I would like to export the linear part of the connectivity of a quadratic 3D
mesh using 20-noded hexahedron. In other words, just the vertex nodes.
The linear part will be used for mass transfert using finite differences and
the obtained results transfered to a mechanical finite element problem using
the quadratic mesh.
Daniel Marceau
Daniel Marceau, Ph.D., ing.
Professeur
Directeur du REGroupement ALuminium (REGAL)
Département des sciences appliquées
Université du Québec à Chicoutimi
In GiD the element nodes are ordered first the “linear part”, and then the
quadratic nodes (hierarchical numeration)
for example, for a 20-noded hexahedral, the corner nodes are the first 8
nodes.
For example, you can print only this nodes using a bas template like:
*loop elems
*elemsconec(1) *elemsconec(2) *elemsconec(3) *elemsconec(4)
*elemsconec(5) *elemsconec(6) *elemsconec(7) *elemsconec(8)
*end elems
Sent: Sunday, November 13, 2005 11:08 PM
Subject: [GiDlist] partial connectivity
3D
and
using
the quadratic mesh.
Daniel Marceau
Professeur
