As i told you, when you do File-open (in postprocess) and click on the file
test12_R.res, GiD will read two files: test12_R.msh and test12_R.res.
The file test12_R.msh contains:
TITRE
Fichier généré par GiD-Aster version 0.2
Le maillage comprend 1230 noeuds et 444 éléments dont 77
éléments linéiques, 0 éléments triangulaires, 367
éléments quadrilatéraux, 0 éléments tétrahédriques et
0 éléments hexahédriques.
FINSF
COOR_2D
N1 7.82130000000000D+02 5.44908000000000D+02
N2 7.79748000000000D+02 5.47296000000000D+02
N3 7.77365000000000D+02 5.49684000000000D+02
Which is not a GiD mesh file, and therefore, GiD complains about it.
I assumed that what you send was a GiD project and put all the files inside
the directory test12.gid.
This project contains geometry and mesh. If the results test12_R.res are
related to this project you can rename it to test12.post.res and then,
when you change from preprocess to postprocess GiD will read automatically
these results.
Ive done this, but then it appears another problem, on line 52391 you
define result over the element number 368, but there are only 367
quadrilaterals.
Miguel
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Mohsen hasheme
Enviado el: martes, 13 de marzo de 2007 18:04
Asunto: RE: [GiDlist] problem
i attach whole folder of test12 for you.
thanks alot.
— Miguel Pasenau miguel at cimne.upc.edu wrote:
¿can you send the files?
Enviado el: martes, 13 de marzo de 2007 17:11
Asunto: [GiDlist] problem
but i dint undrestand what exactly you mean,because
i
check my files and i havent any syntax error,could
you
tell me exactly from where come this problem.
TOO FEW PARAMETERS IN THIS LIN : 7 Reading Mesh
thanks.
Seems to be a syntax problem in your file.
Here is a page which explains the format:
http://www.gidhome.com/support_team/gid_toc/gid_17.html#SEC282
Note that if you click on a FILENAME.res to be
opened inside GiD, and one of
FILENAME.msh, FILENAME.bon, FILENAME.dat exists,
GiD’ll try to read it
first.
Miguel
Enviado el: martes, 13 de marzo de 2007 10:47
Hi every body
I got the message that Too few parameters: in this
line: 7 - Reading Mesh when i want to open .res
filr
in postproccesing.
what i have to do to solve my problem?
thanks.
It’s here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
_http://tools.search.yahoo.com/toolbar/features/mail/_
Expecting? Get great news right away with email
Auto-Check.
Try the Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/newmail_tools.html
The fish are biting.
Get more visitors on your site using Yahoo! Search Marketing.
http://searchmarketing.yahoo.com/arp/sponsoredsearch_v2.php
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20070314/776e80a3/attachment.htm
