I am currently studying problems for which I would like to view different fields on Gauss Points, and I have a question about the post-processing of such problems. In some cases, I have triangles and quadrilaterals together. So I have to define two kinds of Gauss points (for triangles and quadrilaterals), but the problem is that, in the post-processing, I don’t know how to view simultaneously the results on these two kinds of elements.
Louis Christophe
Open Engineering SA
Spatiopôle, WSL - Parc Scientifique du Sart Tilman
Rue des Chasseurs Ardennais
B-4031 Angleur-Liège (Belgium)
Tel: (+32/0)4.372.93.45 - Fax: (+32/0)4.372.93.21
www.open-engineering.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040128/9a3c724e/attachment.htm
At this moment, it’s not possible to simultaneously show this triangle and quadrilateral results.
A trick to solve this is to write an auxiliary mesh “*.flavia.msh”, for postprocess pourposes only,
splitting each quadrilateral in two triangles.
Sent: Wednesday, January 28, 2004 10:28 AM
Subject: [GiDlist] Viewing results on Gauss Points
Louis Christophe
Open Engineering SA
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20040129/b82c30bd/attachment.htm
Dear Gidlist-members!
I’d be appreciate if You had the time for one question!
Is it possible to assign boundary conditions in GID7.2 Academical
Version?
The ‘conditions window’ in the data menu is not existent!
Anke Griesbaum
I wonder if someone can shed some light on this.
At the postprocess stage I import several meshes and results.
My result file follows this pattern
GaussPoints “pexterior” Elemtype Linear “POLAR”
Number of Gauss Points: 1
Natural Coordinates: internal
End GaussPoints
GaussPoints “nexterior” Elemtype Quadrilateral “NORMAL”
End GaussPoints
… etc etc
then a series of results of the form
Result “P Phase Pol” “Analysis Name” 1 Scalar OnGaussPoints “pexterior”
Values
End Values
Result “P Phase Nor” “Analysis Name” 1 Scalar OnGaussPoints “nexterior”
Values
End Values
The MSH file is of the form
MESH NORMAL DIMENSION 3 ELEMTYPE QUADRILATERAL NNODE 4
COORDINATES
END COORDINATES
ELEMENTS
END ELEMENTS
MESH POLAR DIMENSION 3 ELEMTYPE LINEAR NNODE 2
COORDINATES
END COORDINATES
ELEMENTS
The problems I am having is displaying contour lines and viewing multiple results and using border graphs. When I select contour lines I only see the borders and a small coloured cross - however, contour fill worked just fine. I would like to display all the results and I cant seem to get ‘Several’ results to work (I select ‘one over another’ and each time I change the result it defualts back to ‘one by one’ and disposes of the previous result id). In addition when trying to select a border for border graph I am unable to do so.
What am I doing wrong
Ambrose
The Information in this e-mail is confidential and may be legally privileged. It may not represent the views of Martin Audio Limited. It is solely for the addressees. Access to this e-mail by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, distribution, or any action taken or omitted to be taken in reliance on it, is prohibited and may be unlawful. Any unauthorised recipient should advise the sender immediately of the error in transmission.
