the problem are in this line:
GaussStress 2 1 “ealstic” 2 2 0 “Quads”
· first problem:
^^^^^^^^^^^^^^^ - result name must be 15 characters long, unused chars shoul be filled with spaces
· second problem:
the analysis name should only be given when the load analysis number is 4, so
it shoulbe:
GaussStress 2 1 2 2 0 “Quads”
or
GaussStress 4 1 “ealstic” 2 2 0 “Quads”
·third problem:
Sxx
Syy
Sxy
here you are specifying the name, description, for each component, so the last number
should be ‘1’, not ‘0’:
GaussStress 4 1 “ealstic” 2 2 1 “Quads”
Sxx
Syy
Sxy
the rest is o.k.
Note: for stress information, there is also a ‘matrix’ result type, besides the ‘scalar’ and ‘vector’ one.
these ‘matrix’ results are generally used for stress representations, . . .
GiD assumes that its a symmetrical, so only the upper right triangle must be entered:
for 2d matrices: Sxx Syy Sxy
for 3d matrices: Sxx Syy Szz Sxy Syz Sxz
GiD then calculates the main stresses.
more information under:
http://gid.cimne.upc.es/support/gid_16.html#SEC231
Note 2:
You can also use the ‘new’ postprocess format, usable up version 6.1.4b, and more comprehensible.
Your result would look like:
GiD Post Results File 1.0
GaussPoints “Quads” ElemType Quadrilateral
Number of Gauss Points: 4
Natural Coordinates: Internal
End gausspoints
“ealstic”
Result “GaussStress” “ealstic” 1 Vector OnGaussPoints “Quads”
ComponentNames “Sxx”, “Syy”, “Sxy”
Values
1 -52.9953 120.011 -13.7941
-49.9476 127.122 1.38544
3.18081 149.891 3.41724
0.13311 142.78 -11.7623
2 -43.1729 357.488 -40.3418
-25.4268 398.896 -20.8489
42.7981 428.135 -9.0182
25.052 386.728 -28.511
End Values
or, if you use the ‘matrix’ result type:
End gausspoints
“ealstic”
Result “GaussStress” “ealstic” 1 Matrix OnGaussPoints “Quads”
Values
End Values
a couple of images showing the result using following mesh:
MESH dimension 3 elemtype quadrilateral nnode 4
coordinates
1 0 0 0
2 1 0 0
3 2 0 0
4 2 1 0
5 1 1 0
6 0 1 0
end coordinates
elements
1 1 2 5 6
2 2 3 4 5
end elements
hope it helps,
Changho wrote:
Hello, all
I’m trying to load the result files into GID on 4 Gaussian point for
Quadrilateral element which have the stress information. Follwing text is
the header of my file. But it complains as "Node out of range: in this line:
10 - Reading Results". 1 and 2 are the element numbers. What is my mistake?
Could you give me some help?
thank you
End gausspoints
Sxx
Syy
Sxy
Changho Choi
Department of Civil Engineering
Box 352700 More 132A
University of Washington phone: 206-729-3542 (H)
Seattle WA 98195 206-543-6778 (O)
206-543-1543 (fax)
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010710/08af0e35/attachment.png
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010710/08af0e35/attachment-0001.png
