Thanks Blas, i will try, with shell elements export without geometry i never have troubles.
Pablo
=?iso-8859-1?Q?Blas_Molero_=2D_Tecnolog=EDas_CAE_Avanzadas?= escribió:
Dear Pablo,
In COSMOS/M Geostar you don´t see anything when plotting elements because the mesh is not associated to geometry, the information you can import from GiD is only nodes & elements, not the geometry (Curves, Surfaces, etc..).
You can display mesh simply issuing the following commands:
. “BOUNDARY,1,0” command from “Display, Display_Option, Set Bound Plot” to plot boundary element faces only not associated with a surface or region
. “EVAL_BOUND,1,0,20,1” command from “Display Display_Option Eval Element Bound” to evaluate boundary faces,
. “SHADE;” command to activate shading of element plots, and finaly
. “EPLOT;” command to plot ALL elements.
You have this problem well explained in our COSMOS/M Support page in the following address:
_Bienvenido a www.tecnocae.es
Blas.
Blas Molero Hidalgo
Director
Tecnologías CAE Avanzadas, S.L.
Parque Tecnológico de Zamudio - Edificio Central, nº 101
48170 Zamudio (SPAIN)
Tel. +34 94 420 93 54
Fax. +34 94 420 93 55
E-mail: Blas.molero at tecnocae.es
WEB: http://www.tecnocae.es
Desde: Pablo Perez del Castillo
Enviado el: jueves 25 de enero de 2001 3:31
Asunto: [ GiDlist ] troubles with meshview
Hi to everybody
When i generate tetrahedra elements, then meshview does not work, so i can see
the mesh in normal mode, but when i do render filled nothing to see, and when i
export to cosmos it happens the same, i can see the mesh with no hidden, when i
try to render, nothing to see.
Anybody can help me .
advanced thanks
Part 1.2 Type: application/ms-tnef
Encoding: base64
