I have an L shaped slab that I try to mesh it with quadrilateral elements.
I have perfectly square elements of another element underneath it, and I
want to make my mesh matching each other. So, the L shaped 2d element needs
to be meshed with 2 ft by 2 ft square quadrilateral elements. When I mesh
it now, the elements turn to be curved. How can I have exactly square
elements on an L shape element which is not a rectangle but all lines are
parallel or perpendicular.
Arash
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130817/df902503/attachment.htm
[GiDlist] Meshing Quadrilateral
Dear Arash,
I’m Abel Coll, from the GiD developer Team.
The solution may be to change some meshing properties, or maybe GiD is not
working properly. Please, could you send me the model in order to check it
and help you to reach the mesh you want? In case you want, please, send it
to my e-mail adress instead of the GiDList (abelcs at cimne.upc.edu).
ABEL
_________________________________
Abel Coll Sans - Civil Engineer
Ofice c-2, C1 building - Campus Nord UPC
Gran Capità s/n, 08034 Barcelona
_____
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Farzam, Arash
Enviado el: domingo, 18 de agosto de 2013 2:43
Asunto: [GiDlist] Meshing Quadrilateral
I have an L shaped slab that I try to mesh it with quadrilateral elements. I
have perfectly square elements of another element underneath it, and I want
to make my mesh matching each other. So, the L shaped 2d element needs to be
meshed with 2 ft by 2 ft square quadrilateral elements. When I mesh it now,
the elements turn to be curved. How can I have exactly square elements on an
L shape element which is not a rectangle but all lines are parallel or
perpendicular.
Arash
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130819/8e4dfb56/attachment.htm
ABEL
_____
perpendicular.
Arash
[GiDlist] Scripted geometry import
Dear GiD team,
I'm using GiD mesher/customization for my own FEM code. Former releases
of this code used their own preprocessor with a crappy 3D-block volume
geometry generator. It would be nice if GID could import those geometry
in a scriptig style (like GMSH does). I tried to do it via "Import GiD
mesh" and "Create Geometry from mesh" but this often fails on more
complex geometries.
Thanks for reply.
Mit freundlichen Grüßen
Prof. Dr.-Ing. Lutz Nietner
Hochschule für Technik, Wirtschaft und Kultur Leipzig
LG Bausanierung / Baustoffe
Karl-Liebknecht-Strasse 132
04277 Leipzig
Phone: +49(0)341 3076 6313
Lutz.Nietner at fb.htwk-leipzig.de
www.htwk-leipzig.de
Type: application/pgp-keys
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130819/02d303ba/attachment.key
complex geometries.
Thanks for reply.
04277 Leipzig
www.htwk-leipzig.de
You can write a script to read this kind of files with Tcl/Tk language,
You can see as example the .tcl files of the GiD folder
\plugins\Import\pre
Have a look to the subfolder of cases of STAR-CD, EMA3D or UNV that are
relatively simple.
Note that each one of these 'plugins' add an menu to the Files-Import menu
to import the format thought the procedures defined in the .tcl file
You can see some information of GiD-Tcl special commands in GiD help -
Customization - Tcl/Tk extension
And there is a lot of documentation about standard Tcl/Tk scripting language
in Internet
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Lutz Nietner
Enviado el: lunes, 19 de agosto de 2013 15:58
Asunto: [GiDlist] Scripted geometry import
Dear GiD team,
I'm using GiD mesher/customization for my own FEM code. Former releases of
this code used their own preprocessor with a crappy 3D-block volume geometry
generator. It would be nice if GID could import those geometry in a scriptig
style (like GMSH does). I tried to do it via "Import GiD mesh" and "Create
Geometry from mesh" but this often fails on more complex geometries.
Thanks for reply.
Hochschule für Technik, Wirtschaft und Kultur Leipzig LG Bausanierung /
Baustoffe Karl-Liebknecht-Strasse 132
04277 Leipzig
www.htwk-leipzig.de
\plugins\Import\pre
relatively simple.
in Internet
Dear GiD team,
Thanks for reply.
04277 Leipzig
www.htwk-leipzig.de
