[GiDlist] Uncollapse points
Hello to all,
I would like to duplicate points in the intersection of two lines. So I
use Geometry - Edit - Uncollape - Lines and select the two lines. The
problem is that does not work. Is it a bug?
Patrick Lac
Version GiD9.0.2
Hi GiD team
I would also like to see an option of uncollapse points make all points
of spline curves and surfaces be restored.
mark
-----Original Message-----
[mailto:gidlist-admin at gid.cimne.upc.edu] On Behalf Of Lac Patrick
Sent: 04 February 2009 15:49
Subject: [GiDlist] Uncollapse points
Hello to all,
Patrick Lac
GiDlist at gid.cimne.upc.edu
Please be advised that this email may contain confidential information.
If you are not the intended recipient, please do not read, copy or
re-transmit this email. If you have received this email in error,
please notify us by email by replying to the sender and by telephone
(call us collect at +1 202-828-0850) and delete this message and any
attachments. Thank you in advance for your cooperation and assistance.
In addition, Danaher and its subsidiaries disclaim that the content of
this email constitutes an offer to enter into, or the acceptance of,
any
contract or agreement or any amendment thereto; provided that the
foregoing disclaimer does not invalidate the binding effect of any
digital or other electronic reproduction of a manual signature that is
included in any attachment to this email.
Hello Patrick,
You are right, it is a bug, (a variable was not initialized to 0 and the
release version failed)
Next Official 9.0.4 and beta 9.1.1b versions will include this correction
Sorry Mark, we didn’t understood your comment about an option to “uncollapse
points” that “make all points of spline curves and surfaces be restored”.
Could you explain a little more what do you want to mean?
Sent: Wednesday, February 04, 2009 4:49 PM
Hello to all,
Patrick Lac
Hi Enrique
Lets say I define a series of points then put a nurbs line through them. Then I delete the points selecting all that I used, the only ones that are left are the start & finish points of the nurbs line. If I now save the model I cannot recover the points that I used to define the nurbs line as undo doesn’t work once you have saved. like wise if you collapse a model & save all the points used to define lines then surfaces etc are lost forever & if you need to modify the geometry you have to use edit nurbs or divide the lines specifying the number of points which creates a new set & not those originally used. Hope I’m making myself clear?
regards
mark
From: gidlist-admin at gid.cimne.upc.edu on behalf of Enrique Escolano
Sent: Wed 04/02/2009 20:04
Subject: Re: [GiDlist] Uncollapse points
Hello Patrick,
Hello to all,
Patrick Lac
any
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090205/5f354281/attachment.htm
