Hi
I am having some problem with the command Uncollapse volumes. When I use it
with two blocks it works well. But when the number of blocks increases say
4 then it does not work. Infact, Gid stops responding. I am using windows.
Basically I have to draw few polyhedra attached to each other at their
vertices using batch file and I have got all the coordinates. All volumes
are drawn in the sequence of line-surafce-volume. But hese volumes( or
polyhedra) have common vertices. Now finally I wanted to uncollapse all the
vloumes so that these vertices are duplicated. But I am not able to find out
why such strange thing is happening. If it cannot be done in this way, is
there any alternative to draw polyhedra.
Anticipating your response
Thanking You
Anjaney
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20080711/45271c70/attachment.htm
