Hi Claudio,
don’t hesitate to ask questions.
As the manual says, GiD tries to interpolate the gp results to the nodes of
the elements, and if it can not do it, the gp-results are shown as spheres
at the gauss points.
By now, Gauss Points results which can be extrapolated to the nodes are:
- 1 gp for all elements,
- 8, 20 and 27 for hexaedras,
- 6 and 15 for prisms,
- 5 and 13 for pyramids,
- 4 and 10 for tetrahedral,
- 4 and 9 for cuadrilaterals, and
- 3 and 6 for triangles.
Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
De: gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu
[mailto:gidlist-admin at gatxan.cimne.upc.edu.gid.cimne.upc.edu] En nombre de
Claudio AC Silva
Enviado el: jueves, 18 de junio de 2009 16:15
Asunto: Re: [GiDlist] Visualization of high-order discontinuous results
Miguel,
As I do not know how this feature is implemented and the constraints or
trade-offs you have to comply, please forgive me if I say something
wrong (as we say in my country: if advices had any value, they would be
sold, not given for free): a least squares method could be used? This
way, the number of GPs would not be an issue (except for performance;
remember the joke about advices above…).
But what is really important for me, right know is knowing the GiD
limitations in terms of number of GPs for extrapolating GP data to nodes
for each element.
Cláudio
miguel wrote:
Ni,
Yes, when GiD does not know how to extrapolate the results from the N GP
to
the nodes of the hexaedra, then it draws spheres on the GP with the
coloured
result.
If you know how to do this, we can try to implement it.
Miguel Pasenau
IMPORTANT NOTICE
Claudio AC Silva
Enviado el: miércoles, 17 de junio de 2009 22:53
Asunto: [GiDlist] Visualization of high-order discontinuous results
I am dealing with high-order discontinuous results and I am exporting
them to Gauss points. However, GiD is only able to plot ‘contour fill’
of results if I used a limited number of Gauss points. In the case of
hexaedra the maximum is 27 GPs. When I exceed this number, GiD plots
small spheres at the Gauss points locations. Is it the expected behavior?
Cláudio
Claudio Alessandro de Carvalho Silva, Dr. Eng. (#329333)
CAE Solutions
Thorus Scisoft - www.thorus-scisoft.com.br
Fone:+55 019 3705-4002
This message is intended solely for the use of its addressee and may contain
privileged or confidential information. If you are not the addressee you
should not distribute, copy or file this message. In this case, please
notify the sender and destroy its contents immediately.
Esta mensagem é para uso exclusivo de seu destinatário e pode conter
informações privilegiadas e confidenciais. Se você não é o destinatário não
deve distribuir, copiar ou arquivar a mensagem. Neste caso, por favor,
notifique o remetente da mesma e destrua imediatamente a mensagem.
GiDlist at gid.cimne.upc.edu
