Is there a way to visualize a surface graph using similar function like
splot in qnuplot. I have a file that contains three columns represent X Y
and Z and
I would like to find a way in GID to get a surface plot out of that file.
Khaled Obeidat
Research Engineer
EMAG Technologies, Inc.
www.emagtechnologies.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030929/2175f19a/attachment.htm
[GiDlist] Surface plot
You can use the tecplot format by just adding two lines like in this example:
VARIABLES= "x", "y", "z"
ZONE T="test", I=2, J=4, K=1, F=POINT
0 0 0
1 0 0
0 1 0
1 1 0
0 2 1
1 2 1
0 3 1
1 3 1
Hope it helps,
Khaled Obeidat wrote:
Is there a way to visualize a surface graph using similar function like splot in qnuplot. I have a file that contains three
columns represent X Y and Z and
Khaled Obeidat
Research Engineer
0 0 0
1 0 0
0 1 0
1 1 0
0 2 1
1 2 1
0 3 1
1 3 1
Hope it helps,
Khaled Obeidat
Research Engineer
Currently not exists this functionality.
Must create a mesh file with the nodes located at XY coordinates, and set for example z as a scalar or vector result.
Sent: Monday, September 29, 2003 2:42 PM
Subject: [GiDlist] Surface plot
Is there a way to visualize a surface graph using similar function like splot in qnuplot. I have a file that contains three columns represent X Y and Z and
Khaled Obeidat
Research Engineer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030929/3be4c08a/attachment.htm
Khaled Obeidat
Research Engineer
have you a little example about this?
Khaled Obeidat
Research Engineer
Khaled Obeidat
Research Engineer
