[GiDlist] Remote Processing
Hi All,
I need to create models with GiD on my local computer to be
analyzed on a remote server. I understand that there is a
calculate remote option, but it can only be used with
ProcServer at this time. Is there a way to customize this
function so it can be used with another server?
If changing the above option is not possible, then is it
possible to read/save files in GiD from a remote source
through FTP or SSH?
Thank you.
-ammar
Dear sir,
In order to calculate in a remote machine without ProcServer, you must to
save the calculation file
(Files-Export-Calculation file)
Then send this file or files by ftp to the remote machine where the
problemtype (the solver) is also installed,
and from a console (telnet, vnc, ssh) start the problemtype.bat file with
the appropiated arguments
1st argument: project_name (name of the current project)
2nd argument: c:\a\b\c\project_name.gid (path of the current project)
3rd argument: c:\a\b\c\problem_type_name.gid (path of the problem type
selected)
When the process finish you mush download all results files to the local
machine in order to be postprocessed with GiD
ProcServer manage this king of operations, with a direct dialog with GiD,
but now it’s use is not public.
Sent: Tuesday, April 25, 2006 10:07 PM
Subject: [GiDlist] Remote Processing
Hi All,
through FTP or SSH?
Thank you.
-ammar
