Dear all:
Can you help me following problem?
I am using GiD 9.0.4. When I switch to post-processing mode I can not see
mesh as well as other results on the mesh. Someone might change options but
I could not fix it because I did not get this trouble before.
Thank you in advance.
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100223/2933207d/attachment.htm
Maybe do you have set some unusual preference.
You can reset all preferences to the default ones by starting fom the Windows menu “GiD Safe mode” and selecting the “Reset preferences” option.
Sent: Tuesday, February 23, 2010 2:10 PM
Subject: [GiDlist] post-processing
Dear all:
I am using GiD 9.0.4. When I switch to post-processing mode I can not see mesh as well as other results on the mesh. Someone might change options but I could not fix it because I did not get this trouble before.
Thanh
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100223/148ac2a3/attachment.htm
