# \[GiDlist\] mix mesh in GiD
**URL:** <https://forum.gidsimulation.com/t/gidlist-mix-mesh-in-gid/57>\
**Category:** 2013 - 2005\
**Created:** [June 8, 2012, 2:43pm UTC](https://forum.gidsimulation.com/t/gidlist-mix-mesh-in-gid/57 "2012-06-08T14:43:40Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![hbui](https://forum.gidsimulation.com/letter_avatar_proxy/v4/letter/h/8e7dd6/32.png) [@hbui](https://forum.gidsimulation.com/u/hbui)\
**Post date:** [June 8, 2012, 2:43pm UTC](https://forum.gidsimulation.com/t/gidlist-mix-mesh-in-gid/57/1 "2012-06-08T14:43:40Z")
</div>
Is there capabilites to mesh and display mix elements (for example
triangle/quadrilateral or tetrahedra/hexahedra) in GiD? I have a mesh
from other mesher and like to import it to GiD to visualize the results.
However I couldn’t find such a capability in Help/Manual.
Any advice is welcome
Giang Bui
**Post date:** [June 11, 2012, 2:45pm UTC](https://forum.gidsimulation.com/t/gidlist-mix-mesh-in-gid/57/2 "2012-06-11T14:45:14Z")
</div>
I assume that do you mean displaying results in postprocess of these kind of
elements.
Now is not possible to simultaneously show results on gauss points of
different elements, like triangle and quadrilateral, because internally are
considered as different results.
But you can show them simultaneously if do you define the results on nodes,
because it is the same nodal result.
You can also use Window-Several results… to show more than one result:
‘one over another’,
then maybe you will be able to obtain the kind of image you want of a
gaussian result on triangles and other of a gaussian result on
quadrilaterals.
From: “hbui” [hgbk2008 at gmail.com](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Sent: Friday, June 08, 2012 4:43 PM
Subject: [GiDlist] mix mesh in GiD
_Hi,_
_Is there capabilites to mesh and display mix elements (for example_
_triangle/quadrilateral or tetrahedra/hexahedra) in GiD? I have a mesh_
_from other mesher and like to import it to GiD to visualize the results._
_However I couldn’t find such a capability in Help/Manual._
_Any advice is welcome_
_Thanks,_
_Giang Bui_
_GiDlist mailing list_
_[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
\_[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist\_](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist_)
**Post date:** [June 17, 2012, 11:01pm UTC](https://forum.gidsimulation.com/t/gidlist-mix-mesh-in-gid/57/3 "2012-06-17T23:01:07Z")
</div>
I have tried your instruction, the nodal results work fine but Gaussian
results does not work for “Several Results” option. Even for standard
example in manual (see attached file table.post.res). I also attached my
files as a further reference.
GB
On 06/11/2012 04:45 PM, Enrique Escolano wrote:
_I assume that do you mean displaying results in postprocess of these kind of_
_elements._
\_\_ _Now is not possible to simultaneously show results on gauss points of_
_different elements, like triangle and quadrilateral, because internally are_
_considered as different results._
_But you can show them simultaneously if do you define the results on nodes,_
_because it is the same nodal result._
\_\_ _You can also use Window-Several results… to show more than one result:_
_‘one over another’,_
_then maybe you will be able to obtain the kind of image you want of a_
_gaussian result on triangles and other of a gaussian result on_
_quadrilaterals._
\_\_ _Enrique Escolano_
\_\_ _----- Original Message -----_
_From: "hbui"[hgbk2008 at gmail.com](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_To:[gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_Sent: Friday, June 08, 2012 4:43 PM_
_Subject: [GiDlist] mix mesh in GiD_
\_\_\_\_ _Hi,_
\_\_ _Is there capabilites to mesh and display mix elements (for example_
\_\_ _Any advice is welcome_
\_\_ _Thanks,_
_Giang Bui_
Type: model/mesh
Url : [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120618/699036fd/attachment-0002.msh](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120618/699036fd/attachment-0002.msh)
GiD Post Results File 1.0
GaussPoints “Board gauss internal” ElemType Triangle “board”
Number Of Gauss Points: 3
Natural Coordinates: internal
end gausspoints
GaussPoints “Board gauss given” ElemType Triangle “board”
Natural Coordinates: Given
0.2 0.2
0.6 0.2
0.2 0.6
End gausspoints
GaussPoints “Board elements” ElemType Triangle “board”
Number Of Gauss Points: 1
end gausspoints
GaussPoints “Legs gauss points” ElemType Linear
Number Of Gauss Points: 5
Nodes included
Natural Coordinates: Internal
End Gausspoints
ResultRangesTable “My table”
# el ultimo rango es min = res = max
- 0.3: “Less”
0.3 - 0.9: “Normal”
0.9 - 1.2: “Too much”
End ResultRangesTable
Result “Gauss element” “Load Analysis” 1 Scalar OnGaussPoints “Board elements”
Values
5 0.00000E+00
6 0.20855E-04
7 0.35517E-04
8 0.46098E-04
9 0.54377E-04
10 0.60728E-04
11 0.65328E-04
12 0.68332E-04
13 0.69931E-04
14 0.70425E-04
15 0.70452E-04
16 0.51224E-04
17 0.32917E-04
18 0.15190E-04
19 -0.32415E-05
20 -0.22903E-04
21 -0.22919E-04
22 -0.22283E-04
End Values
Result “Displacements” “Load Analysis” 1 Vector OnNodes
ComponentNames “X-Displ”, “Y-Displ”, “Z-Displ”
Values
1 0.0 0.0 0.0
2 -0.1 0.1 0.5
3 0.0 0.0 0.8
4 -0.04 0.04 1.0
5 -0.05 0.05 0.7
6 0.0 0.0 0.0
7 -0.04 -0.04 1.0
8 0.0 0.0 1.2
9 -0.1 -0.1 0.5
10 0.05 0.05 0.7
11 -0.05 -0.05 0.7
12 0.04 0.04 1.0
13 0.04 -0.04 1.0
14 0.05 -0.05 0.7
15 0.0 0.0 0.0
16 0.1 0.1 0.5
17 0.0 0.0 0.8
18 0.0 0.0 0.0
19 0.1 -0.1 0.5
End Values
Result “Gauss displacements” “Load Analysis” 1 Vector OnGaussPoints “Board gauss given”
Values
5 0.1 -0.1 0.5
0.0 0.0 0.8
0.04 -0.04 1.0
6 0.0 0.0 0.8
-0.1 -0.1 0.5
-0.04 -0.04 1.0
7 -0.1 0.1 0.5
0.0 0.0 0.8
-0.04 0.04 1.0
8 0.0 0.0 0.8
0.1 0.1 0.5
0.04 0.04 1.0
9 0.04 0.04 1.0
0.1 0.1 0.5
0.05 0.05 0.7
10 0.04 0.04 1.0
0.05 0.05 0.7
-0.04 0.04 1.0
11 -0.04 -0.04 1.0
-0.1 -0.1 0.5
-0.05 -0.05 0.7
12 -0.04 -0.04 1.0
-0.05 -0.05 0.7
0.04 -0.04 1.0
13 -0.1 0.1 0.5
-0.04 0.04 1.0
-0.05 0.05 0.7
14 -0.05 0.05 0.7
-0.04 0.04 1.0
0.05 0.05 0.7
15 0.1 -0.1 0.5
0.04 -0.04 1.0
0.05 -0.05 0.7
16 0.05 -0.05 0.7
0.04 -0.04 1.0
-0.05 -0.05 0.7
17 0.0 0.0 0.8
-0.04 -0.04 1.0
-0.04 0.04 1.0
18 0.0 0.0 0.8
0.04 0.04 1.0
0.04 -0.04 1.0
19 0.04 -0.04 1.0
0.04 0.04 1.0
0.0 0.0 1.2
20 0.04 -0.04 1.0
0.0 0.0 1.2
-0.04 -0.04 1.0
21 -0.04 -0.04 1.0
0.0 0.0 1.2
-0.04 0.04 1.0
22 -0.04 0.04 1.0
0.0 0.0 1.2
0.04 0.04 1.0
End Values
Result “Legs gauss displacements” “Load Analysis” 1 Vector OnGaussPoints “Legs gauss points”
Values
1 -0.1 -0.1 0.5
-0.2 -0.2 0.375
-0.05 -0.05 0.25
0.2 0.2 0.125
0.0 0.0 0.0
2 0.1 -0.1 0.5
0.2 -0.2 0.375
0.05 -0.05 0.25
-0.2 0.2 0.125
0.0 0.0 0.0
3 0.1 0.1 0.5
0.2 0.2 0.375
0.05 0.05 0.25
-0.2 -0.2 0.125
0.0 0.0 0.0
4 -0.1 0.1 0.5
-0.2 0.2 0.375
-0.05 0.05 0.25
0.2 -0.2 0.125
0.0 0.0 0.0
End Values
Type: model/mesh
Url : [http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120618/699036fd/attachment-0003.msh](http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120618/699036fd/attachment-0003.msh)
Result “DISPLACEMENT” “fem2012 analysis” 0.0 Vector OnNodes
Values
1 -0.06530442428959876 0.021087965274026923 0
2 -0.07516083328194616 -0.09257111947294568 0
3 -0.006726095571417504 -0.1 0
4 -0.014398957914989765 -0.02100452106234868 0
5 0.0 0.0 0
6 0.0 0.0 0
7 -0.06533998321916969 0.011701923255767884 0
8 -0.06568185860063824 0.002630665731381559 0
9 -0.06664127185271522 -0.006450709950278544 0
10 -0.06826358852523622 -0.01616826905094996 0
11 -0.07022346572057646 -0.02685952796438563 0
12 -0.0721597919268168 -0.0388979672009548 0
13 -0.07379270794106735 -0.051867268648943504 0
14 -0.07480125130954844 -0.06551505777573263 0
15 -0.07512944539922767 -0.0792386049440831 0
16 -0.05875051978472112 -0.09264566795048003 0
17 -0.04257400490635227 -0.0935886223483477 0
18 -0.02562273337582429 -0.0959138623313791 0
19 -0.006451044123616605 -0.08165254256514982 0
20 -0.00770429172145177 -0.06905319717058117 0
21 -0.008696619264028786 -0.05938589724407238 0
22 -0.009491395875796739 -0.05164925515696277 0
23 -0.010167021062368678 -0.04533932131140984 0
24 -0.010769365773847682 -0.040123822515720796 0
25 -0.011311043668996304 -0.03577369318257309 0
26 -0.011803701700654602 -0.032107490403418724 0
27 -0.012270331887296636 -0.02896061278082244 0
28 -0.012767879811063997 -0.026164123770246427 0
29 -0.013446548737939263 -0.023571338248076345 0
30 -0.014582091203585525 -0.019530584015369428 0
31 -0.014224729409350866 -0.018591444964215567 0
32 -0.013573725285020832 -0.017712088123238722 0
33 -0.012652301691696953 -0.016771429491574712 0
34 -0.01147914547031768 -0.01571003287842184 0
35 -0.010062661124582309 -0.014479756008958365 0
36 -0.008412626926698981 -0.01303216203540543 0
37 -0.006562988109476511 -0.011299696468462959 0
38 -0.004656176216175088 -0.009193627165170906 0
39 -0.002830291055991856 -0.006643268926231708 0
40 -0.0013085195825274136 -0.0036103721434102946 0
41 0.0 0.0 0
42 0.0 0.0 0
43 0.0 0.0 0
44 -8.682833300529967E-4 0.0030048828021251826 0
45 -0.0030699284795294313 0.006155647497975824 0
46 -0.006615101383871536 0.009403188987694851 0
47 -0.011762426419466534 0.012469421349588644 0
48 -0.018564103220462494 0.015432054026448296 0
49 -0.026807271107096454 0.017823631720032318 0
50 -0.036068665334399015 0.019582691102814614 0
51 -0.045879633988298266 0.02067959575545958 0
52 -0.055757814932381515 0.021048390039306974 0
53 -0.040605676480937866 -0.02555227124973764 0
54 -0.015806891432960376 -8.820610058238372E-4 0
55 -0.02882496545592005 -0.024615932387259044 0
56 -0.015983136455412696 -0.009606930995301471 0
57 -0.03752667849010215 -0.05313958594945131 0
58 -0.00474557100798906 -0.003093327643018229 0
59 -0.03334130407803441 -0.004515854053253843 0
60 -0.02233823192745347 -0.01648142762458418 0
61 -0.02548914064556007 -0.03850069447289454 0
62 -0.010106431191223602 -0.009732517107961348 0
63 -0.021389331213186324 -0.023884486931406074 0
64 -0.01573338829561698 -0.014688591023381775 0
65 -0.018343640006511754 -0.029626305343046 0
66 -0.01267953518320005 -0.014474837097636969 0
67 -0.030900697170033915 -0.015989223427312647 0
68 -0.05112490546110908 -0.011167251860903185 0
69 -0.029094659567312785 0.004504988795242417 0
70 -0.04878999161982404 0.003686490440312239 0
71 -0.035232041260747714 -0.03315435435721912 0
72 -0.0459601419743515 -0.03987999638753568 0
73 -0.012028022529810563 -0.006490936260794923 0
74 -0.009599515811096184 0.001752666992890583 0
75 -0.01831489988519211 -0.022752571557926524 0
76 -0.01733754129242773 -0.0175605003135342 0
77 -0.0144311327805403 -0.016980533069842325 0
78 -0.0243648542187672 -0.051906236920276745 0
79 -0.005659396469309708 -0.006863525501333633 0
80 -0.02027494208279912 -0.03895047667171925 0
81 -0.009891047548042315 -0.011512606838235613 0
82 -0.030538466346398844 -0.06987345610029609 0
83 -0.02476232559413629 -0.02918363097680579 0
84 -0.013753418920645402 -0.011646281442924839 0
85 -0.004541124204104882 0.0028453522106863588 0
86 -0.05144323812206127 -0.058705732759631354 0
87 -0.054598559535814155 -0.027199801929428127 0
88 -0.03150202384819692 -0.044455341537936045 0
89 -0.008428757356980586 -0.0056060237798275766 0
90 -0.024105891024252202 -0.020624199340624396 0
91 -0.01800956035599815 -0.01318934314362016 0
92 -0.04199637268889651 -0.015528612533601506 0
93 -0.025997173610632626 -2.3331488480296078E-4 0
94 -0.01744842562875654 -0.026875779633429395 0
95 -0.0356550652163625 -0.023261246402081555 0
96 -0.01739267365806037 -0.004499434331700604 0
97 -0.019598754224031897 -0.04864672671810518 0
98 -0.006951216698822496 -0.009118049518910437 0
99 -0.043248694340028974 -0.07112595402905948 0
100 -0.001276398672134417 3.918238600808728E-5 0
101 -0.020321981023785015 -0.01923776555325968 0
102 -0.015114032918523661 -0.017977438940057426 0
103 -0.01790632998238114 -0.06549726181113621 0
104 -0.002758022335713772 -0.0056794408981874454 0
105 -0.03619838999204381 0.0017843090066523729 0
106 -0.026587520876122418 -0.013720386430409433 0
107 -0.05812486470939522 -0.005250155830696992 0
108 -0.03684454820954396 0.009926907105781932 0
109 -0.016623111349957826 -0.020191428180341454 0
110 -0.02869240007123669 -0.0189572345039021 0
111 -0.015489396816995092 -0.03500428540043609 0
112 -0.011339286276277533 -0.014411169067151843 0
113 -0.030619973235466884 -0.0319443327775119 0
114 -0.013613310793402889 -0.008583835120309028 0
115 -0.013514244683444102 -0.01686870022658135 0
116 -0.0014848259202553569 0.002384043650151704 0
117 -0.0632835292649669 -0.07497872930910228 0
118 -0.01695974557516793 -0.02501024165120504 0
119 -0.049863768495694225 -0.021359860441665032 0
120 -0.02001147813828598 0.004696675923953874 0
121 -0.017368174646621878 -0.015420890272561787 0
122 -0.056563421886991 0.011950025905023769 0
123 -0.04175438392671651 -0.03394248697013264 0
124 -0.0111809639964324 -0.002304359611359507 0
125 -0.01969460200280671 -0.025260812611432693 0
126 -0.016496934651314712 -0.05689017718127653 0
127 -0.00470804046589515 -0.007931941819604766 0
128 -0.00844685316564461 0.0056531749686815035 0
129 -0.015840669026081614 -0.016702906660758965 0
130 -0.02576695815843828 0.009939729583058747 0
131 -0.015186424297673938 -0.031199353268453762 0
132 -0.015099538267392153 -0.04468985224278253 0
133 -0.008358370843236313 -0.011660563368094323 0
134 -0.014093858017166457 -0.014525412053473841 0
135 -0.03840983472349401 -0.043508894683570415 0
136 -0.007275659171886789 -0.0023696858943029037 0
137 -0.025514967881320672 -0.01720014797291854 0
138 -0.021589015127162176 -0.012654470813339959 0
139 -0.033430144776504384 -0.027305952696483102 0
140 -0.01545974931823377 -0.0077885978551320775 0
141 -0.023877012574091146 -0.025123492675232964 0
142 -0.015981182703605178 -0.012161888319067761 0
143 -0.025160135748503808 -0.03331056677159187 0
144 -0.011716326562479536 -0.011419005176358946 0
145 -0.015809727439098687 -0.022060665616408456 0
146 -0.01944841255338691 -0.07564000143856685 0
147 -0.0015117901548973981 -0.0038862256121795654 0
148 -0.014191539997512282 -0.017984749917137235 0
149 -0.03567062442785474 -0.011995261051305058 0
150 -0.02720020542792293 -0.004679472498197608 0
151 -0.049037925004794196 -0.048119314906304965 0
152 -0.0059913595859838 4.1447258018336206E-4 0
153 -0.012559748579642805 -0.015685530358140295 0
154 -0.02749671042509362 -0.009422586827928002 0
155 -0.01974421678811999 -0.016819693913913396 0
156 -0.04600435512958428 -0.028753532620001798 0
157 -0.01400832536459818 0.0030030741766826287 0
158 -0.031109820635998164 -0.0382137600040556 0
159 -0.010754061377088987 -0.007984289686026661 0
160 -0.025433275686280857 -0.04442941108359025 0
161 -0.008165743454237288 -0.008189459231454338 0
162 -0.057739693531708915 -0.015498335994373887 0
163 -0.02766698388013505 -0.06068354724294219 0
164 -0.0026746143310722695 -0.003959638179967068 0
165 -0.021017688563089672 -0.02764698854692983 0
166 -0.031144466326099695 3.69560143603064E-4 0
167 -0.012813919584461228 0.0060729195650791575 0
168 -0.051838434405716276 -0.03328979510762171 0
169 -0.021006738145655443 -0.021786771236631253 0
170 -0.05733304930410386 0.003299943173948524 0
171 -0.03659220062300941 -0.01873929974563942 0
172 -0.021764401915760713 -0.004392829713229342 0
173 -0.04250508990284685 -0.008176720574259173 0
174 -0.03765527391356591 -0.030058043520629747 0
175 -0.014102086996975825 -0.005242723536576355 0
176 -0.012411982212718305 -0.009842121980893065 0
177 -0.013656590711344719 -0.015755704574049477 0
178 -0.014850545494743099 -0.013256542765677495 0
179 -0.015351685036795466 -0.03957331810023793 0
180 -0.009926862721980527 -0.0130820424988298 0
181 -0.02002541322585978 -0.044215975734306925 0
182 -0.008229852942844344 -0.010090568523928537 0
183 -0.01505559785933924 -0.028171358394424275 0
184 -0.05952922455806428 -0.03997595470632655 0
185 -0.01581323915321249 0.008835842871641025 0
186 -0.015390936866474627 -0.05030569073587682 0
187 -0.006614013169298261 -0.009969428027540054 0
188 -0.034358693001199155 -0.08013956926103784 0
189 -3.713182346619768E-4 -0.0011967186538037015 0
190 -0.01683088270334063 -0.013782709416864733 0
191 -0.01488101359890364 -0.020146293757282073 0
192 -0.05183615532556956 -0.08076804667262498 0
193 -2.0642206823376187E-4 2.1163848101776611E-4 0
194 -0.02026402801067704 -0.033191359430857714 0
195 -0.011441865781126014 -0.01305301926566708 0
196 -0.0034325469853369104 -7.589776828181062E-4 0
197 -0.02075838668363985 -0.08386190636594318 0
198 -8.834789181027692E-4 -0.0027205521838628262 0
199 -0.04733680434527722 0.011675423154856457 0
200 -0.031224191148066772 -0.05006681651809417 0
201 -0.006088696833798211 -0.005003152560181231 0
202 -0.01303494902208263 -0.01304057180623985 0
203 -0.018067863146922363 -0.01986407979667394 0
204 -0.005907537200976892 0.006762528391103653 0
205 -0.06239822503377658 -0.05455422110851753 0
206 -0.03370140800163007 0.005268201002804514 0
207 -0.022202597557257835 -0.01868624210586667 0
208 -0.04197535865021255 -0.020035291549718427 0
209 -0.020758421817255752 -3.3546541597337636E-4 0
210 -0.014963676656057821 -0.01574669313887376 0
211 -0.031817341425584636 -0.0211281502848289 0
212 -0.01825396429194435 -0.007773417587110541 0
213 -0.03684056860561263 -0.037195260873551524 0
214 -0.010561407362551343 -0.004827391748568356 0
215 -0.027858636774317908 -0.02854618791556743 0
216 -0.014874136745983639 -0.0104431380632669 0
217 -0.014560329975080043 -0.01907441352940952 0
218 -0.027204027230276803 -0.021271123809192213 0
219 -0.017786668623469212 -0.010971281404649551 0
220 -0.03905176615790837 -0.0030119336979892368 0
221 -0.01593231322152721 -0.019061218163975747 0
222 -0.02198711184708157 -0.029754090789026508 0
223 -5.4279442275549896E-5 8.925241349282034E-4 0
224 -0.0627301288815876 -0.08593316385756235 0
225 -0.041775431266063534 0.003357852110168316 0
226 -0.016331748562396237 -0.015711622948057995 0
227 -0.06108777717611813 -0.026734980260965914 0
228 -0.0194231284700813 0.01153488191116827 0
229 -0.05183872817083182 -0.06907231880837017 0
230 -0.002369959860895024 0.001128879958120274 0
231 -0.018967014951095405 -0.014550339775390466 0
232 -0.06311523772079908 -0.06666956397566572 0
233 -0.003518877154933921 0.004641176029320561 0
234 -0.0015733660136199098 -0.0013492394819193383 0
235 -0.04099762561074379 -0.06389251755581814 0
236 -0.048807099256236455 -0.0044489293856914604 0
237 -0.033208207714642675 -0.018404984219715054 0
238 -0.02214458416115956 -0.008383609104527411 0
239 -0.015250432694869169 -0.025421454954657422 0
240 -0.043048133889744246 -0.001177734697205014 0
241 -0.04648241610576559 -0.013619763878137335 0
242 -0.025195928099582033 0.003105291290232378 0
End Values
GaussPoints “Triangle\_stress\_gp” ElemType Triangle
End GaussPoints
Result “CAUCHY\_STRESS\_TENSOR” “fem2012 analysis” 0.0 Matrix OnGaussPoints “Triangle\_stress\_gp”
Values
1 -0.08142947925478541 -0.45238599585991895 0.011279982267049364
2 -0.012544214753530358 -0.017674583809766053 -0.011693185350975294
3 -0.036590518308051365 -0.7833484976453609 0.01928559696632802
4 -0.013761906166634984 -0.03137854713280701 -0.022090667751865727
End Values
GaussPoints “Triangle\_principle\_stress\_gp” ElemType Triangle
End GaussPoints
Result “CAUCHY\_STRESS\_TENSOR” “fem2012 analysis” 0.0 Matrix OnGaussPoints “Triangle\_principle\_stress\_gp”
Values
1 -0.08108679604940855 -0.45272867906529585 0
2 -0.0031381522574005487 -0.027080646305895864 0
3 -0.03609278474251887 -0.7838462312108934 0
4 0.0012117857011309137 -0.046352239000572906 0
End Values
GaussPoints “Quadrilateral\_stress\_gp” ElemType Quadrilateral
Number Of Gauss Points: 4
End GaussPoints
Result “CAUCHY\_STRESS\_TENSOR” “fem2012 analysis” 0.0 Matrix OnGaussPoints “Quadrilateral\_stress\_gp”
Values
5 -0.23154840862841608 0.006526742600461509 0.0735099567543735
-0.19102474849032697 -0.005776134908346872 0.06282673731411562
-0.23567008185076183 -0.015477883133251952 0.05317153796731797
-0.1862983199437112 0.016956786615117313 0.08384582909450689
6 0.10719798228715656 0.44112632418352143 0.06450992586659929
0.11085565613730584 0.394483318973501 0.1121991991627863
0.09697589392493933 0.3598488508028099 0.079246327462113
0.12371245998882949 0.4813222445623784 0.1044265464034835
7 0.20899979669166613 0.2785226686680533 0.16284339776575774
0.15964476153903084 0.35338246534155476 0.13947753611394131
0.22287083655936332 0.37388132111444866 0.18401401352684602
0.1495035334206276 0.2569000001454639 0.12064148447479792
8 -0.08892131057733695 -0.021205323623429057 0.056899027163278916
-0.08810822033868956 -0.0034341868939949446 0.05097660251048304
-0.0853182754638668 -0.0017734767801942438 0.05835729528611818
-0.09154958644229538 -0.02240282044733717 0.049774636958157946
9 0.3606360131236599 -0.003465558410076175 0.012539670808446146
0.27112597334181116 -0.002614165447138911 -8.701305919229333E-4
0.2816185020936435 -0.025156865337599157 0.032665811537388685
0.361398948743527 0.02171359529120718 -0.02321746597932023
10 3.0270162051648786E-4 0.9608493543173807 0.021887715470470488
-0.0011362864206753698 0.8542595885594398 -0.01221328114564081
0.022611787531456762 0.962824451221427 -0.03008722334290446
-0.021936457701879353 0.8579373891628632 0.03818793517821222
11 0.5628069972952183 0.4016097875480892 -0.32254577400098244
0.5371181823078142 0.320798379330339 -0.2939001805551238
0.5741532750842367 0.36010923360773817 -0.3221356265848815
0.5223073904139884 0.358726487309758 -0.2916867532289209
12 3.69754566740637E-4 0.10438947871999489 0.19699833463933278
-0.05126229653610127 0.09222162493108278 0.185053058562593
-0.03049935807414951 0.10146791652435683 0.20368650097120955
-0.012521754155849184 0.0969746743542433 0.18011122092815487
13 0.013651801245250478 1.0825593668881899 -0.03187313268728533
0.006324777354537431 1.0703478328916316 -0.0384114420078549
0.00791211491371796 1.0811688159813413 -0.03631989861020028
0.012106537859762734 1.0726746964540768 -0.03385560684014364
14 0.5238086993166885 0.010043731038305359 -0.04689369093213393
0.5816579685655489 0.0063532606458819585 -0.03778820243758124
0.5747956404182284 0.022141748303875372 -0.05757044785690382
0.5233503658179811 -0.00838915713198786 -0.024473007424816808
15 0.022157548222070722 -0.14984177952932418 0.02381454847635423
0.03461686703891191 -0.28174837932140523 0.013014711593311978
-0.016682395701875314 -0.25150153005401255 -0.015149040233298813
0.08409981412162798 -0.17580800333050384 0.05931632040000427
16 0.32273243947548436 0.10152364530678057 -0.14545981215635923
0.40332265488549807 0.17106991124557103 -0.1991506392896216
0.3207964344969256 0.15471607233435275 -0.17494354568047082
0.4040435446088988 0.11995085941457309 -0.17060853238764984
17 0.07084090176139524 0.7486684190221339 -0.07016628782167574
0.11266404986816947 0.8089982306415916 -0.11752180634862751
0.09014841873429724 0.8298834646568811 -0.08702569742891324
0.09101961850773187 0.7197040421534721 -0.09845767637257666
18 -0.004693693327830845 -0.46380009219003887 0.018200902733087214
0.00993299846503369 -0.5113632966780726 0.06279332717420753
0.09142429785546903 -0.46372385362042545 0.017246705624671742
-0.04328884979818905 -0.4957163407175684 0.04856815027147912
19 -0.11801802702620026 0.083886754632882 -0.08590002352174012
-0.09970488357677426 0.1847785337272535 -0.08924187800690793
-0.1123413051190325 0.1238879417719419 -0.06632802162684269
-0.10733851237688966 0.13486904657543067 -0.10639567408434683
20 0.26215146550178664 0.4975670694863949 0.13321018991688083
0.17637328555503468 0.3980477872200932 0.06901014376008416
0.18176981056854058 0.47780854620058316 0.09225117886861198
0.23708657811088513 0.41427789583443825 0.1002882691617747
21 0.19164650659798999 0.004837079852757317 -0.04904869155140082
0.2018794414423056 0.03402639917880727 -0.058941501427893374
0.19192272590707266 0.021258966492482708 -0.049186351831850356
0.2005831560401486 0.015118216824874929 -0.05781417620873869
22 -0.041825810246627015 0.641291597598894 0.04962925034919404
0.05328238652649876 0.749487412935449 -0.04414466954130932
-0.008414047523034124 0.7618136399643681 0.017598761697178673
0.002020421445503698 0.6121099550916932 0.005523767439978855
23 0.5346177295285546 0.7640262803102483 -0.03327799793436439
0.39674764619748965 0.7594200437011283 -0.01694926694109979
0.4245843895555842 0.713495248448334 0.013916821744019828
0.49678479217565796 0.8068206960388308 -0.06092125501466569
24 0.28974636691294314 0.5858779404781129 -0.1634958353585476
0.25197690068862716 0.6495552057549372 -0.14309940284560618
0.2408826944064337 0.5838920707968747 -0.12850256650290556
0.29781297961030545 0.6854175724183462 -0.17939253173022615
25 0.4229469700421743 0.4983393110604014 -0.0068557538217731175
0.31973199066344454 0.4828720940563758 -0.013578376714987224
0.34532833445538574 0.4774097625699246 0.022586678567680842
0.3753746388438566 0.49832690223304665 -0.03635813484990116
26 0.10089042432502508 1.0680789191347664 -0.1643692104135951
0.1375245578750623 1.1232178799374606 -0.20420739276067676
0.11709540917336178 1.1340264507597182 -0.17891650408795526
0.11965161021023346 1.0510301070215182 -0.18812223602296949
27 0.13797192941506664 0.13097082973787097 0.0701621330069099
0.1599778004300513 0.09922203261804942 0.03325735095275199
0.09041323554387715 0.09584442954178936 0.0330848737255244
0.22855895979769808 0.13594463689404698 0.07103485917961548
28 0.10435872886736743 0.10604193762550443 -0.16437668276621437
0.0192688920972499 0.0632144629305482 -0.12267889960133724
0.0935488915998241 0.06741720667026489 -0.12624642650834778
0.03017151891465811 0.09158440141050864 -0.1506620817163215
29 0.0556263462396653 0.36862254986588716 -0.021403088901360896
0.04345444088422694 0.25379735757204996 -0.00993846432042698
0.03392601189260536 0.2855240622452378 -0.04333417938314059
0.07271373022441664 0.3517029459001153 0.024557955580028257
30 0.049684301131188296 1.3400276576006798 -0.12653928043575005
0.046182882646947254 1.3801414810232076 -0.11873230542465678
0.03691902337444361 1.3393832789057323 -0.1107501648412917
0.0576189565310353 1.3763603642303575 -0.13325338405476836
31 -0.13150404556052248 0.19365909062812328 -0.011698860948831382
-0.1092500966581261 0.157964656389154 0.015118529686879531
-0.1309320290687322 0.1448045833351736 -0.008555360028059093
-0.10612907658090248 0.22080554238403668 0.01540606116284232
32 0.10677713677301917 -0.1706577533697674 0.11307135065379217
0.08654840216103785 -0.06737084302380683 0.11113081139914055
0.14592713937544052 -0.06993144047434778 0.15147018484307997
0.05734630489867086 -0.16380505523722846 0.08003420441633907
33 -0.05597967024391323 0.2363321268920043 -0.06493440331492482
-0.07040622564146676 0.15735936637225825 -0.06935715036248859
-0.06330718151952255 0.2016959434419209 -0.08400626320548128
-0.06444042645254426 0.18432460653945787 -0.050036674068716334
34 0.10076331911424466 -0.10321217957962735 0.04889239837624116
0.0774633234717851 -0.003155194340389777 0.06978318556131281
0.14732502293976535 -0.016795782835829817 0.09340116916446568
0.02608267071309165 -0.09713129795729135 0.021084822235221113
35 0.20601578932972497 0.5364484857489712 -0.12079623383493948
0.14827605754522682 0.43605748242834536 -0.06938566120282497
0.1955585648818223 0.45932534923704965 -0.10562469248063283
0.14420283596045577 0.5193196982618958 -0.07474193274621645
36 -0.0025375702288857674 0.18714158861482455 -0.10090580850539212
0.012523842584917788 0.1864241570991461 -0.12741122814348885
0.014126790071381248 0.22918206345523703 -0.1209526953198924
-5.843595735840618E-4 0.159348966957981 -0.11034383614663196
37 0.1367100508860668 0.2017278300769297 0.042099198695439724
0.11631634073097942 0.2677024688001627 -0.0033003843238086123
0.082825008979972 0.22106856337086736 0.033526932579003924
0.19309456647518095 0.24185171128868854 0.007687056109900587
38 -0.019295750014425676 0.23291295165222162 -0.06296251547063096
-0.004843605459348026 0.29995987364648635 -0.051477621024596625
-0.00993331020811674 0.25297390824094046 -0.042527970502745614
-0.015060550951414807 0.27546564427463466 -0.07233048163022802
39 0.21416249511916222 0.065399980411748 -0.11626479785757672
0.162199878215188 0.06478492265088358 -0.13047395696020406
0.1581472677339013 0.053071845929264595 -0.10694775948865977
0.21969293330510944 0.07584184856719015 -0.13666540438204658
40 0.05691794560916223 0.5908627299602209 -0.002859597764264191
0.048644273194973275 0.4628334070156631 -0.046058241530475406
0.07630589263356616 0.601785412679516 -0.06213253083394925
0.027198092015808494 0.44691913307130543 0.017379622766744398
41 0.2048709618130291 0.5911113193577903 0.007137965296051493
0.23096087407415533 0.5449590980228233 0.029593137592793247
0.20212741059640416 0.5310867692767839 0.0032695450792026744
0.24290440813686665 0.6349836971312538 0.042454778119756495
42 -0.11080288821188307 0.02131720527978653 0.1702955222991312
-0.16085548993016566 -0.027346942013270308 0.1354877273184961
-0.15367761359628967 0.011101412176811667 0.15467958851456168
-0.11663877531357926 -0.017237001200660622 0.15140039373842012
43 0.36512131745727705 0.0016407714741493024 2.3164502372947758E-4
0.32236325526986176 -0.0014345979181761628 -0.009764919257391933
0.32921352600939396 -0.006389624716672336 0.006796798993582276
0.3643218262871868 0.007601083799277 -0.016480962297148537
44 -0.004813391277013357 0.9671205132429586 0.015402765458558336
-0.004603597553283045 0.8649738055953492 -0.009491708821522242
0.018215189635606782 0.9666336666025873 -0.027311974071511137
-0.024941526059447994 0.8792624095723819 0.03155713203894627
45 0.0047504359796608775 -0.251359741825107 0.09814871225121677
-0.008617195948812148 -0.16362045777986173 0.08236202384185838
0.023577379747863288 -0.16606831804763186 0.11567258896510457
-0.029995992478347517 -0.2552528508151764 0.062345207443764504
46 0.043675271618600416 0.28211169748640064 0.027110774087236843
-0.022739393134583362 0.24404254751684587 -0.029280239833699293
0.018183059273911478 0.3349940584783902 0.00926218207024651
0.010970931134088969 0.20039548052608055 -0.004199370416795506
47 0.4214071701083801 0.005171597014865664 -0.01925632743218051
0.425012756353801 0.0011637180672819103 -0.019610703388191965
0.4257200577776417 0.006458706648560422 -0.021415350141060496
0.4205159552814247 -1.40135690388829E-4 -0.017370496865925008
48 0.007099189939390571 0.9946889602827831 -0.001874593810859116
-0.0015652294843140901 0.9510629447616447 -0.019323995942777214
0.006042247787398675 0.9936345766904593 -0.02013939882777315
-4.128643541101429E-6 0.9547841495892034 -5.291607080818117E-4
49 -0.060740692857751306 -0.06952400399834804 0.12696152107946707
-0.07591892955497426 -0.039485206559559005 0.12494222714944166
-0.051235796239019006 -0.03362809940708855 0.13922026657717274
-0.08376281892186925 -0.07394218020109353 0.11385426399578798
50 0.04600512382003954 -0.21066424521999735 0.04579049345375571
0.03664128837092989 -0.36113215324857917 0.08019780862476593
0.0035152743210111193 -0.3877806035218196 0.006887592316943104
0.06845438775875488 -0.2231789057702982 0.10726476177241678
51 -0.13268511052096885 0.0649431222916386 -0.13456420493920915
-0.1804574621004287 0.05373471762607862 -0.07835867059580412
-0.1713172487399529 1.739117307470589E-4 -0.09314741100660505
-0.13290850971042198 0.14507323727184918 -0.12849333965730386
52 0.15957605883829615 0.5441346376916615 0.02382707028994511
0.1338892697328956 0.4506498457226285 -0.0017474118068783295
0.139721338101554 0.5324397563506318 -0.011961648431288458
0.1527946614801533 0.4757211928492176 0.02864379889392475
53 -0.03626789892939308 -0.0714266125095213 0.1653718220977655
-0.03519992086053272 -0.14304872373838962 0.1732061435932518
-0.0535841334328726 -0.13983052798532222 0.14981329884666478
-0.01145512018297798 -0.07195082269450297 0.19659843482964384
54 0.6433553960386429 0.9793929647721074 -0.258040135472863
0.5387738412687184 1.0547516629058429 -0.24985937837689154
0.5350211268665956 0.9516048189207038 -0.21161620529466443
0.6943743421230069 1.1314487043943389 -0.3297261770004551
55 0.09828472787502956 0.35780429708418005 0.1722942381586357
0.058592328790934886 0.20730074561753833 0.13184051936237243
0.061873968059536454 0.2971768179979245 0.10858313592229087
0.08415115182126806 0.24355134106568582 0.17872991488514214
56 0.2441174253205646 0.13673487600268325 -0.17010641923973238
0.16571645943219487 0.08259493467335169 -0.12312870387301778
0.24251180777559908 0.09727055975877699 -0.14091388003912633
0.16564977626941393 0.12012655150330327 -0.15074666175633022
57 0.12372779575564913 0.582721521896251 -0.07776811297089935
0.05694805251916629 0.5174394129709099 -0.01820577158402455
0.09013086851134054 0.47384360815443327 -0.044529649896062264
0.08052275216834262 0.6094882638914628 -0.04220253796105353
58 0.2940807163253098 0.016558529029308197 -0.055427099145866666
0.28887940903443304 0.01692174118649733 -0.048368370253565794
0.30528861346729935 0.01930697408517075 -0.05101470444519994
0.2840024997590643 0.01519441781515845 -0.05324132236689359
59 -0.024913356538169534 0.7800367212552191 -0.008692335996937077
0.026694221163193768 0.8008744801532512 -0.03140121925777315
-0.004743336320685493 0.8051995137047787 -0.025194589170838673
-2.991551998023645E-4 0.7614669002387222 -0.0067474311941434625
60 -0.06628405277819979 0.27056888984512634 0.00975116388977955
-0.041114708056399274 0.2533507536890025 0.01787291932850277
-0.06534793223494537 0.24331045877993798 0.0038348470405998613
-0.04135195419447334 0.2843137979602137 0.024991897612349
61 0.16089887417794987 0.011688185878500585 0.12381111458387085
0.13809996706656136 0.08324951746536405 0.12849624281704394
0.19643410614029788 0.08733444392332734 0.1583810643845935
0.10873282854960287 0.009114499231608978 0.09732767014744143
62 0.056916859649476 0.2612789402822465 -0.10932282331370072
0.04717147867937703 0.23579862770751472 -0.11910874759578527
0.04154019186529119 0.25330499188760447 -0.12013907923782068
0.060567318444440355 0.2463558318826029 -0.10916781323635896
63 0.2442073739013615 0.3252089942196561 2.479031055153299E-4
0.16881955378066676 0.3120944391419982 -0.0050331196375430765
0.2004692867000328 0.3164575385995301 0.012839085094703297
0.2050464065847804 0.31943864638118147 -0.016772480195256973
64 1.4297721755056383 1.3382682199084484 -0.6315465283368868
2.135758933560982 1.2543507276564225 -1.024877953990738
2.182803932578739 2.6002882822284445 -1.2838660810128892
1.695970855760415 0.7910074081718644 -0.6910492381297143
65 0.41985371403023575 0.6217496646744944 -0.11140331740089719
0.41446591570247004 0.5466430524711241 -0.05708149482822353
0.4821096409685695 0.597762212942473 -0.10045771393816064
0.3605534934586582 0.5749914368105501 -0.0719850143742703
66 0.12324263461319918 0.32585354297622654 -0.12508484627763836
0.10935885190565366 0.33471114797353746 -0.13927182920187753
0.12479503686796392 0.35953753756158 -0.12403812367170133
0.11044922439251426 0.310874735183719 -0.1377975421594767
67 0.2549504966074082 0.3818337183096356 -3.3643998772236045E-4
0.26694085753950714 0.4008953052725164 -0.03353165689503112
0.22948270086249684 0.3887939126915621 -0.019956514598135865
0.29930238252722074 0.3980899656034546 -0.020071705712809317
68 -0.35847217575426227 0.024352438641726037 -0.003247141818801467
-0.46147471392059203 0.0038055886451899695 0.05034833267961401
-0.3401929597806834 0.02564558080325069 0.04930481998081734
-0.4663360390974317 0.004973989136743448 -0.003513723669370695
69 0.024256310223469427 -0.5016609416492851 0.030482538933674853
0.019665305132139377 -0.5789693511188649 0.07634900155922243
0.008549872972885453 -0.5902740643285411 0.02879055953082151
0.044178586575977855 -0.45077750320137466 0.08810560724906924
70 0.03932472847818457 0.026058633317856725 0.23120347548820036
-0.02362190067880655 -0.011523259402826898 0.19756115075132943
0.003263818528764756 0.03094170896704394 0.22278506982508306
0.014876482286727303 -0.01617823093374298 0.20677796656756697
71 0.3634087490313662 0.48733674875124117 -0.26414282840323494
0.37426957261927907 0.5467549446442229 -0.26764142233316784
0.36126346455743163 0.5046128823752347 -0.2464197301043294
0.37296313331235065 0.5186008982662158 -0.2795526420411376
72 0.024497474990517215 -0.20400467418003937 -0.10444851357827364
0.08781832700269646 -0.04272272537612939 -0.17182642991518354
0.03101374241031894 -0.11217859264602775 -0.1019246698339547
0.07585224624616115 -0.15941367011123395 -0.16993215345155066
73 0.6128595353842375 0.8697317046952011 -0.050793754253879594
0.6612251964194626 1.0729762934352731 -0.11081021961065918
0.5931339969434117 0.9579515422136141 -0.05152040431169669
0.707950014442668 0.9737403369798021 -0.12525232588958188
74 -0.005949633261535095 -0.383088007882462 -0.1204798421545957
-0.010900087202889375 -0.7356053500824148 -0.12784520515731307
0.2408643724215542 -0.25406928415307123 -0.38101285701307047
-0.1748212013009007 -0.7786749207238596 0.04672082517930804
75 0.0234196494638355 0.593171198389868 -0.0230311050301951
0.101417483723736 0.659695615834053 0.0666284171394692
0.0655181957068091 0.4713144235894455 0.037880103072595914
0.06920140424998382 0.7932228770598313 0.016820003827571723
76 0.6129369703277588 0.025409765577516077 -0.07649646058702352
0.7122986715872011 0.014241728314483754 -0.06584905028218219
0.7019730792302833 0.05033558557734839 -0.1006037697020864
0.6103023661009526 -0.014522861474927456 -0.03802985951722266
77 -0.021639420183822748 -0.07935553125055322 0.05679885992397015
-0.016649426482251328 -0.09323507755018846 0.05867806383872899
-0.02522715311223258 -0.09477116101682684 0.052588489514563554
-0.012695146894664201 -0.07777769239933549 0.06314596697230197
78 -0.002949489256088178 0.877816097701463 -0.014006315529546542
-0.024587030617574085 0.9505108134819317 0.001023321685394769
-0.06369502483572889 0.8565449744837341 0.03829371698769491
0.02279986377089499 0.960914617245612 -0.03949777424002023
79 0.18753845386811285 -0.017295581465387906 0.001808898812038628
0.34913142749349346 -0.03771473019774317 0.0034636846402706562
0.35906293010529355 0.04548978850769814 -0.0597997661126713
0.19407142126881413 -0.09923444029627876 0.06273053668265526
80 0.35172485257365305 0.41605410440849816 0.08003173767662833
0.3989866087779117 0.45441630747413775 0.03716033566743473
0.36951014319091197 0.5066148322655062 0.06157538898297057
0.37331259918233267 0.40129377163256297 0.06143460571058319
81 0.01484445848548363 1.1895190618223737 -0.06356050330352121
0.022720620149744936 1.1733989642676312 -0.0641895267162985
0.026469057343908836 1.1892704496056303 -0.06948094196537796
0.010391862259104101 1.1718355163376415 -0.05752304262699562
82 -0.03501073191288904 0.08627189800596387 -0.11449915825152927
0.0016623828732384369 0.18574677811381363 -0.15020522364429476
-0.043318849992897424 0.1359082047293673 -0.11145770801582462
0.0026281576635320825 0.12266955527838405 -0.14655079551962355
83 0.23957838305318596 0.3903927234803871 -0.19521389469116998
0.18225433458769696 0.4499649739867937 -0.16453476428767352
0.1551733532655566 0.3426253529281165 -0.1331260140169422
0.24518051265351637 0.4834596919099562 -0.21055859124363058
84 0.32815781272512745 0.4016151785244696 0.0022338471934327782
0.3273205840562946 0.4619628541814344 -0.03159277579125486
0.26955941804616596 0.41724872068613383 0.0040314255170171365
0.3768280338694179 0.43765147731640663 -0.026859937100440344
85 0.49293972522908563 0.0027904242452166106 -0.026607071560289085
0.46708430493674674 0.006783644004168629 -0.031732313096986944
0.4658428277219369 -0.003558765584046969 -0.02074250388565806
0.4925127859173665 0.012406597200949457 -0.03687814649013248
86 0.0010189805088416104 0.9964858222463511 -0.026067412329831667
0.008836634549747091 1.0283997448310258 -0.013077048080482387
0.0038067309212812817 0.99989432196177 -0.01334239881763904
0.006455372678339566 1.027203330226291 -0.02568766714600644
87 -0.1905461629419958 0.059741035447035934 0.06544504281385394
-0.18322460893688527 0.07925425943511161 0.11961158284450009
-0.19718774065201197 0.012694653227632378 0.09072971996230457
-0.17477254825306393 0.14104720126506484 0.08256063312220976
88 0.021959329883602816 -0.2153237824844161 0.1246224790678695
0.026007846887951692 -0.1665599501832637 0.16771973229207635
0.11254204336485772 -0.1728951582184981 0.16481417457416034
-0.022616622800537244 -0.20485497335119437 0.1324687827881158
89 -0.005270230840819925 0.07162212895021501 -0.15659820461891097
-0.06629452502175986 0.08475369683155841 -0.13876451349746713
-0.06257815980291052 0.03920122923248296 -0.12500780727829058
0.005306731648940813 0.1271299048998935 -0.17885387484093276
90 0.06403394816833959 0.09169690696619164 0.005944975242484121
0.06199300131880749 -0.03524485169996234 0.01552293873819494
0.031183040744759253 -0.012168747838541945 -0.025986004272000218
0.09977148659010901 0.08080256434156055 0.052569561382653396
91 -0.003515950955269992 0.6467668571857976 -0.03594218710659668
0.027100402639098367 0.7408838174763267 0.04744396412525792
-0.0036437031661833152 0.5859872827467962 0.026007661279938588
0.020293920288351378 0.7840018832642522 -0.03716234532906209
92 0.09924222433929675 0.0013939584581139954 -0.07507686183369389
0.06378449792633938 -0.033153084931377766 -0.11517127107555573
0.08016874169053473 0.032125194479293524 -0.10037493748385364
0.08151704919181794 -0.06116860104126787 -0.09169373581961916
93 -0.13514366791457752 0.08678706183633483 -0.1618281148549276
-0.20806152445003526 -0.012927519918487406 -0.09819761384813629
-0.13125306717373342 0.02544424926011558 -0.13526840241976784
-0.20831127258481733 0.04003310833093958 -0.12193074271061602
94 0.3797540150529269 0.02147528658888527 -0.06191754414284463
0.41101258232363197 0.03403134722533777 -0.07898586666809237
0.37904171051616414 0.02762977912216396 -0.0749965182354546
0.4119918565314303 0.02781891678786612 -0.06570727097652743
95 0.013038768970991599 0.8440055133631982 -0.020006585520306
0.030174884152674553 0.9057723998013106 -0.053764779066021215
0.025741181497737797 0.9130748643242196 -0.023703124035645094
0.016892861274925675 0.8343915980270918 -0.04912998495989504
96 -0.11638619459828324 0.15784135555528425 0.07851624464522466
-0.14395298155317948 0.1557918349660573 0.09468732208130648
-0.11264748665003024 0.16148949915026048 0.09598433181232563
-0.15314580140935732 0.1520422081548168 0.08219229357189646
97 0.07644375434968322 -0.07189398896193862 0.16284031863470982
0.08751487500705515 -0.1306188981972782 0.1822103245081426
0.0524809712631441 -0.16863610644435426 0.14151548893107085
0.10452768028858099 -0.05865633438426652 0.19704852818272223
98 0.10032351842668691 0.17646823769882072 -0.0325854618663084
0.11837370233472286 0.2491008224200382 0.019858839849757053
0.10133757308789958 0.16055298258087156 0.007068489183061369
0.12341394631486119 0.30603699222037245 -0.03278643455821516
99 -0.18090847363885545 0.12708991028864883 -0.03693202371631133
-0.17539956630743342 0.10655425499631 0.0026240017149005337
-0.19167011811843965 0.04376953950686733 -0.021651051195900082
-0.16646378042715682 0.17686129223864083 -0.010906450316432448
100 0.047500494654832526 -0.3633698461481046 0.06038451518415635
0.042649976357780284 -0.23666883619781323 0.09715071678828492
0.11835223931241923 -0.24538297748925608 0.12419277589124028
-0.027618286750917993 -0.3271448410046144 0.04196773078637925
101 -0.2699375711385381 0.005016301935792736 0.04501203966227805
-0.3775435569139304 0.01794619367035649 0.07628865290811443
-0.2753965779344992 0.03779766806315805 0.09095357475263052
-0.3807072571406552 -0.018353843380418407 0.026564712593255598
102 0.4252848905591594 0.8187356311438925 -0.2837891189613039
0.3595152479483653 0.5756995737078525 -0.22311303345694639
0.43055623993931147 0.7127195111748847 -0.3072085377416615
0.3683348143246566 0.7266458094254259 -0.21374893560285768
103 0.42207591168085357 0.8511338233899033 -0.25612810495487875
0.3779174018410258 1.0063471538790312 -0.300366699871449
0.3182866339165673 0.8869759047225428 -0.23639799534542047
0.48587745275703664 0.9797235937868423 -0.3248978906597463
104 0.34658616399376596 0.08355869032160679 -0.1370781021843668
0.2898447819687478 0.05972096439660315 -0.10807386396414652
0.34741335238297183 0.06993882111113738 -0.11361080527365715
0.28869466591640086 0.07231913650404687 -0.1298606030998456
105 0.07420122149552133 0.7659240279917715 -0.0797481767674659
0.04341784895429429 0.6872721811319981 -0.0310724697689858
0.05442800990853826 0.6683977142899263 -0.0674979573911317
0.06128238759621986 0.7812530971791191 -0.039766067806229925
106 0.1752223028902339 0.8676368733774239 -0.17006536946340844
0.12553793560058502 0.811920295122975 -0.12229479278526063
0.1506560336568607 0.780227131079131 -0.14627644875135046
0.1469494379293794 0.8918672523104811 -0.14303938918196396
107 0.0513091193029029 0.0540263009691887 0.218399394181926
0.0775982074774857 -0.005210808486686784 0.20841814664446412
0.020517496034794042 -0.009091853724525856 0.1863073339906827
0.10545423399020412 0.05956553499018656 0.2399869488113782
108 0.019831403137577003 -0.24139200773059638 0.16159769141891425
0.05246614386710347 -0.17169377660247115 0.20212097745560234
0.03684199879721073 -0.23220244712472354 0.18800719643738242
0.027135729305398912 -0.17298004568991776 0.16037949402571058
109 0.25184401596423983 0.1717058018106619 -0.17248973674904303
0.17354875672791162 0.20283341555843 -0.16684755675857993
0.17243629222403617 0.15012035944284421 -0.1425412201809334
0.251860705011466 0.2310131565521341 -0.19952398780362868
110 0.1326460912956356 0.4418439809769155 -0.030248175702980756
0.21982876717861416 0.46281522749131243 -0.06577554004845804
0.17208272542485153 0.48988381686772087 -0.060981994409939795
0.17407811977021664 0.4088602470184438 -0.030796654829112556
111 1.792180611020558E-4 -0.3156132405069326 0.06950672120575985
0.007034800176520278 -0.4091685460436315 0.10599012643372742
-0.019501977413055142 -0.417399048911324 0.057690969423573206
0.025730374237587346 -0.3003549343769989 0.11417205443667698
112 0.022626408450562935 -0.06261980734213506 0.20983884540172926
0.03313013045892578 -0.10949608607929084 0.1988731281827452
-0.006592456368745708 -0.10905205501086679 0.18401574571560944
0.056726141454871815 -0.06717423517461266 0.221263786825144
113 0.3760256886017562 -6.029988773237349E-5 -0.014994141153676406
0.38599813376489517 0.004555782890419274 -0.010241073519458329
0.38510757662036454 0.001145610272000927 -0.014182404216063715
0.37783657414911853 0.003637851477057044 -0.010776081216279227
114 -0.0016915581714436745 0.9139766794187614 -0.012280907191484837
0.0031284842884929387 0.9766119441756114 0.008179647177021408
-0.008020777208707058 0.9209120995575538 0.014917612991752703
0.01038842285752456 0.9759222515103798 -0.01861378825896814
115 0.01786280182871211 -0.7576573645100404 0.0043716736554740504
0.00677141367487849 -0.589129529156412 8.748163087616264E-4
-0.048967720861209915 -0.7552779747224935 0.05626377535351282
0.06181980147077536 -0.6495405419582982 -0.03765909592339479
116 -0.3746986522645094 0.02154875370205314 -0.07341966867979612
-0.2557808306768618 0.003907078540277803 -0.049403547966000924
-0.2611160928128758 0.04750433379599554 -0.09707671785034651
-0.37950795446734953 -0.02758531902846028 -0.020130005051541344
117 0.29021463058912184 1.2616279839442748 -0.3466782120859907
0.18978716426256753 1.158239716148513 -0.2643825153054945
0.24800876315690884 1.1277207729829535 -0.3030647815966746
0.2257395243199386 1.2798492960887715 -0.3022866766951559
118 -0.1135010473918695 -0.017059449324650845 -0.07175092893355964
-0.08905731285919315 0.005284741231067338 -0.055457584036433395
-0.09154243939175312 -0.008698629479049 -0.06216224405720427
-0.1103599070180829 0.0015709514703603628 -0.06286443463219618
119 0.05027154694834593 -0.6137750969536571 0.05545873418422774
-0.04849170227963963 -0.7615796925295796 -0.05701669679711149
0.012163629485976019 -0.5624993599123708 0.0012989906651873027
4.957027875135134E-4 -0.7662147716495534 0.006516667604159273
120 0.24970795592328027 0.6778982556204617 -0.14648249221020804
0.17885916644666172 0.6409132882092651 -0.10089921320856331
0.2151589611471238 0.6031124063096512 -0.11326492929898718
0.2092940548475167 0.7090951574976254 -0.13060688862986586
121 -0.04789844512605668 -0.014077084132183875 -0.05475121523825574
-0.05338276893842924 -0.06508157947746726 -0.07715686117080615
-0.11887583486800844 -0.04830156422549148 -0.08941422939078666
0.009756065980288876 -0.03120428667582007 -0.04492174501320683
122 -0.023679772555098497 -0.4189486646585696 0.005710948607899527
0.013744897001048403 -0.4116336693548991 0.009584513767603357
-0.0046779712881498126 -0.42014628648513225 -0.00856278530662312
-0.006535818837063556 -0.41165332107324576 0.020527516068177883
123 0.7153902993970743 0.16823164910475716 -0.2590087717964534
0.6885568685775749 0.12403834624567749 -0.23271300556537344
0.7261534791638113 0.14533622714663025 -0.25216689862514713
0.6834002766706412 0.150611752615756 -0.24267080822243103
124 0.06975386945155096 0.126457785222693 0.19736092545229017
0.029400486381038322 0.1991609138829031 0.1913584066471043
0.0980046684172724 0.23058743061565004 0.233643383773086
-2.226332045501718E-4 0.1117289250593201 0.15781545956508733
125 0.5589565518325577 0.0734748443167816 -0.16154017438661816
0.5843228634978718 0.11360795731805039 -0.18586414059911377
0.5525448293348254 0.09864186870265308 -0.17081038475875823
0.5982561519015431 0.09379302823679503 -0.1809472361131413
126 0.07423963089842679 1.0219060380867193 -0.12725999639741678
0.055972795531228234 0.979605556239816 -0.09834609011474207
0.06223762439637645 0.9653310840171851 -0.11881778685289843
0.06678780306514828 1.0309788145777654 -0.10580902914308517
127 0.5469571291290454 0.7119015893222344 -0.08842957730617976
0.5743728095410687 0.7594838868642027 -0.06277959929237786
0.5669430843633185 0.7006333505427822 -0.07111841600133008
0.5565263293253306 0.7524553760602672 -0.07875365666093004
128 0.7920561865818794 0.06856532588588696 -0.1469163547424076
0.8969659846563002 0.07506795710661025 -0.12324532697756081
0.8875005823573553 0.08974849777509114 -0.16352031726878313
0.7923312408849024 0.051634291980593286 -0.10451605512499783
129 0.4777852858577674 0.0549709901813354 -0.10998736503849098
0.44765348088159373 0.05292876676796378 -0.116787622863037
0.4501466249606686 0.0493002341606079 -0.10634026779885611
0.4752696731632126 0.05920757488442708 -0.1220264787739334
130 0.04060835136894009 0.9600946792143373 -0.05673291136881443
0.03405003072325652 0.8878938021229363 -0.0752622559234117
0.046677535534968284 0.9514398192951377 -0.08255439107386255
0.029262581162743856 0.9011700470084543 -0.05122214151766122
131 0.23125983594418834 0.03096851914496585 -0.07095050294896454
0.3067179719720076 0.05268514212996238 -0.09753840070599226
0.2380082492743707 0.04191130538916964 -0.09733420854440672
0.30147955205656995 0.03820887963184938 -0.06110341281908818
132 0.024592108375131733 0.6521194673279708 -0.011077731128006845
0.04861234474351146 0.7454597710970152 -0.04516876390998928
0.03602206632064897 0.743479448541315 0.006135006266088255
0.033611048269779537 0.6566246815783255 -0.0456303840795143
133 0.5444829358045341 0.6512916916783108 0.02362415682349352
0.41965504985076685 0.6344581866262675 0.014202042442442159
0.4578537016414288 0.6282393137694767 0.0507979273955429
0.5184033138074876 0.6626408310810049 -0.022422606020471844
134 0.05836009427169746 0.10506341319211103 -0.13098432125333295
0.11478055510691854 0.16089049221510546 -0.17129917868620778
0.05301677861741383 0.14132866699323543 -0.1477233570904434
0.11511666006010608 0.12182894938441408 -0.15205002320203148
135 0.14574474819734098 1.7168952067672432 -0.27271291236218165
0.12132202853726251 1.66719697764473 -0.29586220465382124
0.12508939192092738 1.7110045404544088 -0.2913859462416388
0.14175857823770957 1.678410818766667 -0.2772520709683303
136 -0.16300365541857165 0.09246046733619688 0.16016561601304535
-0.23502952737604815 0.009989431525288112 0.10393903014958444
-0.23095006312721678 0.0535938832878734 0.12540686603418008
-0.18604840399497072 0.02531354347983493 0.12303474551943809
137 0.5092400926157301 0.7544249454908496 -0.2085321219992389
0.36794776715628097 0.7058496400959121 -0.15426791785851643
0.4433694109408795 0.671784339459502 -0.15151416297132653
0.424117674637286 0.7795118933213776 -0.20457655807974584
138 0.3434825134809654 0.014161356527938145 -0.055229079217313265
0.3590920961446256 0.019836649591306654 -0.04878625921491358
0.3567127402151935 0.0161131768379226 -0.05461825878270536
0.3448176473746304 0.01834063301406965 -0.048410529343039216
139 0.009475333852267898 0.8178660476438948 -0.03383313896160096
0.019820520351193915 0.8763413983750533 -0.014668432533415382
0.00993519027156034 0.8217873028022116 -0.0075759430608125
0.01872425371732614 0.8691323856893822 -0.03615660132222139
140 0.12951841799286007 0.22937195644851552 -0.17424584241040572
0.0696621224872033 0.16246866087295694 -0.13019211388970636
0.1292041290016681 0.18077182615539827 -0.15718180218719488
0.058646272663506985 0.22170611138167415 -0.14704649367435124
141 0.1327453183417227 0.3971424961991536 -0.04033581011663832
0.13026621070593405 0.3543082228276397 -0.02262306214602278
0.15888814524982967 0.38411608389331675 -0.043070425123107145
0.10031625591920976 0.3729851814960954 -0.020976770961192596
142 0.04758397781945008 0.362191073457494 0.07800150211948492
0.04227346382631727 0.3891519438624573 0.034765505089085255
0.05616675670213675 0.4321851710255763 0.06327722271786282
0.031138876036934247 0.3041648433296213 0.04953389030842118
143 0.8583960677133131 0.2844843873597511 -0.3756145830619039
0.8254589110235219 0.2511707197226078 -0.3472261656988369
0.8632412221014063 0.2663499966706482 -0.36176940374374994
0.8110897230324129 0.26898429453543643 -0.3601478553864433
144 -0.033313430253065796 -0.14301215783197993 -0.01573531175178485
0.052232998489327165 -0.12562813647654805 -0.026579099411725267
0.0021853383609898823 -0.1303198857478995 -0.03480558109988327
-0.004311290312047061 -0.14380059544373072 -0.0016403438239763512
145 1.0748053723191786 0.3117175455342699 -0.36648419435470364
1.2175799242809355 0.28547833966296504 -0.35889117823071953
1.232461850027341 0.3830233596900031 -0.4333122826113942
1.0674785935130149 0.2322849101102586 -0.30628744123408563
146 0.744521619744084 0.9683883958246183 -0.34390528333877096
0.49225092154958433 0.8470029525019178 -0.23128681365301623
0.6551814629047832 0.8328882256885116 -0.2462888083715063
0.5766180274017896 0.9780005373933638 -0.32536664402158516
147 0.2823214886882789 0.5408062435535382 -0.07297485635868615
0.3849236725304489 0.5626672096506614 -0.10276002418636875
0.33085727108641944 0.5858306770364026 -0.10757284939308692
0.3318703509318426 0.5146102146588315 -0.06562658946410417
148 0.8581034421625888 1.4224157381939742 -0.36871041966886
0.8880318351913362 1.254316784511126 -0.1674741043143127
0.7946440644212452 0.9627228870514424 -0.32442019818721674
0.9394761484319276 1.6777249705856305 -0.23266716827395154
149 0.48817052022083085 0.2546057711646448 -0.25557888553742586
0.4439918384530872 0.24618868519413312 -0.24256827909937367
0.45910262384605216 0.23303714335069894 -0.23823397596469725
0.46787570174928556 0.27349999116573975 -0.262074606904586
150 -0.07623532698508483 0.2092851692368776 0.14845300244204512
-0.09577483038276699 0.10133420679361109 0.1533676638782938
-0.08552857206107035 0.15323275451980253 0.1159171060621422
-0.08443578310012538 0.16710030928713987 0.1736236262101747
151 -0.05271614587973514 -0.08059885983345662 -0.14316004054352627
-0.04358726765807855 -0.13091531639728568 -0.15602045380007382
-0.01163115298664197 -0.061997234477589175 -0.18839157356236472
-0.06573016637414653 -0.13271300065619424 -0.13121812269213617
152 0.7122609964333511 0.9564044493209523 -0.1861814533682357
0.7404177240814975 0.8032723867295629 -0.13841010948410798
0.8277506279902992 0.9289682566182265 -0.21342147863145938
0.6298434003189087 0.8107888485287915 -0.10536190964292964
153 0.12188688088408092 0.5849249422077462 -0.06209842498460308
0.17443859363277214 0.625263036686496 -0.10806535049576688
0.14596542463051454 0.6553097992575291 -0.08563471686718101
0.14727935833746736 0.5488443834271081 -0.08165943115080523
154 0.10909290215023441 0.049186398255686284 -0.1261032807376665
0.1152647206485562 0.028983937512125246 -0.13553387569608774
0.09653922283696087 0.03483431776573165 -0.1362302968929477
0.14247954240181088 0.045675133295029466 -0.12120371016848464
155 0.058910038452188083 0.4980226520153998 -0.047615228567900514
-0.024708977039288968 0.464596454827394 -0.004398829116430351
0.01874961962942987 0.424751807832406 -0.009589482347307133
0.01774294608765907 0.5114797373910484 -0.035367823423141195
156 -0.07816124640988333 -0.2348593346217485 -0.2914745173446641
0.10667896591334447 -0.1264896278621911 -0.10072048983647
0.015318028925665667 -0.5177280726545892 -0.18571141113836712
-0.017872722298135933 0.08217030450289567 -0.23700922409135639
157 0.018251358569137566 0.9493064843029786 0.004920826025292032
-0.0042359279261300065 0.8421004057662125 0.02217598477613506
0.03606372570399993 0.9448985363411551 -0.021622835052877754
-0.010169862420155107 0.8873407968624024 0.037327983658246626
158 -0.01231626707058664 -0.17770812383458867 -0.06759320742806564
0.004395847601606072 -0.08498058585698462 -0.04486226734400452
-0.010825736010226305 -0.16966384327939846 -0.021897112621521133
-0.0017286103470347952 -0.11879248785132708 -0.0860049539737278
159 -0.02008436699285422 -0.09377718313849101 0.008156340832179011
-0.05808239437422319 -0.2281842890121986 -0.06451052827921482
-0.018191520250099236 -0.032554286112418875 -0.03459672246022321
-0.05902049096762112 -0.30361452988621934 -0.004976876035587553
160 -0.07662475580662513 -0.00989686108905844 -0.14398462495402597
-0.035501680205668004 0.07236956746175299 -0.18160186445848386
-0.07504858482446713 0.041748528738640434 -0.15158341441984033
-0.034573257257877306 0.023700725043741135 -0.17603590846618736
161 0.03189410318317568 0.162225396304207 -7.710996134220461E-4
0.040816333295833146 0.0775473010205545 -0.01900546812439312
-0.004938405791987174 0.09753998412727229 -0.0340886720523892
0.08113708420520363 0.14123337109673254 0.015599601424397255
162 0.6266901290757801 0.769538843018653 -0.1862454433598339
0.4806188225760436 0.7203324812269922 -0.13743305230445002
0.5730623205593416 0.6973726278185518 -0.12600738752716592
0.5357088090924036 0.7774620707512054 -0.18601289550739508
163 -0.24170493607652183 0.13178456611217693 0.018249534708308746
-0.2810112929374685 0.020894632270274868 0.0570412733641921
-0.23197029277861997 0.05163338293267409 0.017375620578952693
-0.27760876527653666 0.0902051772946885 0.04883749936414303
164 0.1037412851545285 -0.3410429567601739 0.11181269136687962
-0.05596092746935992 -0.3721164914418633 0.09361399907436438
0.049176029696297655 -0.34089987327393034 0.12766180947107222
0.029327350689761444 -0.3688918556000603 0.07591293607413228
165 0.2823685204302718 0.9314045339419234 -0.24193248717355534
0.20034202432480272 0.8678884212649717 -0.1826078212108701
0.2457236360931978 0.8329364492283647 -0.2042456370479058
0.2314510627869858 0.9571603174535128 -0.2155075719913956
166 0.004307976695341817 -0.3970397075082528 0.033738510599234946
0.007643993886202488 -0.5239308432333736 0.011620445484927687
-0.07363769030932081 -0.4933288650825279 -0.027317717220842783
0.06352789979581135 -0.42690739556261403 0.06067860739867485
167 -0.11099145254070591 -0.010298629097982603 -0.14589233796609544
-0.15156321440075918 0.006513437457793134 -0.14120215100799977
-0.1571078169570285 -0.027135496340010303 -0.12569703978117422
-0.10488352164213084 0.026893248262536817 -0.16302413008753894
168 5.242736513917864E-4 -0.2596855415295728 0.011737522943250657
0.0012729099019182094 -0.38225584001060414 -0.006927431445445099
-0.04244695587461329 -0.3471284923487716 -0.027946001275834815
0.04499110069929685 -0.29784788662072964 0.03273540866885397
169 -0.06672050795878325 -0.038317450814401625 -0.12596956967860495
-0.1068628447633639 -0.03457795571778801 -0.12477890220123765
-0.11114359794660537 -0.05542343757600402 -0.10929714319933254
-0.06317526498401575 -0.021073035573642228 -0.13877723484293406
170 -0.1337686185188692 0.08437443845497451 0.160036397327177
-0.12161438935351386 0.08134855168108446 0.15593301960691353
-0.12479220994465186 0.09194158049227602 0.15416275002314636
-0.1325988412452642 0.0724764718252375 0.16300811597927464
171 0.09278627242911026 -0.05262864010773606 0.21879137924342754
0.02846259444874787 -0.10156174318086941 0.17839855970988694
0.052714367399478435 -0.052451696862088455 0.20271011610109735
0.06969548582359349 -0.10865087260482784 0.1928997329280191
172 0.7761283340467054 3.012696456786328 -0.897787501495867
1.2548512702948282 1.6954568120311282 -0.9212665367816897
1.7883555957520652 3.0530499633052037 -1.4689885786535144
0.43568451703797284 2.0143709202250397 -0.5239043392489594
173 0.005241475872463722 0.3551906158043351 0.03282371514572463
-0.014090381831751667 0.2878797228815904 0.01317128213785947
-0.008117986238767208 0.33687773001653365 0.012407957500225662
-6.85285917534223E-5 0.29617783113374546 0.03724634413591131
174 0.240211729089491 0.22817929272880597 0.14812364099111106
0.16338505297424782 0.14799279114617364 0.0918460157228309
0.18413593208605664 0.21559024064853474 0.1170578913886874
0.21194243909063443 0.15354077044005343 0.1175800031106354
175 0.268575866654132 0.5351317164189175 0.0648589827703281
0.3894932541338143 0.5522951747966235 0.07877713080515296
0.34454229496811967 0.5554218693099412 0.03435458039034308
0.2937463463686106 0.5303179018470239 0.10237857070838396
176 0.7845871375058422 0.8907367531657217 -0.5278922245821098
0.9411762197126143 0.5757782594615481 -0.5492203366329415
1.0231744386808213 0.9476788842831666 -0.6668232981494504
0.5775550651217989 0.4340679455980208 -0.32659103836171616
177 0.4925976776172899 0.6534290701342915 -0.09401921821072615
0.47538886634651495 0.6164288794580022 -0.040921574870667006
0.5553286423265931 0.6448752259956088 -0.07120633483681925
0.43538648577753797 0.6280294096493605 -0.06474022193029384
178 0.04811389152002839 0.3870936255434745 -0.03968279376506372
0.03146156693142321 0.3090308709422674 -0.05237651784757957
0.03704065576730845 0.36247959305367156 -0.06295430068495127
0.0437158175250198 0.3364458289189178 -0.026718466165681465
179 0.22799450467680127 0.2143321485772674 0.037469196312597264
0.20351286995931392 0.24839276434028748 0.06039081524797726
0.26865560653605774 0.2537120182368964 0.07018779010278575
0.17606663990112034 0.21340422978816137 0.032103306534374355
180 0.37863439182006436 1.1527026236273203 -0.3630908669209339
0.7931669956934434 1.4207743345717871 -0.5968035359981559
0.5114086639663136 1.4409920857542011 -0.5135999580609281
0.6379827086966802 1.115553458156244 -0.432748135775548
181 0.0440465860022988 -0.3960710942460889 -0.11900530234955596
0.01581811873542805 -0.19697949605143958 -0.10491285626756844
-0.09594762101525207 -0.4168899581134766 -7.727723817760296E-4
0.1404861877615941 -0.1886393502839444 -0.20971256958601867
182 0.04767259882592855 0.30575671443194213 0.01661880173751638
0.0018907804052624017 0.1646863322680756 -0.06301320906445268
0.04632382733154937 0.412268682632008 -0.051464889548870144
0.0038727144145942194 0.06223347885422643 0.004919558275408226
183 0.4502356708342503 0.571017339829215 -0.015293256580319584
0.4345584407215305 0.542041576533586 0.023228351521372457
0.4808739746413988 0.5611080805711013 0.0025533778304246673
0.3953255139547862 0.5489672532925662 0.008442149588411081
184 -0.023257999730662532 0.3102052306322006 0.1029234033464902
0.011483962234566138 0.29914127395897533 0.09150666229510876
-5.630999334270761E-4 0.3326473055732609 0.08707873553847553
-0.02428369109326646 0.2820133902369401 0.11132187182215489
185 0.10264269013392904 0.11924216378444008 0.13737741140709442
0.1841656945180637 0.22662528012661146 0.20403923164409604
0.16020139865754957 0.13362884549054485 0.17559565493818186
0.12317386482619469 0.20615481164091992 0.16278878248598683
186 0.32165495859140236 0.2667798961178841 -0.20914852832278194
0.3913957063671966 0.20882570203092454 -0.21666689398782996
0.434172379843973 0.3063917659977071 -0.26403364966220744
0.31332981116561875 0.19135247803606345 -0.18180209959131605
187 0.25869560140750497 0.32535909798747487 -0.21225176076484228
0.20952611003615004 0.23435757309022903 -0.1679893128633524
0.26259738433115454 0.2626973743776644 -0.2023662567207323
0.18643037855337297 0.287171481928555 -0.16551893314475188
188 0.291046167957273 0.5119997756972668 -0.08756245705418034
0.2078136329125698 0.4941861226810957 -0.056011459005113236
0.2473822908379733 0.4620498249553187 -0.054453060897234035
0.24814684577765828 0.5396608611903851 -0.08632409175367853
189 0.27620889383342406 0.3055610933295799 0.03523359053488089
0.2930496947523382 0.3613158666259776 0.011558032954646117
0.2876186978390442 0.3847231104429515 0.03921670679996629
0.2837183029757504 0.3082422679083131 0.013945637571608575
190 -0.046982314197068775 -0.034670990419172903 -0.15733710603876777
-0.03125087208937214 -0.09053309948188756 -0.169145596253281
-0.06305398433383727 -0.06603654773378316 -0.1733879801290012
-0.012240678780310543 -0.05164138738000545 -0.14959052119105196
191 -0.03151948312952157 0.020207769290947565 0.04480315909666697
0.015529468652064816 0.2355171803279727 -0.014379390639947889
-0.0026465437496980895 0.18199401501494872 0.042039280230111935
-0.024261457912745234 9.43292543951567E-4 -0.02370704593012332
192 0.01203300565394607 -0.03610255201859833 0.014337511787328937
0.02043089475425199 -0.12207845675027768 -0.011326307010395859
-0.03037162778810433 -0.09919345435462962 -0.022046373452415096
0.0655616415741294 -0.05598175303150677 0.027046075986090417
193 0.31199219941161005 0.7435660173706132 -0.08263777280737108
0.265897314401649 0.5599299163290549 -0.04165852686220292
0.3056873201180823 0.6298886057107996 -0.09699712620562084
0.25979064332703206 0.6515816686117224 -0.01008352920268002
194 0.354641967248824 0.644211246320738 0.025736013902443403
0.283178400190293 0.6295577279788536 0.009240884074141469
0.2888041865983183 0.633951284750436 0.0377175622575292
0.3380351390844554 0.6383911178728894 0.0016457259454869106
195 0.2950657886841636 0.38185527980153877 -0.21162582511823008
0.3783267149891694 0.36795125145967755 -0.2517939781274824
0.35732996874552864 0.44583961338725187 -0.2572580717664032
0.30162955281254156 0.3183994083026015 -0.20171911717241345
196 -0.011602412166934986 0.3516940912798499 0.0080700989565419
-0.003191005995519497 0.5289198825587489 -0.005187679019289681
0.020622274434879018 0.4801836303039603 0.036422016787894765
-0.03669867363647539 0.4125145527357673 -0.037141260788658315
197 0.03526260274925034 0.010980962693253235 -0.12796634728225817
0.024911952058960442 -0.004266821434020416 -0.1545387214519629
0.03506441264145503 0.04134115686866472 -0.14561963732251423
0.026141959161599792 -0.029919630686116572 -0.13601931783237292
198 -0.05085149524165772 0.19883444459149713 0.10900021106170654
-0.06709973413177542 0.2385689233103198 0.09106912440698857
-0.038173216513533635 0.2596864272732324 0.1206613312637507
-0.08007659479096624 0.16556819590412744 0.07940521747887992
199 0.09782015940612813 0.06530485666062329 0.1766970993038245
0.13058300377085802 -0.002834849842652358 0.1768669225204623
0.06848485395805344 -0.014748566290656975 0.14393608944500175
0.16068204295723315 0.07827343421818468 0.2102429167009869
200 -0.24323555821151455 0.11331094371825297 -0.0345533143504259
-0.27298541770608703 0.03554777846515986 -0.06540323649237084
-0.272815632978058 0.08445402689775722 -0.056404600700896465
-0.23575348973581778 0.04841862848217559 -0.042168620592998855
201 0.3630823227205376 0.7239161288195431 -0.1865820717795458
0.26247399694293705 0.681868583619392 -0.13593667497385625
0.31600114375207794 0.6436597641717097 -0.14290245536403937
0.3046375871689539 0.7558387016126266 -0.1757454127653155
202 1.082616267945776 1.0707782085293693 -0.2959597206167405
0.9383459259880111 1.315259639478314 -0.5111894604637381
0.7297970124370753 1.0874482883299592 -0.30185998070233505
1.3298293733094972 1.2999767586176976 -0.5075206004705043
203 -0.24087770865407981 0.008658941144679272 -0.07164253111075433
-0.1865636647845128 9.640545897710781E-4 -0.05928341748002432
-0.18320819462538296 0.02312524415508907 -0.08481618209475818
-0.24445883769823262 -0.012051136108213442 -0.0478096945488712
204 -3.443623382016203E-4 -0.8030253839964341 -0.03568379164233417
0.05987215979666491 -0.68604636312845 0.047273673194424236
0.03167957215775474 -0.8037145736728899 0.023366451474934796
0.024814981742898035 -0.6510342561292596 -0.02550238923302786
205 0.10229439337583232 0.43110538550989214 -0.05302520953149676
0.08625254918181867 0.408762541932185 -0.00374471510309696
0.08466758272110109 0.362355529693155 -0.028949208636265267
0.11022495512718378 0.5068748068116555 -0.0333495128978282
206 0.25878857951796397 0.3608191582442719 0.07939559565758007
0.26627415074920024 0.2879403429081221 0.10889822863298546
0.2438122091285363 0.27390656211606734 0.0721583502613583
0.2834110578018563 0.3865940763706514 0.11735693215510466
207 -0.04917435717583139 -0.0359642473043654 0.19188286763901072
-0.013938407301405989 -0.00609633510772852 0.21719593900780243
-0.03047394316399845 -0.043128798632119034 0.2012103383202714
-0.03398674696958835 0.0068557671881983315 0.2081366545776932
208 0.01438032676448453 -0.08838670661911623 0.2102004725978891
-0.03412036931527031 -0.1156443475549988 0.1805795090804731
-0.010113185372501592 -0.07569071863122029 0.20152043994764582
-0.019206805087310375 -0.14510178887973232 0.18070902942204506
209 -0.46092518874013394 -0.003637660192529632 0.00434637464959747
-0.3295350933198154 0.028948555105294427 -0.05576913879624015
-0.4526377665446535 0.006465055732038372 -0.0503345985634213
-0.35377272935721515 0.016301655652673303 -0.0027172676194667667
210 0.012568953239317726 -0.7287377465097513 0.03074265276457715
0.013915003443289081 -0.5364275030372432 0.03600199930123081
0.07827728854215704 -0.5879790837840748 0.093349021629718
-0.05340284129745021 -0.7307334651404033 -0.029189688990552524
211 0.44586141668078505 0.7942504964709598 -0.2011471054093481
0.37625606693541336 0.8466139490235041 -0.12483554685659592
0.3697711993545544 0.6991002310436769 -0.12300841100748487
0.45855487836914366 0.9503846078731972 -0.20932028831202223
212 -0.0924938882685162 -0.0021709870594901447 0.18564272908513166
-0.0692665737267007 -0.029454507010391453 0.1874432556827826
-0.09877862965656103 -0.03746486471655468 0.17292892275830365
-0.0535894923691681 0.024228626452021368 0.20931441916154886
213 -0.082939860115255 -0.013976062481704845 -0.16055003126091805
-0.04133144622731641 -0.02391741338764998 -0.16968297771564936
-0.04422502072645876 0.006024577973235749 -0.18031680722235674
-0.08605005616626255 -0.04213616477786061 -0.14873223761472865
214 0.03973097128522257 0.07105259030977532 0.024245029269813135
-0.02345750819301973 0.027847305555416417 -0.028139504516144047
0.009672442822894471 0.10474740613565267 0.0032086459100854475
0.007484175915833771 -0.023697554988192978 -0.007691801720425964
215 -0.020023921941064893 -0.017965926232487665 0.012617441985203459
-0.013563361062988978 -0.013706963392985806 0.01634202225995328
-0.014218043126375497 -0.016838235756936333 0.013972747349044589
-0.01908638364798045 -0.014721255159700339 0.015095877134128913
216 0.6311904003884083 0.5595748409859885 -0.40208539241726327
0.5819077781134487 0.5469060578535092 -0.3644006114111396
0.5941561051556121 0.5087262034076958 -0.3701192399111119
0.6199061145140499 0.6195839984935964 -0.39900851208572713
217 -0.0731032099164988 0.03164758104921622 0.18297340273622323
-0.07296418199995715 0.03795423882298203 0.19992925850906026
-0.07586614472887954 0.01877875679919577 0.1907336687993747
-0.0694073938292841 0.05421739917553613 0.18901002485983842
End Values
GaussPoints “Quadrilateral\_principle\_stress\_gp” ElemType Quadrilateral
Natural Coordinates: Internal
End GaussPoints
Result “CAUCHY\_STRESS\_TENSOR” “fem2012 analysis” 0.0 Matrix OnGaussPoints “Quadrilateral\_principle\_stress\_gp”
Values
5 0.027395057320179453 -0.25241672334813403 0
0.013521232385928297 -0.21032211578460214 0
-0.003310482035726897 -0.24783748294828686 0
0.04708006878696476 -0.21642160211555866 0
6 0.4531553511947252 0.09516895527595276 0
0.4335004115541796 0.07183856355662721 0
0.38189047595087217 0.07493426877687709 0
0.509582784203398 0.09545192034780992 0
7 0.41027348336388014 0.07724898199583927 0
0.4263298598629611 0.0866973670176244 0
0.49727856445648966 0.09947359321732233 0
0.33525428679886227 0.07114924676722922 0
8 0.011147429870278842 -0.12127406407104485 0
0.020493696507781545 -0.11203610374046605 0
0.02822115851006944 -0.11531291075413048 0
0.0036277015135838878 -0.11758010840321645 0
9 0.36106736879073675 -0.003896914077153063 0
0.2711287391751322 -0.0026169312804599776 0
0.285058229116833 -0.028596592360788653 0
0.362978515509884 0.020134028524850217 0
10 0.9613478450405235 -1.957891026262426E-4 0
0.8544339333798769 -0.0013106312411124144 0
0.9637862718228083 0.02164996693007548 0
0.8595916963865313 -0.023590764925547514 0
11 0.814671791058944 0.1497449937843634 0
0.7421289697738187 0.11578759186433457 0
0.8065794460308637 0.12768306266111124 0
0.7434539619777814 0.137579915745965 0
12 0.2561279162777459 -0.15136868299101033 0
0.21895269363290482 -0.1779933652379233 0
0.24959180144030735 -0.17862324299010002 0
0.23047475057841246 -0.14602183038001834 0
13 1.08350892974125 0.012702238392190424 0
1.0717326910836067 0.004939919162562312 0
1.0823965071833221 0.006684423711737053 0
1.0737543408627706 0.011026893451068775 0
14 0.5280538255651397 0.0057986047898542226 0
0.5841294243526869 0.0038818048587438425 0
0.580729101757715 0.016208286964388807 0
0.5244743461407779 -0.009513137454784604 0
15 0.025393947156571076 -0.15307817846382454 0
0.03515136641965769 -0.28228287870215096 0
-0.015709109877765415 -0.2524748158781224 0
0.0969970316038585 -0.18870522081273436 0
16 0.39486252082078266 0.029393563961482266 0
0.5177311206964952 0.05666144543457394 0
0.4314077854242133 0.044104721407065006 0
0.48399818121835636 0.03999622280511547 0
17 0.755855575928893 0.06365374485463621 0
0.8282977343771116 0.09336454613264944 0
0.839983646316009 0.08004823707516939 0
0.7347627109766336 0.07596094968457034 0
18 -0.0039732637230517065 -0.46452052179481795 0
0.01739016372798824 -0.518820461941027 0
0.09195958257969639 -0.4642591383446528 0
-0.03813379041225082 -0.5008714001035066 0
19 0.11548699205052398 -0.14961826444384224 0
0.21045590222385974 -0.1253822520733805 0
0.14123722763295649 -0.1296905909800471 0
0.17496751543121214 -0.14743698123267113 0
20 0.5576233846481187 0.20209515034006292 0
0.41777583083406106 0.15664524194106683 0
0.5042025186177655 0.15537583815135828 0
0.4594990061035029 0.19186546784182046 0
21 0.20374162556232606 -0.007258039111578754 0
0.2205090587901828 0.015396781830930073 0
0.20508362208159975 0.008098070317955633 0
0.21712918335769085 -0.0014278104926673252 0
22 0.6448783857742035 -0.04541259842193657 0
0.7522753549277249 0.050494444534222804 0
0.7622155404598898 -0.008815948018555841 0
0.6121599633351131 0.001970413202083743 0
23 0.7687560701581716 0.5298879396806314 0
0.7602104345171148 0.3959572553815032 0
0.7141640727433356 0.4239155652605826 0
0.8183619369896115 0.4852435512248773 0
24 0.6583894993027667 0.21723480808828943 0
0.6957039356728622 0.20582817077070226 0
0.6266926967466223 0.1980820684566861 0
0.7557005094751386 0.2275300425535131 0
25 0.49895766301362476 0.42232861808895095 0
0.4839945187285508 0.31860956599126955 0
0.4811654235038663 0.3415726735214441 0
0.5082736571917842 0.36542788388511904 0
26 1.0952494252662688 0.07371991819352264 0
1.16384895091362 0.09689348689890298 0
1.164586255225505 0.08653560470757482 0
1.087592241657171 0.08308947557458046 0
27 0.20472078354014545 0.0642219756127922 0
0.1746428651731007 0.08455696787500003 0
0.1263249669035481 0.05993269818211838 0
0.2670474610910462 0.09745613560069882 0
28 0.26957917049489544 -0.059178504002023596 0
0.1658727960451916 -0.08338944101739348 0
0.207403797814849 -0.046437699544759986 0
0.21463734492074318 -0.09288142459557644 0
29 0.37007934061906045 0.054169555486491994 0
0.2542658950783538 0.04298590337792313 0
0.29277858207288476 0.02667149206495842 0
0.35384815872759307 0.07056851739693887 0
30 1.3523198064236936 0.03739215230817439 0
1.3906271225493132 0.035697241120841494 0
1.3487333816356877 0.027568920644488126 0
1.3896903289229872 0.04428899183840551 0
31 0.19407945390735515 -0.13192440883975431 0
0.15881731482543346 -0.11010275509440556 0
0.1450697779221501 -0.13119722365570868 0
0.22152991353731283 -0.10685344773417864 0
32 0.14702242498933538 -0.21090304158608358 0
0.14476585141069762 -0.1255882922734666 0
0.22398695805663835 -0.1479912591555456 0
0.08327137537461346 -0.18973012571317108 0
33 0.25010753676636643 -0.06975508011827533 0
0.17681713258389514 -0.08986399185310366 0
0.22608197230475063 -0.08769321038235228 0
0.194011770291218 -0.0741275902043044 0
34 0.1118771508165341 -0.1143260112819168 0
0.11774270731790318 -0.04343457818650786 0
0.18959357131995197 -0.05906433121601645 0
0.029590893876359423 -0.10063952112055911 0
35 0.5758981381951209 0.16656613688357524 0
0.45191315369387575 0.13242038627969646 0
0.49640883190152596 0.15847508221734594 0
0.5336635246675472 0.12985900955480445 0
36 0.2307813506668558 -0.04617733228091701 0
0.2537268795690213 -0.05477887988495743 0
0.28349307220282693 -0.040184218676208666 0
0.21565566649439036 -0.0568910591099934 0
37 0.22240888721512514 0.11602899374787139 0
0.2677743866479 0.1162444228832421 0
0.228770449787709 0.07512312256313036 0
0.24303493897950412 0.1919113387843654 0
38 0.24775747684663868 -0.03414027520884273 0
0.3084190544101806 -0.013302786223042234 0
0.25968208697979 -0.016641488946966307 0
0.2924772091970529 -0.032072115873833046 0
39 0.27780324567137415 0.0017592298595360267 0
0.2527614631740194 -0.025776662307947812 0
0.22476506164147328 -0.013545947978307382 0
0.30220416246410337 -0.006669380591803775 0
40 0.5908780443992434 0.05690263117013966 0
0.4678933150915012 0.04358436511913524 0
0.6090320095058495 0.06905929580723263 0
0.4476375511003174 0.026479673986796515 0
41 0.5912431884339224 0.20473909273689692 0
0.5477237959470875 0.22819617614989102 0
0.5311192622548654 0.20209491761832263 0
0.6395280759255073 0.2383600293426131 0
42 0.1379166633268745 -0.22740234625897102 0
0.05693870373711475 -0.24514113568055074 0
0.10396544971568666 -0.24654165113516469 0
0.09241159369480725 -0.22628737020904713 0
43 0.36512146508387167 0.001640623847554673 0
0.32265747304513764 -0.0017288156934520682 0
0.32935112169014935 -0.006527220397427674 0
0.36508164974087465 0.0068412603455891285 0
44 0.9673645479758941 -0.0050574260099489066 0
0.8650773982193004 -0.0047071901772343105 0
0.9674195289262261 0.017429327311968 0
0.8803624297105646 -0.026041546197630716 0
45 0.03803745413668534 -0.28464675998213146 0
0.02697408080848343 -0.19921173453715732 0
0.07832565276532734 -0.22081659106509594 0
-0.013891799719953607 -0.27135704357357027 0
46 0.28515540162712333 0.04063156747787772 0
0.2472183499038033 -0.025915195521540813 0
0.33526461353134274 0.017912504220958914 0
0.20048853104964837 0.010877880610521182 0
47 0.422296128006143 0.004282639117102721 0
0.42591817284338757 2.583015776952968E-4 0
0.4268110881650744 0.005367676261127691 0
0.42123203048901364 -8.562108979777716E-4 0
48 0.9946925185307521 0.007095631691421578 0
0.9514547695078109 -0.001957054230480426 0
0.9940450971514125 0.0056317273264454015 0
0.9547844428594241 -4.4219137617651505E-6 0
49 0.061905104606321606 -0.19216980146242096 0
0.06856120517723074 -0.183965341291764 0
0.09706640475772164 -0.18193030040382918 0
0.0351076016417186 -0.19281260076468137 0
50 0.05392960611675718 -0.218588727516715 0
0.05220180168339908 -0.3766926665610484 0
0.003636472221829029 -0.3879018014226375 0
0.1036576945677061 -0.2583822125792494 0
51 0.13307736572178258 -0.20081935395111283 0
0.07753424699495338 -0.20425699146930348 0
0.041033010347050286 -0.21217634735625615 0
0.19536786573507914 -0.1832031381736519 0
52 0.545605327416028 0.15810536911392967 0
0.4506594850380543 0.13387963041746986 0
0.5328037538927395 0.13935734055944626 0
0.4782422355011523 0.15027361882821866 0
53 0.11245630205693968 -0.22015081349585408 0
0.09228187728862584 -0.27053052188754817 0
0.05918889969640116 -0.252603561114596 0
0.15720876045019677 -0.2406147033276777 0
54 1.119294662697359 0.5034536981133912 0
1.1559117282353892 0.437613775939172 0
1.0402421083193798 0.44638383746791965 0
1.3084843374636663 0.5173387090536794 0
55 0.44373620495590405 0.012352820003305565 0
0.28430858943169823 -0.018415515023225 0
0.33962584650716565 0.01942493955029531 0
0.35954613027450405 -0.031843637387550194 0
56 0.36880481205660526 0.01204748926664262 0
0.25410943761843785 -0.005798043512891274 0
0.3284171331226557 0.011365234411720382 0
0.295343557457573 -0.009567229684855821 0
57 0.5955399277508839 0.11090938990101623 0
0.5181580663154924 0.056229399174583805 0
0.4789434678890191 0.08503100877675471 0
0.6128341516781872 0.0771768643816182 0
58 0.3047411888252884 0.0058980565293296205 0
0.2972257029167764 0.008575447304153966 0
0.3141163518827905 0.010479235669679537 0
0.2941636158512044 0.005033301723018357 0
59 0.7801305753942127 -0.025007210677163216 0
0.8021460440876245 0.025422657228820478 0
0.8059824754832805 -0.0055262980991872546 0
0.7615266617048073 -3.589166658874432E-4 0
60 0.2708509287980726 -0.06656609173114607 0
0.25443160373712065 -0.04219555810451742 0
0.24335809650144602 -0.0653955699564534 0
0.286220536055921 -0.043258692290180645 0
61 0.23084507609466912 -0.058258016038218646 0
0.24206510482524668 -0.02071562029332126 0
0.30939620185960903 -0.025627651795983808 0
0.168256313453105 -0.050408985671893156 0
62 0.30873895281372576 0.00945684711799677 0
0.29341248353917804 -0.010442377152286297 0
0.30756153464876024 -0.012716350895864564 0
0.29680366381231704 0.01011948651472619 0
63 0.3252097529128016 0.24420661520821602 0
0.3122710305153493 0.16864296240731566 0
0.31786173544381613 0.19906508985574678 0
0.3218471590488279 0.20263789391713405 0
64 2.0172217935095627 0.7508186019045237 0
2.8106689784820675 0.5794406827353369 0
3.6922710627750197 1.0908211520321636 0
2.0694968558328704 0.4174814080994088 0
65 0.6711386204423746 0.3704647582623555 0
0.5678814325214835 0.39322753565211066 0
0.6558480990545983 0.4240237548564443 0
0.5969148291431323 0.33863010112607594 0
66 0.3855108603141645 0.06358531727526123 0
0.4011789553079075 0.04289104457128362 0
0.412933574866621 0.0713989995629229 0
0.3810461309559162 0.04027782862031701 0
67 0.3818346103981875 0.25494960451885623 0
0.40882015434788677 0.25901600846413675 0
0.39125577159735214 0.22702084195670677 0
0.40201240060785076 0.29537994752282465 0
68 0.02437997911618145 -0.3584997162287177 0
0.009191474997981813 -0.46686060027338383 0
0.032173993837014775 -0.3467213728144475 0
0.005000183291655025 -0.4663622332523433 0
69 0.026017204032407815 -0.5034218354582235 0
0.029249309077704344 -0.58855335506443 0
0.009930895080589752 -0.5916550864362454 0
0.0593942430405105 -0.4659931596659073 0
70 0.2639902852993952 -0.19860692350335396 0
0.18008116408352495 -0.21522632416515838 0
0.2403172429864732 -0.2061117154906645 0
0.20670926230144537 -0.20801101094846103 0
71 0.6966861674232723 0.1540593303593351 0
0.7417056650963532 0.17931885216714888 0
0.6895701030500588 0.17630624388260752 0
0.7346630801001337 0.15690095147843275 0
72 0.06504562531480247 -0.24455282450432464 0
0.20635357767146695 -0.1612579760448999 0
0.0839753908773008 -0.1651402411130096 0
0.16489403162978802 -0.24845545549486084 0
73 0.8794109099711154 0.6031803301083234 0
1.1009033245615398 0.6332981652931958 0
0.9650877837431823 0.5859977554138435 0
1.0234629980324654 0.6582273533900047 0
74 0.029252783454350062 -0.41829042459834714 0
0.010991768621688491 -0.7574972059069927 0
0.4477219087811805 -0.46092682051269757 0
-0.17122774397819202 -0.7822683780465682 0
75 0.5941006699857987 0.022490177867904804 0
0.6675373229478601 0.093575776609929 0
0.4748201537250597 0.062012465571194886 0
0.7936134179721857 0.06881086333762942 0
76 0.6227335144850017 0.01561322142027316 0
0.7184560265766775 0.008084373325007332 0
0.7171513621003223 0.03515730270730938 0
0.612608533876351 -0.016829029250325755 0
77 0.013212004408061612 -0.11420695584243759 0
0.015125255883211702 -0.1250097599156515 0
0.00304560075308688 -0.1230439148821463 0
0.02580122936540029 -0.11627406865939997 0
78 0.8780387758942079 -0.003172167448833141 0
0.9505118874112043 -0.02458810454684668 0
0.8581357315187161 -0.06528578187071093 0
0.9625746683156886 0.02113981270081844 0
79 0.18755442709132747 -0.01731155468860253 0
0.3491624376235428 -0.037745740327792515 0
0.37007993736720524 0.03447278124578643 0
0.2069246105557005 -0.11208762958316511 0
80 0.470142838981832 0.29763611800031914 0
0.4730588029734707 0.38034411327857875 0
0.5302088521164172 0.345916123340001 0
0.45031070306793974 0.32429566774695584 0
81 1.1929482482957043 0.011415272012152866 0
1.1769686436227365 0.01915094079463986 0
1.1934074301086866 0.022332076840852477 0
1.174677516855302 0.007549861741443564 0
82 0.15519688391337974 -0.1039357178203049 0
0.2698675032463138 -0.08245834225926177 0
0.18931007850477422 -0.09672072376830433 0
0.2210143197284697 -0.09571660678655354 0
83 0.5242574003941968 0.10571370613937639 0
0.5282156072236696 0.10400370135082118 0
0.4117093609354586 0.08608934525821446 0
0.6062481125725725 0.12239209199090006 0
84 0.4016830473766706 0.32808994387292645 0
0.4690072938716308 0.32027614436609814 0
0.41735868328758996 0.2694494554447098 0
0.447814736051649 0.3666647751341755 0
85 0.49437982190404617 0.0013503275702560769 0
0.4692615757326135 0.004606373208301873 0
0.46675764052000746 -0.004473578382117482 0
0.49532896874237575 0.009590414375940243 0
86 0.9971679591557283 3.3684359946445364E-4 0
1.0285674451542102 0.008668934226562786 0
1.0000730087347476 0.0036280441483035886 0
1.0278493652022491 0.005809337702381456 0
87 0.07582057192180341 -0.2066256994167633 0
0.12558374098615233 -0.22955409048792602 0
0.04647813649865354 -0.23097122392303313 0
0.1613276368148484 -0.19505298380284747 0
88 0.07538340403518662 -0.2687478566359999 0
0.12311603122375049 -0.2636681345190625 0
0.18784250401620167 -0.24819561886984204 0
0.04704567634274079 -0.27451727249447244 0
89 0.19442453490407732 -0.12807263679468225 0
0.16721528632570018 -0.14875611451590162 0
0.12328083821980818 -0.14665776879023573 0
0.25515992282685274 -0.12272328627801843 0
90 0.09292041189129147 0.06281044324323976 0
0.0644109403283269 -0.03766279070948174 0
0.04334672108647579 -0.024332428180258478 0
0.14370531621705998 0.03686873471460957 0
91 0.6487474081335165 -0.005496501902988893 0
0.7440235261259391 0.023960693989486026 0
0.5871322150711709 -0.004788635490557913 0
0.7858059566748747 0.018489846877728866 0
92 0.13992894993038232 -0.039292767132971584 0
0.14027027993812496 -0.10963886694316335 0
0.15935633627427576 -0.047062400104447524 0
0.1263531373262077 -0.10600468917565761 0
93 0.17204007265347976 -0.22039667873172247 0
0.027932683583236625 -0.24892172795175926 0
0.10341594460467937 -0.20922476251829722 0
0.08988918828068795 -0.2581673525345657 0
94 0.39015275804510974 0.011076543596702376 0
0.42689290213439546 0.018151027414574278 0
0.39437779288439034 0.012293696753937738 0
0.42291932058287884 0.016891452736417595 0
95 0.8444869185649257 0.012557363769263918 0
0.909061392680335 0.02688589127365021 0
0.9137075888106665 0.02510845701129094 0
0.837333620828923 0.013950838473094473 0
96 0.1787307069950211 -0.13727554603802009 0
0.18319725307078377 -0.17135839965790595 0
0.19175529352972745 -0.1429132810294972 0
0.17277016798784833 -0.17387376124238885 0
97 0.18121059991027932 -0.17666083452253473 0
0.1908066192877714 -0.23391064247799445 0
0.12150479268143279 -0.23765992786264295 0
0.2362086860601548 -0.19033734015584033 0
98 0.18850891921272453 0.08828283691278313 0
0.2520510128353111 0.11542351191944993 0
0.16138504983888888 0.10050550582988223 0
0.311744768971293 0.11770616956394062 0
99 0.13145651482550083 -0.18527507817570746 0
0.10657867313940256 -0.17542398445052598 0
0.045744013455740154 -0.1936445920673125 0
0.1772074098704441 -0.16680989805896007 0
100 0.056191219258863084 -0.37206057075213517 0
0.07311702755895487 -0.2671358873989878 0
0.15671104297201602 -0.28374178114885285 0
-0.021849156955185772 -0.33291397080034657 0
101 0.012197554915164166 -0.27711882411790956 0
0.0321517707647086 -0.3917491340082825 0
0.0622950278400137 -0.29989393771135486 0
-0.016416697504699068 -0.3826444030163745 0
102 0.9673175665337281 0.2767029551693237 0
0.7155254242405705 0.2196893974156473 0
0.9096927728296562 0.23358297828454005 0
0.8263904728177709 0.26859015093231164 0
103 0.9707070660432751 0.30250266902748163 0
1.126817385384202 0.25744717033585496 0
0.9724094242797845 0.23285311435932554 0
1.1408809591024998 0.3247200874413791 0
104 0.40503628970806016 0.02510856460731259 0
0.3326410466347818 0.016924699730569176 0
0.38799547764235043 0.029356695851758763 0
0.3495287006018253 0.011485101818622473 0
105 0.7749990725121128 0.06512617697518014 0
0.6887682650477551 0.04192176503853734 0
0.6757306530791851 0.047095071119279464 0
0.7834428323829583 0.05909265239238065 0
106 0.9071519160414385 0.1357072602262192 0
0.833058914044609 0.10439931667895103 0
0.8125535832217217 0.11832958151427003 0
0.9183894278834226 0.12042726235643797 0
107 0.27107132995056304 -0.16573590967847146 0
0.24868477491258492 -0.176297375921786 0
0.19260744680554764 -0.18118180449527949 0
0.32359115455025955 -0.15857138556986888 0
108 0.09700138955415184 -0.31856199414717123 0
0.17150261968531438 -0.29073025242068207 0
0.1334970549590083 -0.3288575032865211 0
0.11611001619727934 -0.2619543325817982 0
109 0.38885749590742114 0.034692321867480586 0
0.3556799066865507 0.020702265599790937 0
0.3042555955816173 0.018301056085263084 0
0.44123301877717 0.0416408427864301 0
110 0.4447753058598992 0.12971476641265187 0
0.47947780301279186 0.2031661916571347 0
0.5011837032044443 0.16078283908812818 0
0.41283266953190045 0.17010569725676009 0
111 0.014800824130088708 -0.3302348465759193 0
0.03247158910781864 -0.4346053349749299 0
-0.011306196730972301 -0.4255948295934069 0
0.06173084374485613 -0.33635540388426766 0
112 0.19412726083487625 -0.23412065972644835 0
0.1730895488566611 -0.2494555044770262 0
0.13319158414843157 -0.2488360955280441 0
0.22454864340691216 -0.23499673712665298 0
113 0.3766225415618517 -6.571528478278854E-4 0
0.3862728911298838 0.004281025525430693 0
0.3856307193496898 6.224675426756976E-4 0
0.3781466441091953 0.003327781516980266 0
114 0.9141413608560764 -0.0018562396087586364 0
0.9766806684094345 0.0030597600546697357 0
0.92115159782865 -0.00826027547980318 0
0.9762809592343771 0.010029715133527295 0
115 0.01788744454480906 -0.7576820072261373 0
0.006772697951961559 -0.5891308134334952 0
-0.04451390481862538 -0.759731790765078 0
0.06380790072341541 -0.6515286412109382 0
116 0.03471501601021318 -0.3878649145726695 0
0.012988150834787215 -0.26486190297137124 0
0.07550026706554741 -0.28911202608242764 0
-0.02643762388594348 -0.3806556496098663 0
117 1.372659741175823 0.17918287335757344 0
1.2257137218013177 0.12231315860976288 0
1.2220197707632363 0.15370976537662595 0
1.3603831589827018 0.14520566142600844 0
118 0.02116881908765543 -0.15172931580417576 0
0.030919273174591803 -0.1146918448027176 0
0.024578319614982413 -0.12481938848578453 0
0.0297724184034105 -0.13856137395113305 0
119 0.05487139341671393 -0.6183749434220251 0
-0.043961571810808064 -0.7661098229984111 0
0.01216656576020575 -0.5625022961866004 0
5.510873043998443E-4 -0.7662701561664398 0
120 0.723213694824832 0.20439251671891007 0
0.6619857197621208 0.157786734893806 0
0.6337596208154066 0.18451174664136838 0
0.7411670248772031 0.17722218746793905 0
121 0.026315522230668777 -0.08829105148890934 0
0.01814609643528939 -0.1366104448511859 0
0.012536668263880668 -0.1797140673573806 0
0.03864592912416288 -0.06009414981969407 0
122 -0.02359727648962842 -0.4190311607240397 0
0.013960743124652758 -0.41184951547850346 0
-0.004501567525843103 -0.42032269024743896 0
-0.005498335779642288 -0.41269080413066705 0
123 0.8185485367728056 0.06507341172902598 0
0.7721194677114405 0.040475747111811955 0
0.8203554547023215 0.051134251608120185 0
0.7773600405739125 0.05665198871248467 0
124 0.29749280888639373 -0.10128115421214975 0
0.3236193981333735 -0.09505799786943205 0
0.40716181076941227 -0.07856971173648988 0
0.22320166675443465 -0.11169537489966473 0
125 0.6077947611501371 0.02463663499920221 0
0.6488630754299092 0.04906774538601294 0
0.6096411653439099 0.04154553269356864 0
0.656447951047984 0.035601229090354125 0
126 1.0386979576888502 0.057447711296295834 0
0.9899610964869052 0.04561725528413901 0
0.9807020296861859 0.046866678727375655 0
1.0424535949192255 0.05531302272368821 0
127 0.7503485838330416 0.5085101346182382 0
0.778766650336763 0.5550900460685084 0
0.7313899639144852 0.5361864709916155 0
0.7801856667309401 0.5287960386546577 0
128 0.8207517526321276 0.039869759835638674 0
0.915049023931485 0.05698491783142545 0
0.9197173273794889 0.05753175275295763 0
0.8067964854032774 0.03716904746221822 0
129 0.5046850884536493 0.028071187585453516 0
0.47961894341285377 0.020963304236703728 0
0.4766104274470116 0.022836431674264912 0
0.5084177668367954 0.02605948121084431 0
130 0.9635819115374324 0.03712111904584492 0
0.8944770532510102 0.027466779595182567 0
0.9589107460352839 0.03920660879482202 0
0.904168891286175 0.026263736885023203 0
131 0.25384610804761554 0.00838224704153867 0
0.3398480814331023 0.01955503266886771 0
0.27811711880606527 0.001802435857475082 0
0.31496998474098775 0.024718446947431583 0
132 0.652314961448256 0.02439661425484657 0
0.748375354237985 0.04569676160254171 0
0.7435326467590174 0.03596886810294653 0
0.6599489764319892 0.03028675341611592 0
133 0.6562836181488678 0.5394910093339771 0
0.6353931074823798 0.4187201289946547 0
0.6422344285060484 0.443858586904857 0
0.6660461653421841 0.5149979795463084 0
134 0.2147613400286748 -0.051337832564866306 0
0.31067921082834704 -0.03500816350632305 0
0.2513542315448507 -0.05700878593420142 0
0.27055986289201894 -0.0336142534474988 0
135 1.7628852325496056 0.09975472241497851 0
1.721886704016705 0.06663230216528748 0
1.7628472291221258 0.07324670325321025 0
1.7269039795778092 0.09326541742656735 0
136 0.16959056463277114 -0.2401337527151459 0
0.04814075794745849 -0.27318085379821855 0
0.10097474135073992 -0.2783309211900833 0
0.0818238667195465 -0.2425587272346823 0
137 0.8737303258340747 0.3899347122725049 0
0.7656846503414262 0.308112756910767 0
0.7473132356413132 0.3678405147590682 0
0.8727904854440103 0.33083908251465316 0
138 0.3524979474397112 0.005145922569192413 0
0.36596837733304255 0.01296036840288975 0
0.3652569403533209 0.007568976699795199 0
0.35184478434407185 0.011313496044628168 0
139 0.8192795760404638 0.008061805455699012 0
0.8765925304270543 0.01956938829919297 0
0.8218579929134806 0.009864500160291223 0
0.870666878484049 0.01718976092265928 0
140 0.3607027274303042 -0.001812352988928595 0
0.2542798985556497 -0.022149115195489427 0
0.3142705120455901 -0.004294556888523704 0
0.3083124434754515 -0.027960059430270384 0
141 0.4031591180560423 0.12672869648483398 0
0.3565697996031423 0.1280046339304315 0
0.39207146227937073 0.15093276686377569 0
0.3745895118869886 0.09871192552831659 0
142 0.3804683915930155 0.02930665968392862 0
0.3926019638975202 0.03882344379125427 0
0.44254801051475057 0.045803917212962536 0
0.31287376227759567 0.022429957088959895 0
143 1.0441240216529901 0.09875643342007401 0
0.9888897168188011 0.0877399139273285 0
1.0337805614198494 0.09581065735220518 0
0.9907875513692077 0.08928646619864167 0
144 -0.031100961404286802 -0.14522462668075892 0
0.056119963608671636 -0.12951510159589252 0
0.010771466807286537 -0.13890601419419613 0
-0.004292003128252869 -0.1438198826275249 0
145 1.222304389659803 0.1642185281936458 0
1.3397520649010115 0.1633061990428889 0
1.4144929418825098 0.20099226783483426 0
1.1677611961388752 0.13200230748439834 0
146 1.2181177336305369 0.4947922819381653 0
0.9610987899309096 0.37815508412059246 0
1.005861314528029 0.4822083740652656 0
1.159592466534223 0.39502609826093044 0
147 0.5599852991587592 0.26314243308305796 0
0.6096549781786234 0.33793590400248696 0
0.6251515798891475 0.29153636823367457 0
0.5357361213558353 0.31074444423483877 0
148 1.604543410093902 0.675975770262661 0
1.3193451011229511 0.8230035185795114 0
1.2138119401287635 0.543555011343924 0
1.7449339664872634 0.8722671525302947 0
149 0.6523840348672458 0.09039225651822974 0
0.6070461586555539 0.08313436499166638 0
0.6097587678385852 0.0823809993581659 0
0.6502027455244637 0.09117294739056153 0
150 0.27248312653361195 -0.1394332842818192 0
0.18508337291210863 -0.17952399650126455 0
0.2002507638367114 -0.13254658137797923 0
0.2557215469248923 -0.1730570207378778 0
151 0.07717976158756806 -0.21049476730075983 0
0.07476392030785847 -0.2492665043632227 0
0.15325308522586834 -0.22688147269009945 0
0.03620319540273137 -0.23464636243307213 0
152 1.0569647959827098 0.6117006497715934 0
0.913778263505514 0.6299118473055465 0
1.097699314711228 0.6590195698972978 0
0.8591917731552735 0.5814404756924266 0
153 0.5931083853424161 0.11370343774941108 0
0.6498283933370539 0.14987323698221428 0
0.6693218647836112 0.13195335910443245 0
0.5648149101682087 0.13130883159636664 0
154 0.20875151198659345 -0.05047221158067275 0
0.21435837861089976 -0.07010972045021832 0
0.2053670037597817 -0.07399346315708918 0
0.2245883058328555 -0.03643363013601514 0
155 0.5031264926546306 0.05380619781295731 0
0.4646359968654804 -0.024748519077375436 0
0.42497817835637286 0.018523249105463047 0
0.5140003705784992 0.015222312900208201 0
156 0.14531079385970988 -0.4583313748913417 0
0.14416126291832695 -0.16397192486717357 0
0.0736384247825046 -0.5760484685114281 0
0.27437910321724457 -0.21008152101248484 0
157 0.9493324911974614 0.01822535167465472 0
0.8426810698715146 -0.004816592031432199 0
0.9454126920866484 0.03554956995850672 0
0.888890612922839 -0.011719678480591633 0
158 0.011793507865983072 -0.20181789877115838 0
0.023029505020897068 -0.10361424327627561 0
-0.007862330217014032 -0.17262724907261073 0
0.043772330136703064 -0.16429342833506494 0
159 -0.019192416812572534 -0.09466913331877269 0
-0.03638470283200296 -0.24988198055441885 0
0.009961293651181705 -0.06070710001369982 0
-0.058919265898243325 -0.30371575495559716 0
160 0.10453880321102282 -0.19106042010670637 0
0.20787598936533142 -0.17100810210924644 0
0.14579357128111486 -0.17909362736694157 0
0.172994687829849 -0.18386722004398515 0
161 0.16222995832294834 0.03188954116443431 0
0.08561094533386306 0.03275268898252459 0
0.10784339767919562 -0.015241819343910522 0
0.14504137168919687 0.0773290836127393 0
162 0.8975857971199728 0.49864317497446037 0
0.7828310834128211 0.4181202203902148 0
0.7757205874432129 0.4947143609346804 0
0.8784231219681881 0.43474775787542097 0
163 0.13267416043028202 -0.24259453039462692 0
0.03131237266386297 -0.29142903333105663 0
0.0526939733419244 -0.2330308831878703 0
0.09657924928872004 -0.2839828372705682 0
164 0.13026749099256257 -0.36756916259820793 0
-0.03032108378951498 -0.39775633512170827 0
0.08724178928618567 -0.37896563286381835 0
0.04330788792661294 -0.3828723928369118 0
165 1.011662100879418 0.20211095349277713 0
0.9145756864232799 0.15365475916649457 0
0.8969904992821891 0.18166958603937333 0
1.016332933509569 0.1722784467309295 0
166 0.007124375149085094 -0.39985610596199606 0
0.007897900345562814 -0.5241847496927339 0
-0.07186704906544669 -0.495099506326402 0
0.07092376745013937 -0.434303263216942 0
167 0.09369009921827089 -0.2149801808569594 0
0.08929323293334746 -0.2343430098763135 0
0.04938080566713551 -0.23362411896417432 0
0.13684042928712856 -0.21483070266672258 0
168 0.0010526559374615385 -0.26021392381564257 0
0.0013979948146057297 -0.3823809249232917 0
-0.03990490177695957 -0.34967054644642526 0
0.04808879756036724 -0.3009455834818 0
169 0.07424858704425634 -0.1792865458174412 0
0.059187454528213265 -0.20062825500936515 0
0.029508545698261404 -0.19607558122087082 0
0.09824062571921763 -0.1824889262768756 0
170 0.1689733692434297 -0.21836754930732438 0
0.16591437478044485 -0.20618021245287427 0
0.1720144302162967 -0.20486505966867252 0
0.16251507780137128 -0.22263744722139797 0
171 0.25063475693920184 -0.21047712461782764 0
0.15332572208023126 -0.2264248708123528 0
0.20955045196482514 -0.20928778142743515 0
0.1930362187536724 -0.23199160553490675 0
172 3.3284910682081983 0.46033372262483496 0
2.4223949517268712 0.5279131305990853 0
4.020012132044473 0.821393427012796 0
2.1724127758209355 0.27764266144207683 0
173 0.35824271915094485 0.002189372525853911 0
0.2884531368285271 -0.014663795778688316 0
0.33732341316161885 -0.008563669383852418 0
0.3007889518198352 -0.004679649277843229 0
174 0.3824412794884136 0.08594974232988334 0
0.24785681796330977 0.0635210261571117 0
0.31797275285633303 0.08175341987825835 0
0.3038933519949654 0.06158985753572245 0
175 0.5500755608788128 0.25363202219423675 0
0.5841724236705514 0.35761600525988635 0
0.560877464876291 0.33908669940176994 0
0.5684702810761878 0.2555939671394466 0
176 1.3682155580842332 0.3071083325873305 0
1.3372879992573825 0.17966647991677986 0
1.6533175250505587 0.31753579791342923 0
0.8401898011649631 0.17143320955485658 0
177 0.6967319965552226 0.44929475119635903 0
0.6274419742447055 0.4643757715598116 0
0.6842148926311917 0.5159889756910101 0
0.6477644872321463 0.4156514081947521 0
178 0.39167713139690896 0.043530385666593924 0
0.3185852874727638 0.021907150400926778 0
0.37423324397407953 0.025287004846900524 0
0.3388645297456153 0.041297116698322256 0
179 0.2592501441084093 0.18307650914565937 0
0.29037798145868826 0.16152765284091314 0
0.33176818450471873 0.19059944026823533 0
0.2318722924807309 0.15759857720855078 0
180 1.2963571023954623 0.23497991305192223 0
1.7812459824425337 0.4326953478226967 0
1.6688880760906937 0.2835126736298209 0
1.3710244988649007 0.3825116679880235 0
181 0.07416399395956202 -0.4261885022033521 0
0.058842915986523206 -0.24000429330253475 0
-0.09594576032682664 -0.41689181880190207 0
0.24249473525808582 -0.2906478977804361 0
182 0.30682244753027 0.04660686572760067 0
0.18622670496573607 -0.01964959229239803 0
0.41936872573042705 0.039223784233130304 0
0.06264527060185815 0.0034609226669624835 0
183 0.5729236688958452 0.4483293417676202 0
0.5468466774943574 0.429753339760759 0
0.5611892573798307 0.4807927978326694 0
0.5494297318065655 0.39486303544078694 0
184 0.33941406165173416 -0.052466830750196064 0
0.3257830011300694 -0.015157764936527901 0
0.354031463602549 -0.02194725796271521 0
0.3181979809932526 -0.06046828184957889 0
185 0.24857032673347662 -0.026685472815107483 0
0.41053620037663474 2.5477426804043635E-4 0
0.3230127063238669 -0.0291824621757725 0
0.3326573353698576 -0.003328658902742976 0
186 0.5051579996017898 0.08327685510749669 0
0.53522236824653 0.06499904015159114 0
0.641935785342882 0.09862836049879814 0
0.4441004230338818 0.060581866167800424 0
187 0.5068803585008175 0.07717434089416231 0
0.39038933969139805 0.053494343434980995 0
0.4650136422508312 0.06028111645798773 0
0.4098145415745499 0.0637873189073781 0
188 0.5424921460416879 0.2605537976128519 0
0.5047515745807629 0.19724818101290256 0
0.4750725009816894 0.2343596148116026 0
0.563305607054079 0.22450209991396444 0
189 0.32905296190305644 0.25271702525994755 0
0.36321964627637293 0.2911459151019429 0
0.3985829769236093 0.27375883135838636 0
0.3145500733051726 0.2774104975788909 0
190 0.11663082484030009 -0.19828412945654178 0
0.11083112958627464 -0.23261510115753434 0
0.1088491271117687 -0.23793965917938914 0
0.11894113283003194 -0.18282319899034793 0
191 0.0460766302216188 -0.0573883440601928 0
0.23645310046237353 0.014593548517664007 0
0.1911150244035007 -0.011767553138250064 0
0.015189453367482534 -0.0385076187362762 0
192 0.015979905512306585 -0.04004945187695884 0
0.021325467418406165 -0.12297302941443186 0
-0.02391502909190369 -0.10565005305083025 0
0.0713082832411828 -0.061728394698560174 0
193 0.7588483438628428 0.2967098729193804 0
0.5657181493601878 0.260109081370516 0
0.65669286196987 0.278883063859012 0
0.6518410168181171 0.25953129512063733 0
194 0.6464807949507213 0.3523724186188407 0
0.6298040857706276 0.282932042398519 0
0.638024967023633 0.28473050432512137 0
0.6384001349485304 0.3380261220088143 0
195 0.5544896845885278 0.12243138389717459 0
0.6249863973110605 0.12129156913778644 0
0.662621579254605 0.14054800287817548 0
0.5119077921013353 0.10812116901380778 0
196 0.35187326832157345 -0.011781589208658516 0
0.5289704537023685 -0.003241577139139029 0
0.48305230925431364 0.01775359548452568 0
0.4155647073820806 -0.03974882828278872 0
197 0.15166277053337246 -0.10541920509086888 0
0.16554842215869925 -0.1449032915337592 0
0.18385623700890807 -0.1074506674987883 0
0.13698873725674088 -0.14076640878125768 0
198 0.2397226218654464 -0.091739672515607 0
0.2636444522584548 -0.09217526307991038 0
0.30243145691633905 -0.08091824615664032 0
0.1890008153826621 -0.1035092142695009 0
199 0.25900595291242323 -0.0958809368456718 0
0.2529031466797639 -0.1251549927515582 0
0.17669987747612176 -0.1229635898087253 0
0.33372030840406103 -0.09476483122864321 0
200 0.11662867144500955 -0.24655328593827114 0
0.04883942884432631 -0.2862770680852535 0
0.09314746884418837 -0.2815090749244892 0
0.054544042464305 -0.24187890371794718 0
201 0.8030433037520304 0.2839551477880505 0
0.7220747405101008 0.2222678400522282 0
0.6972267617338874 0.2624341461899003 0
0.8162137753925491 0.24426251338903132 0
202 1.3727161415870472 0.7806783348880979 0
1.6716244520374133 0.5819811134289119 0
1.259475976912661 0.5577693238543735 0
1.8226431122007694 0.8071630197264255 0
203 0.027764822280129123 -0.2599835897895297 0
0.018133440467432177 -0.2037330506621739 0
0.053514343563117614 -0.2135972940334115 0
-0.002600294064295544 -0.2539096797421505 0
204 0.0012388648012331416 -0.8046086111358688 0
0.06285625961076247 -0.6890304629425476 0
0.032332634627325774 -0.804367636142461 0
0.025775918621296134 -0.6519951930076576 0
205 0.43944490379322 0.09395487509250441 0
0.40880601655770193 0.08620907455630172 0
0.36534140375007146 0.08168170866418462 0
0.5096592199391721 0.10744054199966727 0
206 0.40417664227804784 0.21543109548418804 0
0.38654298217168703 0.1676715114856353 0
0.3325699346154778 0.18514883662912585 0
0.46319903098093357 0.20680610319157416 0
207 0.14942721242637716 -0.23456581690657394 0
0.20721395813251006 -0.22724870054164456 0
0.16450843161708914 -0.23811117341320662 0
0.1955705775856641 -0.2227015573670541 0
208 0.17938651516050125 -0.25339289501513296 0
0.11024057060595585 -0.260005287476225 0
0.16126854276603472 -0.24707244676975662 0
0.10920437162253134 -0.27351296558957405 0
209 -0.0035963529949113726 -0.4609664959377522 0
0.03742414721077522 -0.3380106854252962 0
0.011918798086433341 -0.4580915088990485 0
0.016321606088572027 -0.3537926797931139 0
210 0.013841693431368152 -0.7300104867018018 0
0.016260168750655057 -0.5387726683446091 0
0.09110925652334884 -0.6008110517652667 0
-0.05214723382408254 -0.731989072613771 0
211 0.8861459709390962 0.3539659422126487 0
0.8776924925119765 0.345177523446941 0
0.7399727482537701 0.3288986821444613 0
1.027407978400048 0.3815315078422927 0
212 0.14372456818210405 -0.23838944351011043 0
0.1391367388293696 -0.2378578195664618 0
0.107503583472567 -0.24374707784568272 0
0.19821963978249868 -0.22758050569964539 0
213 0.11575322554301415 -0.212669148139974 0
0.1372817945087107 -0.2025306541236771 0
0.16295857821636245 -0.20115902096958543 0
0.08625111445893534 -0.21443733540305848 0
214 0.08425494761740804 0.026528613977589842 0
0.04027215820515203 -0.03588236084275535 0
0.10485557035386411 0.009564278604683028 0
0.009278329855501612 -0.02549170892786082 0
215 -0.006335592396907907 -0.031654255776644644 0
0.0027070177658844036 -0.029977342221859188 0
-0.0014941086295355462 -0.029562170253776283 0
-0.0016509805491053547 -0.03215665825857543 0
216 0.9990592980943468 0.19170594328004997 0
0.9292275392511111 0.19958629671584677 0
0.9240170777932838 0.17886523077002414 0
1.0187536010947236 0.22073651191292282 0
217 0.16959414478509383 -0.21104977365237643 0
0.18997378016080918 -0.22498372333778427 0
0.16797283653573544 -0.2250602244654192 0
0.19126566207786574 -0.20645565673161373 0
End Values
<div class="post-metadata">
**Author:** ![miguel](https://forum.gidsimulation.com/user_avatar/forum.gidsimulation.com/miguel/32/7_2.png) [@miguel](https://forum.gidsimulation.com/u/miguel)\
**Post date:** [June 18, 2012, 9:14am UTC](https://forum.gidsimulation.com/t/gidlist-mix-mesh-in-gid/57/4 "2012-06-18T09:14:55Z")
</div>
hi,
seems that there is a bug in which setting a c.fill for gauss points for one
element type (p.ex. triangles), resets the results of the other element type
( p.ex. lines)
we’ll correct it for the next version.
miguel pasenau
De: [gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
[mailto:[gidlist-bounces at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)] En nombre de hbui
Enviado el: lunes, 18 de junio de 2012 1:01
Para: [escolano at cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
CC: [gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)
Asunto: Re: [GiDlist] mix mesh in GiD
I have tried your instruction, the nodal results work fine but Gaussian
results does not work for “Several Results” option. Even for standard
example in manual (see attached file table.post.res). I also attached my
files as a further reference.
GB
On 06/11/2012 04:45 PM, Enrique Escolano wrote:
_I assume that do you mean displaying results in postprocess of these_
_kind of elements._
_Now is not possible to simultaneously show results on gauss points of_
_different elements, like triangle and quadrilateral, because_
_internally are considered as different results._
_But you can show them simultaneously if do you define the results on_
_nodes, because it is the same nodal result._
_You can also use Window-Several results… to show more than one result:_
_‘one over another’,_
_then maybe you will be able to obtain the kind of image you want of a_
_gaussian result on triangles and other of a gaussian result on_
_quadrilaterals._
_Enrique Escolano_
_----- Original Message -----_
_From: "hbui"[hgbk2008 at gmail.com](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_To:[gidlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
_Sent: Friday, June 08, 2012 4:43 PM_
_Subject: [GiDlist] mix mesh in GiD_
_Hi,_
_Is there capabilites to mesh and display mix elements (for example_
_triangle/quadrilateral or tetrahedra/hexahedra) in GiD? I have a mesh_
_from other mesher and like to import it to GiD to visualize the results._
_However I couldn’t find such a capability in Help/Manual._
_Any advice is welcome_
_Thanks,_
_Giang Bui_
_GiDlist mailing list_
_[GiDlist at listas.cimne.upc.edu](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist)_
\_[http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist\_](http://listas.cimne.upc.edu/cgi-bin/mailman/listinfo/gidlist_)
**Post date:** [June 18, 2012, 9:15am UTC](https://forum.gidsimulation.com/t/gidlist-mix-mesh-in-gid/57/5 "2012-06-18T09:15:01Z")
</div>
thanks
GB
_kind of elements._
_quadrilaterals._
_Enrique Escolano_
_Hi,_
_Thanks,_
_Giang Bui_
