In GiD, the philosophy is to apply the conditions over the geometric entities (not directly over the mesh: remeshing these condition are lost)
If the condition is constant for all the nodes/elements generated from a surface, then
is too easy assign a pressure condition to these surface (transfered automatically to nodes or elements)
for example:
File: BEASY.cnd
NUMBER: 1 CONDITION: Pressure
CONDTYPE: over surfaces
CONDMESHTYPE: over elems
QUESTION: Pressure_Value
VALUE: 0
END CONDITION
File: BEASY.bas
*Set Cond Pressure *elems
*loop elems *OnlyInCond
Elmt ElemsNum
*for(i=1;i=nnode;i=i+1)
Cond(Pressure_Value)
*end for
*end elems
Note: another file BEASY.prb can be created for any problem type
If the value of the pressure on a node can be defined from your geometric position
(for example a hydrostatic pressure), then must be used a #FUNC# field of a condition.
NUMBER: 2 CONDITION: Hydrostatic_pressure
CONDMESHTYPE: over nodes
CANREPEAT: yes
QUESTION: Density:
VALUE: 0
QUESTION: Z_Water_Level:
VALUE: 0
QUESTION: AutoCalculatePressure#FUNC#(Cond(1,REAL)(Cond(2,REAL)-z))
VALUE: AutoCalculate
END CONDITION
(The field AutoCalculatePressure contain the Density(Z_Water_Level-Znode) calculated for each node)
*Set Cond Hydrostatic_pressure *nodes
*loop nodes *OnlyInCond
*nodesnum *Cond(AutoCalculatePressure)
*end nodes
In a small case, the user can apply condition values to a node directly.
(physically this pressure can be considered as is over the face of the parent element)
Sent: Wednesday, August 01, 2001 6:15 PM
Subject: [ GiDlist ] Problem type definition
Hi
We are trying to develop a problem type for BEASY which is a
BEM code. The main problem appears to be defining the boundary
conditions.
Generally the condition we need to apply is like a face pressure on
an element. We wish to define the values of the pressure at each of
the nodes on the element as they may be different.
For example for a three node triangle we want to define the
pressure at each of the three nodes. Note we cannot apply it as a
nodal condition as pressure has to act over an area therefore it only
means something if applied over the surface of the element.
How do we define this in the cnd file?
Assuming we can do this successfully haw do we write the data
using the bas file.?
We want to create a record for each element with the condition
applied something like the following.
Elmt No FacePresNode1 FacePresNode2 FacePresNode3
Thanks for the help
Bob Adey
Dr Robert Adey
Computational Mechanics BEASY
Ashurst Lodge, Ashurst,
Southampton, SO40 7AA, UK.
Tel: +44 (0) 238 029 3223
Fax: +44 (0) 238 029 2853
http://www.beasy.com
See BEASY on the www. www.beasy.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010801/3f1d83ba/attachment.htm
