Hello
It’s available a new GiD beta version 7.4.3b for Windows, with multiple corrected
small bugs and some new feature.
Can see a list of changes and corrections in the GiD Help:
What’s new - Last detailed changes from version 7.2 to 7.4b
For example:
a.. New GiD-tcl, info and bas template commands
b.. RecentFiles menu to access to the last models.
c.. ‘Utilities-graphical-animation script’ window which allows the user to define a sequence of scenes which will be animated
d.. ‘Utilities-Report’ window for creating reports: images, List Entities info, text, etc. can be inserted.
e.. Smooth Contour fill: shows a contour fill with smoothed gauss points results: min, max and mean value of the nodal extrapolated results
Etc.
The GiD Team
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030801/d1aaed54/attachment.htm
another added feature is this one:
using the ‘points’ display style which draws spheres at the nodes,
when a c.fill of a gauss point results is selected, it will draw
coloured spheres at the gauss points.
Guy HUBERT wrote:
I have 2 quastions about Post Procesing on Gauss Points
1 - For a result file with given gauss points, “contour fill” is displayed
with “big colored points” located at gauss point location, it is very
convenient for some applications. Is there any options to get this display
on all results at “gauss points”
2 - My solver give me “results on node”, but elements by elments, in order
to keep this information for results dysplay, I use the option "results on
gauss point" with “given gauss points” located on nodes of the reference
element. Is there any other way to achieve this objective ?
Guy HUBERT Mailto:hubert at deltacad.fr
Tel direct : +33 (0)3 44 23 52 99 mobile: 06 76 80 03 42
DeltaCAD
Centre de Transfert - 66 Avenue de Landshut
60200 COMPIEGNE (FRANCE)
Tel : +33 (0)3 44 23 46 54 - Fax : +33 (0)3 44 23 46 31
Web : http://www.deltacad.fr
Enrique Escolano wrote:
Hello
For example:
* New GiD-tcl, info and bas template commands
* RecentFiles menu to access to the last models.
* ‘Utilities-graphical-animation script’ window which allows the user to define a sequence of scenes which will be animated
* ‘Utilities-Report’ window for creating reports: images, List Entities info, text, etc. can be inserted.
* Smooth Contour fill: shows a contour fill with smoothed gauss points results: min, max and mean value of the nodal
Etc.
The GiD Team
Dear Gid team,
How can I download the new version 7.4.3b for windows; I 've seen only v.7.2 is the lastest version on gid homepage.
Thank you
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030801/e888a2c8/attachment.htm
look into the betas section,
ftp://www.gidhome.com/pub/gid_adds/Windows
Adisorn Owatsiriwong wrote:
Dear Gid team,
Thank you
