[GiDlist] Problems with lable select res
Warning: This message has had one or more attachments removed.
Warning: Please read the “VirusWarning.txt” attachment(s) for more information.
Hi everyone,
I’m using GiD 7.4.9 b in Windows for post processing files of 3D elasticity and the
command:
label Select resultonview (using the mouse)
seems not to work. My result is a gauss points one.
To have a quick look at the result values I have to zoom so that the displayed part
contains only few elements and than use
label resultonview
I had the same problem with previous versions of GiD but it seemed to be rotation
dependent: the command worked if the labels were mostly outside the model surface.
With this version the command never works.
I append a zip file with an example called “Slab_4.gid”.
Thanks for any help.
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any another MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
---- File information -----------
File: Slab_4.gid.rar
Date: 13 Aug 2004, 10:37
Type: Unknown
This is a message from the MailScanner E-Mail Virus Protection Service
The original e-mail attachment “Slab_4.gid.rar”
is on the list of unacceptable attachments for this site and has been
replaced by this warning message.
If you wish to receive a copy of the original attachment, please
e-mail helpdesk and include the whole of this message
in your request. Alternatively, you can call them, with
the contents of this message to hand when you call.
At Fri Aug 13 12:17:13 2004 the virus scanner said:
Attempt to hide real filename extension in Slab_4.gid.rar
Note to Help Desk: Look on the MailScanner in /var/spool/mailscanner/quarantine (message i7DAGf8H021267).
Postmaster
