Re: [GiDlist] glibc version?
Johnny Geling
Post by Johnny Geling »
Thanks for the reply,
I use a mix from woody, sarge and a little bit of unstable. I'm planning an
update to sarge.
Unless the statically compiled installer it gives me a segmentation fault.
The internet retrieve also has the segmentation fault. This evening I can
investigate futher.
Should I compile the problem types for Linux? I tried it with the cmas2d,
without succes.
Johnny
On Mon, 12 May 2003 08:55:34 +0200, you wrote:
it uses glibc 2.2.
GiD is compiled statically, and the installator too, so
no external libraries are needed.
There is a dynamic version:
ftp://www.gidhome.com/pub/gid_adds/Linux/gid7.3b-dyn.tar.gz
to take advantage of the graphics acceleraiton provided by
the X server.
Which version of Debian are you using?
To do any calculation you have to install a simulation code,
for instance Rambshell, Tdyn, caltep, emant, or any other.
take a look at http://www.gidhome.com/gidplus/
or into the option menu 'Data-Problem type-Internet retrieve'.
Johnny Geling wrote:
I installed GID on a Linux box (Debian, woody with sarge and unstable
parts)
What Glibc version needs GID? And what other versions of libraries are
required?
The problems I have:
- instal verion not working: segmentation fault
- I cannot do any calculation: cannot find problemtype.dat file and
when
it can find it it cannot open or run. Because I'm not at that computer I
cannot phrase the exact error.
- retrieve problem type list causes a segmentation fault.
Any help is appriciated.
Johnny
Miguel A. Pasenau de Riera miguel at cimne.upc.es
The "internet retrieve" problemtypes, at this moment, only includes the
Win32 compiled executable.
Are not compiled for Linux. To obtain a Linux/Unix version of Ramseries of
Tdyn contact Compass
web page: http://www.compassis.com
What's the problem with cmas2d? It exists some problem to compile cmas2d.c
to cmas2d?
Must also change cmas2d.unix.bat to start this executable: $3/cmas2d $2/$1
(and set the permission execution flag of cmas2d with chmod +x)
Sent: Monday, May 12, 2003 2:15 PM
Subject: Re: [GiDlist] glibc version?
an
update to sarge.
investigate futher.
without succes.
Johnny
it uses glibc 2.2.
the X server.
parts)
required?
when
I
Johnny
