Hi GiD team
I’m very pleased with the surface modelling ability of gid but (there is
always a but) I would like to suggest a feature that I would find very
useful & hopefully you might think of developing it for future releases?
I would like to impose a tangency condition where 2 surfaces
meet/intersect. This is difficult to do manually as it requires the
surfaces to be deleted the common edge to be modified & then the
surfaces redefined. I’d like to select the surfaces and define a radius
which blend 1 surface into the other.
Maybe this should be possible using the tools:right
buttons:geometry:edit:tangentnurbsSurface but most of the time gid
crashes & exits without warning! Can you explain the use of the enter
maximum angle to accept tangents?
I’m using gid7.7.7b, is this fixed in version 8?
Thanks in advance.
mark
This message (including any attachments) contains confidential
and/or proprietary information intended only for the addressee.
Any unauthorized disclosure, copying, distribution or reliance on
the contents of this information is strictly prohibited and may
constitute a violation of law. If you are not the intended
recipient, please notify the sender immediately by responding to
this e-mail, and delete the message from your system. If you
have any questions about this e-mail please notify the sender
immediately.
