[GiDlist] Some problems with rendering and animations
Hi GiD team,
I have been trying to use GiD 7.5.8b for creating animations of a
simple model and I experienced some problems.
I would like to render a simple volume with few other surfaces. The
target is having transparent surfaces with visible lines. I tried with
a single window and I couldn’t do it because of bad rendering. The
rendering was ok only with invisible lines. By chance I selected two
windows and the second appeared to be fine. The picture attached
to this e-mail regards the situation with two windows, the
rendering on the right is ok.
The same situation repeats over different Windows machines and
the second window is always fine at the beginning. The same is
valid for the GiD release 7.2. Linux machines seem not to have any
problems.
Playing around with the rendering of the second window can cause
it to have the same problem of the first.
Trying to animate the second window with a rotation and recording
to a gif file causes GiD to crash and in some cases different errors
arise.
On both Windows machines the graphic card hardware acceleration
is set to 0.
Thanks for any suggestions.
In the Automatic animation list is it possible to delete an animation
only with right-click-Delete?
Andrea
Andrea Calaon
WESSEX INSTITUTE on the Web - http://www.wessex.ac.uk
SEE 2005 Call for Papers at: http://www.wessex.ac.uk/conferences/2005/index.html
WIT PRESS on the Web - visit http://www.witpress.com
to download individual Wessex Institute conference papers from our WIT eLIBRARY
and browse our BOOKSTORE. Save 10% and ensure fast delivery when you order our books on-line!
BEASY on the Web: http://www.beasy.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050707/ed832d1a/attachment.htm
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any other MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
---- File information -----------
File: imag.jpg
Date: 7 Jul 2005, 13:44
Type: JPEG-image
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20050707/ed832d1a/attachment.jpg
