[GiDlist] A question about Mesh extrusion
edodo
Post by edodo »
Dear,Enrique Escolano
Thanks.
How can I set boundaries(such as surface load) on the Hexahra element,I only Can set the Load on the first surface ,I can't set it on the create element surface.
BTW,What's mean of S_i S_ii S_iii in the menu ViewRests Which the rest files used the matrix type in postpress.
======= 2003-07-25 23:02:00 You wrote:=======
Yes, This is a bug (a variable not initialized), with random results.
It'is corrected for the next beta version (the next week be available).
Note: It's possible to generate prims by triangle extrusion, but this
element type has a very small support in GiD at this moment (cannot be
loaded in postprocess or see boundaries in preprocess, etc).
Thanks for your bug report.
Sent: Friday, July 25, 2003 3:52 AM
Subject: Re: Re: Re: [GiDlist] A question about Mesh extrusion
Dear,sir/madam,Enrique Escolano
There is a sample in attached files. You should tanslate to Mesh view in
Gid When you open the files of "sa.gid",And I create a bach file,butTHe
model which you import bach files are better than the sa.gid,but there are
some wrong on the boundary.
BTW,I will get different model when i import sa.bch? Why?
Thanks for your help
======= 2003-07-24 14:53:00 You wrote:=======
Send us a small sample and the procedure to obtain this error.
Note: If you use a version previous to 7.4.2-b, must update (from the web
section download beta versions). Some bugs can be corrected.
Sent: Thursday, July 24, 2003 3:12 AM
Subject: Re: Re: [GiDlist] A question about Mesh extrusion
There are some error in this way when I use Offest.Can you help me.
======= 2003-07-22 20:26:00 You wrote:=======
This feature is also available in previous 7.x versions.
Select mesh view, and then open the "copy window".
Can extrude elements by translation, rotation, etc.
Sent: Tuesday, July 22, 2003 11:00 AM
Subject: [GiDlist] A question about Mesh extrusion
Dear GiD teams
There are a new availab in GID 7.4.2b of Mesh extrusion,But I can't
find it in Copy windows! Can you help me?
Fegen software Co.,Ltd
http://www.fegensoft.com/english
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-22
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-24
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-25
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-28
I don't understand your questions, but i try to request it:
If you want to apply a condition 'over face elems' directly over the mesh, instead to over the surfaces and after generate the mesh, it exists some
problems:
It is not possible to select a face, it's needed to select a element, and
GiD automatically apply this conditions over the boundary faces (the interface betwheen two materials is considered also boundary)
If your condition is defined CanRepeat: No (by default), then only is applied
the condition over one face by element, else is applied a condition foreach boundary face. Probably you must set CanRepeat: yes in the *.cnd file.
Si, Sii and Siii represent the eigen values & vectors of the symmetric tensor matrix results which are calculated by GiD, and which are ordered according to the eigen value.
Sent: Monday, July 28, 2003 10:36 AM
Subject: Re: Re: Re: Re: [GiDlist] A question about Mesh extrusion
Thanks.
Dear GiD teams
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-22
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-24
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-25
086-10-82131600
086-10-82121900
ShaolinZhou
fea at eyou.com
2003-07-28
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030730/12b2b9f0/attachment.htm
