Hello Gid Team,
I'm would like to be able to save some informations about the projecct
and to restore them when i open the project.
Exactly, I want to keep the information about two selected surfaces,
without assigning conditions or materials to those surfaces.
The goal is to create an contact zone which i need to mesh in a specific
way. For this I need to surfaces: a master surface and a slave surface.
I created a new list in which i keep the name of the contact zone, the
numbers of each surface (master and slave) and some options. I would
like to keep track of this list over sessions.
Is this possible?
Thank you,
Mihai TEODORESCU
Tel: 05.49.25.40.63
Email: mihai.teodorescu at prevost-industries.com
[GiDlist] Saving informations about the project
Conditions are specifically for THIS, to save contact information
between entities (among other things). So, my advice is to use a
condition
with numeric or named fields to identify the master and the slave pairs.
In any case, you can save things from TCL inside the project, by
using:
SaveGIDProject
LoadGIDProject
Check the Help for details.
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de Mihai TEODORESCU
Enviado el: miércoles, 30 de abril de 2003 14:10
Para: GID Mailing List (E-mail)
Asunto: [GiDlist] Saving informations about the project
Importancia: Alta
Hello Gid Team,
Is this possible?
Thank you,
Mihai TEODORESCU
Tel: 05.49.25.40.63
condition
using:
SaveGIDProject
LoadGIDProject
Importancia: Alta
Hello Gid Team,
Is this possible?
Thank you,
Mihai TEODORESCU
Tel: 05.49.25.40.63
This is the help information about the tcl procedures related by Ramon to save
and reload specific problemtype data. (see help on Tcl/Tk extension)
proc LoadGIDProject { filespd } {
...body(5)...
LoadGIDProject: will be called when a GiD project is loaded. It receives the filespd argument, which is the path of the file which is being opened, but with a .spd extension (specific problemtype data). This path can be useful if you want to write specific information of the problem type in a new file.
proc SaveGIDProject { filespd } {
...body(6)...
SaveGIDProject: will be called when the current opened file is saved to disk. It receives the filespd argument, which is the path of the file which is being saved, but with a .spd extension (specific problemtype data). This path can be useful if you want to write specific information of the problem type in a new file.
Sent: Wednesday, April 30, 2003 4:15 PM
Subject: RE: [GiDlist] Saving informations about the project
condition
using:
SaveGIDProject
LoadGIDProject
Importancia: Alta
Hello Gid Team,
Is this possible?
Thank you,
Mihai TEODORESCU
Tel: 05.49.25.40.63
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030430/4fc2731c/attachment.htm
...body(5)...
...body(6)...
condition
using:
SaveGIDProject
LoadGIDProject
Importancia: Alta
Hello Gid Team,
Is this possible?
Thank you,
Mihai TEODORESCU
Tel: 05.49.25.40.63
[GiDlist] Problem of the Local Axes on the post.
Hi Enrique
Many thanks for your prompt advise
It seems to me that there are a problem in GiD
about drawing the Local axes on the Post. I attached
the simple Post of the local axes. I played around
with the rotating the local axes from X,Y,and Z as
shown in the file. In my case the local Axis rotate
around the Y-axis base on the surface of the element.
The problem is:
1. Rotate about x axis......this's OK.
2. Rotate about y axis......this's not OK.
3. Rotate about z axis......this's OK.
The Zoom command "screen axis" in the post also didn't
work properly. Is it a GiD problem or my problem???
Best Regars.
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
Desc: ShLocal.gid.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030501/e2d29742/attachment.bin
The problem is:
Best Regars.
Do you Yahoo!?
