You need to create a hole in a Surface:
First create the missing cylinder surface (for example, use a copy of the opposite surface, with a mirror)
To add the hole to this surface pick the menu:Geometry-Edit-Hole NURBS Surface, then select the surface, and the lines over this surface to define the hole loop.
I’ attach your file with this modifications.
Sent: Monday, November 04, 2002 2:19 PM
Subject: SV: [GiDlist] New beta version 7.1.3b for Windows
Dear Enrique,
I have no problems making the actual intersection. The problems come when I try to create the nurb with a hole on the side of the cylinder. I send you the file. Hopefully you can see what I’m trying to do.
Kristian.
-----Oprindelig meddelelse-----
Fra: gidlist-admin at gatxan.cimne.upc.es [mailto:gidlist-admin at gatxan.cimne.upc.es]På vegne af Enrique Escolano
Sendt: 4. november 2002 10:55
Til: gidlist at gatxan.cimne.upc.es
Emne: Re: [GiDlist] New beta version 7.1.3b for Windows
You can intersect surface-surface, or multiple surfaces. Also you can create the auxiliary volumes, use some boolean operation, and after delete the volumes.
Please, if your intersection surface-surface fails, send us you GiD geometric model (.geo file).
Sent: Friday, November 01, 2002 12:27 PM
I’m having some problems with cylinder-cylinder intersection. I need only a shell model (no volumes). Is it possible to do this?
Kristian Krabbenhoft
Sendt: 30. oktober 2002 20:14
Emne: [GiDlist] New beta version 7.1.3b for Windows
It is available for download the last beta version 7.1.3b for Windows.
If some user has download the previous 7.1.2b version, is recommended to update to this new
version to avoid some errors reading ascii results with time steps, and generating quadratic elements.
The GiD Team
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021104/c7f33f7f/attachment.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20021104/c7f33f7f/attachment.obj
