Warning: This message has had one or more attachments removed.
Warning: Please read the “VirusWarning.txt” attachment(s) for more information.
I’m actually using :
GiD internal version: 8.1.5b
Operating system: ‘x86_64’ ‘unix’ ‘Linux’ ‘2.6.18.8-0.5-default’
I’m using GiD to solve a simple mechanical problem but I’m enable to see
results in post-processing mode in GiD. It seems that the quadrature rules
used in my code are not supported by GiD. Coulds you tell me more details
aboit the note display in the help menu explaining the “Postprocess results
format: ProjectName.post.res, ProjectName.flavia.res” :
Note:
If the natural coordinates used are the internal ones, almost all the Results
visualization possibilities will have some limitations for tetrahedra and
hexahedra with more than one gauss points. If the natural coordinates are
given, these limitations are extended to those elements with
number_gauss_points_per_element not included in the list written above.
Also, I use an hexahedron quadratic mesh (H20) created in GiD to solve a
problem using the linear version of this mesh (H8). In this way, the results
in the result file are those at vertices (the 12 other nodes are not included
in the result file). In post-processing mode, I’m unable to see these
results. According to this problem, What is the sense of this note in the
help:
Holes are allowed in any result. The element nodes with no result defined will
not be drawn, i.e. they will appear transparent.
Is the element nodes with no result can be skipped from the result file or
not ?
As I can see, the hexahedra of 20 nodes in postprocess are supported since
version 8.1.2b
Daniel Marceau
P.S. the result and mesh files are attached.
This is a message from the MailScanner E-Mail Virus Protection Service
The original e-mail attachment “poutre.post.msh”
is on the list of unacceptable attachments for this site and has been
replaced by this warning message.
If you wish to receive a copy of the original attachment, please
e-mail helpdesk and include the whole of this message
in your request. Alternatively, you can call them, with
the contents of this message to hand when you call.
At Fri Aug 3 04:27:29 2007 the virus scanner said:
Attempt to hide real filename extension in poutre.post.msh
Note to Help Desk: Look on the MailScanner in /var/spool/mailscanner/quarantine (message l732R0Gx019095).
Postmaster
The original e-mail attachment “poutre.post.res”
Attempt to hide real filename extension in poutre.post.res
Postmaster
