[GiDlist] problem in bas file
Hi you might be able to do someting like this (it worked for me recently)
*loop elems
*loop materials
*if(Matnum==Elemsmat)
*end materials
*end elems
Mark
-----Original Message-----
From: Andreas Friedberg [mailto:andiatje at mailszrz.zrz.tu-berlin.de]
Sent: 05 August 2001 22:38
To: GiD mailinglist
Subject: [GiDlist] problem in bas file
Hi everybody,
I have a problem specific to the template file I wrote for the tochnog
solver. In the input file for a calculation with tochnog, the materials are
assigned to the elements of the generated mesh. I do this assignement
through the materials file. As I try to implement a template file for
geotechnical analysis with the modified Cam Clay plasticity model, I have to
assign initial values (preconsolidation mean pressure and void ratio) to the
nodes belonging to the elements which were assigned the material specified
by the Cam Clay model. So I have a list of elements which belong to this
material (with *elemsmat I can sort that out in the template file), but I
need a nodes list (something a command like *nodesmat could do, but that
doesn’t exist).
I tried to get this list with the following commands:
*loop elems
*if(ElemsMat==imaterial)
*ElemsConec
*endif
*end elems
with imaterial being the number of the plastic material specified by the Cam
Clay model.
The problem with this set of commands is the fact that I get almost all the
points repeated several times in the list. Could you help me get that list
of nodes belonging to a certain material without every node being repeated
several times in the list?
best regards, Andreas Friedberg
+44 (0)1480302100
http://www.linx.co.uk/
person.
