[GiDlist] Cut planes
Nunzio Losacco
Post by Nunzio Losacco »
Dear GiD people,
I have a very annoying bug (well, I guess it's a bug) happening whenever I
try to use "Do cuts -- cut plane -- 3 points". Whenever I try to use this
command I have a huge (and apparently random) number of warning windows
opening, last time they were 50!!! The warnings are about the fact that
"quadratic elements are treated as linear in cut planes" "results at gauss
points are not shown", just "warning", etc. Moreover a very small writing
says: "to disable this warning do Utilities -- preferences -- use multiple
windows". But that command path simply doesn't seem to exist!!!
Did anyone else experienced this phenomenon?
n.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091012/1fa6c038/attachment.htm
Post by miguel »
the utilities--preferences--use multiple windows is wrong. Just change the
option 'Pop-up messages' ( located n the 'General' panel of the
'Preferences' window, which can be opened with 'utilities--preferences')
from 'Beginner' to 'Normal'. Then the messages will appear in the command
line, and not in separated windows. we'll correct this problem.
Thanks for the advice.
Miguel Pasenau
Miguel Pasenau @: miguel at cimne.upc.edu
Despacho C2, Edifico C1, Campus Norte UPC, c/ Gran Capitán s/n
08034 - Barcelona ( SPAIN)
T: +34 3 93 401 74 03 F: +34 3 93 401 65 17
IMPORTANT NOTICE
All personal data contained in this mail will be processed confidentially
and stored in a file property of CIMNE in order to manage corporate
communications. You may exercise the right of access, rectification,
deletion and objection by letter sent to CIMNE, Gran Capitán, Edificio C1 -
Campus Norte UPC, 08034 Barcelona, Spain.
De: gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu
[mailto:gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de
Nunzio Losacco
Enviado el: lunes, 12 de octubre de 2009 10:49
Para: gidlist at gatxan.cimne.upc.edu
Asunto: [GiDlist] Cut planes
Dear GiD people,
n.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20091013/4f704b3f/attachment.htm
