# \[GiDlist\] Why RamDebugger not works?
**URL:** <https://forum.gidsimulation.com/t/gidlist-why-ramdebugger-not-works/272>\
**Category:** 2013 - 2005\
**Created:** [March 21, 2013, 9:34am UTC](https://forum.gidsimulation.com/t/gidlist-why-ramdebugger-not-works/272 "2013-03-21T09:34:19Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![\_21016\_21147\_39118](https://forum.gidsimulation.com/letter_avatar_proxy/v4/letter/_/ed8c4c/32.png) [@\_21016\_21147\_39118](https://forum.gidsimulation.com/u/_21016_21147_39118)\
**Post date:** [March 21, 2013, 9:34am UTC](https://forum.gidsimulation.com/t/gidlist-why-ramdebugger-not-works/272/1 "2013-03-21T09:34:19Z")
</div>
Hello guys,
Gid have Ramdebugger which is said to be able to debugging TCL in Dataà
Problem Type àDebugger.
I tried to use RamDebugger per following course
[http://www.gidhome.com/images/news/gidconf/2004/courses/09-Debugging%20tcl%2](http://www.gidhome.com/images/news/gidconf/2004/courses/09-Debugging%20tcl%252)
0code.pdf
but nothing happened. The Debugger seems not work? Anybody know the reason.
How can I debug in RamDebugger? I am using Gid 10.0.9
Michael Liu
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/fe4b9d17/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/fe4b9d17/attachment.htm)
**Post date:** [March 21, 2013, 10:31am UTC](https://forum.gidsimulation.com/t/gidlist-why-ramdebugger-not-works/272/2 "2013-03-21T10:31:21Z")
</div>
You must open RamDebugger (e.g. press F12 in GiD or from the Data-Problemtype-Debugger… menu)
then open the Tcl file you want to debug,
and then press F5 in RamDebugger to start debugging (and you can set breakpoints F9 to stop the flow and see/change variables)
Sent: Thursday, March 21, 2013 10:34 AM
Subject: [GiDlist] Why RamDebugger not works?
Hello guys,
Gid have Ramdebugger which is said to be able to debugging TCL in DataàProblem Type àDebugger.
I tried to use RamDebugger per following course [http://www.gidhome.com/images/news/gidconf/2004/courses/09-Debugging%20tcl%20code.pdf](http://www.gidhome.com/images/news/gidconf/2004/courses/09-Debugging%20tcl%20code.pdf)
but nothing happened. The Debugger seems not work? Anybody know the reason. How can I debug in RamDebugger? I am using Gid 10.0.9
## Michael Liu \
[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/bd76c7cf/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/bd76c7cf/attachment.htm)
