Thank you very much. That did the trick
Mark
Just out of curiosity does this mean that my GiD6.3.0b application would not
run correctly under an up to date GiD version?
-----Original Message-----
Sent: 03 September 2003 15:01
Subject: Re: [GiDlist] WarnWinText
For your old GiD 6.3.0b this window has another name: .gid.__warnwintext
use:
if { [winfo exists .gid.__warnwintext] } {
destroy .gid.__warnwintext
Version: 6.0.512 / Virus Database: 309 - Release Date: 19/08/2003
the error.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030903/f93a8621/attachment.htm
Some GiD changes can create incompatibilities with old problemtype version.
For example, if your problemtype access directly to the widget name .gid.__warnwintext then for latests versions
this name has changed to .gid.warning . It’s dangerous for future compatibility to access directly to undocummented GiD procedures,
it’s best to use some documented interface function (if exists) .
I added for example a procedure CloseWarnWinText to close this window without use the widget name (If a next GiD version change this name, the problemtype not need to be updated)
A old problemtype can require a test, and perhaps small changes, to be used in the nexts GiD versions.
To: ‘gidlist at gatxan.cimne.upc.es’
Sent: Wednesday, September 03, 2003 4:27 PM
Subject: RE: [GiDlist] WarnWinText
Mark
Just out of curiosity does this mean that my GiD6.3.0b application would not run correctly under an up to date GiD version?
use:
The information contained in this e-mail message (and any attachment transmitted herewith) is privileged and confidential and is intended for the exclusive use of the addressee(s). If you are not an addressee, any disclosure, reproduction, distribution or other dissemination or use of this communication is strictly prohibited. If you have received this communication in error, please contact us immediately so that we can correct the error.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030903/ceb20d5b/attachment.htm
