My geometry has two volumes next to each other i.e. they have one common
surface (see attached picture). If I try Geometry - create - volume
boolean op - union and select the two volumes, GiD tries to perform the
operation, but crashes.
Also, say I have a third volume enclosing the two volumes. I try to
substract one of the inner volumes from the outer one, it works. Now, if I
try to substract the other inner volume from the outer one, GiD crashes.
Rama Karve.
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20031117/1dd1570f/attachment.jpg
For this simple cases, where it’s unneeded to find the intersection curves
bethween surfaces, It’s unneeded to use the boolean volume operation tool:
they work very slow and can be unstable.
To create a single volume, in your case only need to create a new volume
selecting the boundary surfaces
(select all surfaces except the shared ones).
Sent: Monday, November 17, 2003 4:39 PM
Subject: [GiDlist] Volume boolean op (bug?)
Rama Karve.
