Dear Mark,
By now there is no tutorial for the boundary layer meshing. However, it is
very simple to use: The only thing you have to do is select ‘Mesh-Boundary
layer-2D or 3D’, and select the entities. For 3d, for example, first of all
you have to select the volumes into which the boundary layer mesh has to
“grow”, and then the surfaces from which it should grow.
By the moment the 3d bundary layer meshes are only available for tetrahedra
volume meshes (no connection between hexas and tetras), and for linear
elements (not quadratic ones).
2D boundary layer mesher is available from the oficial version 9.0.x, and 3D
is only available from the 9.2.xb beta versions (all of them downladable
from the web site).
Kind regards,
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per
IMPORTANT NOTICE
De: gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu
[mailto:gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de
Smith, Mark
Enviado el: viernes, 28 de agosto de 2009 20:28
Asunto: [GiDlist] boundary layer meshing
Hi GiD team
Is there a tutorial or example of how to use the boundary layer feature in
meshing for arbitrary 3D geometry for CFD problems?
How do you mix hexahedra and tet meshes? is there an automatic way of
bridging between them with prism and pyramid elements as I seem unable to
have some parts as structured mesh & other parts unstructured.
Are there any plans for full automatic hexahedral meshing?
GiD 9.04 on winXP
mark
Please be advised that this email may contain confidential information.
If you are not the intended recipient, please do not read, copy or
re-transmit this email. If you have received this email in error,
please notify us by email by replying to the sender and by telephone
(call us collect at +1 202-828-0850) and delete this message and any
attachments. Thank you in advance for your cooperation and assistance.
In addition, Danaher and its subsidiaries disclaim that the content of
this email constitutes an offer to enter into, or the acceptance of,
any
contract or agreement or any amendment thereto; provided that the
foregoing disclaimer does not invalidate the binding effect of any
digital or other electronic reproduction of a manual signature that is
included in any attachment to this email.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20090831/fe8140ac/attachment.htm
