[GiDlist] postprocessing
Hi ALL
I tried to run the gid with code-aster to solve one
problem,for the preprocessing part everythings is
ok,but when i want to see the results in
postprocessing i got the message:
“Too few parameters:in this line:7-Reading Mesh.”
Could somebody help me to find the solution.
Thanks.
____________________________________________________________________________________Be a better Heartthrob. Get better relationship answers from someone who knows. Yahoo! Answers - Check it out.
Can you send us your results and mesh file to check it?
(can send directly to escolano at cimne.upc.es instead to the GiDList)
Sent: Thursday, May 24, 2007 11:23 AM
Subject: [GiDlist] postprocessing
Hi ALL
Thanks.
Hi Miguel,
I attached a folder containing postprocessing files but also a picture
showing the graph I obtained using “border graph” option.
The graph shows the "Voltage in electrolyte (average) Vs pipe length (To
be honest, I can’ t manage to make a proper selection of the lines that
interst me, and I end up with several same curves on the graph that I
have to delete on the graph management window).
I tried the “line graph” option but it doesn’t work (I can’t display
anything, I don’t really know why…).
Besides, the model is made of 4 pipes of varying diameters protected by
an anode. The whole is embedded in an electrolyte made of 2 parts
separated by an interface.
Many thanks.
Ahmed.
C M BEASY Ltd
www.beasy.com http://www.beasy.com/
Tel: 44 (0) 23 8029 3223; Fax: 44 (0) 23 8029 2853
Registered Office Address: Ashurst Lodge, Ashurst, Southampton, SO40
7AA, UK
Registered in England as a limited company
Registration Number: 1865517
[mailto:gidlist-admin at gatxan.cimne.upc.edu] On Behalf Of Miguel Pasenau
Sent: 22 May 2007 16:32
Subject: RE: [GiDlist] Postprocessing results
I thinl, the best way is to send an example so that we can take a look.
Miguel
[mailto:gidlist-admin at gatxan.cimne.upc.edu] En nombre de Ahmed Arbane
Enviado el: martes, 22 de mayo de 2007 13:17
Asunto: RE: [GiDlist] Postprocessing results
My model is a tube model represented by lines, and I d like to display a
graph along the tube length (along the lines)…
When i go on “WindowView graph” I select Border graph, “Z variation”
for the X axis, and one of my results for the Y Axis. But I don’t
understand what do I have to select when it says " Select Border". I
drag the mouse on the line I want to select and it draws arrows on it,
but it also displays a warning saying " Sorry but no lines can be
selected"
How this selection process wors?
What am I suppose to select as a border?
Arbane
Beasy
[mailto:gidlist-admin at gatxan.cimne.upc.edu] On Behalf Of Enrique
Escolano
Sent: 21 May 2007 19:23
Subject: Re: [GiDlist] Postprocessing results
You can plot a graph along the segment between two points
View results-Graphs-Line graph
You can also do a cut, convert it to set and use a “border graph” along
this cutting line.
From: Ahmed Arbane mailto:Ahmed.Arbane at beasy.com
Sent: Monday, May 21, 2007 4:20 PM
Subject: [GiDlist] Postprocessing results
Hi all,
I wonder if it s possible to plot a graph of any result Vs
existing line length and how to perform it …
A Arbane
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20070524/5fa85efd/attachment.htm
Desc: To_Gid.zip
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20070524/5fa85efd/attachment.bin
