is it possible to apply the same selection to display the same line graph
for different analysis steps all at once? I mean is there a way quicker then
open multiple postprocess files – line graph – selection – change
analysis step – line graph – (same) selection — and so on… ?
don’t know if this is a bug or I miss something. When I open multiple
(many!!!) postprocess files all at once, whenever I try “do cut” or “divide
by volume sets” after selection I have a large number of Dialog windows
opening asking if I want to do a cut for current analysis step only or for
all of them. Is thet normal?
No, there is no other possibility. We can think about it and add this
possibility in a future version.
in multiple files, when you do a cut, GiD asks you if the cut should be
done only for the viewed mesh or for all loaded meshes. The question is done
whenever the user wants to do a new cut. This was thought for the case when
a lot of meshes were loaded and the user wanted to cut just a couple of them
(saving so some memory).
Yes, we can change this behaviour and turn it into a preference rather than
a pop-up window for each cut.
Thanks for your suggestions,
Miguel Pasenau
08034 - Barcelona ( SPAIN)
IMPORTANT NOTICE
