Hello everyone,
I had some problems with the command Remove.
Here is the part of the .bas file where I used it:
*# For triangular elements
*set Elems(All)
*Remove elems(Quadrilateral)
*set cond Type_of_field *elems
*loop elems
*if(strcmp(cond(1),“Linear”)==0)
T2 *
*elseif(strcmp(cond(1),“Quadratical9”)==0)
*MessageBox error: Quadratical9 elements can NOT be Triangular.
Please redefine the element type on this surface.
*else
T3 *
*endif
*elemsnum *ElemsConec *elemsnum
*end elems
*# For quadrilateral elements
*set Elems(all)
*Remove elems(Triangle)
*loop elems
Q2 *
Q3 *
*else
Q38 *
*endif
end elems\
I noticed that only the first loop worked, and the second one was
always going to the else cllause, no matter the condition
Type_of_field. The same happened swapping the two loops: only
the firs one worked properly.
I dont know exactly what the problem was, but I solved it thanks
to an advice of a friend (Andres Peratta) who suggested me to try
to use Set elems(
) instead of *Remove elems(
). In this way
both loops work fine.
I hope this notice will be useful.
I wish a nice day to everyone.
Andrea Calaon
Ashurst Lodge, Ashurst
Southampton, Hampshire
SO40 7AA, UK
Fax office: +44 23 80 292 853
Mobile: +44 7766 488 225
E-mail: andrea at beasy.com
This is a GiD bug with a internal cache to speed the write calculation file procedure. It’s corrected for the next version.
A detail: instead to use
*loop elems
must use
*loop elems *onlyincond
because a loop over all selected elements not necessary has the related condition fields: *if(strcmp(cond(1),“Linear”)==0)
Another detail: it’s more easy to mantain a problemtype using fielnames instead fieldnumbers
instead cond(1) use for example cond(quadratic)
Sent: Tuesday, August 26, 2003 12:57 PM
Subject: [GiDlist] Some coupling between Remove and cond?
Hello everyone,
I had some problems with the command “Remove”.
*set Elems(All)
*loop elems
_T2 *_
*else
T3 _
*endif
*end elems
_# For quadrilateral elements
*set Elems(all)
*loop elems
_Q2 *_
_Q3 *_
*else
_Q38 *_
*endif
_end elems_
always going to the “else” cllause, no matter the condition
“Type_of_field”. The same happened swapping the two loops: only
I don’t know exactly what the problem was, but I solved it thanks
to use “Set elems(.)” instead of “*Remove elems(.)”. In this way
Andrea Calaon
SO40 7AA, UK
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030903/7d6d0c6f/attachment.htm
