On Monday 23 September 2002 05:43 am, gidlist-request at gatxan.cimne.upc.es
wrote:
Message: 2
From: =?Windows-1252?Q?Ramon_Rib=F3?= ramsan at compassis.com
Subject: RE: [GiDlist] [Fwd: Basic NURBS line problem: Given a line and a
point not in the line ...] Date: Mon, 23 Sep 2002 14:23:57 +0200
Reply-To: gidlist at gid.cimne.upc.es
To make a closed NURBS line tangent in the origin/end point, it
is possible to use:
- Select with Control-a the first point
- In contextual submenu use 'Tangents','Next','By line'
That's it! Thanks.
Here's another basic NURBS problem:
After submitting a few points to a NURBS curve, generate a place in the curve
where the curve is tangent to itself, but in the opposite direction in the
middle of the curve -- that is, somewhere before the last point in the curve.
A similar problem might be to make a closed curve tangent to itself in the
opposite direction at the closure point.
Paul Pikowsky
[GiDlist] Re: Simple NURBS problem: Closed curve, tangent to
I do not understand your question, please send a small picture to explain.
Sent: Monday, September 23, 2002 9:12 PM
Subject: [GiDlist] Re: Simple NURBS problem: Closed curve, tangent to itself
at closure point
wrote:
Message: 2
a
is possible to use:
That's it! Thanks.
curve
curve.
Paul Pikowsky
at closure point
wrote:
Message: 2
a
is possible to use:
That's it! Thanks.
curve
curve.
Paul Pikowsky
