[GiDlist] (no subject)
Dear GiD Staff,
I’ve install GiD 10 under ubuntu 10 in /opt folder. I have a usb license,
I cannot register because GiD is trying to look up for my usb device in
/proc/bus/usb while all my pendrives are listed in /media.
What should I do?
Andrea Petronio
Ph.D. Student
Dep of Civil and Environmental Engineering
University of Trieste,
P.le Europa 1, 34100 Trieste, Italy
Lab tel: +39-040-558-7803
Lab fax: +39-040-572082
mobile: +39-393-9350398
e-mail: apetroni at ictp.it
Maybe this F.A.Q. answer your question: (http://www.gidhome.com/component/manual/21079?id=21079)
GiD doesn’t detect the USB memory stick
When oppening the “Help - Register GiD …”, if some USB memory stick is plugged, a “Sysinfo selection” window must be opened to ask the user which device can be registered.
in some Linux distributions (e.g. Suse 10.x) the USB device is not detected, and this “Sysinfo selection” is not opened.
This is because /proc/bus/usb is not automatically mounted, it can be manually mounted (as root user) with
mount -t usbfs none /proc/bus/usb
Note: It’s possible to automatize it adding to the /etc/fstab file something like this:
usbfs /proc/bus/usb usbfs noauto 0 0
Note: OpenSuSE 10.2 does not have this support by default and the kernel should be recompiled or a patch should be applied. More information can be found here: http://en.opensuse.org/SDB:VMware_-_USB_support
Note: Ubuntu 8.04.1 does not mount /proc/bus/usb automatically, so it should be done by hand or added to the /etc/fstab file, as explained above.
Sent: Monday, October 18, 2010 1:31 PM
Dear GiD Staff,
What should I do?
Andrea Petronio
Ph.D. Student
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101103/cb29e8fb/attachment.htm
a clarification:
in /media you can find the contents of the usb drive, but GiD needs actually
to look into /proc/bus/usb/devices to get the serial number of the usb
device, which is where all the information about the usb device (not its
data) is.
Miguel Pasenau
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Enrique Escolano
Enviado el: miércoles, 03 de noviembre de 2010 13:18
Asunto: Re: [GiDlist] (no subject)
like this:
From: mailto:apetroni at ictp.it apetroni at ictp.it
To: mailto:gidlist at listas.cimne.upc.edu gidlist at listas.cimne.upc.edu
Dear GiD Staff,
What should I do?
Andrea Petronio
Ph.D. Student
e-mail: mailto:apetroni at ictp.it apetroni at ictp.it
mailto:GiDlist at listas.cimne.upc.edu GiDlist at listas.cimne.upc.edu
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101103/e04a9fb0/attachment-0001.htm
Dear GiD Team
I haven’t worked out wih GID for about 4-5 years.. what’s now your
development of GID in Brief commpared to GID 8.??
Willy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101107/43b54139/attachment.htm
Dear Willy,
there are a lot of news from 8 version to the current one (10). You can find
them in http://www.gidhome.com/support/whats-new.
Kind regards,
ABEL
AVISO IMPORTANTE
AVÍS IMPORTANT
poden exercir els drets d’accés, rectificació, cancel·lació i oposició, per
IMPORTANT NOTICE
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Villy S
Enviado el: lunes, 08 de noviembre de 2010 7:12
Asunto: [GiDlist] What’s the latest GID Version? and what’s new?
Dear GiD Team
Willy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101108/57e9b784/attachment.htm
key features:
8 – 9:
Layer labels, transparent layers, draw surface curvatures, , rhino import,
3dsolid (acis) import, cgns import, nurbs tools, surfaces edition tools
sphere mesher, , draw meshing data related to boundary layer, better
semistructured/unstructured mesher, global cordal error, new quadrilateral
mesher, cartesian mesher,
smooth and c.fill coloured isosurfaces, stream lines for hexas, prisms and
pyramids, new stream lines/ribbons options, c.fill with shininess, separate
mesh styles for each layer, several visualization options, better graphs
memory savings in pre and posprocess in order to handle big meshes
two colours background, preview images of model in the filebrowser box
environment reflection over surfaces and meshes in render mode
TruType fonts
9 – 10:
stereoscopy ( 3d view) and shadow added
mac osx version
gmed: medical images treatment modules
import plugins support,
rhino 4 export, hdf5 import
geometric reconstruction
boundary layer mesh generation, quad dominant meshes, new unstructured
volume mesher
logaritmic results and graphs, polar graphs, integral of results in surfaces
/ lines
faster visualization modes
create delaunay option in postprocess
file with list of results and graphs to be loaded
Dear GiD Team
Willy
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101109/dd4d0649/attachment.htm
I’ve tried both solutions but still doesn’t work, it cannot mount
/proc/bus/usb/ and adding the line at fstab file is not effective.
I’m working on a
Ubuntu 10.04 lucid
Kernel Linux 2.6.32-26-generic
Gnome 2.30.2
I would like to fix this…
a clarification:
actually
data) is.
Miguel Pasenau
Escolano
detected,
something
like this:
_found here: http://en.opensuse.org/SDB:VMware_-_USB_support_
_http://en.opensuse.org/SDB:VMware_-_USB_support_
should
Dear GiD Staff,
license,
What should I do?
Andrea Petronio
Ph.D. Student
Andrea Petronio
Ph.D. Student
Hello Petronio,
Other GiD user pointed a possible solution of this problem, this is his message:
I had the same issue (I use Ubuntu Lucid too) and to solve it I had to recompile a Linux kernel with the following options:
CONFIG_USB_DEVICEFS=y
CONFIG_USB_DEVICE_CLASS=y
On recent Linux systems the USB device filesystem is not active by default.
Pascal.
Best wishes
Sent: Thursday, December 09, 2010 11:51 AM
Subject: Re: [GiDlist] (no subject)
I’m working on a
Ubuntu 10.04 lucid
Gnome 2.30.2
a clarification:
actually
data) is.
Miguel Pasenau
Escolano
detected,
something
like this:
should
Dear GiD Staff,
license,
What should I do?
Andrea Petronio
Ph.D. Student
Andrea Petronio
Ph.D. Student
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20101217/106053ff/attachment.htm
