[GiDlist] Problems (GiD6.0 -> GiD7.1)
Dear GiD team,
I’m having problems with some input DATA options. The program is working with
the version 6.0, but when I try to copy my problem type definition files, and use it in
the 7.1 version, the CONDITIONS and PROBLEM DATA options do not works. Only
an empty window appears. Is it necessary to make some changes in the .CND and
.PRB files to use this version? This two files are following attached, if it helps …
Thanks in Advanced !
Alisson P. Chaves alisson at dees.ufmg.br
MSc. student
Universidade Federal de Minas Gerais
Av. do Contorno 842 - 2o. andar
30110-060 Belo Horizonte, MG, Brasil
PROBLEM DATA
QUESTION: PROBLEM TITLE :
VALUE: Titulo
QUESTION: IKIND Parameter : #CB#(Subelement.,Pt-Fora-Subel,Pt-Fora-Simples,Mapeam-Degen.,Int-Analitica)
VALUE: Subelement.
QUESTION: Nodes per Element: #CB#(3,6)
VALUE: 3
HELP: Only the 3 nodes elements are availabe
QUESTION: N. Points Hammer: #CB#(1,3,7,13)
VALUE: 13
QUESTION: N. Pts Gauss/Direct.:
VALUE: 8
HELP: Number of integration points on each direction.
QUESTION: Alpha (Ponto Fora) :
Value: 1.50
HELP: Distance parameter Alpha (only for collocation point outside domain).
QUESTION: CALCULATE INTERNAL POINTS #CB#(YES, NO)
Value: NO
HELP: If YES, insert its co-ordinates in the fields below.
QUESTION: ONLY INTERNAL POINTS EVALUATION #CB#(YES, NO)
Value: NO
HELP: Boundary values must be already calculated (*.RESU files)
QUESTION: Internal_Points(X,Y,Z)
VALUE: #N# 3 0.0 0.0 0.0
HELP: Enter the internal points coordinates
END INTERVAL DATA
NUMBER: 1 CONDITION: Point-Constraints
CONDTYPE: over points
CONDMESHTYPE: over nodes
QUESTION: X-Constraint#CB#(0,1)
VALUE: 1
QUESTION: Y-Constraint#CB#(0,1)
VALUE: 1
QUESTION: Z-Constraint#CB#(0,1)
VALUE: 1
END CONDITION
NUMBER: 2 CONDITION: Point-Load
QUESTION: On direction X#CB#(0,1)
VALUE: 0
QUESTION: X-Traction
VALUE: 0.0
QUESTION: On direction Y#CB#(0,1)
VALUE: 0
QUESTION: Y-Traction
VALUE: 0.0
QUESTION: On direction Z#CB#(0,1)
VALUE: 0
QUESTION: Z-Traction
VALUE: 0.0
END CONDITION
NUMBER: 3 CONDITION: Discontinuities
CONDTYPE: over surfaces
CONDMESHTYPE: over elems
QUESTION: X-Direction#CB#(0,1)
VALUE: 0
QUESTION: Tract. Value
VALUE: 0.0
QUESTION: Y-Direction#CB#(0,1)
VALUE: 0
VALUE: 0.0
QUESTION: Z-Direction#CB#(0,1)
VALUE: 0
VALUE: 0.0
END CONDITION
Hi Alisson,
I take a look to files that you attached with your email, and I have the
impression that problems don’t came form the change of the version:
In file *.prb: The name of some files has blanks spaces, it is not allowed.
Instead of to use blank space use “". In problem data window statements
will appear with blanks spaces instead of "
Actual definition: QUESTION: N. Points Hammer: #CB#(1,3,7,13)
VALUE: 13
New definition: QUESTION: N._Points_Hammer:#CB#(1,3,7,13)
VALUE: 13
In *.cnd :In this file happens the same thing like in *.prb. A part of this
I thinking there is another mistake:
Statement CONDMESHTYPE is omitted
Best Regards
Aleix
Compass Ing. y Sistemas Aleix Valls
http://www.compassis.com/ aleix at compassis.com
-----Original Message-----
[mailto:gidlist-admin at gatxan.cimne.upc.es]On Behalf Of Alisson P. Chaves
Sent: Thursday, October 24, 2002 1:43 PM
Subject: [GiDlist] Problems (GiD6.0 - GiD7.1)
Dear GiD team,
with
and use it in
and
helps …
MSc. student
Another error in addition to the spaces in the name:
The field “Tract. Value” is repeated 3 times in the same condition!!.
To reference in the bas file a field by your name: *Cond(Tract_Value)
(recommended instead the index number *Cond(2)) , this name cannot be
repeated.
Sent: Thursday, October 24, 2002 3:32 PM
Subject: RE: [GiDlist] Problems (GiD6.0 - GiD7.1)
Hi Alisson,
allowed.
Instead of to use blank space use "“. In problem data window statements_
will appear with blanks spaces instead of "”._
VALUE: 13
_New definition: QUESTION: N.Points_Hammer:#CB#(1,3,7,13)
VALUE: 13
this
Best Regards
Aleix
Dear GiD team,
working
with
and use it in
Only
and
it
helps …
MSc. student
Hi all,
Dear Aleix, I’d like to thanks for your answer, but I think this is not the problem. I
tried to follow your suggestion but the problem remains. The same blank window is
there. And else, if the blank spaces were the problem, it woldn’t work in the 6.0
version ( I think!).
Anyway, I have a new information, if it helps. When I close the blank Problem Data
window, a GiD message appear, like this:
message 1:---------------- can’t read “GidData(PD, SYNC,TKWIDGET)”: no such
element in array
I’d appreciate if you have new suggestions.
best regards
Send reply to: gidlist at gatxan.cimne.upc.es
mailto:gidlist-request at gid.cimne.upc.es?subject=subscribe
mailto:gidlist-request at gid.cimne.upc.es?subject=unsubscribe
Date sent: Thu, 24 Oct 2002 15:32:34 +0200
[ Double-click this line for list subscription options ]
Hi Alisson,
VALUE: 13
VALUE: 13
Best Regards
Aleix
Alisson P. Chaves
Dear Alisson, here is attached the problem type fixed, please as Enrique
said you must provide unique names to QUESTIONS.
best regards,
Jorge Suit
Alisson P. Chaves wrote:
Hi all,
element in array
best regards
Hi Alisson,
VALUE: 13
VALUE: 13
Best Regards
Aleix
Alisson P. Chaves
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021024/aa85a2a1/attachment.txt
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021024/aa85a2a1/attachment-0001.txt
