[GiDlist] (no subject)
Hi:
I am interested in your application.
Can you please send me some info on it’s proposed use and availability/
JM
-----Original Message-----
From: Andreas Friedberg [mailto:andreasfriedberg at hotmail.com]
Sent: Thursday, January 23, 2003 12:40 PM
To: GiD mailinglist
Hi everybody,
I am working on the embeddement of a solver called dyn3D (for geotechnical
dynamics analysis) into the preprocessor of gid. The solver has three
different calculation modules which demand different input data. I have
created the configuration files and a tcl-file. When a new project is created
within gid ( by choosing the problemtype “dyn3D”), the tcl-file makes a
window pop up in which the calculation module can be selected by the user.
The selection is stored in a global variable within the tcl procedure and is
used in other procedures to specify the menu and the symbols that appear in
the gid window. That works fine as long as this global variable is defined.
But if I save a project and reopen that project later on, the variable is
lost or is set to a standard value. So either the tcl file cannot be
interpreted by gid or the wrong values are read.
What I would need to do is to save the global variables values in a file
within the project directory so it can be read whenever the project is opened
within gid. Does anybody have a clue if that is possible?
Thanks for response, Andreas
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20030123/12785eba/attachment.htm
