# \[GiDlist\] Post Processing Results on Guass Points
**URL:** <https://forum.gidsimulation.com/t/gidlist-post-processing-results-on-guass-points/300>\
**Category:** 2013 - 2005\
**Created:** [September 27, 2013, 8:53pm UTC](https://forum.gidsimulation.com/t/gidlist-post-processing-results-on-guass-points/300 "2013-09-27T20:53:47Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Farzam\_Arash](https://forum.gidsimulation.com/letter_avatar_proxy/v4/letter/f/c2a13f/32.png) [@Farzam\_Arash](https://forum.gidsimulation.com/u/Farzam_Arash)\
**Post date:** [September 27, 2013, 8:53pm UTC](https://forum.gidsimulation.com/t/gidlist-post-processing-results-on-guass-points/300/1 "2013-09-27T20:53:47Z")
</div>
I have developed this post processing file, but I am not able to use the
GiD post processing data demonstration for the data that are on Gauss
points. Please let me know if there is any problems.
Arash
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.htm)
Url : [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.obj](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.obj)
Type: model/mesh
Url : [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.msh](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130927/1eee9de9/attachment-0001.msh)
**Post date:** [October 4, 2013, 3:47pm UTC](https://forum.gidsimulation.com/t/gidlist-post-processing-results-on-guass-points/300/2 "2013-10-04T15:47:37Z")
</div>
I would like to ask if you can help me with this issue.
Arash Farzam
On Fri, Sep 27, 2013 at 3:53 PM, Farzam, Arash
[farzam at ostatemail.okstate.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) wrote:
_Hi,_
_I have developed this post processing file, but I am not able to use the_
_GiD post processing data demonstration for the data that are on Gauss_
_points. Please let me know if there is any problems._
_Thanks,_
_Arash_
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/e7038017/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/e7038017/attachment.htm)
**Post date:** [October 4, 2013, 4:33pm UTC](https://forum.gidsimulation.com/t/gidlist-post-processing-results-on-guass-points/300/3 "2013-10-04T16:33:44Z")
</div>
Attached, please find the files.
On Fri, Oct 4, 2013 at 10:47 AM, Farzam, Arash
_Hi,_
_I would like to ask if you can help me with this issue._
_Thanks,_
_Arash Farzam_
_On Fri, Sep 27, 2013 at 3:53 PM, Farzam, Arash_
_[farzam at ostatemail.okstate.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) wrote:_
_Hi,_
_Thanks,_
_Arash_
URL: [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/ec932811/attachment.htm](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/ec932811/attachment.htm)
Type: application/zip
Url : [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/ec932811/attachment.zip](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131004/ec932811/attachment.zip)
**Author:** ![anna](https://forum.gidsimulation.com/user_avatar/forum.gidsimulation.com/anna/32/5_2.png) [@anna](https://forum.gidsimulation.com/u/anna)\
**Post date:** [October 8, 2013, 10:01am UTC](https://forum.gidsimulation.com/t/gidlist-post-processing-results-on-guass-points/300/4 "2013-10-08T10:01:11Z")
</div>
Dear Arash,
Your .res file is not including the Gauss points definition header.
Please find the header structure in this link
[http://www.gidhome.com/component/manual/customizationmanual/postprocess\_data\_files/postprocess\_results\_format-\_projectnamepostres/gauss\_points](http://www.gidhome.com/component/manual/customizationmanual/postprocess_data_files/postprocess_results_format-_projectnamepostres/gauss_points)
El viernes, 04 de octubre de 2013 18:33:44, Farzam, Arash escribió:
_Attached, please find the files._
_Thanks_
_On Fri, Oct 4, 2013 at 10:47 AM, Farzam, Arash_
_[farzam at ostatemail.okstate.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) mailto:[farzam at ostatemail.okstate.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_wrote:_
_Hi,_
_Thanks,_
_Arash Farzam_
_[farzam at ostatemail.okstate.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_mailto:[farzam at ostatemail.okstate.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) wrote:_
_Hi,_
_I have developed this post processing file, but I am not able_
_to use the GiD post processing data demonstration for the data_
_that are on Gauss points. Please let me know if there is any_
_problems._
_Thanks,_
_Arash_
## _GiDlist mailing list_ _[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_ \_[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist\_](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist_)
_Anna Monros Bellart_
AVISO IMPORTANTE
AVÍS IMPORTANT
del CIMNE. Es poden exercir els drets d’accés, rectificació,
cancel•lació i oposició, per escrit a les nostres oficines del CIMNE,
IMPORTANT NOTICE
**Post date:** [October 8, 2013, 11:06am UTC](https://forum.gidsimulation.com/t/gidlist-post-processing-results-on-guass-points/300/5 "2013-10-08T11:06:01Z")
</div>
Do you have two errors:
1- in the .msh file your definition of gauss points is wrong:
You not must to define the global position of your (n\_elem x n\_gauss\_by\_elem) gauss points !!
what you must define is only the location of n\_gauss\_by\_elem gauss points in a single ‘reference element’ (e.g. only 4 local coordinates for quadrilaterals with 4 gauss points)
and in case that you use the same locations that GiD (see Customization manual about postprocess files), then this definition is unneded, and you can use our ‘standard names’ for your result
(e.g. for quadrilaterals with 4 gauss points the keyword is GP\_QUADRILATERAL\_4)
2- in the .res file, you are using a ‘gauss location name’ for the result “Board Gauss Given” that is not defined in the .msh or predefined by GiD (e.g GP\_QUADRILATERAL\_4)
And then for each element you must write the element id and as many values as n\_gauss\_by\_elem (4 values for GP\_QUADRILATERAL\_4)
Read the related Customization manual on postprocess files to know other options
De: [gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist) [mailto:[gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)] En nombre de Anna Monros
Enviado el: martes, 8 de octubre de 2013 12:01
Para: [gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
CC: Bulut, Rifat
Asunto: Re: [GiDlist] Post Processing Results on Guass Points
Dear Arash,
Please find the header structure in this link [http://www.gidhome.com/component/manual/customizationmanual/postprocess\_data\_files/postprocess\_results\_format-\_projectnamepostres/gauss\_points](http://www.gidhome.com/component/manual/customizationmanual/postprocess_data_files/postprocess_results_format-_projectnamepostres/gauss_points)
_Thanks_
_wrote:_
_Hi,_
_Thanks,_
_Arash Farzam_
_Hi,_
_problems._
_Thanks,_
_Arash_
CIMNE - International Center for Numerical Methods in Engineering Campus Nord UPC - C1 building - C2 Office Gran Capità s/n - 08034 Barcelona
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán en un fichero para facilitar la gestión de las comunicaciones de CIMNE.
Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVÍS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d’accés, rectificació, cancel•lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
