[/i][i] 32
[/i][i] -186.799
[/i][i] 13
[/i][i] -34.5293
[/i][i] 23
[/i][i] -88.4936
[/i][i] 33
[/i][i] -186.799
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -38.8693
[/i][i] 20
[/i][i] -77.3611
[/i][i] 30
[/i][i] -186.044
[/i][i] 11
[/i][i] -34.5293
[/i][i] 21
[/i][i] -88.4936
[/i][i] 31
[/i][i] -186.799
[/i][i] 12
[/i][i] -42.2655
[/i][i] 22
[/i][i] -77.5497
[/i][i] 32
[/i][i] -181.516
[/i][i] 13
[/i][i] -42.2655
[/i][i] 23
[/i][i] -77.5497
[/i][i] 33
[/i][i] -181.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -38.6804
[/i][i] 20
[/i][i] -89.437
[/i][i] 30
[/i][i] -181.327
[/i][i] 11
[/i][i] -34.5293
[/i][i] 21
[/i][i] -88.4936
[/i][i] 31
[/i][i] -186.799
[/i][i] 12
[/i][i] -33.2086
[/i][i] 22
[/i][i] -99.0599
[/i][i] 32
[/i][i] -181.705
[/i][i] 13
[/i][i] -33.2086
[/i][i] 23
[/i][i] -99.0599
[/i][i] 33
[/i][i] -181.705
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -33.2086
[/i][i] 20
[/i][i] -99.0599
[/i][i] 30
[/i][i] -181.705
[/i][i] 11
[/i][i] -23.9629
[/i][i] 21
[/i][i] -102.834
[/i][i] 31
[/i][i] -186.611
[/i][i] 12
[/i][i] -34.5293
[/i][i] 22
[/i][i] -88.4936
[/i][i] 32
[/i][i] -186.799
[/i][i] 13
[/i][i] -34.5293
[/i][i] 23
[/i][i] -88.4936
[/i][i] 33
[/i][i] -186.799
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -33.2086
[/i][i] 20
[/i][i] -99.0599
[/i][i] 30
[/i][i] -181.705
[/i][i] 11
[/i][i] -27.548
[/i][i] 21
[/i][i] -105.475
[/i][i] 31
[/i][i] -181.327
[/i][i] 12
[/i][i] -23.9629
[/i][i] 22
[/i][i] -102.834
[/i][i] 32
[/i][i] -186.611
[/i][i] 13
[/i][i] -23.9629
[/i][i] 23
[/i][i] -102.834
[/i][i] 33
[/i][i] -186.611
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -27.548
[/i][i] 20
[/i][i] -105.475
[/i][i] 30
[/i][i] -181.327
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -113.212
[/i][i] 31
[/i][i] -184.535
[/i][i] 12
[/i][i] 4.15083
[/i][i] 22
[/i][i] -119.816
[/i][i] 32
[/i][i] -176.799
[/i][i] 13
[/i][i] 4.15083
[/i][i] 23
[/i][i] -119.816
[/i][i] 33
[/i][i] -176.799
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -40.3788
[/i][i] 20
[/i][i] -52.0773
[/i][i] 30
[/i][i] -179.629
[/i][i] 11
[/i][i] -35.8502
[/i][i] 21
[/i][i] -42.643
[/i][i] 31
[/i][i] -179.44
[/i][i] 12
[/i][i] -35.2842
[/i][i] 22
[/i][i] -45.2845
[/i][i] 32
[/i][i] -172.459
[/i][i] 13
[/i][i] -35.2842
[/i][i] 23
[/i][i] -45.2845
[/i][i] 33
[/i][i] -172.459
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -39.0579
[/i][i] 20
[/i][i] -53.7754
[/i][i] 30
[/i][i] -173.968
[/i][i] 11
[/i][i] -35.2842
[/i][i] 21
[/i][i] -45.2845
[/i][i] 31
[/i][i] -172.459
[/i][i] 12
[/i][i] -40.3788
[/i][i] 22
[/i][i] -52.0773
[/i][i] 32
[/i][i] -179.629
[/i][i] 13
[/i][i] -40.3788
[/i][i] 23
[/i][i] -52.0773
[/i][i] 33
[/i][i] -179.629
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -40.3788
[/i][i] 20
[/i][i] -52.0773
[/i][i] 30
[/i][i] -179.629
[/i][i] 11
[/i][i] -39.0579
[/i][i] 21
[/i][i] -53.7754
[/i][i] 31
[/i][i] -173.968
[/i][i] 12
[/i][i] -42.2655
[/i][i] 22
[/i][i] -66.2287
[/i][i] 32
[/i][i] -175.101
[/i][i] 13
[/i][i] -42.2655
[/i][i] 23
[/i][i] -66.2287
[/i][i] 33
[/i][i] -175.101
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.8315
[/i][i] 20
[/i][i] -66.2287
[/i][i] 30
[/i][i] -181.139
[/i][i] 11
[/i][i] -42.2655
[/i][i] 21
[/i][i] -66.2287
[/i][i] 31
[/i][i] -175.101
[/i][i] 12
[/i][i] -40.3788
[/i][i] 22
[/i][i] -52.0773
[/i][i] 32
[/i][i] -179.629
[/i][i] 13
[/i][i] -40.3788
[/i][i] 23
[/i][i] -52.0773
[/i][i] 33
[/i][i] -179.629
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -77.5497
[/i][i] 30
[/i][i] -181.516
[/i][i] 11
[/i][i] -42.2655
[/i][i] 21
[/i][i] -66.2287
[/i][i] 31
[/i][i] -175.101
[/i][i] 12
[/i][i] -42.8315
[/i][i] 22
[/i][i] -66.2287
[/i][i] 32
[/i][i] -181.139
[/i][i] 13
[/i][i] -42.8315
[/i][i] 23
[/i][i] -66.2287
[/i][i] 33
[/i][i] -181.139
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -66.2287
[/i][i] 30
[/i][i] -175.101
[/i][i] 11
[/i][i] -41.888
[/i][i] 21
[/i][i] -77.5497
[/i][i] 31
[/i][i] -176.233
[/i][i] 12
[/i][i] -42.2655
[/i][i] 22
[/i][i] -77.5497
[/i][i] 32
[/i][i] -181.516
[/i][i] 13
[/i][i] -42.2655
[/i][i] 23
[/i][i] -77.5497
[/i][i] 33
[/i][i] -181.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -42.2655
[/i][i] 20
[/i][i] -77.5497
[/i][i] 30
[/i][i] -181.516
[/i][i] 11
[/i][i] -41.888
[/i][i] 21
[/i][i] -77.5497
[/i][i] 31
[/i][i] -176.233
[/i][i] 12
[/i][i] -37.7372
[/i][i] 22
[/i][i] -89.437
[/i][i] 32
[/i][i] -175.855
[/i][i] 13
[/i][i] -37.7372
[/i][i] 23
[/i][i] -89.437
[/i][i] 33
[/i][i] -175.855
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -38.6804
[/i][i] 20
[/i][i] -89.437
[/i][i] 30
[/i][i] -181.327
[/i][i] 11
[/i][i] -37.7372
[/i][i] 21
[/i][i] -89.437
[/i][i] 31
[/i][i] -175.855
[/i][i] 12
[/i][i] -42.2655
[/i][i] 22
[/i][i] -77.5497
[/i][i] 32
[/i][i] -181.516
[/i][i] 13
[/i][i] -42.2655
[/i][i] 23
[/i][i] -77.5497
[/i][i] 33
[/i][i] -181.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -38.6804
[/i][i] 20
[/i][i] -89.437
[/i][i] 30
[/i][i] -181.327
[/i][i] 11
[/i][i] -33.2086
[/i][i] 21
[/i][i] -99.0599
[/i][i] 31
[/i][i] -181.705
[/i][i] 12
[/i][i] -37.7372
[/i][i] 22
[/i][i] -89.437
[/i][i] 32
[/i][i] -175.855
[/i][i] 13
[/i][i] -37.7372
[/i][i] 23
[/i][i] -89.437
[/i][i] 33
[/i][i] -175.855
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -37.7372
[/i][i] 20
[/i][i] -89.437
[/i][i] 30
[/i][i] -175.855
[/i][i] 11
[/i][i] -27.7366
[/i][i] 21
[/i][i] -105.853
[/i][i] 31
[/i][i] -176.044
[/i][i] 12
[/i][i] -33.2086
[/i][i] 22
[/i][i] -99.0599
[/i][i] 32
[/i][i] -181.705
[/i][i] 13
[/i][i] -33.2086
[/i][i] 23
[/i][i] -99.0599
[/i][i] 33
[/i][i] -181.705
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -33.2086
[/i][i] 20
[/i][i] -99.0599
[/i][i] 30
[/i][i] -181.705
[/i][i] 11
[/i][i] -27.7366
[/i][i] 21
[/i][i] -105.853
[/i][i] 31
[/i][i] -176.044
[/i][i] 12
[/i][i] -27.548
[/i][i] 22
[/i][i] -105.475
[/i][i] 32
[/i][i] -181.327
[/i][i] 13
[/i][i] -27.548
[/i][i] 23
[/i][i] -105.475
[/i][i] 33
[/i][i] -181.327
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -27.7366
[/i][i] 20
[/i][i] -105.853
[/i][i] 30
[/i][i] -176.044
[/i][i] 11
[/i][i] -27.548
[/i][i] 21
[/i][i] -105.475
[/i][i] 31
[/i][i] -181.327
[/i][i] 12
[/i][i] -15.4721
[/i][i] 22
[/i][i] -115.287
[/i][i] 32
[/i][i] -173.78
[/i][i] 13
[/i][i] -15.4721
[/i][i] 23
[/i][i] -115.287
[/i][i] 33
[/i][i] -173.78
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.4721
[/i][i] 20
[/i][i] -115.287
[/i][i] 30
[/i][i] -173.78
[/i][i] 11
[/i][i] 9.62289
[/i][i] 21
[/i][i] -120.193
[/i][i] 31
[/i][i] -171.704
[/i][i] 12
[/i][i] 4.15083
[/i][i] 22
[/i][i] -119.816
[/i][i] 32
[/i][i] -176.799
[/i][i] 13
[/i][i] 4.15083
[/i][i] 23
[/i][i] -119.816
[/i][i] 33
[/i][i] -176.799
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -26.982
[/i][i] 20
[/i][i] -90.9466
[/i][i] 30
[/i][i] -142.458
[/i][i] 11
[/i][i] -26.2274
[/i][i] 21
[/i][i] -92.6447
[/i][i] 31
[/i][i] -157.553
[/i][i] 12
[/i][i] -11.6984
[/i][i] 22
[/i][i] -108.306
[/i][i] 32
[/i][i] -143.967
[/i][i] 13
[/i][i] -11.6984
[/i][i] 23
[/i][i] -108.306
[/i][i] 33
[/i][i] -143.967
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.6984
[/i][i] 20
[/i][i] -108.306
[/i][i] 30
[/i][i] -143.967
[/i][i] 11
[/i][i] 3.39621
[/i][i] 21
[/i][i] -118.495
[/i][i] 31
[/i][i] -159.251
[/i][i] 12
[/i][i] -26.2274
[/i][i] 22
[/i][i] -92.6447
[/i][i] 32
[/i][i] -157.553
[/i][i] 13
[/i][i] -26.2274
[/i][i] 23
[/i][i] -92.6447
[/i][i] 33
[/i][i] -157.553
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -26.2274
[/i][i] 20
[/i][i] -92.6447
[/i][i] 30
[/i][i] -157.553
[/i][i] 11
[/i][i] -15.2835
[/i][i] 21
[/i][i] -108.683
[/i][i] 31
[/i][i] -165.666
[/i][i] 12
[/i][i] -27.3594
[/i][i] 22
[/i][i] -91.5126
[/i][i] 32
[/i][i] -167.742
[/i][i] 13
[/i][i] -27.3594
[/i][i] 23
[/i][i] -91.5126
[/i][i] 33
[/i][i] -167.742
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -27.3594
[/i][i] 20
[/i][i] -91.5126
[/i][i] 30
[/i][i] -167.742
[/i][i] 11
[/i][i] -15.2835
[/i][i] 21
[/i][i] -108.683
[/i][i] 31
[/i][i] -165.666
[/i][i] 12
[/i][i] -6.98128
[/i][i] 22
[/i][i] -118.495
[/i][i] 32
[/i][i] -169.629
[/i][i] 13
[/i][i] -6.98128
[/i][i] 23
[/i][i] -118.495
[/i][i] 33
[/i][i] -169.629
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.4721
[/i][i] 20
[/i][i] -115.287
[/i][i] 30
[/i][i] -173.78
[/i][i] 11
[/i][i] -6.98128
[/i][i] 21
[/i][i] -118.495
[/i][i] 31
[/i][i] -169.629
[/i][i] 12
[/i][i] -27.3594
[/i][i] 22
[/i][i] -91.5126
[/i][i] 32
[/i][i] -167.742
[/i][i] 13
[/i][i] -27.3594
[/i][i] 23
[/i][i] -91.5126
[/i][i] 33
[/i][i] -167.742
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -26.2274
[/i][i] 20
[/i][i] -92.6447
[/i][i] 30
[/i][i] -157.553
[/i][i] 11
[/i][i] 3.39621
[/i][i] 21
[/i][i] -118.495
[/i][i] 31
[/i][i] -159.251
[/i][i] 12
[/i][i] -15.2835
[/i][i] 22
[/i][i] -108.683
[/i][i] 32
[/i][i] -165.666
[/i][i] 13
[/i][i] -15.2835
[/i][i] 23
[/i][i] -108.683
[/i][i] 33
[/i][i] -165.666
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.2835
[/i][i] 20
[/i][i] -108.683
[/i][i] 30
[/i][i] -165.666
[/i][i] 11
[/i][i] 3.39621
[/i][i] 21
[/i][i] -118.495
[/i][i] 31
[/i][i] -159.251
[/i][i] 12
[/i][i] -6.98128
[/i][i] 22
[/i][i] -118.495
[/i][i] 32
[/i][i] -169.629
[/i][i] 13
[/i][i] -6.98128
[/i][i] 23
[/i][i] -118.495
[/i][i] 33
[/i][i] -169.629
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.98128
[/i][i] 20
[/i][i] -118.495
[/i][i] 30
[/i][i] -169.629
[/i][i] 11
[/i][i] 3.39621
[/i][i] 21
[/i][i] -118.495
[/i][i] 31
[/i][i] -159.251
[/i][i] 12
[/i][i] 9.62289
[/i][i] 22
[/i][i] -120.193
[/i][i] 32
[/i][i] -171.704
[/i][i] 13
[/i][i] 9.62289
[/i][i] 23
[/i][i] -120.193
[/i][i] 33
[/i][i] -171.704
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 9.62289
[/i][i] 20
[/i][i] -120.193
[/i][i] 30
[/i][i] -171.704
[/i][i] 11
[/i][i] 15.4721
[/i][i] 21
[/i][i] -118.683
[/i][i] 31
[/i][i] -161.515
[/i][i] 12
[/i][i] 25.2839
[/i][i] 22
[/i][i] -116.042
[/i][i] 32
[/i][i] -162.836
[/i][i] 13
[/i][i] 25.2839
[/i][i] 23
[/i][i] -116.042
[/i][i] 33
[/i][i] -162.836
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 18.3023
[/i][i] 20
[/i][i] -118.306
[/i][i] 30
[/i][i] -171.893
[/i][i] 11
[/i][i] 25.2839
[/i][i] 21
[/i][i] -116.042
[/i][i] 31
[/i][i] -162.836
[/i][i] 12
[/i][i] 9.62289
[/i][i] 22
[/i][i] -120.193
[/i][i] 32
[/i][i] -171.704
[/i][i] 13
[/i][i] 9.62289
[/i][i] 23
[/i][i] -120.193
[/i][i] 33
[/i][i] -171.704
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 9.62289
[/i][i] 20
[/i][i] -120.193
[/i][i] 30
[/i][i] -171.704
[/i][i] 11
[/i][i] 18.3023
[/i][i] 21
[/i][i] -118.306
[/i][i] 31
[/i][i] -171.893
[/i][i] 12
[/i][i] 13.0191
[/i][i] 22
[/i][i] -118.117
[/i][i] 32
[/i][i] -177.176
[/i][i] 13
[/i][i] 13.0191
[/i][i] 23
[/i][i] -118.117
[/i][i] 33
[/i][i] -177.176
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 4.15083
[/i][i] 20
[/i][i] -119.816
[/i][i] 30
[/i][i] -176.799
[/i][i] 11
[/i][i] 13.0191
[/i][i] 21
[/i][i] -118.117
[/i][i] 31
[/i][i] -177.176
[/i][i] 12
[/i][i] 9.62289
[/i][i] 22
[/i][i] -120.193
[/i][i] 32
[/i][i] -171.704
[/i][i] 13
[/i][i] 9.62289
[/i][i] 23
[/i][i] -120.193
[/i][i] 33
[/i][i] -171.704
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.4346
[/i][i] 20
[/i][i] -116.985
[/i][i] 30
[/i][i] -149.439
[/i][i] 11
[/i][i] 25.2839
[/i][i] 21
[/i][i] -116.042
[/i][i] 31
[/i][i] -162.836
[/i][i] 12
[/i][i] 15.4721
[/i][i] 22
[/i][i] -118.683
[/i][i] 32
[/i][i] -161.515
[/i][i] 13
[/i][i] 15.4721
[/i][i] 23
[/i][i] -118.683
[/i][i] 33
[/i][i] -161.515
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 9.62289
[/i][i] 20
[/i][i] -120.193
[/i][i] 30
[/i][i] -171.704
[/i][i] 11
[/i][i] 15.4721
[/i][i] 21
[/i][i] -118.683
[/i][i] 31
[/i][i] -161.515
[/i][i] 12
[/i][i] 3.39621
[/i][i] 22
[/i][i] -118.495
[/i][i] 32
[/i][i] -159.251
[/i][i] 13
[/i][i] 3.39621
[/i][i] 23
[/i][i] -118.495
[/i][i] 33
[/i][i] -159.251
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 3.39621
[/i][i] 20
[/i][i] -118.495
[/i][i] 30
[/i][i] -159.251
[/i][i] 11
[/i][i] 19.4346
[/i][i] 21
[/i][i] -116.985
[/i][i] 31
[/i][i] -149.439
[/i][i] 12
[/i][i] 15.4721
[/i][i] 22
[/i][i] -118.683
[/i][i] 32
[/i][i] -161.515
[/i][i] 13
[/i][i] 15.4721
[/i][i] 23
[/i][i] -118.683
[/i][i] 33
[/i][i] -161.515
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.6984
[/i][i] 20
[/i][i] -108.306
[/i][i] 30
[/i][i] -143.967
[/i][i] 11
[/i][i] 8.11337
[/i][i] 21
[/i][i] -116.985
[/i][i] 31
[/i][i] -145.854
[/i][i] 12
[/i][i] 3.39621
[/i][i] 22
[/i][i] -118.495
[/i][i] 32
[/i][i] -159.251
[/i][i] 13
[/i][i] 3.39621
[/i][i] 23
[/i][i] -118.495
[/i][i] 33
[/i][i] -159.251
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 3.39621
[/i][i] 20
[/i][i] -118.495
[/i][i] 30
[/i][i] -159.251
[/i][i] 11
[/i][i] 8.11337
[/i][i] 21
[/i][i] -116.985
[/i][i] 31
[/i][i] -145.854
[/i][i] 12
[/i][i] 19.4346
[/i][i] 22
[/i][i] -116.985
[/i][i] 32
[/i][i] -149.439
[/i][i] 13
[/i][i] 19.4346
[/i][i] 23
[/i][i] -116.985
[/i][i] 33
[/i][i] -149.439
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 11.6985
[/i][i] 20
[/i][i] -112.268
[/i][i] 30
[/i][i] -126.042
[/i][i] 11
[/i][i] 19.4346
[/i][i] 21
[/i][i] -116.985
[/i][i] 31
[/i][i] -149.439
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -106.796
[/i][i] 32
[/i][i] -119.627
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -106.796
[/i][i] 33
[/i][i] -119.627
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.6984
[/i][i] 20
[/i][i] -108.306
[/i][i] 30
[/i][i] -143.967
[/i][i] 11
[/i][i] 11.6985
[/i][i] 21
[/i][i] -112.268
[/i][i] 31
[/i][i] -126.042
[/i][i] 12
[/i][i] 8.11337
[/i][i] 22
[/i][i] -116.985
[/i][i] 32
[/i][i] -145.854
[/i][i] 13
[/i][i] 8.11337
[/i][i] 23
[/i][i] -116.985
[/i][i] 33
[/i][i] -145.854
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 5.09431
[/i][i] 20
[/i][i] -117.363
[/i][i] 30
[/i][i] -181.893
[/i][i] 11
[/i][i] 13.0191
[/i][i] 21
[/i][i] -118.117
[/i][i] 31
[/i][i] -177.176
[/i][i] 12
[/i][i] 4.15083
[/i][i] 22
[/i][i] -119.816
[/i][i] 32
[/i][i] -176.799
[/i][i] 13
[/i][i] 4.15083
[/i][i] 23
[/i][i] -119.816
[/i][i] 33
[/i][i] -176.799
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -23.9629
[/i][i] 20
[/i][i] -102.834
[/i][i] 30
[/i][i] -186.611
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -113.212
[/i][i] 31
[/i][i] -184.535
[/i][i] 12
[/i][i] -27.548
[/i][i] 22
[/i][i] -105.475
[/i][i] 32
[/i][i] -181.327
[/i][i] 13
[/i][i] -27.548
[/i][i] 23
[/i][i] -105.475
[/i][i] 33
[/i][i] -181.327
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.1324
[/i][i] 20
[/i][i] -113.212
[/i][i] 30
[/i][i] -184.535
[/i][i] 11
[/i][i] 4.15083
[/i][i] 21
[/i][i] -119.816
[/i][i] 31
[/i][i] -176.799
[/i][i] 12
[/i][i] 5.09431
[/i][i] 22
[/i][i] -117.363
[/i][i] 32
[/i][i] -181.893
[/i][i] 13
[/i][i] 5.09431
[/i][i] 23
[/i][i] -117.363
[/i][i] 33
[/i][i] -181.893
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 11.6985
[/i][i] 20
[/i][i] -112.268
[/i][i] 30
[/i][i] -126.042
[/i][i] 11
[/i][i] 27.7366
[/i][i] 21
[/i][i] -106.796
[/i][i] 31
[/i][i] -119.627
[/i][i] 12
[/i][i] 29.0575
[/i][i] 22
[/i][i] -100.947
[/i][i] 32
[/i][i] -108.683
[/i][i] 13
[/i][i] 29.0575
[/i][i] 23
[/i][i] -100.947
[/i][i] 33
[/i][i] -108.683
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 4.90573
[/i][i] 20
[/i][i] -97.7393
[/i][i] 30
[/i][i] -105.475
[/i][i] 11
[/i][i] 11.6985
[/i][i] 21
[/i][i] -112.268
[/i][i] 31
[/i][i] -126.042
[/i][i] 12
[/i][i] -1.32063
[/i][i] 22
[/i][i] -103.589
[/i][i] 32
[/i][i] -120.193
[/i][i] 13
[/i][i] -1.32063
[/i][i] 23
[/i][i] -103.589
[/i][i] 33
[/i][i] -120.193
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 14.5286
[/i][i] 20
[/i][i] -102.268
[/i][i] 30
[/i][i] -105.475
[/i][i] 11
[/i][i] 29.0575
[/i][i] 21
[/i][i] -100.947
[/i][i] 31
[/i][i] -108.683
[/i][i] 12
[/i][i] 11.6985
[/i][i] 22
[/i][i] -112.268
[/i][i] 32
[/i][i] -126.042
[/i][i] 13
[/i][i] 11.6985
[/i][i] 23
[/i][i] -112.268
[/i][i] 33
[/i][i] -126.042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 14.5286
[/i][i] 20
[/i][i] -102.268
[/i][i] 30
[/i][i] -105.475
[/i][i] 11
[/i][i] 17.3591
[/i][i] 21
[/i][i] -92.8335
[/i][i] 31
[/i][i] -91.324
[/i][i] 12
[/i][i] 29.0575
[/i][i] 22
[/i][i] -100.947
[/i][i] 32
[/i][i] -108.683
[/i][i] 13
[/i][i] 29.0575
[/i][i] 23
[/i][i] -100.947
[/i][i] 33
[/i][i] -108.683
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 17.3591
[/i][i] 20
[/i][i] -92.8335
[/i][i] 30
[/i][i] -91.324
[/i][i] 11
[/i][i] 29.0575
[/i][i] 21
[/i][i] -100.947
[/i][i] 31
[/i][i] -108.683
[/i][i] 12
[/i][i] 31.8877
[/i][i] 22
[/i][i] -91.324
[/i][i] 32
[/i][i] -95.0977
[/i][i] 13
[/i][i] 31.8877
[/i][i] 23
[/i][i] -91.324
[/i][i] 33
[/i][i] -95.0977
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.11337
[/i][i] 20
[/i][i] 15.8496
[/i][i] 30
[/i][i] -57.549
[/i][i] 11
[/i][i] 8.49081
[/i][i] 21
[/i][i] 24.7178
[/i][i] 31
[/i][i] -37.1709
[/i][i] 12
[/i][i] -0.188568
[/i][i] 22
[/i][i] 16.9816
[/i][i] 32
[/i][i] -51.1338
[/i][i] 13
[/i][i] -0.188568
[/i][i] 23
[/i][i] 16.9816
[/i][i] 33
[/i][i] -51.1338
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -8.30194
[/i][i] 20
[/i][i] -13.774
[/i][i] 30
[/i][i] -164.723
[/i][i] 11
[/i][i] -2.26413
[/i][i] 21
[/i][i] -22.8309
[/i][i] 31
[/i][i] -159.817
[/i][i] 12
[/i][i] -13.0191
[/i][i] 22
[/i][i] -26.0385
[/i][i] 32
[/i][i] -110.947
[/i][i] 13
[/i][i] -13.0191
[/i][i] 23
[/i][i] -26.0385
[/i][i] 33
[/i][i] -110.947
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -13.0191
[/i][i] 20
[/i][i] -26.0385
[/i][i] 30
[/i][i] -110.947
[/i][i] 11
[/i][i] -11.1324
[/i][i] 21
[/i][i] -28.6801
[/i][i] 31
[/i][i] -103.966
[/i][i] 12
[/i][i] -2.26413
[/i][i] 22
[/i][i] -22.8309
[/i][i] 32
[/i][i] -159.817
[/i][i] 13
[/i][i] -2.26413
[/i][i] 23
[/i][i] -22.8309
[/i][i] 33
[/i][i] -159.817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -8.86797
[/i][i] 20
[/i][i] 0.56604
[/i][i] 30
[/i][i] -85.2859
[/i][i] 11
[/i][i] -7.16986
[/i][i] 21
[/i][i] 3.01875
[/i][i] 31
[/i][i] -102.268
[/i][i] 12
[/i][i] -3.39619
[/i][i] 22
[/i][i] 7.92479
[/i][i] 32
[/i][i] -89.0596
[/i][i] 13
[/i][i] -3.39619
[/i][i] 23
[/i][i] 7.92479
[/i][i] 33
[/i][i] -89.0596
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -7.16986
[/i][i] 20
[/i][i] 3.01875
[/i][i] 30
[/i][i] -102.268
[/i][i] 11
[/i][i] 7.16988
[/i][i] 21
[/i][i] 12.6419
[/i][i] 31
[/i][i] -100.381
[/i][i] 12
[/i][i] -3.39619
[/i][i] 22
[/i][i] 7.92479
[/i][i] 32
[/i][i] -89.0596
[/i][i] 13
[/i][i] -3.39619
[/i][i] 23
[/i][i] 7.92479
[/i][i] 33
[/i][i] -89.0596
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.39619
[/i][i] 20
[/i][i] 7.92479
[/i][i] 30
[/i][i] -89.0596
[/i][i] 11
[/i][i] 7.16988
[/i][i] 21
[/i][i] 12.6419
[/i][i] 31
[/i][i] -100.381
[/i][i] 12
[/i][i] 6.98129
[/i][i] 22
[/i][i] 13.9626
[/i][i] 32
[/i][i] -67.1722
[/i][i] 13
[/i][i] 6.98129
[/i][i] 23
[/i][i] 13.9626
[/i][i] 33
[/i][i] -67.1722
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -8.30194
[/i][i] 20
[/i][i] -6.41525
[/i][i] 30
[/i][i] -1.88667
[/i][i] 11
[/i][i] -0.188568
[/i][i] 21
[/i][i] -11.321
[/i][i] 31
[/i][i] 1.88669
[/i][i] 12
[/i][i] -13.208
[/i][i] 22
[/i][i] -13.3965
[/i][i] 32
[/i][i] -6.22638
[/i][i] 13
[/i][i] -13.208
[/i][i] 23
[/i][i] -13.3965
[/i][i] 33
[/i][i] -6.22638
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.6607
[/i][i] 20
[/i][i] -1.69809
[/i][i] 30
[/i][i] -6.0378
[/i][i] 11
[/i][i] -13.208
[/i][i] 21
[/i][i] -13.3965
[/i][i] 31
[/i][i] -6.22638
[/i][i] 12
[/i][i] -21.3213
[/i][i] 22
[/i][i] -9.4343
[/i][i] 32
[/i][i] -13.3965
[/i][i] 13
[/i][i] -21.3213
[/i][i] 23
[/i][i] -9.4343
[/i][i] 33
[/i][i] -13.3965
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 11.6985
[/i][i] 20
[/i][i] -112.268
[/i][i] 30
[/i][i] -126.042
[/i][i] 11
[/i][i] 19.4346
[/i][i] 21
[/i][i] -116.985
[/i][i] 31
[/i][i] -149.439
[/i][i] 12
[/i][i] 8.11337
[/i][i] 22
[/i][i] -116.985
[/i][i] 32
[/i][i] -145.854
[/i][i] 13
[/i][i] 8.11337
[/i][i] 23
[/i][i] -116.985
[/i][i] 33
[/i][i] -145.854
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -27.3594
[/i][i] 20
[/i][i] -91.5126
[/i][i] 30
[/i][i] -167.742
[/i][i] 11
[/i][i] -15.4721
[/i][i] 21
[/i][i] -115.287
[/i][i] 31
[/i][i] -173.78
[/i][i] 12
[/i][i] -27.7366
[/i][i] 22
[/i][i] -105.853
[/i][i] 32
[/i][i] -176.044
[/i][i] 13
[/i][i] -27.7366
[/i][i] 23
[/i][i] -105.853
[/i][i] 33
[/i][i] -176.044
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -6.98128
[/i][i] 20
[/i][i] -118.495
[/i][i] 30
[/i][i] -169.629
[/i][i] 11
[/i][i] 9.62289
[/i][i] 21
[/i][i] -120.193
[/i][i] 31
[/i][i] -171.704
[/i][i] 12
[/i][i] -15.4721
[/i][i] 22
[/i][i] -115.287
[/i][i] 32
[/i][i] -173.78
[/i][i] 13
[/i][i] -15.4721
[/i][i] 23
[/i][i] -115.287
[/i][i] 33
[/i][i] -173.78
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -27.548
[/i][i] 20
[/i][i] -105.475
[/i][i] 30
[/i][i] -181.327
[/i][i] 11
[/i][i] -15.4721
[/i][i] 21
[/i][i] -115.287
[/i][i] 31
[/i][i] -173.78
[/i][i] 12
[/i][i] 4.15083
[/i][i] 22
[/i][i] -119.816
[/i][i] 32
[/i][i] -176.799
[/i][i] 13
[/i][i] 4.15083
[/i][i] 23
[/i][i] -119.816
[/i][i] 33
[/i][i] -176.799
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.9255
[/i][i] 20
[/i][i] 12.2645
[/i][i] 30
[/i][i] -184.912
[/i][i] 11
[/i][i] 28.869
[/i][i] 21
[/i][i] 11.887
[/i][i] 31
[/i][i] -181.705
[/i][i] 12
[/i][i] 32.8312
[/i][i] 22
[/i][i] 6.79242
[/i][i] 32
[/i][i] -180.761
[/i][i] 13
[/i][i] 32.8312
[/i][i] 23
[/i][i] 6.79242
[/i][i] 33
[/i][i] -180.761
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.9255
[/i][i] 20
[/i][i] 12.2645
[/i][i] 30
[/i][i] -184.912
[/i][i] 11
[/i][i] 29.8122
[/i][i] 21
[/i][i] -4.90572
[/i][i] 31
[/i][i] -183.214
[/i][i] 12
[/i][i] 32.8312
[/i][i] 22
[/i][i] 6.79242
[/i][i] 32
[/i][i] -180.761
[/i][i] 13
[/i][i] 32.8312
[/i][i] 23
[/i][i] 6.79242
[/i][i] 33
[/i][i] -180.761
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.2461
[/i][i] 20
[/i][i] 14.1512
[/i][i] 30
[/i][i] -23.2083
[/i][i] 11
[/i][i] 38.1144
[/i][i] 21
[/i][i] -1.88667
[/i][i] 31
[/i][i] -26.0385
[/i][i] 12
[/i][i] 33.2087
[/i][i] 22
[/i][i] -1.13205
[/i][i] 32
[/i][i] -16.6042
[/i][i] 13
[/i][i] 33.2087
[/i][i] 23
[/i][i] -1.13205
[/i][i] 33
[/i][i] -16.6042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.2461
[/i][i] 20
[/i][i] 14.1512
[/i][i] 30
[/i][i] -23.2083
[/i][i] 11
[/i][i] 38.1144
[/i][i] 21
[/i][i] -1.88667
[/i][i] 31
[/i][i] -26.0385
[/i][i] 12
[/i][i] 34.9068
[/i][i] 22
[/i][i] 13.0191
[/i][i] 32
[/i][i] -34.9068
[/i][i] 13
[/i][i] 34.9068
[/i][i] 23
[/i][i] 13.0191
[/i][i] 33
[/i][i] -34.9068
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 34.9068
[/i][i] 20
[/i][i] 13.0191
[/i][i] 30
[/i][i] -34.9068
[/i][i] 11
[/i][i] 43.9636
[/i][i] 21
[/i][i] -2.45271
[/i][i] 31
[/i][i] -36.9823
[/i][i] 12
[/i][i] 38.1144
[/i][i] 22
[/i][i] -1.88667
[/i][i] 32
[/i][i] -26.0385
[/i][i] 13
[/i][i] 38.1144
[/i][i] 23
[/i][i] -1.88667
[/i][i] 33
[/i][i] -26.0385
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 34.9068
[/i][i] 20
[/i][i] 13.0191
[/i][i] 30
[/i][i] -34.9068
[/i][i] 11
[/i][i] 40.19
[/i][i] 21
[/i][i] 12.2645
[/i][i] 31
[/i][i] -45.4731
[/i][i] 12
[/i][i] 43.9636
[/i][i] 22
[/i][i] -2.45271
[/i][i] 32
[/i][i] -36.9823
[/i][i] 13
[/i][i] 43.9636
[/i][i] 23
[/i][i] -2.45271
[/i][i] 33
[/i][i] -36.9823
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 40.19
[/i][i] 20
[/i][i] 12.2645
[/i][i] 30
[/i][i] -45.4731
[/i][i] 11
[/i][i] 43.9636
[/i][i] 21
[/i][i] -2.45271
[/i][i] 31
[/i][i] -36.9823
[/i][i] 12
[/i][i] 47.5487
[/i][i] 22
[/i][i] -3.58478
[/i][i] 32
[/i][i] -44.5296
[/i][i] 13
[/i][i] 47.5487
[/i][i] 23
[/i][i] -3.58478
[/i][i] 33
[/i][i] -44.5296
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 40.19
[/i][i] 20
[/i][i] 12.2645
[/i][i] 30
[/i][i] -45.4731
[/i][i] 11
[/i][i] 47.5487
[/i][i] 21
[/i][i] -3.58478
[/i][i] 31
[/i][i] -44.5296
[/i][i] 12
[/i][i] 45.4731
[/i][i] 22
[/i][i] 10.9435
[/i][i] 32
[/i][i] -54.7189
[/i][i] 13
[/i][i] 45.4731
[/i][i] 23
[/i][i] 10.9435
[/i][i] 33
[/i][i] -54.7189
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 45.4731
[/i][i] 20
[/i][i] 10.9435
[/i][i] 30
[/i][i] -54.7189
[/i][i] 11
[/i][i] 52.2659
[/i][i] 21
[/i][i] -6.22638
[/i][i] 31
[/i][i] -56.2284
[/i][i] 12
[/i][i] 47.5487
[/i][i] 22
[/i][i] -3.58478
[/i][i] 32
[/i][i] -44.5296
[/i][i] 13
[/i][i] 47.5487
[/i][i] 23
[/i][i] -3.58478
[/i][i] 33
[/i][i] -44.5296
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -16.9816
[/i][i] 30
[/i][i] -21.6988
[/i][i] 11
[/i][i] 33.2087
[/i][i] 21
[/i][i] -1.13205
[/i][i] 31
[/i][i] -16.6042
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -0.188568
[/i][i] 32
[/i][i] -9.62288
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -0.188568
[/i][i] 33
[/i][i] -9.62288
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.0381
[/i][i] 20
[/i][i] 20.5667
[/i][i] 30
[/i][i] -47.9261
[/i][i] 11
[/i][i] 16.0381
[/i][i] 21
[/i][i] 24.529
[/i][i] 31
[/i][i] -19.0572
[/i][i] 12
[/i][i] 29.2461
[/i][i] 22
[/i][i] 14.1512
[/i][i] 32
[/i][i] -23.2083
[/i][i] 13
[/i][i] 29.2461
[/i][i] 23
[/i][i] 14.1512
[/i][i] 33
[/i][i] -23.2083
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 7.16988
[/i][i] 20
[/i][i] 26.0385
[/i][i] 30
[/i][i] -8.30194
[/i][i] 11
[/i][i] 16.0381
[/i][i] 21
[/i][i] 24.529
[/i][i] 31
[/i][i] -19.0572
[/i][i] 12
[/i][i] 17.1702
[/i][i] 22
[/i][i] 17.5477
[/i][i] 32
[/i][i] -8.11336
[/i][i] 13
[/i][i] 17.1702
[/i][i] 23
[/i][i] 17.5477
[/i][i] 33
[/i][i] -8.11336
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 3.58479
[/i][i] 20
[/i][i] 29.0575
[/i][i] 30
[/i][i] -11.5096
[/i][i] 11
[/i][i] 16.0381
[/i][i] 21
[/i][i] 24.529
[/i][i] 31
[/i][i] -19.0572
[/i][i] 12
[/i][i] 7.16988
[/i][i] 22
[/i][i] 26.0385
[/i][i] 32
[/i][i] -8.30194
[/i][i] 13
[/i][i] 7.16988
[/i][i] 23
[/i][i] 26.0385
[/i][i] 33
[/i][i] -8.30194
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.0381
[/i][i] 20
[/i][i] 24.529
[/i][i] 30
[/i][i] -19.0572
[/i][i] 11
[/i][i] 29.2461
[/i][i] 21
[/i][i] 14.1512
[/i][i] 31
[/i][i] -23.2083
[/i][i] 12
[/i][i] 24.3404
[/i][i] 22
[/i][i] 15.8496
[/i][i] 32
[/i][i] -15.2835
[/i][i] 13
[/i][i] 24.3404
[/i][i] 23
[/i][i] 15.8496
[/i][i] 33
[/i][i] -15.2835
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.3404
[/i][i] 20
[/i][i] 15.8496
[/i][i] 30
[/i][i] -15.2835
[/i][i] 11
[/i][i] 33.2087
[/i][i] 21
[/i][i] -1.13205
[/i][i] 31
[/i][i] -16.6042
[/i][i] 12
[/i][i] 29.2461
[/i][i] 22
[/i][i] 14.1512
[/i][i] 32
[/i][i] -23.2083
[/i][i] 13
[/i][i] 29.2461
[/i][i] 23
[/i][i] 14.1512
[/i][i] 33
[/i][i] -23.2083
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.3404
[/i][i] 20
[/i][i] 15.8496
[/i][i] 30
[/i][i] -15.2835
[/i][i] 11
[/i][i] 27.7366
[/i][i] 21
[/i][i] -0.188568
[/i][i] 31
[/i][i] -9.62288
[/i][i] 12
[/i][i] 33.2087
[/i][i] 22
[/i][i] -1.13205
[/i][i] 32
[/i][i] -16.6042
[/i][i] 13
[/i][i] 33.2087
[/i][i] 23
[/i][i] -1.13205
[/i][i] 33
[/i][i] -16.6042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 16.0381
[/i][i] 20
[/i][i] 24.529
[/i][i] 30
[/i][i] -19.0572
[/i][i] 11
[/i][i] 17.1702
[/i][i] 21
[/i][i] 17.5477
[/i][i] 31
[/i][i] -8.11336
[/i][i] 12
[/i][i] 24.3404
[/i][i] 22
[/i][i] 15.8496
[/i][i] 32
[/i][i] -15.2835
[/i][i] 13
[/i][i] 24.3404
[/i][i] 23
[/i][i] 15.8496
[/i][i] 33
[/i][i] -15.2835
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 45.4731
[/i][i] 20
[/i][i] 10.9435
[/i][i] 30
[/i][i] -54.7189
[/i][i] 11
[/i][i] 51.6998
[/i][i] 21
[/i][i] 9.05685
[/i][i] 31
[/i][i] -69.4364
[/i][i] 12
[/i][i] 52.2659
[/i][i] 22
[/i][i] -6.22638
[/i][i] 32
[/i][i] -56.2284
[/i][i] 13
[/i][i] 52.2659
[/i][i] 23
[/i][i] -6.22638
[/i][i] 33
[/i][i] -56.2284
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.6998
[/i][i] 20
[/i][i] 9.05685
[/i][i] 30
[/i][i] -69.4364
[/i][i] 11
[/i][i] 52.2659
[/i][i] 21
[/i][i] -6.22638
[/i][i] 31
[/i][i] -56.2284
[/i][i] 12
[/i][i] 55.8509
[/i][i] 22
[/i][i] -10.0003
[/i][i] 32
[/i][i] -77.3611
[/i][i] 13
[/i][i] 55.8509
[/i][i] 23
[/i][i] -10.0003
[/i][i] 33
[/i][i] -77.3611
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.6998
[/i][i] 20
[/i][i] 9.05685
[/i][i] 30
[/i][i] -69.4364
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -10.0003
[/i][i] 31
[/i][i] -77.3611
[/i][i] 12
[/i][i] 53.3979
[/i][i] 22
[/i][i] 6.79242
[/i][i] 32
[/i][i] -80.1913
[/i][i] 13
[/i][i] 53.3979
[/i][i] 23
[/i][i] 6.79242
[/i][i] 33
[/i][i] -80.1913
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 53.3979
[/i][i] 20
[/i][i] 6.79242
[/i][i] 30
[/i][i] -80.1913
[/i][i] 11
[/i][i] 55.4735
[/i][i] 21
[/i][i] -12.8305
[/i][i] 31
[/i][i] -89.0596
[/i][i] 12
[/i][i] 55.8509
[/i][i] 22
[/i][i] -10.0003
[/i][i] 32
[/i][i] -77.3611
[/i][i] 13
[/i][i] 55.8509
[/i][i] 23
[/i][i] -10.0003
[/i][i] 33
[/i][i] -77.3611
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 53.3979
[/i][i] 20
[/i][i] 6.79242
[/i][i] 30
[/i][i] -80.1913
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] 3.01875
[/i][i] 31
[/i][i] -97.5507
[/i][i] 12
[/i][i] 55.4735
[/i][i] 22
[/i][i] -12.8305
[/i][i] 32
[/i][i] -89.0596
[/i][i] 13
[/i][i] 55.4735
[/i][i] 23
[/i][i] -12.8305
[/i][i] 33
[/i][i] -89.0596
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 54.7189
[/i][i] 20
[/i][i] 3.01875
[/i][i] 30
[/i][i] -97.5507
[/i][i] 11
[/i][i] 55.4735
[/i][i] 21
[/i][i] -12.8305
[/i][i] 31
[/i][i] -89.0596
[/i][i] 12
[/i][i] 52.4547
[/i][i] 22
[/i][i] -17.5477
[/i][i] 32
[/i][i] -106.796
[/i][i] 13
[/i][i] 52.4547
[/i][i] 23
[/i][i] -17.5477
[/i][i] 33
[/i][i] -106.796
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 36.0388
[/i][i] 20
[/i][i] -6.22638
[/i][i] 30
[/i][i] -171.704
[/i][i] 11
[/i][i] 38.1144
[/i][i] 21
[/i][i] 2.26414
[/i][i] 31
[/i][i] -146.986
[/i][i] 12
[/i][i] 38.6804
[/i][i] 22
[/i][i] -7.7359
[/i][i] 32
[/i][i] -159.817
[/i][i] 13
[/i][i] 38.6804
[/i][i] 23
[/i][i] -7.7359
[/i][i] 33
[/i][i] -159.817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.20761
[/i][i] 20
[/i][i] 12.4531
[/i][i] 30
[/i][i] -179.063
[/i][i] 11
[/i][i] -1.88667
[/i][i] 21
[/i][i] 3.58479
[/i][i] 31
[/i][i] -169.818
[/i][i] 12
[/i][i] 10.1889
[/i][i] 22
[/i][i] 2.26414
[/i][i] 32
[/i][i] -170.572
[/i][i] 13
[/i][i] 10.1889
[/i][i] 23
[/i][i] 2.26414
[/i][i] 33
[/i][i] -170.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.7366
[/i][i] 20
[/i][i] -16.793
[/i][i] 30
[/i][i] -165.666
[/i][i] 11
[/i][i] 38.6804
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -159.817
[/i][i] 12
[/i][i] 38.6804
[/i][i] 22
[/i][i] -17.7362
[/i][i] 32
[/i][i] -140.382
[/i][i] 13
[/i][i] 38.6804
[/i][i] 23
[/i][i] -17.7362
[/i][i] 33
[/i][i] -140.382
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.1144
[/i][i] 20
[/i][i] 2.26414
[/i][i] 30
[/i][i] -146.986
[/i][i] 11
[/i][i] 38.6804
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -159.817
[/i][i] 12
[/i][i] 42.643
[/i][i] 22
[/i][i] -7.92477
[/i][i] 32
[/i][i] -147.741
[/i][i] 13
[/i][i] 42.643
[/i][i] 23
[/i][i] -7.92477
[/i][i] 33
[/i][i] -147.741
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 42.643
[/i][i] 20
[/i][i] -7.92477
[/i][i] 30
[/i][i] -147.741
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -130.005
[/i][i] 12
[/i][i] 38.1144
[/i][i] 22
[/i][i] 2.26414
[/i][i] 32
[/i][i] -146.986
[/i][i] 13
[/i][i] 38.1144
[/i][i] 23
[/i][i] 2.26414
[/i][i] 33
[/i][i] -146.986
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 42.643
[/i][i] 20
[/i][i] -7.92477
[/i][i] 30
[/i][i] -147.741
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -130.005
[/i][i] 12
[/i][i] 38.6804
[/i][i] 22
[/i][i] -17.7362
[/i][i] 32
[/i][i] -140.382
[/i][i] 13
[/i][i] 38.6804
[/i][i] 23
[/i][i] -17.7362
[/i][i] 33
[/i][i] -140.382
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.6804
[/i][i] 20
[/i][i] -7.7359
[/i][i] 30
[/i][i] -159.817
[/i][i] 11
[/i][i] 42.643
[/i][i] 21
[/i][i] -7.92477
[/i][i] 31
[/i][i] -147.741
[/i][i] 12
[/i][i] 38.6804
[/i][i] 22
[/i][i] -17.7362
[/i][i] 32
[/i][i] -140.382
[/i][i] 13
[/i][i] 38.6804
[/i][i] 23
[/i][i] -17.7362
[/i][i] 33
[/i][i] -140.382
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.8122
[/i][i] 20
[/i][i] -4.90572
[/i][i] 30
[/i][i] -183.214
[/i][i] 11
[/i][i] 32.8312
[/i][i] 21
[/i][i] 6.79242
[/i][i] 31
[/i][i] -180.761
[/i][i] 12
[/i][i] 36.0388
[/i][i] 22
[/i][i] -6.22638
[/i][i] 32
[/i][i] -171.704
[/i][i] 13
[/i][i] 36.0388
[/i][i] 23
[/i][i] -6.22638
[/i][i] 33
[/i][i] -171.704
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.8877
[/i][i] 20
[/i][i] 2.83018
[/i][i] 30
[/i][i] -171.327
[/i][i] 11
[/i][i] 36.0388
[/i][i] 21
[/i][i] -6.22638
[/i][i] 31
[/i][i] -171.704
[/i][i] 12
[/i][i] 32.8312
[/i][i] 22
[/i][i] 6.79242
[/i][i] 32
[/i][i] -180.761
[/i][i] 13
[/i][i] 32.8312
[/i][i] 23
[/i][i] 6.79242
[/i][i] 33
[/i][i] -180.761
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 36.0388
[/i][i] 20
[/i][i] -6.22638
[/i][i] 30
[/i][i] -171.704
[/i][i] 11
[/i][i] 38.6804
[/i][i] 21
[/i][i] -7.7359
[/i][i] 31
[/i][i] -159.817
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -16.793
[/i][i] 32
[/i][i] -165.666
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -16.793
[/i][i] 33
[/i][i] -165.666
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 25.4725
[/i][i] 20
[/i][i] -13.208
[/i][i] 30
[/i][i] -183.025
[/i][i] 11
[/i][i] 36.0388
[/i][i] 21
[/i][i] -6.22638
[/i][i] 31
[/i][i] -171.704
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -16.793
[/i][i] 32
[/i][i] -165.666
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -16.793
[/i][i] 33
[/i][i] -165.666
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.8122
[/i][i] 20
[/i][i] -4.90572
[/i][i] 30
[/i][i] -183.214
[/i][i] 11
[/i][i] 36.0388
[/i][i] 21
[/i][i] -6.22638
[/i][i] 31
[/i][i] -171.704
[/i][i] 12
[/i][i] 25.4725
[/i][i] 22
[/i][i] -13.208
[/i][i] 32
[/i][i] -183.025
[/i][i] 13
[/i][i] 25.4725
[/i][i] 23
[/i][i] -13.208
[/i][i] 33
[/i][i] -183.025
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.7934
[/i][i] 20
[/i][i] 6.41527
[/i][i] 30
[/i][i] -170.572
[/i][i] 11
[/i][i] 28.869
[/i][i] 21
[/i][i] 11.887
[/i][i] 31
[/i][i] -181.705
[/i][i] 12
[/i][i] 32.8312
[/i][i] 22
[/i][i] 6.79242
[/i][i] 32
[/i][i] -180.761
[/i][i] 13
[/i][i] 32.8312
[/i][i] 23
[/i][i] 6.79242
[/i][i] 33
[/i][i] -180.761
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.321
[/i][i] 20
[/i][i] 8.6794
[/i][i] 30
[/i][i] -184.158
[/i][i] 11
[/i][i] -10.7549
[/i][i] 21
[/i][i] 7.73592
[/i][i] 31
[/i][i] -179.629
[/i][i] 12
[/i][i] -3.20761
[/i][i] 22
[/i][i] 12.4531
[/i][i] 32
[/i][i] -179.063
[/i][i] 13
[/i][i] -3.20761
[/i][i] 23
[/i][i] 12.4531
[/i][i] 33
[/i][i] -179.063
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -3.20761
[/i][i] 20
[/i][i] 12.4531
[/i][i] 30
[/i][i] -179.063
[/i][i] 11
[/i][i] 10.1889
[/i][i] 21
[/i][i] 2.26414
[/i][i] 31
[/i][i] -170.572
[/i][i] 12
[/i][i] 8.6794
[/i][i] 22
[/i][i] 10.755
[/i][i] 32
[/i][i] -180.572
[/i][i] 13
[/i][i] 8.6794
[/i][i] 23
[/i][i] 10.755
[/i][i] 33
[/i][i] -180.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.6794
[/i][i] 20
[/i][i] 11.6985
[/i][i] 30
[/i][i] -184.346
[/i][i] 11
[/i][i] 19.0572
[/i][i] 21
[/i][i] 15.2835
[/i][i] 31
[/i][i] -179.818
[/i][i] 12
[/i][i] 19.4346
[/i][i] 22
[/i][i] 16.0381
[/i][i] 32
[/i][i] -184.535
[/i][i] 13
[/i][i] 19.4346
[/i][i] 23
[/i][i] 16.0381
[/i][i] 33
[/i][i] -184.535
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.6794
[/i][i] 20
[/i][i] 10.755
[/i][i] 30
[/i][i] -180.572
[/i][i] 11
[/i][i] 8.6794
[/i][i] 21
[/i][i] 11.6985
[/i][i] 31
[/i][i] -184.346
[/i][i] 12
[/i][i] 19.0572
[/i][i] 22
[/i][i] 15.2835
[/i][i] 32
[/i][i] -179.818
[/i][i] 13
[/i][i] 19.0572
[/i][i] 23
[/i][i] 15.2835
[/i][i] 33
[/i][i] -179.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 8.6794
[/i][i] 20
[/i][i] 10.755
[/i][i] 30
[/i][i] -180.572
[/i][i] 11
[/i][i] 10.1889
[/i][i] 21
[/i][i] 2.26414
[/i][i] 31
[/i][i] -170.572
[/i][i] 12
[/i][i] 19.0572
[/i][i] 22
[/i][i] 15.2835
[/i][i] 32
[/i][i] -179.818
[/i][i] 13
[/i][i] 19.0572
[/i][i] 23
[/i][i] 15.2835
[/i][i] 33
[/i][i] -179.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.0572
[/i][i] 20
[/i][i] 15.2835
[/i][i] 30
[/i][i] -179.818
[/i][i] 11
[/i][i] 21.3213
[/i][i] 21
[/i][i] 7.16988
[/i][i] 31
[/i][i] -170.006
[/i][i] 12
[/i][i] 10.1889
[/i][i] 22
[/i][i] 2.26414
[/i][i] 32
[/i][i] -170.572
[/i][i] 13
[/i][i] 10.1889
[/i][i] 23
[/i][i] 2.26414
[/i][i] 33
[/i][i] -170.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 21.3213
[/i][i] 20
[/i][i] 7.16988
[/i][i] 30
[/i][i] -170.006
[/i][i] 11
[/i][i] 26.7934
[/i][i] 21
[/i][i] 6.41527
[/i][i] 31
[/i][i] -170.572
[/i][i] 12
[/i][i] 19.0572
[/i][i] 22
[/i][i] 15.2835
[/i][i] 32
[/i][i] -179.818
[/i][i] 13
[/i][i] 19.0572
[/i][i] 23
[/i][i] 15.2835
[/i][i] 33
[/i][i] -179.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.0572
[/i][i] 20
[/i][i] 15.2835
[/i][i] 30
[/i][i] -179.818
[/i][i] 11
[/i][i] 28.869
[/i][i] 21
[/i][i] 11.887
[/i][i] 31
[/i][i] -181.705
[/i][i] 12
[/i][i] 26.7934
[/i][i] 22
[/i][i] 6.41527
[/i][i] 32
[/i][i] -170.572
[/i][i] 13
[/i][i] 26.7934
[/i][i] 23
[/i][i] 6.41527
[/i][i] 33
[/i][i] -170.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.0572
[/i][i] 20
[/i][i] 15.2835
[/i][i] 30
[/i][i] -179.818
[/i][i] 11
[/i][i] 27.9255
[/i][i] 21
[/i][i] 12.2645
[/i][i] 31
[/i][i] -184.912
[/i][i] 12
[/i][i] 28.869
[/i][i] 22
[/i][i] 11.887
[/i][i] 32
[/i][i] -181.705
[/i][i] 13
[/i][i] 28.869
[/i][i] 23
[/i][i] 11.887
[/i][i] 33
[/i][i] -181.705
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.0572
[/i][i] 20
[/i][i] 15.2835
[/i][i] 30
[/i][i] -179.818
[/i][i] 11
[/i][i] 19.4346
[/i][i] 21
[/i][i] 16.0381
[/i][i] 31
[/i][i] -184.535
[/i][i] 12
[/i][i] 27.9255
[/i][i] 22
[/i][i] 12.2645
[/i][i] 32
[/i][i] -184.912
[/i][i] 13
[/i][i] 27.9255
[/i][i] 23
[/i][i] 12.2645
[/i][i] 33
[/i][i] -184.912
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 17.3591
[/i][i] 20
[/i][i] -92.8335
[/i][i] 30
[/i][i] -91.324
[/i][i] 11
[/i][i] 26.7934
[/i][i] 21
[/i][i] -86.6069
[/i][i] 31
[/i][i] -84.9088
[/i][i] 12
[/i][i] 31.8877
[/i][i] 22
[/i][i] -91.324
[/i][i] 32
[/i][i] -95.0977
[/i][i] 13
[/i][i] 31.8877
[/i][i] 23
[/i][i] -91.324
[/i][i] 33
[/i][i] -95.0977
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.7934
[/i][i] 20
[/i][i] -86.6069
[/i][i] 30
[/i][i] -84.9088
[/i][i] 11
[/i][i] 31.8877
[/i][i] 21
[/i][i] -91.324
[/i][i] 31
[/i][i] -95.0977
[/i][i] 12
[/i][i] 35.0954
[/i][i] 22
[/i][i] -78.6821
[/i][i] 32
[/i][i] -80.9462
[/i][i] 13
[/i][i] 35.0954
[/i][i] 23
[/i][i] -78.6821
[/i][i] 33
[/i][i] -80.9462
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 26.7934
[/i][i] 20
[/i][i] -86.6069
[/i][i] 30
[/i][i] -84.9088
[/i][i] 11
[/i][i] 35.0954
[/i][i] 21
[/i][i] -78.6821
[/i][i] 31
[/i][i] -80.9462
[/i][i] 12
[/i][i] 20.3779
[/i][i] 22
[/i][i] -80.7576
[/i][i] 32
[/i][i] -76.9837
[/i][i] 13
[/i][i] 20.3779
[/i][i] 23
[/i][i] -80.7576
[/i][i] 33
[/i][i] -76.9837
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 20.3779
[/i][i] 20
[/i][i] -80.7576
[/i][i] 30
[/i][i] -76.9837
[/i][i] 11
[/i][i] 26.7934
[/i][i] 21
[/i][i] -86.6069
[/i][i] 31
[/i][i] -84.9088
[/i][i] 12
[/i][i] 17.3591
[/i][i] 22
[/i][i] -92.8335
[/i][i] 32
[/i][i] -91.324
[/i][i] 13
[/i][i] 17.3591
[/i][i] 23
[/i][i] -92.8335
[/i][i] 33
[/i][i] -91.324
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 20.3779
[/i][i] 20
[/i][i] -80.7576
[/i][i] 30
[/i][i] -76.9837
[/i][i] 11
[/i][i] 29.435
[/i][i] 21
[/i][i] -73.21
[/i][i] 31
[/i][i] -71.3233
[/i][i] 12
[/i][i] 35.0954
[/i][i] 22
[/i][i] -78.6821
[/i][i] 32
[/i][i] -80.9462
[/i][i] 13
[/i][i] 35.0954
[/i][i] 23
[/i][i] -78.6821
[/i][i] 33
[/i][i] -80.9462
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.435
[/i][i] 20
[/i][i] -73.21
[/i][i] 30
[/i][i] -71.3233
[/i][i] 11
[/i][i] 35.0954
[/i][i] 21
[/i][i] -78.6821
[/i][i] 31
[/i][i] -80.9462
[/i][i] 12
[/i][i] 37.1709
[/i][i] 22
[/i][i] -64.3418
[/i][i] 32
[/i][i] -68.4929
[/i][i] 13
[/i][i] 37.1709
[/i][i] 23
[/i][i] -64.3418
[/i][i] 33
[/i][i] -68.4929
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.435
[/i][i] 20
[/i][i] -73.21
[/i][i] 30
[/i][i] -71.3233
[/i][i] 11
[/i][i] 37.1709
[/i][i] 21
[/i][i] -64.3418
[/i][i] 31
[/i][i] -68.4929
[/i][i] 12
[/i][i] 22.8309
[/i][i] 22
[/i][i] -66.4173
[/i][i] 32
[/i][i] -64.1532
[/i][i] 13
[/i][i] 22.8309
[/i][i] 23
[/i][i] -66.4173
[/i][i] 33
[/i][i] -64.1532
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 22.8309
[/i][i] 20
[/i][i] -66.4173
[/i][i] 30
[/i][i] -64.1532
[/i][i] 11
[/i][i] 29.435
[/i][i] 21
[/i][i] -73.21
[/i][i] 31
[/i][i] -71.3233
[/i][i] 12
[/i][i] 20.3779
[/i][i] 22
[/i][i] -80.7576
[/i][i] 32
[/i][i] -76.9837
[/i][i] 13
[/i][i] 20.3779
[/i][i] 23
[/i][i] -80.7576
[/i][i] 33
[/i][i] -76.9837
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 22.8309
[/i][i] 20
[/i][i] -66.4173
[/i][i] 30
[/i][i] -64.1532
[/i][i] 11
[/i][i] 24.9064
[/i][i] 21
[/i][i] -51.3224
[/i][i] 31
[/i][i] -53.3979
[/i][i] 12
[/i][i] 37.1709
[/i][i] 22
[/i][i] -64.3418
[/i][i] 32
[/i][i] -68.4929
[/i][i] 13
[/i][i] 37.1709
[/i][i] 23
[/i][i] -64.3418
[/i][i] 33
[/i][i] -68.4929
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.9064
[/i][i] 20
[/i][i] -51.3224
[/i][i] 30
[/i][i] -53.3979
[/i][i] 11
[/i][i] 37.1709
[/i][i] 21
[/i][i] -64.3418
[/i][i] 31
[/i][i] -68.4929
[/i][i] 12
[/i][i] 38.1144
[/i][i] 22
[/i][i] -48.6808
[/i][i] 32
[/i][i] -57.549
[/i][i] 13
[/i][i] 38.1144
[/i][i] 23
[/i][i] -48.6808
[/i][i] 33
[/i][i] -57.549
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.9064
[/i][i] 20
[/i][i] -51.3224
[/i][i] 30
[/i][i] -53.3979
[/i][i] 11
[/i][i] 38.1144
[/i][i] 21
[/i][i] -48.6808
[/i][i] 31
[/i][i] -57.549
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -42.643
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -42.643
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.9064
[/i][i] 20
[/i][i] -51.3224
[/i][i] 30
[/i][i] -53.3979
[/i][i] 11
[/i][i] 39.0579
[/i][i] 21
[/i][i] -28.6801
[/i][i] 31
[/i][i] -42.643
[/i][i] 12
[/i][i] 24.529
[/i][i] 22
[/i][i] -35.6617
[/i][i] 32
[/i][i] -43.0204
[/i][i] 13
[/i][i] 24.529
[/i][i] 23
[/i][i] -35.6617
[/i][i] 33
[/i][i] -43.0204
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 24.529
[/i][i] 20
[/i][i] -35.6617
[/i][i] 30
[/i][i] -43.0204
[/i][i] 11
[/i][i] 35.4728
[/i][i] 21
[/i][i] -20.3778
[/i][i] 31
[/i][i] -30.7556
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -42.643
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -42.643
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 23.2083
[/i][i] 20
[/i][i] -30.001
[/i][i] 30
[/i][i] -36.4163
[/i][i] 11
[/i][i] 24.529
[/i][i] 21
[/i][i] -35.6617
[/i][i] 31
[/i][i] -43.0204
[/i][i] 12
[/i][i] 35.4728
[/i][i] 22
[/i][i] -20.3778
[/i][i] 32
[/i][i] -30.7556
[/i][i] 13
[/i][i] 35.4728
[/i][i] 23
[/i][i] -20.3778
[/i][i] 33
[/i][i] -30.7556
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 35.4728
[/i][i] 20
[/i][i] -20.3778
[/i][i] 30
[/i][i] -30.7556
[/i][i] 11
[/i][i] 43.9636
[/i][i] 21
[/i][i] -2.45271
[/i][i] 31
[/i][i] -36.9823
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -42.643
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -42.643
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 39.0579
[/i][i] 20
[/i][i] -28.6801
[/i][i] 30
[/i][i] -42.643
[/i][i] 11
[/i][i] 43.9636
[/i][i] 21
[/i][i] -2.45271
[/i][i] 31
[/i][i] -36.9823
[/i][i] 12
[/i][i] 47.3601
[/i][i] 22
[/i][i] -13.208
[/i][i] 32
[/i][i] -43.3976
[/i][i] 13
[/i][i] 47.3601
[/i][i] 23
[/i][i] -13.208
[/i][i] 33
[/i][i] -43.3976
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 47.3601
[/i][i] 20
[/i][i] -13.208
[/i][i] 30
[/i][i] -43.3976
[/i][i] 11
[/i][i] 48.4922
[/i][i] 21
[/i][i] -19.0572
[/i][i] 31
[/i][i] -48.4922
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -42.643
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -42.643
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -16.9816
[/i][i] 30
[/i][i] -21.6988
[/i][i] 11
[/i][i] 33.2087
[/i][i] 21
[/i][i] -1.13205
[/i][i] 31
[/i][i] -16.6042
[/i][i] 12
[/i][i] 35.4728
[/i][i] 22
[/i][i] -20.3778
[/i][i] 32
[/i][i] -30.7556
[/i][i] 13
[/i][i] 35.4728
[/i][i] 23
[/i][i] -20.3778
[/i][i] 33
[/i][i] -30.7556
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 33.2087
[/i][i] 20
[/i][i] -1.13205
[/i][i] 30
[/i][i] -16.6042
[/i][i] 11
[/i][i] 35.4728
[/i][i] 21
[/i][i] -20.3778
[/i][i] 31
[/i][i] -30.7556
[/i][i] 12
[/i][i] 38.1144
[/i][i] 22
[/i][i] -1.88667
[/i][i] 32
[/i][i] -26.0385
[/i][i] 13
[/i][i] 38.1144
[/i][i] 23
[/i][i] -1.88667
[/i][i] 33
[/i][i] -26.0385
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.1144
[/i][i] 20
[/i][i] -1.88667
[/i][i] 30
[/i][i] -26.0385
[/i][i] 11
[/i][i] 43.9636
[/i][i] 21
[/i][i] -2.45271
[/i][i] 31
[/i][i] -36.9823
[/i][i] 12
[/i][i] 35.4728
[/i][i] 22
[/i][i] -20.3778
[/i][i] 32
[/i][i] -30.7556
[/i][i] 13
[/i][i] 35.4728
[/i][i] 23
[/i][i] -20.3778
[/i][i] 33
[/i][i] -30.7556
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 39.0579
[/i][i] 20
[/i][i] -28.6801
[/i][i] 30
[/i][i] -42.643
[/i][i] 11
[/i][i] 48.4922
[/i][i] 21
[/i][i] -19.0572
[/i][i] 31
[/i][i] -48.4922
[/i][i] 12
[/i][i] 49.2468
[/i][i] 22
[/i][i] -28.114
[/i][i] 32
[/i][i] -56.417
[/i][i] 13
[/i][i] 49.2468
[/i][i] 23
[/i][i] -28.114
[/i][i] 33
[/i][i] -56.417
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 49.2468
[/i][i] 20
[/i][i] -28.114
[/i][i] 30
[/i][i] -56.417
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -40.3788
[/i][i] 31
[/i][i] -66.2287
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -42.643
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -42.643
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 39.0579
[/i][i] 20
[/i][i] -28.6801
[/i][i] 30
[/i][i] -42.643
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -40.3788
[/i][i] 31
[/i][i] -66.2287
[/i][i] 12
[/i][i] 38.1144
[/i][i] 22
[/i][i] -48.6808
[/i][i] 32
[/i][i] -57.549
[/i][i] 13
[/i][i] 38.1144
[/i][i] 23
[/i][i] -48.6808
[/i][i] 33
[/i][i] -57.549
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.1144
[/i][i] 20
[/i][i] -48.6808
[/i][i] 30
[/i][i] -57.549
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -40.3788
[/i][i] 31
[/i][i] -66.2287
[/i][i] 12
[/i][i] 37.1709
[/i][i] 22
[/i][i] -64.3418
[/i][i] 32
[/i][i] -68.4929
[/i][i] 13
[/i][i] 37.1709
[/i][i] 23
[/i][i] -64.3418
[/i][i] 33
[/i][i] -68.4929
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 37.1709
[/i][i] 20
[/i][i] -64.3418
[/i][i] 30
[/i][i] -68.4929
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -40.3788
[/i][i] 31
[/i][i] -66.2287
[/i][i] 12
[/i][i] 49.2468
[/i][i] 22
[/i][i] -56.6058
[/i][i] 32
[/i][i] -79.4367
[/i][i] 13
[/i][i] 49.2468
[/i][i] 23
[/i][i] -56.6058
[/i][i] 33
[/i][i] -79.4367
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.9827
[/i][i] 20
[/i][i] -70.5684
[/i][i] 30
[/i][i] -92.6447
[/i][i] 11
[/i][i] 49.2468
[/i][i] 21
[/i][i] -56.6058
[/i][i] 31
[/i][i] -79.4367
[/i][i] 12
[/i][i] 37.1709
[/i][i] 22
[/i][i] -64.3418
[/i][i] 32
[/i][i] -68.4929
[/i][i] 13
[/i][i] 37.1709
[/i][i] 23
[/i][i] -64.3418
[/i][i] 33
[/i][i] -68.4929
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 37.1709
[/i][i] 20
[/i][i] -64.3418
[/i][i] 30
[/i][i] -68.4929
[/i][i] 11
[/i][i] 46.9827
[/i][i] 21
[/i][i] -70.5684
[/i][i] 31
[/i][i] -92.6447
[/i][i] 12
[/i][i] 35.0954
[/i][i] 22
[/i][i] -78.6821
[/i][i] 32
[/i][i] -80.9462
[/i][i] 13
[/i][i] 35.0954
[/i][i] 23
[/i][i] -78.6821
[/i][i] 33
[/i][i] -80.9462
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 35.0954
[/i][i] 20
[/i][i] -78.6821
[/i][i] 30
[/i][i] -80.9462
[/i][i] 11
[/i][i] 46.9827
[/i][i] 21
[/i][i] -70.5684
[/i][i] 31
[/i][i] -92.6447
[/i][i] 12
[/i][i] 31.8877
[/i][i] 22
[/i][i] -91.324
[/i][i] 32
[/i][i] -95.0977
[/i][i] 13
[/i][i] 31.8877
[/i][i] 23
[/i][i] -91.324
[/i][i] 33
[/i][i] -95.0977
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.8877
[/i][i] 20
[/i][i] -91.324
[/i][i] 30
[/i][i] -95.0977
[/i][i] 11
[/i][i] 46.9827
[/i][i] 21
[/i][i] -70.5684
[/i][i] 31
[/i][i] -92.6447
[/i][i] 12
[/i][i] 41.6995
[/i][i] 22
[/i][i] -87.5504
[/i][i] 32
[/i][i] -109.815
[/i][i] 13
[/i][i] 41.6995
[/i][i] 23
[/i][i] -87.5504
[/i][i] 33
[/i][i] -109.815
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 36.9823
[/i][i] 20
[/i][i] -97.1732
[/i][i] 30
[/i][i] -116.042
[/i][i] 11
[/i][i] 41.6995
[/i][i] 21
[/i][i] -87.5504
[/i][i] 31
[/i][i] -109.815
[/i][i] 12
[/i][i] 31.8877
[/i][i] 22
[/i][i] -91.324
[/i][i] 32
[/i][i] -95.0977
[/i][i] 13
[/i][i] 31.8877
[/i][i] 23
[/i][i] -91.324
[/i][i] 33
[/i][i] -95.0977
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.7366
[/i][i] 20
[/i][i] -106.796
[/i][i] 30
[/i][i] -119.627
[/i][i] 11
[/i][i] 36.9823
[/i][i] 21
[/i][i] -97.1732
[/i][i] 31
[/i][i] -116.042
[/i][i] 12
[/i][i] 30.7556
[/i][i] 22
[/i][i] -108.494
[/i][i] 32
[/i][i] -126.42
[/i][i] 13
[/i][i] 30.7556
[/i][i] 23
[/i][i] -108.494
[/i][i] 33
[/i][i] -126.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.4346
[/i][i] 20
[/i][i] -116.985
[/i][i] 30
[/i][i] -149.439
[/i][i] 11
[/i][i] 30.7556
[/i][i] 21
[/i][i] -108.494
[/i][i] 31
[/i][i] -126.42
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -106.796
[/i][i] 32
[/i][i] -119.627
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -106.796
[/i][i] 33
[/i][i] -119.627
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.8877
[/i][i] 20
[/i][i] -91.324
[/i][i] 30
[/i][i] -95.0977
[/i][i] 11
[/i][i] 36.9823
[/i][i] 21
[/i][i] -97.1732
[/i][i] 31
[/i][i] -116.042
[/i][i] 12
[/i][i] 29.0575
[/i][i] 22
[/i][i] -100.947
[/i][i] 32
[/i][i] -108.683
[/i][i] 13
[/i][i] 29.0575
[/i][i] 23
[/i][i] -100.947
[/i][i] 33
[/i][i] -108.683
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.0575
[/i][i] 20
[/i][i] -100.947
[/i][i] 30
[/i][i] -108.683
[/i][i] 11
[/i][i] 36.9823
[/i][i] 21
[/i][i] -97.1732
[/i][i] 31
[/i][i] -116.042
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -106.796
[/i][i] 32
[/i][i] -119.627
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -106.796
[/i][i] 33
[/i][i] -119.627
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 0
[/i][i] 20
[/i][i] 0
[/i][i] 30
[/i][i] 0
[/i][i] 11
[/i][i] 0.754623
[/i][i] 21
[/i][i] 9.81148
[/i][i] 31
[/i][i] 0
[/i][i] 12
[/i][i] 14.34
[/i][i] 22
[/i][i] 0
[/i][i] 32
[/i][i] -1.50922
[/i][i] 13
[/i][i] 14.34
[/i][i] 23
[/i][i] 0
[/i][i] 33
[/i][i] -1.50922
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 14.34
[/i][i] 20
[/i][i] 0
[/i][i] 30
[/i][i] -1.50922
[/i][i] 11
[/i][i] 18.3023
[/i][i] 21
[/i][i] -10.0003
[/i][i] 31
[/i][i] -3.77365
[/i][i] 12
[/i][i] 9.62289
[/i][i] 22
[/i][i] -17.5477
[/i][i] 32
[/i][i] -0.566025
[/i][i] 13
[/i][i] 9.62289
[/i][i] 23
[/i][i] -17.5477
[/i][i] 33
[/i][i] -0.566025
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -13.208
[/i][i] 20
[/i][i] -13.3965
[/i][i] 30
[/i][i] -6.22638
[/i][i] 11
[/i][i] -5.47176
[/i][i] 21
[/i][i] -21.3213
[/i][i] 31
[/i][i] -5.66034
[/i][i] 12
[/i][i] -22.0762
[/i][i] 22
[/i][i] -16.9816
[/i][i] 32
[/i][i] -16.2267
[/i][i] 13
[/i][i] -22.0762
[/i][i] 23
[/i][i] -16.9816
[/i][i] 33
[/i][i] -16.2267
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 17.1702
[/i][i] 20
[/i][i] 17.5477
[/i][i] 30
[/i][i] -8.11336
[/i][i] 11
[/i][i] 27.7366
[/i][i] 21
[/i][i] -0.188568
[/i][i] 31
[/i][i] -9.62288
[/i][i] 12
[/i][i] 24.3404
[/i][i] 22
[/i][i] 15.8496
[/i][i] 32
[/i][i] -15.2835
[/i][i] 13
[/i][i] 24.3404
[/i][i] 23
[/i][i] 15.8496
[/i][i] 33
[/i][i] -15.2835
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -9.24542
[/i][i] 20
[/i][i] -6.22638
[/i][i] 30
[/i][i] -58.1151
[/i][i] 11
[/i][i] -7.54732
[/i][i] 21
[/i][i] -16.2267
[/i][i] 31
[/i][i] -55.0963
[/i][i] 12
[/i][i] -7.35873
[/i][i] 22
[/i][i] -6.98128
[/i][i] 32
[/i][i] -69.8138
[/i][i] 13
[/i][i] -7.35873
[/i][i] 23
[/i][i] -6.98128
[/i][i] 33
[/i][i] -69.8138
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -30.3782
[/i][i] 20
[/i][i] -10.7549
[/i][i] 30
[/i][i] -38.3033
[/i][i] 11
[/i][i] -26.4159
[/i][i] 21
[/i][i] -9.81146
[/i][i] 31
[/i][i] -31.3217
[/i][i] 12
[/i][i] -30.9445
[/i][i] 22
[/i][i] -8.67938
[/i][i] 32
[/i][i] -36.6049
[/i][i] 13
[/i][i] -30.9445
[/i][i] 23
[/i][i] -8.67938
[/i][i] 33
[/i][i] -36.6049
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -30.9445
[/i][i] 20
[/i][i] -8.67938
[/i][i] 30
[/i][i] -36.6049
[/i][i] 11
[/i][i] -30.3782
[/i][i] 21
[/i][i] -10.7549
[/i][i] 31
[/i][i] -38.3033
[/i][i] 12
[/i][i] -34.3407
[/i][i] 22
[/i][i] -6.22638
[/i][i] 32
[/i][i] -41.322
[/i][i] 13
[/i][i] -34.3407
[/i][i] 23
[/i][i] -6.22638
[/i][i] 33
[/i][i] -41.322
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -30.567
[/i][i] 20
[/i][i] -6.22638
[/i][i] 30
[/i][i] -35.2842
[/i][i] 11
[/i][i] -26.4159
[/i][i] 21
[/i][i] -9.81146
[/i][i] 31
[/i][i] -31.3217
[/i][i] 12
[/i][i] -30.9445
[/i][i] 22
[/i][i] -8.67938
[/i][i] 32
[/i][i] -36.6049
[/i][i] 13
[/i][i] -30.9445
[/i][i] 23
[/i][i] -8.67938
[/i][i] 33
[/i][i] -36.6049
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -34.3407
[/i][i] 20
[/i][i] -6.22638
[/i][i] 30
[/i][i] -41.322
[/i][i] 11
[/i][i] -30.9445
[/i][i] 21
[/i][i] -8.67938
[/i][i] 31
[/i][i] -36.6049
[/i][i] 12
[/i][i] -30.567
[/i][i] 22
[/i][i] -6.22638
[/i][i] 32
[/i][i] -35.2842
[/i][i] 13
[/i][i] -30.567
[/i][i] 23
[/i][i] -6.22638
[/i][i] 33
[/i][i] -35.2842
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 43.9636
[/i][i] 20
[/i][i] -2.45271
[/i][i] 30
[/i][i] -36.9823
[/i][i] 11
[/i][i] 47.3601
[/i][i] 21
[/i][i] -13.208
[/i][i] 31
[/i][i] -43.3976
[/i][i] 12
[/i][i] 47.5487
[/i][i] 22
[/i][i] -3.58478
[/i][i] 32
[/i][i] -44.5296
[/i][i] 13
[/i][i] 47.5487
[/i][i] 23
[/i][i] -3.58478
[/i][i] 33
[/i][i] -44.5296
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 47.5487
[/i][i] 20
[/i][i] -3.58478
[/i][i] 30
[/i][i] -44.5296
[/i][i] 11
[/i][i] 52.2659
[/i][i] 21
[/i][i] -6.22638
[/i][i] 31
[/i][i] -56.2284
[/i][i] 12
[/i][i] 48.4922
[/i][i] 22
[/i][i] -19.0572
[/i][i] 32
[/i][i] -48.4922
[/i][i] 13
[/i][i] 48.4922
[/i][i] 23
[/i][i] -19.0572
[/i][i] 33
[/i][i] -48.4922
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 47.3601
[/i][i] 20
[/i][i] -13.208
[/i][i] 30
[/i][i] -43.3976
[/i][i] 11
[/i][i] 48.4922
[/i][i] 21
[/i][i] -19.0572
[/i][i] 31
[/i][i] -48.4922
[/i][i] 12
[/i][i] 47.5487
[/i][i] 22
[/i][i] -3.58478
[/i][i] 32
[/i][i] -44.5296
[/i][i] 13
[/i][i] 47.5487
[/i][i] 23
[/i][i] -3.58478
[/i][i] 33
[/i][i] -44.5296
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 48.4922
[/i][i] 20
[/i][i] -19.0572
[/i][i] 30
[/i][i] -48.4922
[/i][i] 11
[/i][i] 54.5303
[/i][i] 21
[/i][i] -17.9251
[/i][i] 31
[/i][i] -68.8703
[/i][i] 12
[/i][i] 52.2659
[/i][i] 22
[/i][i] -6.22638
[/i][i] 32
[/i][i] -56.2284
[/i][i] 13
[/i][i] 52.2659
[/i][i] 23
[/i][i] -6.22638
[/i][i] 33
[/i][i] -56.2284
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -6.22638
[/i][i] 30
[/i][i] -56.2284
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -10.0003
[/i][i] 31
[/i][i] -77.3611
[/i][i] 12
[/i][i] 54.5303
[/i][i] 22
[/i][i] -17.9251
[/i][i] 32
[/i][i] -68.8703
[/i][i] 13
[/i][i] 54.5303
[/i][i] 23
[/i][i] -17.9251
[/i][i] 33
[/i][i] -68.8703
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 54.5303
[/i][i] 20
[/i][i] -17.9251
[/i][i] 30
[/i][i] -68.8703
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -10.0003
[/i][i] 31
[/i][i] -77.3611
[/i][i] 12
[/i][i] 55.4735
[/i][i] 22
[/i][i] -12.8305
[/i][i] 32
[/i][i] -89.0596
[/i][i] 13
[/i][i] 55.4735
[/i][i] 23
[/i][i] -12.8305
[/i][i] 33
[/i][i] -89.0596
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 54.7189
[/i][i] 20
[/i][i] -28.6801
[/i][i] 30
[/i][i] -80.0027
[/i][i] 11
[/i][i] 55.4735
[/i][i] 21
[/i][i] -12.8305
[/i][i] 31
[/i][i] -89.0596
[/i][i] 12
[/i][i] 54.5303
[/i][i] 22
[/i][i] -17.9251
[/i][i] 32
[/i][i] -68.8703
[/i][i] 13
[/i][i] 54.5303
[/i][i] 23
[/i][i] -17.9251
[/i][i] 33
[/i][i] -68.8703
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 54.5303
[/i][i] 20
[/i][i] -17.9251
[/i][i] 30
[/i][i] -68.8703
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] -28.6801
[/i][i] 31
[/i][i] -80.0027
[/i][i] 12
[/i][i] 49.6243
[/i][i] 22
[/i][i] -40.3788
[/i][i] 32
[/i][i] -66.2287
[/i][i] 13
[/i][i] 49.6243
[/i][i] 23
[/i][i] -40.3788
[/i][i] 33
[/i][i] -66.2287
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 49.2468
[/i][i] 20
[/i][i] -28.114
[/i][i] 30
[/i][i] -56.417
[/i][i] 11
[/i][i] 49.6243
[/i][i] 21
[/i][i] -40.3788
[/i][i] 31
[/i][i] -66.2287
[/i][i] 12
[/i][i] 54.5303
[/i][i] 22
[/i][i] -17.9251
[/i][i] 32
[/i][i] -68.8703
[/i][i] 13
[/i][i] 54.5303
[/i][i] 23
[/i][i] -17.9251
[/i][i] 33
[/i][i] -68.8703
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 48.4922
[/i][i] 20
[/i][i] -19.0572
[/i][i] 30
[/i][i] -48.4922
[/i][i] 11
[/i][i] 54.5303
[/i][i] 21
[/i][i] -17.9251
[/i][i] 31
[/i][i] -68.8703
[/i][i] 12
[/i][i] 49.2468
[/i][i] 22
[/i][i] -28.114
[/i][i] 32
[/i][i] -56.417
[/i][i] 13
[/i][i] 49.2468
[/i][i] 23
[/i][i] -28.114
[/i][i] 33
[/i][i] -56.417
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.4547
[/i][i] 20
[/i][i] -17.5477
[/i][i] 30
[/i][i] -106.796
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] -28.6801
[/i][i] 31
[/i][i] -80.0027
[/i][i] 12
[/i][i] 54.1528
[/i][i] 22
[/i][i] -43.775
[/i][i] 32
[/i][i] -94.7202
[/i][i] 13
[/i][i] 54.1528
[/i][i] 23
[/i][i] -43.775
[/i][i] 33
[/i][i] -94.7202
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 49.6243
[/i][i] 20
[/i][i] -40.3788
[/i][i] 30
[/i][i] -66.2287
[/i][i] 11
[/i][i] 54.1528
[/i][i] 21
[/i][i] -43.775
[/i][i] 31
[/i][i] -94.7202
[/i][i] 12
[/i][i] 54.7189
[/i][i] 22
[/i][i] -28.6801
[/i][i] 32
[/i][i] -80.0027
[/i][i] 13
[/i][i] 54.7189
[/i][i] 23
[/i][i] -28.6801
[/i][i] 33
[/i][i] -80.0027
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 49.6243
[/i][i] 20
[/i][i] -40.3788
[/i][i] 30
[/i][i] -66.2287
[/i][i] 11
[/i][i] 54.1528
[/i][i] 21
[/i][i] -43.775
[/i][i] 31
[/i][i] -94.7202
[/i][i] 12
[/i][i] 49.2468
[/i][i] 22
[/i][i] -56.6058
[/i][i] 32
[/i][i] -79.4367
[/i][i] 13
[/i][i] 49.2468
[/i][i] 23
[/i][i] -56.6058
[/i][i] 33
[/i][i] -79.4367
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.4547
[/i][i] 20
[/i][i] -17.5477
[/i][i] 30
[/i][i] -106.796
[/i][i] 11
[/i][i] 54.1528
[/i][i] 21
[/i][i] -43.775
[/i][i] 31
[/i][i] -94.7202
[/i][i] 12
[/i][i] 53.0208
[/i][i] 22
[/i][i] -43.209
[/i][i] 32
[/i][i] -107.362
[/i][i] 13
[/i][i] 53.0208
[/i][i] 23
[/i][i] -43.209
[/i][i] 33
[/i][i] -107.362
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -107.551
[/i][i] 11
[/i][i] 53.0208
[/i][i] 21
[/i][i] -43.209
[/i][i] 31
[/i][i] -107.362
[/i][i] 12
[/i][i] 54.1528
[/i][i] 22
[/i][i] -43.775
[/i][i] 32
[/i][i] -94.7202
[/i][i] 13
[/i][i] 54.1528
[/i][i] 23
[/i][i] -43.775
[/i][i] 33
[/i][i] -94.7202
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -107.551
[/i][i] 11
[/i][i] 54.1528
[/i][i] 21
[/i][i] -43.775
[/i][i] 31
[/i][i] -94.7202
[/i][i] 12
[/i][i] 49.2468
[/i][i] 22
[/i][i] -56.6058
[/i][i] 32
[/i][i] -79.4367
[/i][i] 13
[/i][i] 49.2468
[/i][i] 23
[/i][i] -56.6058
[/i][i] 33
[/i][i] -79.4367
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 49.2468
[/i][i] 20
[/i][i] -56.6058
[/i][i] 30
[/i][i] -79.4367
[/i][i] 11
[/i][i] 52.2659
[/i][i] 21
[/i][i] -56.983
[/i][i] 31
[/i][i] -107.551
[/i][i] 12
[/i][i] 46.9827
[/i][i] 22
[/i][i] -70.5684
[/i][i] 32
[/i][i] -92.6447
[/i][i] 13
[/i][i] 46.9827
[/i][i] 23
[/i][i] -70.5684
[/i][i] 33
[/i][i] -92.6447
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.4547
[/i][i] 20
[/i][i] -17.5477
[/i][i] 30
[/i][i] -106.796
[/i][i] 11
[/i][i] 53.0208
[/i][i] 21
[/i][i] -43.209
[/i][i] 31
[/i][i] -107.362
[/i][i] 12
[/i][i] 47.9262
[/i][i] 22
[/i][i] -20.9439
[/i][i] 32
[/i][i] -118.872
[/i][i] 13
[/i][i] 47.9262
[/i][i] 23
[/i][i] -20.9439
[/i][i] 33
[/i][i] -118.872
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 47.9262
[/i][i] 20
[/i][i] -20.9439
[/i][i] 30
[/i][i] -118.872
[/i][i] 11
[/i][i] 50.3792
[/i][i] 21
[/i][i] -39.8125
[/i][i] 31
[/i][i] -122.646
[/i][i] 12
[/i][i] 53.0208
[/i][i] 22
[/i][i] -43.209
[/i][i] 32
[/i][i] -107.362
[/i][i] 13
[/i][i] 53.0208
[/i][i] 23
[/i][i] -43.209
[/i][i] 33
[/i][i] -107.362
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 50.3792
[/i][i] 20
[/i][i] -39.8125
[/i][i] 30
[/i][i] -122.646
[/i][i] 11
[/i][i] 53.0208
[/i][i] 21
[/i][i] -43.209
[/i][i] 31
[/i][i] -107.362
[/i][i] 12
[/i][i] 52.4547
[/i][i] 22
[/i][i] -49.4357
[/i][i] 32
[/i][i] -113.212
[/i][i] 13
[/i][i] 52.4547
[/i][i] 23
[/i][i] -49.4357
[/i][i] 33
[/i][i] -113.212
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -107.551
[/i][i] 11
[/i][i] 52.4547
[/i][i] 21
[/i][i] -49.4357
[/i][i] 31
[/i][i] -113.212
[/i][i] 12
[/i][i] 53.0208
[/i][i] 22
[/i][i] -43.209
[/i][i] 32
[/i][i] -107.362
[/i][i] 13
[/i][i] 53.0208
[/i][i] 23
[/i][i] -43.209
[/i][i] 33
[/i][i] -107.362
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.9827
[/i][i] 20
[/i][i] -70.5684
[/i][i] 30
[/i][i] -92.6447
[/i][i] 11
[/i][i] 52.2659
[/i][i] 21
[/i][i] -56.983
[/i][i] 31
[/i][i] -107.551
[/i][i] 12
[/i][i] 48.6808
[/i][i] 22
[/i][i] -74.3421
[/i][i] 32
[/i][i] -106.042
[/i][i] 13
[/i][i] 48.6808
[/i][i] 23
[/i][i] -74.3421
[/i][i] 33
[/i][i] -106.042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 41.6995
[/i][i] 20
[/i][i] -87.5504
[/i][i] 30
[/i][i] -109.815
[/i][i] 11
[/i][i] 48.6808
[/i][i] 21
[/i][i] -74.3421
[/i][i] 31
[/i][i] -106.042
[/i][i] 12
[/i][i] 46.9827
[/i][i] 22
[/i][i] -70.5684
[/i][i] 32
[/i][i] -92.6447
[/i][i] 13
[/i][i] 46.9827
[/i][i] 23
[/i][i] -70.5684
[/i][i] 33
[/i][i] -92.6447
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -107.551
[/i][i] 11
[/i][i] 52.4547
[/i][i] 21
[/i][i] -49.4357
[/i][i] 31
[/i][i] -113.212
[/i][i] 12
[/i][i] 59.436
[/i][i] 22
[/i][i] -55.6623
[/i][i] 32
[/i][i] -120.759
[/i][i] 13
[/i][i] 59.436
[/i][i] 23
[/i][i] -55.6623
[/i][i] 33
[/i][i] -120.759
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 58.6811
[/i][i] 20
[/i][i] -70.5684
[/i][i] 30
[/i][i] -117.174
[/i][i] 11
[/i][i] 59.436
[/i][i] 21
[/i][i] -55.6623
[/i][i] 31
[/i][i] -120.759
[/i][i] 12
[/i][i] 52.2659
[/i][i] 22
[/i][i] -56.983
[/i][i] 32
[/i][i] -107.551
[/i][i] 13
[/i][i] 52.2659
[/i][i] 23
[/i][i] -56.983
[/i][i] 33
[/i][i] -107.551
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -56.983
[/i][i] 30
[/i][i] -107.551
[/i][i] 11
[/i][i] 58.6811
[/i][i] 21
[/i][i] -70.5684
[/i][i] 31
[/i][i] -117.174
[/i][i] 12
[/i][i] 48.6808
[/i][i] 22
[/i][i] -74.3421
[/i][i] 32
[/i][i] -106.042
[/i][i] 13
[/i][i] 48.6808
[/i][i] 23
[/i][i] -74.3421
[/i][i] 33
[/i][i] -106.042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 50.3792
[/i][i] 20
[/i][i] -39.8125
[/i][i] 30
[/i][i] -122.646
[/i][i] 11
[/i][i] 52.4547
[/i][i] 21
[/i][i] -49.4357
[/i][i] 31
[/i][i] -113.212
[/i][i] 12
[/i][i] 59.436
[/i][i] 22
[/i][i] -55.6623
[/i][i] 32
[/i][i] -120.759
[/i][i] 13
[/i][i] 59.436
[/i][i] 23
[/i][i] -55.6623
[/i][i] 33
[/i][i] -120.759
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 38.6804
[/i][i] 20
[/i][i] -17.7362
[/i][i] 30
[/i][i] -140.382
[/i][i] 11
[/i][i] 47.9262
[/i][i] 21
[/i][i] -20.9439
[/i][i] 31
[/i][i] -118.872
[/i][i] 12
[/i][i] 37.5484
[/i][i] 22
[/i][i] -32.4537
[/i][i] 32
[/i][i] -148.118
[/i][i] 13
[/i][i] 37.5484
[/i][i] 23
[/i][i] -32.4537
[/i][i] 33
[/i][i] -148.118
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 37.5484
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -148.118
[/i][i] 11
[/i][i] 44.5297
[/i][i] 21
[/i][i] -34.3407
[/i][i] 31
[/i][i] -135.665
[/i][i] 12
[/i][i] 47.9262
[/i][i] 22
[/i][i] -20.9439
[/i][i] 32
[/i][i] -118.872
[/i][i] 13
[/i][i] 47.9262
[/i][i] 23
[/i][i] -20.9439
[/i][i] 33
[/i][i] -118.872
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 44.5297
[/i][i] 20
[/i][i] -34.3407
[/i][i] 30
[/i][i] -135.665
[/i][i] 11
[/i][i] 47.9262
[/i][i] 21
[/i][i] -20.9439
[/i][i] 31
[/i][i] -118.872
[/i][i] 12
[/i][i] 50.3792
[/i][i] 22
[/i][i] -39.8125
[/i][i] 32
[/i][i] -122.646
[/i][i] 13
[/i][i] 50.3792
[/i][i] 23
[/i][i] -39.8125
[/i][i] 33
[/i][i] -122.646
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.7366
[/i][i] 20
[/i][i] -16.793
[/i][i] 30
[/i][i] -165.666
[/i][i] 11
[/i][i] 38.6804
[/i][i] 21
[/i][i] -17.7362
[/i][i] 31
[/i][i] -140.382
[/i][i] 12
[/i][i] 31.3217
[/i][i] 22
[/i][i] -32.4537
[/i][i] 32
[/i][i] -163.213
[/i][i] 13
[/i][i] 31.3217
[/i][i] 23
[/i][i] -32.4537
[/i][i] 33
[/i][i] -163.213
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -163.213
[/i][i] 11
[/i][i] 37.5484
[/i][i] 21
[/i][i] -32.4537
[/i][i] 31
[/i][i] -148.118
[/i][i] 12
[/i][i] 38.6804
[/i][i] 22
[/i][i] -17.7362
[/i][i] 32
[/i][i] -140.382
[/i][i] 13
[/i][i] 38.6804
[/i][i] 23
[/i][i] -17.7362
[/i][i] 33
[/i][i] -140.382
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 54.7189
[/i][i] 20
[/i][i] -28.6801
[/i][i] 30
[/i][i] -80.0027
[/i][i] 11
[/i][i] 55.4735
[/i][i] 21
[/i][i] -12.8305
[/i][i] 31
[/i][i] -89.0596
[/i][i] 12
[/i][i] 52.4547
[/i][i] 22
[/i][i] -17.5477
[/i][i] 32
[/i][i] -106.796
[/i][i] 13
[/i][i] 52.4547
[/i][i] 23
[/i][i] -17.5477
[/i][i] 33
[/i][i] -106.796
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 48.6808
[/i][i] 20
[/i][i] -74.3421
[/i][i] 30
[/i][i] -106.042
[/i][i] 11
[/i][i] 58.6811
[/i][i] 21
[/i][i] -70.5684
[/i][i] 31
[/i][i] -117.174
[/i][i] 12
[/i][i] 55.4735
[/i][i] 22
[/i][i] -81.1348
[/i][i] 32
[/i][i] -117.74
[/i][i] 13
[/i][i] 55.4735
[/i][i] 23
[/i][i] -81.1348
[/i][i] 33
[/i][i] -117.74
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 55.4735
[/i][i] 20
[/i][i] -81.1348
[/i][i] 30
[/i][i] -117.74
[/i][i] 11
[/i][i] 58.6811
[/i][i] 21
[/i][i] -70.5684
[/i][i] 31
[/i][i] -117.174
[/i][i] 12
[/i][i] 60.9456
[/i][i] 22
[/i][i] -73.7761
[/i][i] 32
[/i][i] -130.193
[/i][i] 13
[/i][i] 60.9456
[/i][i] 23
[/i][i] -73.7761
[/i][i] 33
[/i][i] -130.193
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 55.4735
[/i][i] 20
[/i][i] -90.0031
[/i][i] 30
[/i][i] -134.533
[/i][i] 11
[/i][i] 60.9456
[/i][i] 21
[/i][i] -73.7761
[/i][i] 31
[/i][i] -130.193
[/i][i] 12
[/i][i] 55.4735
[/i][i] 22
[/i][i] -81.1348
[/i][i] 32
[/i][i] -117.74
[/i][i] 13
[/i][i] 55.4735
[/i][i] 23
[/i][i] -81.1348
[/i][i] 33
[/i][i] -117.74
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 55.4735
[/i][i] 20
[/i][i] -90.0031
[/i][i] 30
[/i][i] -134.533
[/i][i] 11
[/i][i] 55.4735
[/i][i] 21
[/i][i] -81.1348
[/i][i] 31
[/i][i] -117.74
[/i][i] 12
[/i][i] 46.7941
[/i][i] 22
[/i][i] -98.4939
[/i][i] 32
[/i][i] -126.42
[/i][i] 13
[/i][i] 46.7941
[/i][i] 23
[/i][i] -98.4939
[/i][i] 33
[/i][i] -126.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 41.6995
[/i][i] 20
[/i][i] -87.5504
[/i][i] 30
[/i][i] -109.815
[/i][i] 11
[/i][i] 46.7941
[/i][i] 21
[/i][i] -98.4939
[/i][i] 31
[/i][i] -126.42
[/i][i] 12
[/i][i] 55.4735
[/i][i] 22
[/i][i] -81.1348
[/i][i] 32
[/i][i] -117.74
[/i][i] 13
[/i][i] 55.4735
[/i][i] 23
[/i][i] -81.1348
[/i][i] 33
[/i][i] -117.74
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 41.6995
[/i][i] 20
[/i][i] -87.5504
[/i][i] 30
[/i][i] -109.815
[/i][i] 11
[/i][i] 55.4735
[/i][i] 21
[/i][i] -81.1348
[/i][i] 31
[/i][i] -117.74
[/i][i] 12
[/i][i] 48.6808
[/i][i] 22
[/i][i] -74.3421
[/i][i] 32
[/i][i] -106.042
[/i][i] 13
[/i][i] 48.6808
[/i][i] 23
[/i][i] -74.3421
[/i][i] 33
[/i][i] -106.042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 36.9823
[/i][i] 20
[/i][i] -97.1732
[/i][i] 30
[/i][i] -116.042
[/i][i] 11
[/i][i] 41.6995
[/i][i] 21
[/i][i] -87.5504
[/i][i] 31
[/i][i] -109.815
[/i][i] 12
[/i][i] 46.7941
[/i][i] 22
[/i][i] -98.4939
[/i][i] 32
[/i][i] -126.42
[/i][i] 13
[/i][i] 46.7941
[/i][i] 23
[/i][i] -98.4939
[/i][i] 33
[/i][i] -126.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 35.4728
[/i][i] 20
[/i][i] -112.457
[/i][i] 30
[/i][i] -145.477
[/i][i] 11
[/i][i] 46.7941
[/i][i] 21
[/i][i] -98.4939
[/i][i] 31
[/i][i] -126.42
[/i][i] 12
[/i][i] 36.9823
[/i][i] 22
[/i][i] -97.1732
[/i][i] 32
[/i][i] -116.042
[/i][i] 13
[/i][i] 36.9823
[/i][i] 23
[/i][i] -97.1732
[/i][i] 33
[/i][i] -116.042
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 35.4728
[/i][i] 20
[/i][i] -112.457
[/i][i] 30
[/i][i] -145.477
[/i][i] 11
[/i][i] 36.9823
[/i][i] 21
[/i][i] -97.1732
[/i][i] 31
[/i][i] -116.042
[/i][i] 12
[/i][i] 30.7556
[/i][i] 22
[/i][i] -108.494
[/i][i] 32
[/i][i] -126.42
[/i][i] 13
[/i][i] 30.7556
[/i][i] 23
[/i][i] -108.494
[/i][i] 33
[/i][i] -126.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.7941
[/i][i] 20
[/i][i] -104.343
[/i][i] 30
[/i][i] -146.609
[/i][i] 11
[/i][i] 46.7941
[/i][i] 21
[/i][i] -98.4939
[/i][i] 31
[/i][i] -126.42
[/i][i] 12
[/i][i] 35.4728
[/i][i] 22
[/i][i] -112.457
[/i][i] 32
[/i][i] -145.477
[/i][i] 13
[/i][i] 35.4728
[/i][i] 23
[/i][i] -112.457
[/i][i] 33
[/i][i] -145.477
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -10.7549
[/i][i] 20
[/i][i] 7.73592
[/i][i] 30
[/i][i] -179.629
[/i][i] 11
[/i][i] -9.05684
[/i][i] 21
[/i][i] -9.4343
[/i][i] 31
[/i][i] -172.836
[/i][i] 12
[/i][i] -6.7924
[/i][i] 22
[/i][i] 0
[/i][i] 32
[/i][i] -171.516
[/i][i] 13
[/i][i] -6.7924
[/i][i] 23
[/i][i] 0
[/i][i] 33
[/i][i] -171.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -9.05684
[/i][i] 20
[/i][i] -9.4343
[/i][i] 30
[/i][i] -172.836
[/i][i] 11
[/i][i] -8.30194
[/i][i] 21
[/i][i] -13.774
[/i][i] 31
[/i][i] -164.723
[/i][i] 12
[/i][i] -6.7924
[/i][i] 22
[/i][i] 0
[/i][i] 32
[/i][i] -171.516
[/i][i] 13
[/i][i] -6.7924
[/i][i] 23
[/i][i] 0
[/i][i] 33
[/i][i] -171.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -15.8495
[/i][i] 20
[/i][i] -13.3965
[/i][i] 30
[/i][i] -171.893
[/i][i] 11
[/i][i] -9.05684
[/i][i] 21
[/i][i] -9.4343
[/i][i] 31
[/i][i] -172.836
[/i][i] 12
[/i][i] -8.30194
[/i][i] 22
[/i][i] -13.774
[/i][i] 32
[/i][i] -164.723
[/i][i] 13
[/i][i] -8.30194
[/i][i] 23
[/i][i] -13.774
[/i][i] 33
[/i][i] -164.723
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] -11.321
[/i][i] 20
[/i][i] 8.6794
[/i][i] 30
[/i][i] -184.158
[/i][i] 11
[/i][i] -9.05684
[/i][i] 21
[/i][i] -9.4343
[/i][i] 31
[/i][i] -172.836
[/i][i] 12
[/i][i] -6.22638
[/i][i] 22
[/i][i] -11.6984
[/i][i] 32
[/i][i] -184.535
[/i][i] 13
[/i][i] -6.22638
[/i][i] 23
[/i][i] -11.6984
[/i][i] 33
[/i][i] -184.535
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.4346
[/i][i] 20
[/i][i] -116.985
[/i][i] 30
[/i][i] -149.439
[/i][i] 11
[/i][i] 35.4728
[/i][i] 21
[/i][i] -112.457
[/i][i] 31
[/i][i] -145.477
[/i][i] 12
[/i][i] 30.7556
[/i][i] 22
[/i][i] -108.494
[/i][i] 32
[/i][i] -126.42
[/i][i] 13
[/i][i] 30.7556
[/i][i] 23
[/i][i] -108.494
[/i][i] 33
[/i][i] -126.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.7941
[/i][i] 20
[/i][i] -98.4939
[/i][i] 30
[/i][i] -126.42
[/i][i] 11
[/i][i] 55.4735
[/i][i] 21
[/i][i] -90.0031
[/i][i] 31
[/i][i] -134.533
[/i][i] 12
[/i][i] 51.8884
[/i][i] 22
[/i][i] -97.3618
[/i][i] 32
[/i][i] -139.439
[/i][i] 13
[/i][i] 51.8884
[/i][i] 23
[/i][i] -97.3618
[/i][i] 33
[/i][i] -139.439
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.7941
[/i][i] 20
[/i][i] -104.343
[/i][i] 30
[/i][i] -146.609
[/i][i] 11
[/i][i] 51.8884
[/i][i] 21
[/i][i] -97.3618
[/i][i] 31
[/i][i] -139.439
[/i][i] 12
[/i][i] 46.7941
[/i][i] 22
[/i][i] -98.4939
[/i][i] 32
[/i][i] -126.42
[/i][i] 13
[/i][i] 46.7941
[/i][i] 23
[/i][i] -98.4939
[/i][i] 33
[/i][i] -126.42
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 53.5868
[/i][i] 20
[/i][i] -41.6995
[/i][i] 30
[/i][i] -132.269
[/i][i] 11
[/i][i] 59.436
[/i][i] 21
[/i][i] -55.6623
[/i][i] 31
[/i][i] -120.759
[/i][i] 12
[/i][i] 50.3792
[/i][i] 22
[/i][i] -39.8125
[/i][i] 32
[/i][i] -122.646
[/i][i] 13
[/i][i] 50.3792
[/i][i] 23
[/i][i] -39.8125
[/i][i] 33
[/i][i] -122.646
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 53.5868
[/i][i] 20
[/i][i] -41.6995
[/i][i] 30
[/i][i] -132.269
[/i][i] 11
[/i][i] 59.436
[/i][i] 21
[/i][i] -55.6623
[/i][i] 31
[/i][i] -120.759
[/i][i] 12
[/i][i] 59.436
[/i][i] 22
[/i][i] -51.6998
[/i][i] 32
[/i][i] -136.986
[/i][i] 13
[/i][i] 59.436
[/i][i] 23
[/i][i] -51.6998
[/i][i] 33
[/i][i] -136.986
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 59.436
[/i][i] 20
[/i][i] -51.6998
[/i][i] 30
[/i][i] -136.986
[/i][i] 11
[/i][i] 61.7002
[/i][i] 21
[/i][i] -62.0776
[/i][i] 31
[/i][i] -131.703
[/i][i] 12
[/i][i] 59.436
[/i][i] 22
[/i][i] -55.6623
[/i][i] 32
[/i][i] -120.759
[/i][i] 13
[/i][i] 59.436
[/i][i] 23
[/i][i] -55.6623
[/i][i] 33
[/i][i] -120.759
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 59.436
[/i][i] 20
[/i][i] -55.6623
[/i][i] 30
[/i][i] -120.759
[/i][i] 11
[/i][i] 61.7002
[/i][i] 21
[/i][i] -62.0776
[/i][i] 31
[/i][i] -131.703
[/i][i] 12
[/i][i] 58.6811
[/i][i] 22
[/i][i] -70.5684
[/i][i] 32
[/i][i] -117.174
[/i][i] 13
[/i][i] 58.6811
[/i][i] 23
[/i][i] -70.5684
[/i][i] 33
[/i][i] -117.174
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 58.6811
[/i][i] 20
[/i][i] -70.5684
[/i][i] 30
[/i][i] -117.174
[/i][i] 11
[/i][i] 61.7002
[/i][i] 21
[/i][i] -62.0776
[/i][i] 31
[/i][i] -131.703
[/i][i] 12
[/i][i] 60.9456
[/i][i] 22
[/i][i] -73.7761
[/i][i] 32
[/i][i] -130.193
[/i][i] 13
[/i][i] 60.9456
[/i][i] 23
[/i][i] -73.7761
[/i][i] 33
[/i][i] -130.193
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 37.5484
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -148.118
[/i][i] 11
[/i][i] 44.5297
[/i][i] 21
[/i][i] -34.3407
[/i][i] 31
[/i][i] -135.665
[/i][i] 12
[/i][i] 45.2846
[/i][i] 22
[/i][i] -36.9823
[/i][i] 32
[/i][i] -144.156
[/i][i] 13
[/i][i] 45.2846
[/i][i] 23
[/i][i] -36.9823
[/i][i] 33
[/i][i] -144.156
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 44.5297
[/i][i] 20
[/i][i] -34.3407
[/i][i] 30
[/i][i] -135.665
[/i][i] 11
[/i][i] 45.2846
[/i][i] 21
[/i][i] -36.9823
[/i][i] 31
[/i][i] -144.156
[/i][i] 12
[/i][i] 50.3792
[/i][i] 22
[/i][i] -39.8125
[/i][i] 32
[/i][i] -122.646
[/i][i] 13
[/i][i] 50.3792
[/i][i] 23
[/i][i] -39.8125
[/i][i] 33
[/i][i] -122.646
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 45.2846
[/i][i] 20
[/i][i] -36.9823
[/i][i] 30
[/i][i] -144.156
[/i][i] 11
[/i][i] 50.3792
[/i][i] 21
[/i][i] -39.8125
[/i][i] 31
[/i][i] -122.646
[/i][i] 12
[/i][i] 53.5868
[/i][i] 22
[/i][i] -41.6995
[/i][i] 32
[/i][i] -132.269
[/i][i] 13
[/i][i] 53.5868
[/i][i] 23
[/i][i] -41.6995
[/i][i] 33
[/i][i] -132.269
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 45.2846
[/i][i] 20
[/i][i] -36.9823
[/i][i] 30
[/i][i] -144.156
[/i][i] 11
[/i][i] 53.5868
[/i][i] 21
[/i][i] -41.6995
[/i][i] 31
[/i][i] -132.269
[/i][i] 12
[/i][i] 54.7189
[/i][i] 22
[/i][i] -46.4166
[/i][i] 32
[/i][i] -144.345
[/i][i] 13
[/i][i] 54.7189
[/i][i] 23
[/i][i] -46.4166
[/i][i] 33
[/i][i] -144.345
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 45.2846
[/i][i] 20
[/i][i] -36.9823
[/i][i] 30
[/i][i] -144.156
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] -46.4166
[/i][i] 31
[/i][i] -144.345
[/i][i] 12
[/i][i] 44.7185
[/i][i] 22
[/i][i] -40.5674
[/i][i] 32
[/i][i] -154.345
[/i][i] 13
[/i][i] 44.7185
[/i][i] 23
[/i][i] -40.5674
[/i][i] 33
[/i][i] -154.345
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 53.5868
[/i][i] 20
[/i][i] -41.6995
[/i][i] 30
[/i][i] -132.269
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] -46.4166
[/i][i] 31
[/i][i] -144.345
[/i][i] 12
[/i][i] 59.436
[/i][i] 22
[/i][i] -51.6998
[/i][i] 32
[/i][i] -136.986
[/i][i] 13
[/i][i] 59.436
[/i][i] 23
[/i][i] -51.6998
[/i][i] 33
[/i][i] -136.986
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -163.213
[/i][i] 11
[/i][i] 37.5484
[/i][i] 21
[/i][i] -32.4537
[/i][i] 31
[/i][i] -148.118
[/i][i] 12
[/i][i] 37.7372
[/i][i] 22
[/i][i] -34.9068
[/i][i] 32
[/i][i] -155.666
[/i][i] 13
[/i][i] 37.7372
[/i][i] 23
[/i][i] -34.9068
[/i][i] 33
[/i][i] -155.666
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 37.7372
[/i][i] 20
[/i][i] -34.9068
[/i][i] 30
[/i][i] -155.666
[/i][i] 11
[/i][i] 44.7185
[/i][i] 21
[/i][i] -40.5674
[/i][i] 31
[/i][i] -154.345
[/i][i] 12
[/i][i] 45.2846
[/i][i] 22
[/i][i] -36.9823
[/i][i] 32
[/i][i] -144.156
[/i][i] 13
[/i][i] 45.2846
[/i][i] 23
[/i][i] -36.9823
[/i][i] 33
[/i][i] -144.156
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 37.5484
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -148.118
[/i][i] 11
[/i][i] 45.2846
[/i][i] 21
[/i][i] -36.9823
[/i][i] 31
[/i][i] -144.156
[/i][i] 12
[/i][i] 37.7372
[/i][i] 22
[/i][i] -34.9068
[/i][i] 32
[/i][i] -155.666
[/i][i] 13
[/i][i] 37.7372
[/i][i] 23
[/i][i] -34.9068
[/i][i] 33
[/i][i] -155.666
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -163.213
[/i][i] 11
[/i][i] 37.7372
[/i][i] 21
[/i][i] -34.9068
[/i][i] 31
[/i][i] -155.666
[/i][i] 12
[/i][i] 44.7185
[/i][i] 22
[/i][i] -40.5674
[/i][i] 32
[/i][i] -154.345
[/i][i] 13
[/i][i] 44.7185
[/i][i] 23
[/i][i] -40.5674
[/i][i] 33
[/i][i] -154.345
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -163.213
[/i][i] 11
[/i][i] 44.7185
[/i][i] 21
[/i][i] -40.5674
[/i][i] 31
[/i][i] -154.345
[/i][i] 12
[/i][i] 41.322
[/i][i] 22
[/i][i] -40.5674
[/i][i] 32
[/i][i] -160.572
[/i][i] 13
[/i][i] 41.322
[/i][i] 23
[/i][i] -40.5674
[/i][i] 33
[/i][i] -160.572
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -163.213
[/i][i] 11
[/i][i] 41.322
[/i][i] 21
[/i][i] -40.5674
[/i][i] 31
[/i][i] -160.572
[/i][i] 12
[/i][i] 39.4353
[/i][i] 22
[/i][i] -39.8125
[/i][i] 32
[/i][i] -164.345
[/i][i] 13
[/i][i] 39.4353
[/i][i] 23
[/i][i] -39.8125
[/i][i] 33
[/i][i] -164.345
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.3217
[/i][i] 20
[/i][i] -32.4537
[/i][i] 30
[/i][i] -163.213
[/i][i] 11
[/i][i] 39.4353
[/i][i] 21
[/i][i] -39.8125
[/i][i] 31
[/i][i] -164.345
[/i][i] 12
[/i][i] 28.3029
[/i][i] 22
[/i][i] -24.529
[/i][i] 32
[/i][i] -171.893
[/i][i] 13
[/i][i] 28.3029
[/i][i] 23
[/i][i] -24.529
[/i][i] 33
[/i][i] -171.893
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 28.3029
[/i][i] 20
[/i][i] -24.529
[/i][i] 30
[/i][i] -171.893
[/i][i] 11
[/i][i] 31.3217
[/i][i] 21
[/i][i] -32.4537
[/i][i] 31
[/i][i] -163.213
[/i][i] 12
[/i][i] 27.7366
[/i][i] 22
[/i][i] -16.793
[/i][i] 32
[/i][i] -165.666
[/i][i] 13
[/i][i] 27.7366
[/i][i] 23
[/i][i] -16.793
[/i][i] 33
[/i][i] -165.666
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.8884
[/i][i] 20
[/i][i] -50.0017
[/i][i] 30
[/i][i] -155.477
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] -46.4166
[/i][i] 31
[/i][i] -144.345
[/i][i] 12
[/i][i] 59.436
[/i][i] 22
[/i][i] -51.6998
[/i][i] 32
[/i][i] -136.986
[/i][i] 13
[/i][i] 59.436
[/i][i] 23
[/i][i] -51.6998
[/i][i] 33
[/i][i] -136.986
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 41.322
[/i][i] 20
[/i][i] -40.5674
[/i][i] 30
[/i][i] -160.572
[/i][i] 11
[/i][i] 44.7185
[/i][i] 21
[/i][i] -40.5674
[/i][i] 31
[/i][i] -154.345
[/i][i] 12
[/i][i] 51.8884
[/i][i] 22
[/i][i] -50.0017
[/i][i] 32
[/i][i] -155.477
[/i][i] 13
[/i][i] 51.8884
[/i][i] 23
[/i][i] -50.0017
[/i][i] 33
[/i][i] -155.477
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.8884
[/i][i] 20
[/i][i] -50.0017
[/i][i] 30
[/i][i] -155.477
[/i][i] 11
[/i][i] 54.7189
[/i][i] 21
[/i][i] -46.4166
[/i][i] 31
[/i][i] -144.345
[/i][i] 12
[/i][i] 44.7185
[/i][i] 22
[/i][i] -40.5674
[/i][i] 32
[/i][i] -154.345
[/i][i] 13
[/i][i] 44.7185
[/i][i] 23
[/i][i] -40.5674
[/i][i] 33
[/i][i] -154.345
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 41.322
[/i][i] 20
[/i][i] -40.5674
[/i][i] 30
[/i][i] -160.572
[/i][i] 11
[/i][i] 51.8884
[/i][i] 21
[/i][i] -50.0017
[/i][i] 31
[/i][i] -155.477
[/i][i] 12
[/i][i] 46.9827
[/i][i] 22
[/i][i] -50.7563
[/i][i] 32
[/i][i] -164.911
[/i][i] 13
[/i][i] 46.9827
[/i][i] 23
[/i][i] -50.7563
[/i][i] 33
[/i][i] -164.911
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.9827
[/i][i] 20
[/i][i] -50.7563
[/i][i] 30
[/i][i] -164.911
[/i][i] 11
[/i][i] 51.8884
[/i][i] 21
[/i][i] -65.6627
[/i][i] 31
[/i][i] -167.742
[/i][i] 12
[/i][i] 51.8884
[/i][i] 22
[/i][i] -50.0017
[/i][i] 32
[/i][i] -155.477
[/i][i] 13
[/i][i] 51.8884
[/i][i] 23
[/i][i] -50.0017
[/i][i] 33
[/i][i] -155.477
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.8884
[/i][i] 20
[/i][i] -65.6627
[/i][i] 30
[/i][i] -167.742
[/i][i] 11
[/i][i] 51.8884
[/i][i] 21
[/i][i] -50.0017
[/i][i] 31
[/i][i] -155.477
[/i][i] 12
[/i][i] 57.7379
[/i][i] 22
[/i][i] -59.6246
[/i][i] 32
[/i][i] -150.76
[/i][i] 13
[/i][i] 57.7379
[/i][i] 23
[/i][i] -59.6246
[/i][i] 33
[/i][i] -150.76
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 57.7379
[/i][i] 20
[/i][i] -59.6246
[/i][i] 30
[/i][i] -150.76
[/i][i] 11
[/i][i] 59.436
[/i][i] 21
[/i][i] -51.6998
[/i][i] 31
[/i][i] -136.986
[/i][i] 12
[/i][i] 51.8884
[/i][i] 22
[/i][i] -50.0017
[/i][i] 32
[/i][i] -155.477
[/i][i] 13
[/i][i] 51.8884
[/i][i] 23
[/i][i] -50.0017
[/i][i] 33
[/i][i] -155.477
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 57.7379
[/i][i] 20
[/i][i] -59.6246
[/i][i] 30
[/i][i] -150.76
[/i][i] 11
[/i][i] 59.436
[/i][i] 21
[/i][i] -51.6998
[/i][i] 31
[/i][i] -136.986
[/i][i] 12
[/i][i] 61.7002
[/i][i] 22
[/i][i] -62.0776
[/i][i] 32
[/i][i] -131.703
[/i][i] 13
[/i][i] 61.7002
[/i][i] 23
[/i][i] -62.0776
[/i][i] 33
[/i][i] -131.703
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 57.7379
[/i][i] 20
[/i][i] -59.6246
[/i][i] 30
[/i][i] -150.76
[/i][i] 11
[/i][i] 61.7002
[/i][i] 21
[/i][i] -62.0776
[/i][i] 31
[/i][i] -131.703
[/i][i] 12
[/i][i] 59.2474
[/i][i] 22
[/i][i] -72.078
[/i][i] 32
[/i][i] -149.817
[/i][i] 13
[/i][i] 59.2474
[/i][i] 23
[/i][i] -72.078
[/i][i] 33
[/i][i] -149.817
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 59.2474
[/i][i] 20
[/i][i] -72.078
[/i][i] 30
[/i][i] -149.817
[/i][i] 11
[/i][i] 60.9456
[/i][i] 21
[/i][i] -73.7761
[/i][i] 31
[/i][i] -130.193
[/i][i] 12
[/i][i] 61.7002
[/i][i] 22
[/i][i] -62.0776
[/i][i] 32
[/i][i] -131.703
[/i][i] 13
[/i][i] 61.7002
[/i][i] 23
[/i][i] -62.0776
[/i][i] 33
[/i][i] -131.703
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 59.2474
[/i][i] 20
[/i][i] -72.078
[/i][i] 30
[/i][i] -149.817
[/i][i] 11
[/i][i] 60.9456
[/i][i] 21
[/i][i] -73.7761
[/i][i] 31
[/i][i] -130.193
[/i][i] 12
[/i][i] 59.0586
[/i][i] 22
[/i][i] -81.3237
[/i][i] 32
[/i][i] -151.137
[/i][i] 13
[/i][i] 59.0586
[/i][i] 23
[/i][i] -81.3237
[/i][i] 33
[/i][i] -151.137
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 55.4735
[/i][i] 20
[/i][i] -90.0031
[/i][i] 30
[/i][i] -134.533
[/i][i] 11
[/i][i] 59.0586
[/i][i] 21
[/i][i] -81.3237
[/i][i] 31
[/i][i] -151.137
[/i][i] 12
[/i][i] 60.9456
[/i][i] 22
[/i][i] -73.7761
[/i][i] 32
[/i][i] -130.193
[/i][i] 13
[/i][i] 60.9456
[/i][i] 23
[/i][i] -73.7761
[/i][i] 33
[/i][i] -130.193
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 55.4735
[/i][i] 20
[/i][i] -90.0031
[/i][i] 30
[/i][i] -134.533
[/i][i] 11
[/i][i] 59.0586
[/i][i] 21
[/i][i] -81.3237
[/i][i] 31
[/i][i] -151.137
[/i][i] 12
[/i][i] 55.8509
[/i][i] 22
[/i][i] -91.8901
[/i][i] 32
[/i][i] -155.477
[/i][i] 13
[/i][i] 55.8509
[/i][i] 23
[/i][i] -91.8901
[/i][i] 33
[/i][i] -155.477
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.8884
[/i][i] 20
[/i][i] -97.3618
[/i][i] 30
[/i][i] -139.439
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -91.8901
[/i][i] 31
[/i][i] -155.477
[/i][i] 12
[/i][i] 55.4735
[/i][i] 22
[/i][i] -90.0031
[/i][i] 32
[/i][i] -134.533
[/i][i] 13
[/i][i] 55.4735
[/i][i] 23
[/i][i] -90.0031
[/i][i] 33
[/i][i] -134.533
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.8884
[/i][i] 20
[/i][i] -97.3618
[/i][i] 30
[/i][i] -139.439
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -91.8901
[/i][i] 31
[/i][i] -155.477
[/i][i] 12
[/i][i] 46.7941
[/i][i] 22
[/i][i] -104.343
[/i][i] 32
[/i][i] -146.609
[/i][i] 13
[/i][i] 46.7941
[/i][i] 23
[/i][i] -104.343
[/i][i] 33
[/i][i] -146.609
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.7941
[/i][i] 20
[/i][i] -104.343
[/i][i] 30
[/i][i] -146.609
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -91.8901
[/i][i] 31
[/i][i] -155.477
[/i][i] 12
[/i][i] 47.9262
[/i][i] 22
[/i][i] -101.513
[/i][i] 32
[/i][i] -159.628
[/i][i] 13
[/i][i] 47.9262
[/i][i] 23
[/i][i] -101.513
[/i][i] 33
[/i][i] -159.628
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 57.7379
[/i][i] 20
[/i][i] -59.6246
[/i][i] 30
[/i][i] -150.76
[/i][i] 11
[/i][i] 59.2474
[/i][i] 21
[/i][i] -72.078
[/i][i] 31
[/i][i] -149.817
[/i][i] 12
[/i][i] 51.5112
[/i][i] 22
[/i][i] -80.9462
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] 51.5112
[/i][i] 23
[/i][i] -80.9462
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 59.0586
[/i][i] 20
[/i][i] -81.3237
[/i][i] 30
[/i][i] -151.137
[/i][i] 11
[/i][i] 59.2474
[/i][i] 21
[/i][i] -72.078
[/i][i] 31
[/i][i] -149.817
[/i][i] 12
[/i][i] 51.5112
[/i][i] 22
[/i][i] -80.9462
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] 51.5112
[/i][i] 23
[/i][i] -80.9462
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.5112
[/i][i] 20
[/i][i] -80.9462
[/i][i] 30
[/i][i] -169.818
[/i][i] 11
[/i][i] 52.2659
[/i][i] 21
[/i][i] -92.8335
[/i][i] 31
[/i][i] -169.818
[/i][i] 12
[/i][i] 59.0586
[/i][i] 22
[/i][i] -81.3237
[/i][i] 32
[/i][i] -151.137
[/i][i] 13
[/i][i] 59.0586
[/i][i] 23
[/i][i] -81.3237
[/i][i] 33
[/i][i] -151.137
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -92.8335
[/i][i] 30
[/i][i] -169.818
[/i][i] 11
[/i][i] 59.0586
[/i][i] 21
[/i][i] -81.3237
[/i][i] 31
[/i][i] -151.137
[/i][i] 12
[/i][i] 55.8509
[/i][i] 22
[/i][i] -91.8901
[/i][i] 32
[/i][i] -155.477
[/i][i] 13
[/i][i] 55.8509
[/i][i] 23
[/i][i] -91.8901
[/i][i] 33
[/i][i] -155.477
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 52.2659
[/i][i] 20
[/i][i] -92.8335
[/i][i] 30
[/i][i] -169.818
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -91.8901
[/i][i] 31
[/i][i] -155.477
[/i][i] 12
[/i][i] 47.1715
[/i][i] 22
[/i][i] -100.381
[/i][i] 32
[/i][i] -173.214
[/i][i] 13
[/i][i] 47.1715
[/i][i] 23
[/i][i] -100.381
[/i][i] 33
[/i][i] -173.214
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 47.1715
[/i][i] 20
[/i][i] -100.381
[/i][i] 30
[/i][i] -173.214
[/i][i] 11
[/i][i] 55.8509
[/i][i] 21
[/i][i] -91.8901
[/i][i] 31
[/i][i] -155.477
[/i][i] 12
[/i][i] 47.9262
[/i][i] 22
[/i][i] -101.513
[/i][i] 32
[/i][i] -159.628
[/i][i] 13
[/i][i] 47.9262
[/i][i] 23
[/i][i] -101.513
[/i][i] 33
[/i][i] -159.628
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 51.8884
[/i][i] 20
[/i][i] -65.6627
[/i][i] 30
[/i][i] -167.742
[/i][i] 11
[/i][i] 57.7379
[/i][i] 21
[/i][i] -59.6246
[/i][i] 31
[/i][i] -150.76
[/i][i] 12
[/i][i] 51.5112
[/i][i] 22
[/i][i] -80.9462
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] 51.5112
[/i][i] 23
[/i][i] -80.9462
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 30.7556
[/i][i] 20
[/i][i] -111.891
[/i][i] 30
[/i][i] -176.044
[/i][i] 11
[/i][i] 36.9823
[/i][i] 21
[/i][i] -107.362
[/i][i] 31
[/i][i] -180.195
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -107.551
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -107.551
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 30.7556
[/i][i] 20
[/i][i] -111.891
[/i][i] 30
[/i][i] -176.044
[/i][i] 11
[/i][i] 39.0579
[/i][i] 21
[/i][i] -107.551
[/i][i] 31
[/i][i] -169.818
[/i][i] 12
[/i][i] 27.9255
[/i][i] 22
[/i][i] -113.966
[/i][i] 32
[/i][i] -171.516
[/i][i] 13
[/i][i] 27.9255
[/i][i] 23
[/i][i] -113.966
[/i][i] 33
[/i][i] -171.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.9255
[/i][i] 20
[/i][i] -113.966
[/i][i] 30
[/i][i] -171.516
[/i][i] 11
[/i][i] 31.8877
[/i][i] 21
[/i][i] -112.834
[/i][i] 31
[/i][i] -166.987
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -107.551
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -107.551
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.9255
[/i][i] 20
[/i][i] -113.966
[/i][i] 30
[/i][i] -171.516
[/i][i] 11
[/i][i] 31.8877
[/i][i] 21
[/i][i] -112.834
[/i][i] 31
[/i][i] -166.987
[/i][i] 12
[/i][i] 25.2839
[/i][i] 22
[/i][i] -116.042
[/i][i] 32
[/i][i] -162.836
[/i][i] 13
[/i][i] 25.2839
[/i][i] 23
[/i][i] -116.042
[/i][i] 33
[/i][i] -162.836
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 25.2839
[/i][i] 20
[/i][i] -116.042
[/i][i] 30
[/i][i] -162.836
[/i][i] 11
[/i][i] 27.9255
[/i][i] 21
[/i][i] -113.966
[/i][i] 31
[/i][i] -171.516
[/i][i] 12
[/i][i] 18.3023
[/i][i] 22
[/i][i] -118.306
[/i][i] 32
[/i][i] -171.893
[/i][i] 13
[/i][i] 18.3023
[/i][i] 23
[/i][i] -118.306
[/i][i] 33
[/i][i] -171.893
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 18.3023
[/i][i] 20
[/i][i] -118.306
[/i][i] 30
[/i][i] -171.893
[/i][i] 11
[/i][i] 27.9255
[/i][i] 21
[/i][i] -113.966
[/i][i] 31
[/i][i] -171.516
[/i][i] 12
[/i][i] 13.0191
[/i][i] 22
[/i][i] -118.117
[/i][i] 32
[/i][i] -177.176
[/i][i] 13
[/i][i] 13.0191
[/i][i] 23
[/i][i] -118.117
[/i][i] 33
[/i][i] -177.176
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 27.9255
[/i][i] 20
[/i][i] -113.966
[/i][i] 30
[/i][i] -171.516
[/i][i] 11
[/i][i] 30.7556
[/i][i] 21
[/i][i] -111.891
[/i][i] 31
[/i][i] -176.044
[/i][i] 12
[/i][i] 25.661
[/i][i] 22
[/i][i] -113.589
[/i][i] 32
[/i][i] -178.686
[/i][i] 13
[/i][i] 25.661
[/i][i] 23
[/i][i] -113.589
[/i][i] 33
[/i][i] -178.686
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 25.661
[/i][i] 20
[/i][i] -113.589
[/i][i] 30
[/i][i] -178.686
[/i][i] 11
[/i][i] 30.7556
[/i][i] 21
[/i][i] -111.891
[/i][i] 31
[/i][i] -176.044
[/i][i] 12
[/i][i] 36.9823
[/i][i] 22
[/i][i] -107.362
[/i][i] 32
[/i][i] -180.195
[/i][i] 13
[/i][i] 36.9823
[/i][i] 23
[/i][i] -107.362
[/i][i] 33
[/i][i] -180.195
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.0572
[/i][i] 20
[/i][i] -116.23
[/i][i] 30
[/i][i] -178.119
[/i][i] 11
[/i][i] 25.661
[/i][i] 21
[/i][i] -113.589
[/i][i] 31
[/i][i] -178.686
[/i][i] 12
[/i][i] 27.9255
[/i][i] 22
[/i][i] -113.966
[/i][i] 32
[/i][i] -171.516
[/i][i] 13
[/i][i] 27.9255
[/i][i] 23
[/i][i] -113.966
[/i][i] 33
[/i][i] -171.516
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 13.0191
[/i][i] 20
[/i][i] -118.117
[/i][i] 30
[/i][i] -177.176
[/i][i] 11
[/i][i] 19.0572
[/i][i] 21
[/i][i] -116.23
[/i][i] 31
[/i][i] -178.119
[/i][i] 12
[/i][i] 5.09431
[/i][i] 22
[/i][i] -117.363
[/i][i] 32
[/i][i] -181.893
[/i][i] 13
[/i][i] 5.09431
[/i][i] 23
[/i][i] -117.363
[/i][i] 33
[/i][i] -181.893
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 13.0191
[/i][i] 20
[/i][i] -118.117
[/i][i] 30
[/i][i] -177.176
[/i][i] 11
[/i][i] 27.9255
[/i][i] 21
[/i][i] -113.966
[/i][i] 31
[/i][i] -171.516
[/i][i] 12
[/i][i] 19.0572
[/i][i] 22
[/i][i] -116.23
[/i][i] 32
[/i][i] -178.119
[/i][i] 13
[/i][i] 19.0572
[/i][i] 23
[/i][i] -116.23
[/i][i] 33
[/i][i] -178.119
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 46.7941
[/i][i] 20
[/i][i] -104.343
[/i][i] 30
[/i][i] -146.609
[/i][i] 11
[/i][i] 47.9262
[/i][i] 21
[/i][i] -101.513
[/i][i] 31
[/i][i] -159.628
[/i][i] 12
[/i][i] 42.643
[/i][i] 22
[/i][i] -107.362
[/i][i] 32
[/i][i] -152.27
[/i][i] 13
[/i][i] 42.643
[/i][i] 23
[/i][i] -107.362
[/i][i] 33
[/i][i] -152.27
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 42.643
[/i][i] 20
[/i][i] -107.362
[/i][i] 30
[/i][i] -152.27
[/i][i] 11
[/i][i] 47.9262
[/i][i] 21
[/i][i] -101.513
[/i][i] 31
[/i][i] -159.628
[/i][i] 12
[/i][i] 36.4163
[/i][i] 22
[/i][i] -111.136
[/i][i] 32
[/i][i] -161.326
[/i][i] 13
[/i][i] 36.4163
[/i][i] 23
[/i][i] -111.136
[/i][i] 33
[/i][i] -161.326
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 35.4728
[/i][i] 20
[/i][i] -112.457
[/i][i] 30
[/i][i] -145.477
[/i][i] 11
[/i][i] 36.4163
[/i][i] 21
[/i][i] -111.136
[/i][i] 31
[/i][i] -161.326
[/i][i] 12
[/i][i] 42.643
[/i][i] 22
[/i][i] -107.362
[/i][i] 32
[/i][i] -152.27
[/i][i] 13
[/i][i] 42.643
[/i][i] 23
[/i][i] -107.362
[/i][i] 33
[/i][i] -152.27
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 35.4728
[/i][i] 20
[/i][i] -112.457
[/i][i] 30
[/i][i] -145.477
[/i][i] 11
[/i][i] 42.643
[/i][i] 21
[/i][i] -107.362
[/i][i] 31
[/i][i] -152.27
[/i][i] 12
[/i][i] 46.7941
[/i][i] 22
[/i][i] -104.343
[/i][i] 32
[/i][i] -146.609
[/i][i] 13
[/i][i] 46.7941
[/i][i] 23
[/i][i] -104.343
[/i][i] 33
[/i][i] -146.609
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 19.4346
[/i][i] 20
[/i][i] -116.985
[/i][i] 30
[/i][i] -149.439
[/i][i] 11
[/i][i] 35.4728
[/i][i] 21
[/i][i] -112.457
[/i][i] 31
[/i][i] -145.477
[/i][i] 12
[/i][i] 29.6236
[/i][i] 22
[/i][i] -115.098
[/i][i] 32
[/i][i] -156.609
[/i][i] 13
[/i][i] 29.6236
[/i][i] 23
[/i][i] -115.098
[/i][i] 33
[/i][i] -156.609
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 29.6236
[/i][i] 20
[/i][i] -115.098
[/i][i] 30
[/i][i] -156.609
[/i][i] 11
[/i][i] 35.4728
[/i][i] 21
[/i][i] -112.457
[/i][i] 31
[/i][i] -145.477
[/i][i] 12
[/i][i] 36.4163
[/i][i] 22
[/i][i] -111.136
[/i][i] 32
[/i][i] -161.326
[/i][i] 13
[/i][i] 36.4163
[/i][i] 23
[/i][i] -111.136
[/i][i] 33
[/i][i] -161.326
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 25.2839
[/i][i] 20
[/i][i] -116.042
[/i][i] 30
[/i][i] -162.836
[/i][i] 11
[/i][i] 36.4163
[/i][i] 21
[/i][i] -111.136
[/i][i] 31
[/i][i] -161.326
[/i][i] 12
[/i][i] 29.6236
[/i][i] 22
[/i][i] -115.098
[/i][i] 32
[/i][i] -156.609
[/i][i] 13
[/i][i] 29.6236
[/i][i] 23
[/i][i] -115.098
[/i][i] 33
[/i][i] -156.609
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 25.2839
[/i][i] 20
[/i][i] -116.042
[/i][i] 30
[/i][i] -162.836
[/i][i] 11
[/i][i] 29.6236
[/i][i] 21
[/i][i] -115.098
[/i][i] 31
[/i][i] -156.609
[/i][i] 12
[/i][i] 19.4346
[/i][i] 22
[/i][i] -116.985
[/i][i] 32
[/i][i] -149.439
[/i][i] 13
[/i][i] 19.4346
[/i][i] 23
[/i][i] -116.985
[/i][i] 33
[/i][i] -149.439
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 25.2839
[/i][i] 20
[/i][i] -116.042
[/i][i] 30
[/i][i] -162.836
[/i][i] 11
[/i][i] 36.4163
[/i][i] 21
[/i][i] -111.136
[/i][i] 31
[/i][i] -161.326
[/i][i] 12
[/i][i] 31.8877
[/i][i] 22
[/i][i] -112.834
[/i][i] 32
[/i][i] -166.987
[/i][i] 13
[/i][i] 31.8877
[/i][i] 23
[/i][i] -112.834
[/i][i] 33
[/i][i] -166.987
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 31.8877
[/i][i] 20
[/i][i] -112.834
[/i][i] 30
[/i][i] -166.987
[/i][i] 11
[/i][i] 36.4163
[/i][i] 21
[/i][i] -111.136
[/i][i] 31
[/i][i] -161.326
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -107.551
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -107.551
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 39.0579
[/i][i] 20
[/i][i] -107.551
[/i][i] 30
[/i][i] -169.818
[/i][i] 11
[/i][i] 47.9262
[/i][i] 21
[/i][i] -101.513
[/i][i] 31
[/i][i] -159.628
[/i][i] 12
[/i][i] 36.4163
[/i][i] 22
[/i][i] -111.136
[/i][i] 32
[/i][i] -161.326
[/i][i] 13
[/i][i] 36.4163
[/i][i] 23
[/i][i] -111.136
[/i][i] 33
[/i][i] -161.326
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 39.0579
[/i][i] 20
[/i][i] -107.551
[/i][i] 30
[/i][i] -169.818
[/i][i] 11
[/i][i] 47.9262
[/i][i] 21
[/i][i] -101.513
[/i][i] 31
[/i][i] -159.628
[/i][i] 12
[/i][i] 47.1715
[/i][i] 22
[/i][i] -100.381
[/i][i] 32
[/i][i] -173.214
[/i][i] 13
[/i][i] 47.1715
[/i][i] 23
[/i][i] -100.381
[/i][i] 33
[/i][i] -173.214
[/i][i] 0
[/i][i] 3DFACE
[/i][i] 8
[/i][i] 0
[/i][i] 10
[/i][i] 36.9823
[/i][i] 20
[/i][i] -107.362
[/i][i] 30
[/i][i] -180.195
[/i][i] 11
[/i][i] 47.1715
[/i][i] 21
[/i][i] -100.381
[/i][i] 31
[/i][i] -173.214
[/i][i] 12
[/i][i] 39.0579
[/i][i] 22
[/i][i] -107.551
[/i][i] 32
[/i][i] -169.818
[/i][i] 13
[/i][i] 39.0579
[/i][i] 23
[/i][i] -107.551
[/i][i] 33
[/i][i] -169.818
[/i][i] 0
[/i][i] ENDSEC
[/i][i] 0
[/i][i] EOF
[/i][i]
[/i]-------------- next part --------------
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021216/bf381bda/attachment.bin
Xiang Lan
[GiDlist] How to get tetrahedral mesh for a 3d model from su
Post by Xiang Lan »
Thanks a lot for your help! Enrique.
Xiang
--- Enrique Escolano escolano at cimne.upc.es wrote:
You must first create the missing bottom surfaces to
close a volume,
and then create this volume and generate the mesh.
I attach the model with this modifications, the
aditional surfaces are in
the layer 'Layer0'.
(The mesh is not included, you must re-generate for
example with the default
size=27)
Sent: Sunday, December 15, 2002 9:13 PM
Subject: [GiDlist] How to get tetrahedral mesh for a
3d model from surface
mesh?
Hello All,
I'm a beginner using GiD.
I try to generate tetrahedral volume mesh from
existing 3d models in surface meshes, such as
triangle
meshes.
It seems I couldn't generate tetrahedral volume
mesh.
Here I send a example to you. (A cat model in DXF
format)
Can anyone give me some help?
Thanks in advance.
Xiang
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up
now.
http://mailplus.yahoo.com
0
SECTION
2
ENTITIES
0
3DFACE
8
0
10
-0.188568
20
-11.321
30
1.88669
11
0
21
0
31
0
12
-8.30194
22
-6.41525
32
-1.88667
13
-8.30194
23
-6.41525
33
-1.88667
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
-13.208
21
-13.3965
31
-6.22638
12
-8.30194
22
-6.41525
32
-1.88667
13
-8.30194
23
-6.41525
33
-1.88667
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
-8.30194
21
-6.41525
31
-1.88667
12
0
22
0
32
0
13
0
23
0
33
0
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
0
21
0
31
0
12
-6.60382
22
4.52829
32
-1.69809
13
-6.60382
23
4.52829
33
-1.69809
0
3DFACE
8
0
10
-15.6607
20
-1.69809
30
-6.0378
11
-6.60382
21
4.52829
31
-1.69809
12
-13.774
22
10.3775
32
-6.7924
13
-13.774
23
10.3775
33
-6.7924
0
3DFACE
8
0
10
=== message truncated ===
ATTACHMENT part 2 application/x-zip-compressed
name=cat.gid.zip
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
