No subject
.gid.central.s disable windows 1
Note: can write a tcl command directly in the GiD command line with -np- =
tclcommand=20
For example:
-np- .gid.central.s disable windows 1
But if don’t open this message window, do not have any echo of the “end =
of calculation” event.
Remember to reactivate the normal windows state with:
.gid.central.s disable windows 0
Other details: Instead to use WarnWinText “…”, must be more elegant to =
put a message in the lower message bar, for example
GidUtils::SetWarnLine “Meshing volumes …”
To: gidlist at gatxan.cimne.upc.es=20
Sent: Tuesday, November 25, 2003 8:55 PM
Subject: Re: [GiDlist] mesh only volumes
Thanks I have applied the changes and it works but I wonder if i can =
make it look user friendly for the user, since I’m creating three files =
one for volumes, one for surfaces and the other one for lines. but GID =
will show some dialogs likes meshing in progress and then it will ask =
about boundary visualization another dialog will show the number of =
tetrahedral elements, triangles or lines.
the following four functions will do what is required but they appear =
to be not user friendly.
proc GenerateMeshAndFiles {} {
global mysizes
=20
=20
if {[lindex [.central.s info Mesh] 0]} {
there is a previous mesh we should erase
.central.s process escape escape escape escape meshing cancelmesh =
yes
now ganerate the mesh
if {![info exists mysizes]} {
set mysizes {}
set retval [tk_dialogComboRAM .gid.tempwinec [_ “Enter value =
window”]
“Enter size of the elements” questhead 3 $mysizes]
if { $retval !=3D “–CANCEL–” } {=20
=20
set idx [lsearch $mysizes $retval]
if { $idx !=3D -1} {
set mysizes [lreplace $mysizes $idx $idx]=20
=20
=20
set mysizes [linsert $mysizes 0 $retval]
=20
JustVolumes $retval
JustSurfaces $retval
JustLines $retval
=20
=20
} else {
WarnWinText “Canceled …”
proc JustVolumes {retval} {
set P_info [.central.s info Project]
set ProjectName [lindex $P_info 1]
set FileName1 [file join $ProjectName.gid [file tail =
$ProjectName].msh]
=20
.central.s process escape escape escape escape Meshing =
MeshCriteria NoMesh Surfaces 1:
MeshCriteria NoMesh Lines 1: =20
.central.s process escape escape escape escape meshing =
generate $retval
WarnWinText “…”
.central.s process escape escape escape escape Files WriteMesh =
"$FileName1"
.central.s process escape=20
=20
proc JustSurfaces {retval} {
set FileName2 [file join $ProjectName.gid [file tail =
$ProjectName].msh2]
=20
yes
.central.s process escape escape escape escape meshing reset yes
=20
MeshCriteria NoMesh Lines 1:=20
MeshCriteria NoMesh Volumes 1:
generate $retval
WarnWinText “…”
"$FileName2"
=20
proc JustLines {retval} {
set FileName3 [file join $ProjectName.gid [file tail =
$ProjectName].msh3]
=20
yes
=20
MeshCriteria NoMesh Surfaces SelWindow 1:=20
MeshCriteria NoMesh Volumes SelWindow 1:
generate $retval
WarnWinText “…”
"$FileName3"
=20
Best Regards,
dialogs=20
Khaled Obeidat=20
Research Engineer=20
EMAG Technologies, Inc.=20
www.emagtechnologies.com
------=_NextPart_000_0180_01C3B39C.246477E0
Content-Type: text/html;
charset=“iso-8859-1”
!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.0 Transitional//EN”
HTMLHEAD
charset=3Diso-8859-1"
META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR
STYLE/STYLE
/HEAD
BODY bgColor=3D#ffffff
DIVFONT face=3DArial size=3D2Read my request to a similar =
question of some=20
days ago FONT size=3D1FONT size=3D1
Plunes, 17 de noviembre de 2003 11:27/P
P/FONTRe: [GiDlist] getting rid off the message box appering at the =
end of=20
calculation action/P/FONT/FONT/DIV
DIVFONT face=3DArial size=3D2 /DIV
DIVFONT face=3DArial size=3D2Can use a trick to disable the window=20
messages:/FONT/DIV
DIVFONT face=3DArial size=3D2From tcl use:/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2.gid.central.s disable =
windows=20
1/FONT/DIV
DIVFONT face=3DArial color=3D#0000ff size=3D2/FONT /DIV
DIVFONT face=3DArial size=3D2Note: can write a tcl command =
directly in the GiD command line with /FONTFONT face=3DArial =
size=3D2-np-=20
 /FONT/DIV
DIVFONT face=3DArial size=3D2For example:/FONT/DIV
DIVFONT face=3DArial size=3D2FONT color=3D#0000ff-np- =
.gid.central.s disable=20
windows 1/FONT/FONT/DIV
DIVFONT face=3DArial size=3D2But if don’t open this =
message window, do=20
of calculation” event./FONT/DIV
DIVFONT face=3DArial size=3D2/FONT /DIV
DIVFONT face=3DArial size=3D2Remember to reactivate the normal =
windows state=20
with:/FONT/DIV
windows=20
0/FONT/DIV
DIVFONT color=3D#0000ff/FONT /DIV
DIVOther details: Instead to use WarnWinText “…”, must be =
more=20
elegant to put a message in the lower message bar, for=20
example/DIV
DIV /DIV
DIVGidUtils::SetWarnLine “Meshing volumes …“BR/DIV
DIVEnrique/DIVX-TAB/FONT
BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px”
DIV style=3D"FONT: 10pt arial”----- Original Message ----- /DIV
DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"BFrom:/B=20
A title=3Dkobeidat at emagtechnologies.com=20
href=3D"mailto:kobeidat at emagtechnologies.com"Khaled Obeidat/A =
/DIV
title=3Dgidlist at gatxan.cimne.upc.es=20
href=3D"mailto:gidlist at gatxan.cimne.upc.es"gidlist at gatxan.cimne.upc.es/=
A=20
/DIV
DIV style=3D"FONT: 10pt arial"BSent:/B Tuesday, November 25, =
2003 8:55=20
PM/DIV
DIV style=3D"FONT: 10pt arial"BSubject:/B Re: [GiDlist] mesh =
only=20
volumes/DIV
DIVBR/DIVThanks I have applied the changes and it works but =
I =20
wonder if i can make it look user friendly for the user, since I’m =
creating=20
three files one for volumes, one for surfaces and the other one for =
lines. but=20
GID will show some dialogs likes meshing in progress and then it will =
ask=20
about boundary visualization another dialog will show the number of=20
tetrahedral elements, triangles or lines.BRBRthe  following =
four=20
functions will do what is required but they appear to be not user=20
friendly.BRBRproc GenerateMeshAndFiles {} {BR    =
global=20
mysizesBRX-TAB        /X-TAB=
BRX-TAB        /X-TABBR&=
nbsp;  =20
if {[lindex [.central.s info Mesh] 0]} {BR    # there =
is a=20
previous mesh we should eraseBR    .central.s process =
escape=20
escape escape escape meshing cancelmesh yesBR   =20
}BR    # now ganerate the =
meshBRBR    if=20
{![info exists mysizes]} {BR    set mysizes=20
{}BR    }BR    set retval =
[tk_dialogComboRAM=20
.gid.tempwinec [_ “Enter value window”]=20
\BR            =
“Enter=20
size of the elements” questhead 3 $mysizes]BR    if { =
$retval=20
!=3D “–CANCEL–” } { BRBR  BR    set idx =
[lsearch=20
$mysizes $retval]BR    if { $idx !=3D -1}=20
{BR        set mysizes [lreplace =
$mysizes=20
$idx $idx] BR       =20
BR        BR   =20
}BR    set mysizes [linsert $mysizes 0=20
$retval]BR    BR   =20
X-TAB    /X-TABJustVolumes=20
$retvalBR   =20
X-TAB    /X-TABJustSurfaces=20
$retvalBR    =
X-TAB    /X-TABJustLines=20
$retvalBRX-TAB        /X-TAB=
BR =20
BR    } else {BR    WarnWinText =
"Canceled=20
…"BR    }BR}BRBRproc JustVolumes {retval}=20
{BRX-TAB        /X-TABset =
P_info=20
[.central.s info=20
Project]BRX-TAB        /X-TA=
Bset=20
ProjectName  [lindex $P_info=20
1]BRX-TAB        /X-TABset =
FileName1 [file join  $ProjectName.gid [file tail=20
$ProjectName].msh]BRX-TAB       &n=
bsp;/X-TABBRX-TAB        /=
X-TAB.central.s=20
process escape escape escape escape Meshing MeshCriteria NoMesh =
Surfaces=20
1:BR    .central.s process escape escape escape =
escape=20
Meshing MeshCriteria NoMesh Lines 1: =20
BRX-TAB        /X-TAB.centr=
al.s=20
process escape escape escape escape meshing generate=20
WarnWinText=20
"…"BRX-TAB        /X-TAB.=
central.s=20
process escape escape escape escape Files WriteMesh=20
"$FileName1"BRX-TAB        =
/X-TAB.central.s=20
process escape=20
BRBRX-TAB        /X-TABB=
R}BRBRproc=20
JustSurfaces {retval}=20
P_info=20
[.central.s info=20
Bset=20
FileName2 [file join  $ProjectName.gid [file tail=20
$ProjectName].msh2]BRX-TAB       &=
nbsp;/X-TABBRX-TAB        =
/X-TABif=20
{[lindex [.central.s info Mesh] 0]} {BR    # there is =
a=20
escape=20
yesBR    =20
.central.s process escape escape escape escape meshing reset=20
yesBR   =20
}BRX-TAB        /X-TABBR=
X-TAB        /X-TAB.central.s =
process escape escape escape escape Meshing MeshCriteria NoMesh Lines =
1:=20
al.s=20
Volumes=20
1:BRX-TAB        /X-TAB.cen=
tral.s=20
WarnWinText=20
"…"BRX-TAB        /X-TAB.=
central.s=20
"$FileName2"BRX-TAB        =
/X-TAB.central.s=20
process escape=20
BRBRX-TAB        /X-TABB=
R}BRBRproc=20
JustLines {retval}=20
P_info=20
[.central.s info=20
Bset=20
FileName3 [file join  $ProjectName.gid [file tail=20
$ProjectName].msh3]BRX-TAB       &=
/X-TABif=20
a=20
escape=20
yesBR    =20
yesBR   =20
}BRX-TAB        /X-TABBR=
Surfaces=20
SelWindow 1:=20
al.s=20
Volumes=20
SelWindow=20
tral.s=20
WarnWinText=20
"…"BRX-TAB        /X-TAB.=
central.s=20
"$FileName3"BRX-TAB        =
/X-TAB.central.s=20
process escape=20
BRBRX-TAB        /X-TABB=
R}BRBRBRBRBest=20
Regards,BRBR dialogs BRAt 01:44 PM 11/25/2003, you =
wrote:BR
BLOCKQUOTE class=3Dcite cite=3D"" type=3D"cite"FONT=20
face=3D"Times New Roman, Times".central.s process escape=20
/FONT/BLOCKQUOTEX-SIGSEP
P/X-SIGSEPKhaled Obeidat BRResearch Engineer BREMAG =
BRFONT color=3D#0000ffUA =
href=3D"http://www.emagtechnologies.com/"=20
eudora=3D"autourl"www.emagtechnologies.comBR/A/FONT/U/P/BLOCK=
QUOTE/BODY/HTML
------=_NextPart_000_0180_01C3B39C.246477E0–
