[GiDlist] RamDebugger
Georg Haasemann
Post by Georg Haasemann »
I try to use the RamDebugger but it doesn't work.
I'm using GiD9 (64bit) for Linux which is Ubuntu 8.04.
Starting the RamDebugger inside Gid (DataProblem TypeDebugger...), the RamDebugger window opens. After setting a break point in the tcl-file, I start the procedure in GiD. However, Gid runs through the entire script without changing the focus to the RamDebugger. What do I have to change that it is working properly?
Thanks in advance.
Georg
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
After open the file, you must explicitly start the debugging
(with the F5 key or the 'Debug-Continue/Go' menu)
To: gidlist at gid.cimne.upc.edu
Sent: Monday, October 27, 2008 3:12 PM
Subject: [GiDlist] RamDebugger
Thanks in advance.
Georg
GiDlist at gid.cimne.upc.edu
Georg Haasemann
Am Montag, den 27.10.2008, 17:44 +0100 schrieb Enrique Escolano:
That is working! Thank you.
Georg
