[GiDlist] Still gid.exe error
Calogero Fontana
Post by Calogero Fontana »
Dear GiD team,
I'm sorry to underline aleays the same problem, but I try to do everything you suggest me.
I update my graphic card (It's SiS 650),
its resolution is on 32 bit,
GiD safe mode doesn't start.
I can't find commands to deactive graphic hardware acceleration.
Calogero
I
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030807/97c9fad8/attachment.htm
To try to deactivate the hardware OpenGL acceleraction:
(Note: I work in a spanish Windows version, some message can change for your language !!)
Click the left mouse button over the Windows screen, and select "Properties"
Configuration-Advanced options-Solve problems-Hardware acceleration (select none)
See also the content of this GiD F.A.Q.
I try to open GiD by the first time on MS Windows and it crashes
Tipically, these type of problems are caused by the graphics acceleration card.
A possibility to avoid the problem is the following: Try to start GiD safe mode (from the start menu) and activate use Software OpenGL If the problem persists, try to deactivate the graphic hardware acceleration (Screen properties-Advanced options). Also try a different colour resolutions (select 32 bits of colour for example) Search in the web page of your card if there are actualized drivers for your graphic card.
Sent: Thursday, August 07, 2003 6:11 PM
Subject: [GiDlist] Still gid.exe error
Dear GiD team,
Calogero
I
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030811/c0b47aaa/attachment.htm
