[GiDlist] Problem Type in Linux
Name: not available
Url: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051122/e9221d93/attachment.txt
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051122/e9221d93/attachment.htm
If you used only pure Tcl/Tk (without any compiled extension), then your problemtype
must works well, without any change, on Windows, Linux, MacOSX, or Unix.
But probably you must add an analisis program specific for each platform
(and also add an .unix.bat file with Unix/Linux like operating system commands to rename files, etc and start the solver)
Sent: Tuesday, November 22, 2005 5:49 PM
Subject: [GiDlist] Problem Type in Linux
Hi.
I have developed my problem type in Gid 7.5.6b for Windows XP.
I would like to know if the problem type, with tcl files, works for Linux? I.e. if i open my Problem Type, in GiD for Linux, it works, or just works in my version of GiD.
Thank you.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20051122/79e3e517/attachment.htm
I want to get some problem types to get some Ideas about designing my
own one (especially to get an idea about using dependencies).
But i can’t access the Problem types because I need a proxy for ftp-ing.
Can I download them manually? Or what do I have to set…
I’m running latest gid-beta on a Gentoo- Linux system.
Thanks in advance
Bjoern Brodersen
Dipl.-Ing. Björn Brodersen MSc
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
Tel.: 0531 / 391 - 3670
If you can download the problemtypes from the GiD menu
Data-Problemtypes-Internet retrieve
Maybe you can try to directly download the zip files from
ftp://gid.cimne.upc.es/pub/gidmodules/
I recommend to you to see as sample the last versions of GiD_Nastran,
Ramseries and TDyn:
After download, you must unzip inside the /problemtypes GiD directory
From: “Björn Brodersen” bjoern.brodersen at tu-bs.de
Sent: Wednesday, November 23, 2005 10:27 AM
Subject: [GiDlist] Internet Retrieve trough Proxy
Thanks in advance
Bjoern Brodersen
TU Braunschweig
Institut für Statik
Beethovenstr. 51
38106 Braunschweig
