[GiDlist] meshing
Mark Smith
[GiDlist] meshing
Post by Mark Smith »
I have an electrostatics application where I have a surface & discrete point
charges not on the surface.
I have found that the only way to write out both the surface mesh and the
points to a mesh file is to join the points to a dummy point with lines to
make them linear elements.
Is there a more elegant method to enable both surface elements & points to
be written to a mesh file?
Thanks in advance
Mark
GiD6.3.0b & win98
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.458 / Virus Database: 257 - Release Date: 24/02/03
The information contained in this e-mail message (and any attachment
transmitted herewith) is privileged and confidential and is intended for the
exclusive use of the addressee(s). If you are not an addressee, any
disclosure, reproduction, distribution or other dissemination or use of this
communication is strictly prohibited. If you have received this
communication in error, please contact us immediately so that we can correct
the error.
[GiDlist] meshing
By default, isolated points are not meshed as nodes, but you can change this
setting with:
Utilities-Preferences: Meshing , and select "Mesh Always by default" for
Points
Note: The nodes are hidden by default, but can show their labels.
(or show written "escape escape View Entities Nodes" in the command line or
with the right buttons)
Sent: Monday, May 12, 2003 2:39 PM
Subject: [GiDlist] meshing
point
Thanks in advance
Mark
GiD6.3.0b & win98
the
this
correct
the error.
