[GiDlist] Symmetric meshes
Hi! What is the way to create symmetric meshes?
Thanks in advance!
Gero.
You can create a mirror of the mesh elements (utility copy).
Note: you must then apply the conditions and materials directly to the mesh.
To: “GIDLIST” gidlist at gatxan.cimne.upc.es
Sent: Wednesday, April 23, 2003 11:45 AM
Subject: [GiDlist] Symmetric meshes
Thanks in advance!
Gero.
Dear All,
Sometimes, I am using GID on windows NT 4.0 : some problems appear,
especially,
it is no more possible to select, on a GID’s geometry, several lines
together (or surfaces together)
using the mouse.
In fact, the selection of entities is only possible entity by entity.
Is it a known bug ?
Is there a solution (GID 7.2 of course, but an other one if possible !)
Thank you in advance.
G.W.R. Geis
This bug is unknown. In fact, GiD works ok on Win NT 4.0 in our tests.
In any case, if GiD 7.2 works in your system, what’s the problem to update?
The password is the same
To: “GID” GiDlist at gatxan.cimne.upc.es
Sent: Wednesday, April 23, 2003 12:16 PM
Subject: [GiDlist] GID 7.1 on Windows NT 4.0
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
Thank you for your message.
I cannot explain why this bug is, but it is !
I ever installed a GID 7.1 version on a Windows NT 4.0 network, it was running,
but now, in an other WNT4.0 network, this bug appears !!
At the moment, I prefer to use the GID 7.1 version, because all my software is
developed from GID 7.1
Especially, the GID 7.2 version has a little problem with the automatic reading
of the *.flavia.msh (cf. Problem with *.flavia.msh in GID 7.2 - 21/03/03). I
should be necessary for me to change some lines specifically for the 7.2
version, and change again for the 7.3 version…
In fact I am waiting for the next version of GID…
G.W.R. Geis
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
Hello;
In Windows 2000 (pro) (kernell NT), and GID 7.2 has the same bug when select
several lines together.
Pablo
G.W.R. Geis
Dear All,
especially,
using the mouse.
Is it a known bug ?
G.W.R. Geis
I’ develop under Windows 2000 professional, and this problem not appears in
any of our machines!!
For example (using GiD 7.1 or 7.2): It fail if you create some lines, and
try to list it selecting all ?
It is, can be, a redraw problem?
Sent: Wednesday, April 23, 2003 6:21 PM
Subject: Re: [GiDlist] GID 7.1 on Windows NT 4.0
Hello;
select
Pablo
running,
software is
reading
21/03/03). I
G.W.R. Geis
update?
Dear All,
especially,
using the mouse.
entity.
Is it a known bug ?
G.W.R. Geis
Hello Enrique; you are right.
It is not happening with Gid tools, but if i use my tool (it is a tcl to create
splines similar to NACA profiles) and then i try to select all to get nurbs, i
must do it one to one. I tried to redraw, but nothin change. I guess, we have to
repair our tcl code.
Pablo
Hello;
select
Pablo
running,
software is
reading
21/03/03). I
G.W.R. Geis
update?
Dear All,
especially,
using the mouse.
entity.
Is it a known bug ?
G.W.R. Geis
Can you send some model, with this type of nurblines, to check it?
Sent: Wednesday, April 23, 2003 7:54 PM
create
nurbs, i
have to
Pablo
in
and
Hello;
select
Pablo
was
running,
software is
automatic
reading
21/03/03). I
7.2
G.W.R. Geis
tests.
to
update?
Dear All,
appear,
especially,
lines
using the mouse.
entity.
Is it a known bug ?
possible
G.W.R. Geis
Hello Enrique;
Attached file with nurbs lines.
It is curious, i tried to build a nurbs surface with those lines (attached file)
in two diferents PC with “geometrycreatenurbs_surfaceparallel_lines” .
Results:
-PC with Windows 2000 pro (over windows 95), GID 7.2 , it works fine (select all
with window).
-PC with Windows 2000 pro, GID 7.2, i had to select line to line.
Pablo.
Nota: el sistema operativo win2000 instalado sobre win95, me selecciona todas
por ventana y lo hace perfecto. El mismo fichero en el pc con win2000 sobre un
disco duro formateado, no selecciona nada por ventana, debo picar una a una.
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030424/b995d05d/attachment.bin
Hello Pablo.
In my computer your sample works fine.
This seems a graphic card problem.
Try to use software OpenGL instead hardware
Run GiD from the start button of Windows … GiD7.2- GiD safe mode, and
select software OpenGL (this selection is only necessary one time)
Nota: Mi sistema operativo no ha sido instalado encima de otro previo, el
problema no tiene nada
que ver con haber tenido un sistema win95 previo.
Sent: Thursday, April 24, 2003 10:53 AM
Hello Enrique;
file)
Results:
(select all
with window).
Pablo.
todas
sobre un
una.
a IGES file is joined.
It has been made from a GID geometry saved as a IGES format file.
This file induces the bug on WNT4.0
Bye,
G.W.R.Geis
Translator GID - IGES S0000001
1H,1H;,3HGID,75HC:/Documents and Settings/Administrateur/Mes documents/G0000001
Johann/test/cube.igs,32,1,1,0,0,0,5HCIMNE,9,; G0000002
128 1 1 D0000001
128 12 NURBSURF 1D0000002
128 13 1 D0000003
128 13 NURBSURF 2D0000004
128 26 1 D0000005
128 14 NURBSURF 3D0000006
128 40 1 D0000007
128 13 NURBSURF 4D0000008
128 53 1 D0000009
128 13 NURBSURF 5D0000010
128 66 1 D0000011
128 13 NURBSURF 6D0000012
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 1P0000001
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 1P0000002
1.064019,-0.03,-0.147367,1.064019,-0.03,-0.024367,1.064019, 1P0000003
-0.03,0.098633,1.064019,-0.03,0.175698,1.064019,-0.03,-0.234302, 1P0000004
0.970619,-0.03,-0.147367,0.970619,-0.03,-0.024367,0.970619, 1P0000005
-0.03,0.098633,0.970619,-0.03,0.175698,0.970619,-0.03,-0.234302, 1P0000006
0.830519,-0.03,-0.147367,0.830519,-0.03,-0.024367,0.830519, 1P0000007
-0.03,0.098633,0.830519,-0.03,0.175698,0.830519,-0.03,-0.234302, 1P0000008
0.690419,-0.03,-0.147367,0.690419,-0.03,-0.024367,0.690419, 1P0000009
-0.03,0.098633,0.690419,-0.03,0.175698,0.690419,-0.03,-0.234302, 1P0000010
0.597019,-0.03,-0.147367,0.597019,-0.03,-0.024367,0.597019, 1P0000011
-0.03,0.098633,0.597019,-0.03,0.175698,0.597019,-0.03,0,1,0,1; 1P0000012
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 3P0000013
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0.175698, 3P0000014
0.597019,-0.03,0.175698,0.597019,0.014634,0.175698,0.597018, 3P0000015
0.077784,0.175698,0.597019,0.140934,0.175698,0.597019,0.1805, 3P0000016
0.175698,0.690419,-0.03,0.175698,0.690419,0.014634,0.175698, 3P0000017
0.690418,0.077784,0.175698,0.690419,0.140934,0.175698,0.690419, 3P0000018
0.1805,0.175698,0.830518,-0.03,0.175698,0.830518,0.014634, 3P0000019
0.175698,0.830518,0.077784,0.175698,0.830518,0.140934,0.175698, 3P0000020
0.830518,0.1805,0.175698,0.970618,-0.03,0.175698,0.970618, 3P0000021
0.014634,0.175698,0.970618,0.077784,0.175698,0.970618,0.140934, 3P0000022
0.175698,0.970618,0.1805,0.175698,1.064019,-0.03,0.175698, 3P0000023
1.064019,0.014634,0.175698,1.064019,0.077784,0.175698,1.064019, 3P0000024
0.140934,0.175698,1.064019,0.1805,0,1,0,1; 3P0000025
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 5P0000026
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 5P0000027
1.064019,-0.03,-0.234302,1.064019,0.014634,-0.234302,1.064019, 5P0000028
0.077784,-0.234302,1.064019,0.140934,-0.234302,1.064019,0.1805, 5P0000029
-0.234302,0.970619,-0.03,-0.234302,0.970619,0.014634,-0.234302, 5P0000030
0.970619,0.077784,-0.234302,0.970619,0.140934,-0.234302, 5P0000031
0.970619,0.1805,-0.234302,0.830519,-0.03,-0.234302,0.830519, 5P0000032
0.014634,-0.234302,0.830519,0.077784,-0.234302,0.830519, 5P0000033
0.140934,-0.234302,0.830519,0.1805,-0.234302,0.690419,-0.03, 5P0000034
-0.234302,0.690419,0.014634,-0.234302,0.690419,0.077784, 5P0000035
-0.234302,0.690419,0.140934,-0.234302,0.690419,0.1805,-0.234302, 5P0000036
0.597019,-0.03,-0.234302,0.597019,0.014634,-0.234302,0.597019, 5P0000037
0.077784,-0.234302,0.597019,0.140934,-0.234302,0.597019,0.1805, 5P0000038
0,1,0,1; 5P0000039
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 7P0000040
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 7P0000041
1.064019,0.1805,-0.147367,1.064019,0.1805,-0.024367,1.064019, 7P0000042
0.1805,0.098633,1.064019,0.1805,0.175698,1.064019,0.1805, 7P0000043
-0.234302,0.970619,0.1805,-0.147367,0.970619,0.1805,-0.024367, 7P0000044
0.970619,0.1805,0.098633,0.970619,0.1805,0.175698,0.970619, 7P0000045
0.1805,-0.234302,0.830519,0.1805,-0.147367,0.830519,0.1805, 7P0000046
-0.024367,0.830519,0.1805,0.098633,0.830519,0.1805,0.175698, 7P0000047
0.830519,0.1805,-0.234302,0.690419,0.1805,-0.147367,0.690419, 7P0000048
0.1805,-0.024367,0.690419,0.1805,0.098633,0.690419,0.1805, 7P0000049
0.175698,0.690419,0.1805,-0.234302,0.597019,0.1805,-0.147367, 7P0000050
0.597019,0.1805,-0.024367,0.597019,0.1805,0.098633,0.597019, 7P0000051
0.1805,0.175698,0.597019,0.1805,0,1,0,1; 7P0000052
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 9P0000053
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,-0.234302, 9P0000054
0.597019,-0.03,-0.234302,0.597019,0.014634,-0.234302,0.597018, 9P0000055
0.077784,-0.234302,0.597019,0.140934,-0.234302,0.597019,0.1805, 9P0000056
-0.152302,0.597019,-0.03,-0.152302,0.597019,0.014634,-0.152302, 9P0000057
0.597019,0.077784,-0.152302,0.597019,0.140934,-0.152302, 9P0000058
0.597019,0.1805,-0.029302,0.597019,-0.03,-0.029302,0.597019, 9P0000059
0.014634,-0.029302,0.597019,0.077784,-0.029302,0.597019, 9P0000060
0.140934,-0.029302,0.597019,0.1805,0.093698,0.597019,-0.03, 9P0000061
0.093698,0.597019,0.014634,0.093698,0.597019,0.077784,0.093698, 9P0000062
0.597019,0.140934,0.093698,0.597019,0.1805,0.175698,0.597019, 9P0000063
-0.03,0.175698,0.597019,0.014634,0.175698,0.597018,0.077784, 9P0000064
0.175698,0.597019,0.140934,0.175698,0.597019,0.1805,0,1,0,1; 9P0000065
128,4,4,3,3,0,0,1,0,0,0,0,0,0,0.414105,1,1,1,1,0,0,0,0,0.5,1,1, 11P0000066
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0.175698, 11P0000067
1.064019,-0.03,0.175698,1.064019,0.014634,0.175698,1.064019, 11P0000068
0.077784,0.175698,1.064019,0.140934,0.175698,1.064019,0.1805, 11P0000069
0.093698,1.064019,-0.03,0.093698,1.064019,0.014634,0.093698, 11P0000070
1.064019,0.077784,0.093698,1.064019,0.140934,0.093698,1.064019, 11P0000071
0.1805,-0.029302,1.064019,-0.03,-0.029302,1.064019,0.014634, 11P0000072
-0.029302,1.064019,0.077784,-0.029302,1.064019,0.140934, 11P0000073
-0.029302,1.064019,0.1805,-0.152302,1.064019,-0.03,-0.152302, 11P0000074
1.064019,0.014634,-0.152302,1.064019,0.077784,-0.152302, 11P0000075
1.064019,0.140934,-0.152302,1.064019,0.1805,-0.234302,1.064019, 11P0000076
-0.03,-0.234302,1.064019,0.014634,-0.234302,1.064019,0.077784, 11P0000077
-0.234302,1.064019,0.140934,-0.234302,1.064019,0.1805,0,1,0,1; 11P0000078
S0000001G0000002D0000012P0000078 T0000001
I import your IGES file without problems with GiD7.1 or 7.2 in WinNT4.0 and
Win2000 professional.
Also, the multiple lines selection works ok with GiD7.1 and WinNT4.0 in my
machine.
I’ unknown wath’s the problem in your machine. The selection problem surely
is by the graphical card
(try deactivate graphic acceleration to solve), but I do not have idea of
the import problem cause..
----- O
Sent: Thursday, April 24, 2003 9:58 AM
Bye,
G.W.R.Geis
S0000001
documents/G0000001
G0000002
128 1 1
D0000001
128 12 NURBSURF
1D0000002
128 13 1
D0000003
128 13 NURBSURF
2D0000004
128 26 1
D0000005
128 14 NURBSURF
3D0000006
128 40 1
D0000007
128 13 NURBSURF
4D0000008
128 53 1
D0000009
128 13 NURBSURF
5D0000010
128 66 1
D0000011
128 13 NURBSURF
6D0000012
1P0000001
1P0000002
1P0000003
1P0000004
1P0000005
1P0000006
1P0000007
1P0000008
1P0000009
1P0000010
1P0000011
1P0000012
3P0000013
3P0000014
3P0000015
3P0000016
3P0000017
3P0000018
3P0000019
3P0000020
3P0000021
3P0000022
3P0000023
3P0000024
3P0000025
5P0000026
5P0000027
5P0000028
5P0000029
5P0000030
5P0000031
5P0000032
5P0000033
5P0000034
5P0000035
5P0000036
5P0000037
5P0000038
0,1,0,1;
5P0000039
7P0000040
7P0000041
7P0000042
7P0000043
7P0000044
7P0000045
7P0000046
7P0000047
7P0000048
7P0000049
7P0000050
7P0000051
7P0000052
9P0000053
9P0000054
9P0000055
9P0000056
9P0000057
9P0000058
9P0000059
9P0000060
9P0000061
9P0000062
9P0000063
9P0000064
9P0000065
11P0000066
11P0000067
11P0000068
11P0000069
11P0000070
11P0000071
11P0000072
11P0000073
11P0000074
11P0000075
11P0000076
11P0000077
11P0000078
T0000001
