Your *.flavia.res must be inside your model directory, and with the same model name. For example, if your model is saved in
C:/tmp/test.gid, then your result file must be inside this directory and must be named C:/tmp/test.flavia.res (or C:/tmp/test.flavia.post)
(when you change from pre to postprocess this files are automatically loaded, but if you use another name, mush open it manually from the postprocess)
Read GiD help about Posprocessing data files.
Sent: Tuesday, December 30, 2003 9:36 PM
Subject: [GiDlist] Results files
Hi: I want to know if the results files (flavia.res flavia.msh) that my excecution module produce must be in a particular way, and if it is like that where i can find it, becuase in the tutorial doesn't apear.
¿Buscás un auto?
Encontralo en Yahoo! Autos
¡Más de 4000 clasificados todos los días!
Usados - 0 km - Vendé el tuyo
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040107/0c51462a/attachment.htm
