[GiDlist] triangles, tetrahedra and nodes
Hi there!
If i have a .igs model and i need both a triangular model and a tetrahedral
model to be generated, but they MUST have the same nodes defined and in the
same order. Is that possible with GiD? How? When i try i get a small
discrepancy in the number of nodes, but somewhere around halfway through the
nodes the ordering of them changes significantly.
It might sound strange, but what i need is a tetrahedral mesh, all surface
nodes, with 2d
texture coordinates. If any of you have a better tool, then i’m all ears :slight_smile:
Thanks in advance.
/Michael
Hi Michael,
looks as if we have the same kind of problem … :slight_smile:
Sören
Wednesday, October 12, 2005, 11:16:37 AM, you wrote:
MN Hi there!
MN If i have a .igs model and i need both a triangular model and a tetrahedral
MN model to be generated, but they MUST have the same nodes defined and in the
MN same order. Is that possible with GiD? How? When i try i get a small
MN discrepancy in the number of nodes, but somewhere around halfway through the
MN nodes the ordering of them changes significantly.
MN It might sound strange, but what i need is a tetrahedral mesh, all surface
MN nodes, with 2d
MN texture coordinates. If any of you have a better tool, then i’m all ears :slight_smile:
MN Thanks in advance.
MN /Michael
MN _______________________________________________
MN GiDlist mailing list
MN GiDlist at gid.cimne.upc.es
MN http://gid.cimne.upc.es/mailman/listinfo/gidlist
Warning: This message has had one or more attachments removed.
Warning: Please read the “VirusWarning.txt” attachment(s) for more information.
Dear GiD-Users and Developers,
I have a problem with generating reinforced concrete members. I want
to define concrete volume elements with line elements for the steel
reinforcement. Both types of elements have to use the same nodes where
the reinforcement is located. I tried to solve the problem by defining
two exactly located lines, one to define surfaces/volumes for the
concrete elements and one for the line elements, but GiD meshes them
differently …
This should be a common problem for everybody, who works in the field
of civil/structural engineering. I also could think of meshing in two
steps, first the reinforcement, then the volume by defining the nodes
of the line elements as fixed for the mesh ceneration of the volume
elements but GiD doesn’t have this feature … ? To demonstrate the
problem, I attached a model of a concrete slab with reinforcement …
(it’s just half of the model because it’s symmetric)
Any suggestions? Thank you in advance.
Soeren Schwarz
Universität Leipzig
Wirtschaftswissenschaftliche Fakultät
Institut für Massivbau und Baustofftechnologie
Marschnerstrasse 31
04109 Leipzig
Dipl.-Ing. Sören Schwarz
Tel.: 0341/97-33800 (Sekretariat)
Tel.: 0341/97-33813 (Durchwahl)
Fax: 0341/97-33809
e-mail: sschwarz at wifa.uni-leipzig.de
URL: http://www.uni-leipzig.de/massivbau
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051012/b003ebc0/attachment.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051012/b003ebc0/attachment-0001.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051012/b003ebc0/attachment-0002.obj
This is a message from the MailScanner E-Mail Virus Protection Service
The original e-mail attachment “concrete-slab.mat”
is on the list of unacceptable attachments for this site and has been
replaced by this warning message.
If you wish to receive a copy of the original attachment, please
e-mail helpdesk and include the whole of this message
in your request. Alternatively, you can call them, with
the contents of this message to hand when you call.
At Wed Oct 12 12:13:13 2005 the virus scanner said:
Microsoft Access Shortcuts are dangerous in email in concrete-slab.mat
Note to Help Desk: Look on the MailScanner in /var/spool/mailscanner/quarantine (message j9CACokr006615).
Postmaster
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051012/b003ebc0/attachment-0003.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051012/b003ebc0/attachment-0004.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051012/b003ebc0/attachment-0005.obj
Hello, Soren,
GiD meshes the geometrical entities hierarchically. It means that when a
volume have to be meshed, first of all, all its contour surfaces are meshed,
wich, at the same time, needs its lines meshes to be meshed.
The problem you have is that the lines that define the steel reinforcement
are not part of the volume (topollogically). If you want that lines meshes
share nodes with volume elements, the only way to do it is to create
surfaces owning the lines, and split the volume in different volumes
(smaller), with that surfaces as the contour ones.
ABEL
From: “Sören Schwarz” sschwarz at wifa.uni-leipzig.de
Sent: Wednesday, October 12, 2005 11:40 AM
Subject: [GiDlist] define fixed points/lines when meshing
information.
differently …
Soeren Schwarz
Universität Leipzig
Marschnerstrasse 31
04109 Leipzig
Fax: 0341/97-33809
_URL: http://www.uni-leipzig.de/massivbau_
Hello Soren & Michael,
As Abel remarked, to obtain tetrahedras with nodes on the lines, it’
necessary that this lines are in the boundary of a surface, that is in the
boundary of the volume. Several “steel” lines are not each other
intersected, then will not be generated a common node, you also need to
intersect this lines if they are really connected.
In other hand, by default, when GiD generate for example a mesh, then are
not explicitly created the “lower hierarchy elements”, for example, when
generate a tetrahedral mesh from a volume, are not created triangle, or line
elements.
To force to have this “lower hierarchy elements”, you must assign this
criteria to the desired geometric entities:
Mesh-Mesh criteria-Mesh- Lines or surfaces
They will be generated also triangles and/or lines, but will not be
generated any new node, they are shared with the tetrahedral ones.
Sent: Friday, October 14, 2005 9:29 AM
Subject: Re: [GiDlist] define fixed points/lines when meshing
Hello, Soren,
meshed,
ABEL
information.
differently …
Soeren Schwarz
Universität Leipzig
Marschnerstrasse 31
04109 Leipzig
Fax: 0341/97-33809
is there a possibility in GiD to visualize scalar and vectorial results
with logarithmic scaling (e.g. acoustic pressure)?
Andreas
/ // /// Friedrich Alexander Universität Erlangen
_/ _/ _/ Paul-Gordan-Str. 3-5, D-91052 Erlangen
_/ _/ _/ Friedrich Alexander University Erlangen
_/ _/ / / Department of Sensor Technology
M.Sc. Andreas Hauck
email.: andreas.hauck at lse.eei.uni-erlangen.de
url. : http://www.lse.uni-erlangen.de
tel. : (+49)-9131-85-23147
fax. : (+49)-9131-85-23133
Hi GiD Team
I found that some of the User displayed the mesh
with a nice nodal ball.. I have tried in the Render
customize but it dind’t work.. How would you do that
I herewith attached the file that I found it
Regards..
— Andreas Hauck
Andreas
__/ // /// Friedrich Alexander
__/ _/ _/ / Lehrstuhl für
Sensorik
_/ / / Paul-Gordan-Str. 3-5,
D-91052 Erlangen
__/ // //
_/ / / Friedrich Alexander
University Erlangen
__/ / / / Department of
Sensor Technology
__/
D-91052 Erlangen
M.Sc. Andreas Hauck
Yahoo! Music Unlimited
Access over 1 million songs. Try it free.
http://music.yahoo.com/unlimited/
Type: image/bmp
Desc: 1855625856-MESH.bmp
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051014/c027ca42/attachment.bin
Well, in post there is the ‘points’ display style which draws points or
spheres at the nodes (Options-Geometry-Point options).
But to achieve what you see at your picture, the only way I see is to create
‘point’ elements on your nodes and ‘line’ elements on your edges.
Something like this (just 2 balls and 1 edge):
MESH “balls” dimension 3 Elemtype Point Nnode 1
Coordinates
1 0.0
2 1.0
End coordinates
Elements
1 1
2 2
End elements
MESH “bars” dimension 3 ElemType Lineas Nnode 2
Coordinates
End Coordinates
Elements
1 1 2
End Elements
If you want to change the balls and lines visualization, just use the
“Options-Geometry-Points options” and “Options-Geometry-Line Options”.
reagrds
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de VSayako Willy
Enviado el: viernes, 14 de octubre de 2005 12:26
Asunto: [GiDlist] How to display a node as a ball
Hi GiD Team
Regards..
— Andreas Hauck
Andreas
Sensorik
D-91052 Erlangen
__/ // //
University Erlangen
Sensor Technology
__/
D-91052 Erlangen
M.Sc. Andreas Hauck
Thanks much Miguel..for the information..
options).
on your edges.
Coordinates
1 0.0
2 1.0
End coordinates
Elements
1 1
2 2
End elements
Coordinates
End Coordinates
Elements
1 1 2
End Elements
reagrds
Hi GiD Team
mesh
Regards..
— Andreas Hauck
Andreas
Sensorik
3-5,
D-91052 Erlangen
__/ // //
University Erlangen
Sensor Technology
__/
D-91052 Erlangen
M.Sc. Andreas Hauck
Yahoo! Mail - PC Magazine Editors’ Choice 2005
Hi Miguel
I tried what you gave me an example but it didn’t
work out..especially the .msh file and I never saw
such commands you have given here.. Any further
suggestion??
options).
on your edges.
Coordinates
1 0.0
2 1.0
End coordinates
Elements
1 1
2 2
End elements
Coordinates
End Coordinates
Elements
1 1 2
End Elements
reagrds
Hi GiD Team
mesh
Regards..
— Andreas Hauck
Andreas
Sensorik
3-5,
D-91052 Erlangen
__/ // //
University Erlangen
Sensor Technology
__/
D-91052 Erlangen
M.Sc. Andreas Hauck
Andreas
M.Sc. Andreas Hauck
By now the only way to operate results is through Tcl-Tk, with
GiD_Result get {“pressure” “acoustic analysis” 1.0}
Operate this result in order to change its scale and then
GiD_Result create {Result “Log pressure” “acoustic analysis” 1.0 scalar
onnodes} {node_id_1 value_1} {node_id_2 value_2} …
You can find more info here (Tcl-Tk extensions-Special functions):
http://www.gidhome.com/support/gidbeta/gid_18.subst#SEC293
(look for GiD_Result)
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Andreas Hauck
Enviado el: viernes, 14 de octubre de 2005 11:35
Asunto: [GiDlist] Logarithmic scaling of results
Andreas
M.Sc. Andreas Hauck
does somebody know how to hide the coordinate system by plotting results in picture files like png or gif?
Thanks in advance
Rafael
There is a “dark” command to show/hide this axes:
escape escape escape view hardcopy options _showaxes
Sent: Saturday, October 15, 2005 6:16 AM
Subject: [GiDlist] coordinate system in pictures
Thanks in advance
Rafael
I’m using Gid 7.6.0b. When I make Utilities - list - Points and pick a point belonging to 3 lines I get the folowing result:
POINT
Num: 3 HigherEntity: 3 conditions: 1 material: 0
LAYER: Layer0
Coord: 0.000000 5.000000 0.000000
END POINT
POINT (more)
Higher entities points: 1 4 11
END POINT
But I think it should be lines instead of points in: Higher entities points: 1 4 11
Mihai TEODORESCU
Yes, the correct message must be: “Higher entities lines: 1 4 11”
Thanks for your bug report
From: “Mihai TEODORESCU” mihai.teodorescu at prevost-industries.com
Sent: Tuesday, October 18, 2005 4:48 PM
Subject: [GiDlist] Probleme in reporting higher entities for a point
POINT
LAYER: Layer0
END POINT
POINT (more)
END POINT
Mihai TEODORESCU
Hi everybody,
when creating a mesh, GiD complains about
“There are elements with negative jacobian in some node in surface 1 mesh”
“There are elements with negative jacobian in some node in surface 2 mesh”
Steps to reproduce this behaviour:
creating geometries
- create two rectangles
rectangle 0,0 8e-4,1e-2
rectangle 0,1e-2 8e-4,46e-2
- create a quarter of a circle
utilities copy lines DoExtrude surfaces MaintainLayers Rotation FJoin 2
TwoDim -90 2 escape
set import tolerance
utilities variables ImportTolerance 1e-6
collapse model
utilities collapse model yes
renumber all entities
utilities renumber yes
setup the mesh
- structured surfaces of the rectangles
Meshing Structured Surfaces 1 2 3 escape 4 2 4 escape 3 1 3 6 escape
- select quadratic elements
Meshing quadratic Quadratic
generate mesh
Meshing Generate 4e-3
When creating the mesh, the messages about the elemtents with negative
jacobian appeear.
This doesn’t happen, when i don’t use structured surfaces.
But the question is: If GiD already knows about elements defined in the
wrong direction meaning clockwise, why does he not correct the wrong
elements instead of telling me that there have been mistakes along the
element definition.
Martin Meiler
_/ // //
Dipl.-Ing. Martin Meiler
tel.: (+49)-9131-85-23140
fax.: (+49)-9131-85-23133
Which GiD version are you working with?
Abel Coll
From: “Martin Meiler” Martin.Meiler at lse.eei.uni-erlangen.de
Sent: Wednesday, October 19, 2005 9:40 AM
Subject: [GiDlist] Problems with Mesh-Generation
Hi everybody,
# creating geometries
# - create two rectangles
# - create a quarter of a circle
TwoDim -90 2 escape
# set import tolerance
# collapse model
# renumber all entities
# setup the mesh
# - structured surfaces of the rectangles
# - select quadratic elements
# generate mesh
jacobian appeear.
element definition.
Martin Meiler
__/ // /// Friedrich Alexander Universität Erlangen
__/ _/ _/ / Lehrstuhl für Sensorik
__/ _/ / Paul-Gordanstr. 5, 91052 Erlangen, Germany
_/ // //
_/ / / University of Erlangen
__/ / / / Department of Sensor Technology
__/
i’m working with the latest GiD beta 7.6.0b on an SuSE linux machine.
Bye Martin
Abel Coll
Hi everybody,
TwoDim -90 2 escape
# collapse model
# setup the mesh
# generate mesh
jacobian appeear.
element definition.
Martin Meiler
_/ // //
__/
_/ // //
Thanks for notifying us this behaviour. It is now corrected, so it will be
available to you in the next beta version, that provably will be ready in
this week.
Regards.
ABEL
Sent: Wednesday, October 19, 2005 2:51 PM
Subject: Re: [GiDlist] Problems with Mesh-Generation
Bye Martin
Abel Coll
Hi everybody,
"There are elements with negative jacobian in some node in surface 1
mesh"
"There are elements with negative jacobian in some node in surface 2
mesh"
TwoDim -90 2 escape
# collapse model
# setup the mesh
# generate mesh
jacobian appeear.
element definition.
Martin Meiler
_/ // //
__/
__/ // //
/ Friedrich Alexander Universität Erlangen_
_/ // //
__/
