the problem is that gid.exe can not find the file tk.tcl. ¿which access
permission does this file and the whole path
/home/software/gid-beta/scripts/tk/ have?
¿have you installed GiD (ungzipped, untared and done: ‘./install
/home/software/gid-beta/’) as a different user?
ps. I use also the opportunity to tell you that you have also to rename a
file, scripts/tkhtml/libTkhtml.so to scripts/tkhtml/libTkHtml.so (note the
capital ‘T’ ant ‘H’ of the library name) so that gid can show up the html
help. (my mistake)
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Björn Brodersen
Enviado el: martes, 25 de octubre de 2005 15:34
Asunto: [GiDlist] GiD Beta 7.7.0 won’t start
after installing gid-7.7.0b-dyn I get the following error:
GID internal error (init2): Can’t find a usable tk.tcl in the following
directories:
/home/software/gid-beta/scripts/tcl/tk8.4
/home/software/gid-beta/scripts/tk8.4 /home/software/lib/tk8.4
/usr/local/lib/tk8.4 /home/lib/tk8.4 /home/software/library /home/library
/home/tk8.4.8/library /tk8.4.8/library
/home/software/gid-beta/scripts/tk/tk.tcl: invalid command name
“LoadGidAddons”
invalid command name “LoadGidAddons”
while executing
“LoadGidAddons”
(file “/home/software/gid-beta/scripts/tk/tk.tcl” line 585)
invoked from within
“source /home/software/gid-beta/scripts/tk/tk.tcl”
(“uplevel” body line 1)
invoked from within
“uplevel #0 [list source $file]”
This probably means that tk wasn’t installed properly.
STACK IS:
Can’t find a usable tk.tcl in the following directories:
“LoadGidAddons”
while executing
“LoadGidAddons”
invoked from within
invoked from within
while executing
“error $msg”
(procedure “tcl_findLibrary” line 119)
invoked from within
“tcl_findLibrary tk $tk_version $tk_patchLevel tk.tcl TK_LIBRARY tk_library”
(procedure “tkInit” line 4)
invoked from within
“tkInit”
Segmentation fault
What’ s the problem with LoadGidAddons?
Thx for your help,
Greetings Bjoern
Dipl.-Ing. Björn Brodersen MSc
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Tel.: 0531 / 391 - 3670
